RTEMS on embedded CPUs(RISCV)
Sachin Ghadi sachin.ghadi at sifive.com
Wed Jun 5 10:20:11 UTC 2019
Thanks Sebastian,
On Wed, Jun 5, 2019 at 10:41 AM Sebastian Huber
> Hello Sachin,
> On 05/06/2019 06:15, sachin.ghadi at sifive.com wrote:
> > Hi RTEMS dev team,
> > I don’t know if I should send this query to users list or developer list.
> > I am working on the getting RTEMS BSP ported on the one of RISC-V
> > based SoC.
> > Current RTEMS has support only for Spike simulator.
> we have also support for Qemu. At least at some point in time it worked
> with a non-upstream Qemu. I am not sure how far the upstreaming of the
> Qemu support progressed in the last months.
> > It looks like RTEMS does not fit very well on the systems having less RAM.
> > We have 64K of RAM on our standard FPGA development kit for our E
> > series embedded cores.
> 64KiB for code and data is a challenge for RTEMS. You have to tinker
> with the configuration and reduce the feature set to get into this range.
Yes 64K is challenge,for both data and code.
I can use external xip flash for code and but I need to change linker
script and start up code to load data section from flash to RAM.
I see RTEMs uses some initialized global variables.
> > All of the RTEMS test does not fit within this given RAM and linker
> > throws error.
> > Regarding this I have few questions
> >  1. Does RTEMS accept support for new core with limited tests passing?
> >     Or one need full test suit passing to qualify complete test?
> What do you mean with "new core"? I think we already support the
> practically relevant ISA combinations:
I guess 'core' is wrong word I used..I mean new BSP for our RISCV
based hardware development kit(Arty100). Core is rv32imac.
> bsps/riscv/riscv/config/rv32iac.cfg
> bsps/riscv/riscv/config/rv32i.cfg
> bsps/riscv/riscv/config/rv32imac.cfg
> bsps/riscv/riscv/config/rv32imafc.cfg
> bsps/riscv/riscv/config/rv32imafdc.cfg
> bsps/riscv/riscv/config/rv32imafd.cfg
> bsps/riscv/riscv/config/rv32im.cfg
> bsps/riscv/riscv/config/rv64imac.cfg
> bsps/riscv/riscv/config/rv64imac_medany.cfg
> bsps/riscv/riscv/config/rv64imafdc.cfg
> bsps/riscv/riscv/config/rv64imafd.cfg
> bsps/riscv/riscv/config/rv64imafdc_medany.cfg
> bsps/riscv/riscv/config/rv64imafd_medany.cfg
> We have couple of BSP for other architectures (e.g. ARM, PowerPC) that
> cannot run all tests.
Ok understand , so I can submit RTEMS patches even if it doesn't pass
all the tests.
> > 1.
> >  2. I saw some thread regarding tinyRTEMS
> > https://devel.rtems.org/wiki/Projects/TinyRTEMS
> > Is there any plan for this to support as separate port for embedded
> > cores with limited resources?
> I don't think someone is actively working on this. This wiki page is out
> of date and needs an update. The next step to get a real size reduction
> would be self-contained threads. This way we get rid of all the objects
> support and the heap.
Thanks and Regards,
Sachin Ghadi
