[PATCH] adding basic support for trace compass
Thu Jun 6 10:43:12 UTC 2019
On 6/6/19 8:03 pm, Sebastian Huber wrote:
> Hello Chris,
> On 06/06/2019 11:54, Ravindra Meena wrote:
>>   create mode 100644 images/user/event-recording-trace.png
> what is the desired way to include new images in the documentation? Should we
> try to use PlantUML if possible?
https://git.rtems.org/rtems-docs/tree/README.txt#n45 ? :)
Ditaa and PlantUML can be used. I think they are pretty good and let us create
reasonable images quickly and in an open way.
There are real examples in the User manual. You can see the source here
https://git.rtems.org/rtems-docs/tree/images/user.
I cover installing the tools on FreeBSD and Joel has added CentOS.
I cannot remember what happens with git when regenerating the images. I suggest
only adding the ones you create and add them. We add the .png files to avoid
everyone needing to install the tools to generate them.
