RSB SPARC gdb 8.2.1 Build Issue on MSYS2 (64-bit)
Jiri Gaisler jiri at gaisler.se
Tue Jun 4 21:13:19 UTC 2019
On 6/4/19 12:59 AM, Joel Sherrill wrote:
> Hi
> I was trying to build the sparc tools on MSYS2 today. SIS was enabled
> by default and failed to build.
> Is it expected to build?
> Is it supposed to be disabled and the host is not properly detected by
> the RSB?
> Not sure which way to push on the fix.
Did you catch any specific error output from the build?
Maybe it is time to switch to the standalone sis - it does build/work on
msys2 (but has the same ctrl-c limitation as cygwin).
Jiri.
