[PATCH 2/2] sparc: Fix mistakenly cleared PSR[EF] bit.
Thu Jun 6 13:13:26 UTC 2019
Hello Maksim,
On 06/06/2019 14:43, Maksim Kozlov wrote:
> On Thu, 6 Jun 2019 at 09:57, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 05/06/2019 21:22, Maksim E. Kozlov wrote:
>     >   cpukit/score/cpu/sparc/cpu_asm.S | 3 ++-
>     >   1 file changed, 2 insertions(+), 1 deletion(-)
>     > diff --git a/cpukit/score/cpu/sparc/cpu_asm.S
>     b/cpukit/score/cpu/sparc/cpu_asm.S
>     > index 2f3ad24510..69bbfb2748 100644
>     > --- a/cpukit/score/cpu/sparc/cpu_asm.S
>     > +++ b/cpukit/score/cpu/sparc/cpu_asm.S
>     > @@ -682,10 +682,11 @@ isr_dispatch:
>     >           ld      [%g6 + SPARC_PER_CPU_FP_OWNER_OFFSET], %l7
>     >           cmp     %l6, %l7
>     >           bne     .Ldisable_fp
>     > -         andn   %l0, %l5, %l0
>     > +         nop
>     Wouldn't it be sufficient to change this to
>     bne,a .Ldisable_fp
>       andn %l0, %l5, %l0
> Yes, you are right, this is my inattentiveness, and it is enough just
> to set
> an annul flag.
> If it is needed, I attached modified patch, but if you prefer, you can
> just add
> this flag yourself.
I still have problems to understand why this patch is necessary. The
current code is like this:
          * If we are still the floating point unit owner, then reset the
          * floating point unit owner to NULL, otherwise clear PSR[EF]
in the
          * interrupt frame and let the FP disabled system call do the
floating
          * point context save/restore.
         cmp     %l6, %l7
         bne     .Ldisable_fp
          andn   %l0, %l5, %l0
---> No matter what happens, the PSR[FP] is now cleared in %l0.
---> In this path we are the FPU owner and direct jump to ...
         ba      .Lthread_dispatch_done
          st     %g0, [%g6 + SPARC_PER_CPU_FP_OWNER_OFFSET]
.Ldisable_fp:
          st      %l0, [%fp + ISF_PSR_OFFSET]
.Lnon_fp_thread_dispatch:
         call    SYM(_Thread_Do_dispatch)
          mov    %g6, %o0
---> ... here. From now on %l0 is no longer used and ...
#if SPARC_HAS_FPU == 1
.Lthread_dispatch_done:
#endif
         [... %l0 not used ]
---> ... here it is loaded:
         ldd     [%fp + ISF_PSR_OFFSET], %l0    ! restore psr, PC
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
