RTEMS on embedded CPUs(RISCV)
Sachin Ghadi sachin.ghadi at sifive.com
Thu Jun 6 04:14:30 UTC 2019
On Wed, Jun 5, 2019 at 4:36 PM Sebastian Huber
> On 05/06/2019 12:20, Sachin Ghadi wrote:
> > Thanks Sebastian,
> > On Wed, Jun 5, 2019 at 10:41 AM Sebastian Huber
> >> Hello Sachin,
> >> On 05/06/2019 06:15, sachin.ghadi at sifive.com wrote:
> >>> Hi RTEMS dev team,
> >>> I don’t know if I should send this query to users list or developer list.
> >>> I am working on the getting RTEMS BSP ported on the one of RISC-V
> >>> based SoC.
> >>> Current RTEMS has support only for Spike simulator.
> >> we have also support for Qemu. At least at some point in time it worked
> >> with a non-upstream Qemu. I am not sure how far the upstreaming of the
> >> Qemu support progressed in the last months.
> >>> It looks like RTEMS does not fit very well on the systems having less RAM.
> >>> We have 64K of RAM on our standard FPGA development kit for our E
> >>> series embedded cores.
> >> 64KiB for code and data is a challenge for RTEMS. You have to tinker
> >> with the configuration and reduce the feature set to get into this range.
> > Yes 64K is challenge,for both data and code.
> > I can use external xip flash for code and but I need to change linker
> > script and start up code to load data section from flash to RAM.
> > I see RTEMs uses some initialized global variables.
> We have to adjust
> bsps/riscv/riscv/start/linkcmds.in
> so that a ROM can be optionally used for text and read-only data.
Yes Aagree.
> >>> All of the RTEMS test does not fit within this given RAM and linker
> >>> throws error.
> >>> Regarding this I have few questions
> >>>   1. Does RTEMS accept support for new core with limited tests passing?
> >>>      Or one need full test suit passing to qualify complete test?
> >> What do you mean with "new core"? I think we already support the
> >> practically relevant ISA combinations:
> > I guess 'core' is wrong word I used..I mean new BSP for our RISCV
> > based hardware development kit(Arty100). Core is rv32imac.
> The current BSP uses a device tree for initialization. Do you want to
> use this also for this tiny system? If not, then we have to find a way
> to initialize everything with a static configuration.
I have device tree blob statically linked as part of bsp
`rtems\bsps\riscv\frdm310atry\dts`
We are thinking of increasing memory of this FPGA development kit OR
have DDR integrated within system.
So there is not issue with memory.
Thanks and Regards,
Sachin Ghadi
