Problem building RTEMS - readline/undefined reference to tputs
Wed Jun 5 13:09:27 UTC 2019
On 05/06/2019 15:07, John Graham wrote:
> I'm on Ubuntu 19.04, assumed that would be fine as I saw Ubuntu marked
> as supported elsewhere, however in your link I see 18.04 LTS is
> specifically mentioned so I may try that if I can't get this to work.
Did you install the packages listed here:
https://docs.rtems.org/branches/master/user/hosts/posix.html#xubuntu
sudo apt-get build-dep gcc-defaults g++ gdb git unzip pax bison \
        flex libpython-dev git libncurses5-dev zlib1g-dev
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
