[PATCH 2/2] sparc: Fix mistakenly cleared PSR[EF] bit.
Maksim Kozlov
maksim.e.kozlov at gmail.com
Thu Jun 6 16:11:56 UTC 2019
Hello, Sebastian
I think that this patch is necessary in two reasons.
In general view, if we have a conditional branch, we want, obviously, to
invoke two instruction siquences with different results. Without this
patch we clear EF bit in conditional branch in any case and I think this
is not that we want regardless if this causes error or not.
More specific technical reason is that there is a real situation - I have
debugging info and instruction trace (which was got with hardware debugging
module DSU on LEON3) where I see that sometimes we return from interrupt
with cleared PSR[EF] flag in the floating point task (I described this a
bit in my first message) and this causes excessive lazy fp switch
(previously I had system crash before fixing lazy fp switch syscall).
Just now I can't give very detail description why and how this happens,
but bellow I put part of LEON3 DSU trace for mentioned above situation
This is part of code which I use to investigate problem which we talk about
4f102d8c: 95 a2 88 58 faddd %f10, %f24, %f10
4f102d90: 80 a3 00 09 cmp %o4, %o1
4f102d94: 91 a2 09 54 fmuld %f8, %f20, %f8
4f102d98: 95 a0 05 4a fsqrtd %f10, %f10
4f102d9c: d5 3b bf f8 std %f10, [ %sp + -8 ]
4f102da0: 01 00 00 00 nop
4f102da4: 91 a2 08 4a faddd %f8, %f10, %f8
4f102da8: 95 a4 89 c8 fdivd %f18, %f8, %f10
4f102dac: d5 3b bf f8 std %f10, [ %sp + -8 ]
4f102db0: 01 00 00 00 nop
4f102db4: d1 38 7f 70 std %f8, [ %g1 + -144 ]
4f102db8: d1 18 80 00 ldd [ %g2 ], %f8 <--- Interrupt
4f102dbc: 91 a2 08 ce fsubd %f8, %f14, %f8
4f102dc0: 91 a2 09 4a fmuld %f8, %f10, %f8
4f102dc4: d1 38 7f 58 std %f8, [ %g1 + -168 ]
4f102dc8: d1 18 a0 08 ldd [ %g2 + 8 ], %f8
4f102dcc: 91 a2 08 cc fsubd %f8, %f12, %f8
Part of trace
463493523 4F06D6A0 restore [00000000]
463493524 4F06D6A4 ldd [%g1], %l0 [0000000C 4F57C348]
463493526 4F06D6A8 ldd [%g1 + 0x8], %l2 [0406CE9C 0406CE78]
463493528 4F06D6AC ldd [%g1 + 0x10], %l4 [0406CE54 0406CE30]
463493530 4F06D6B0 ldd [%g1 + 0x18], %l6 [4F57C528 0406CE84]
463493533 4F06D6B4 ldd [%g1 + 0x20], %i0 [0406CF78 4F534BB0]
463493610 4F06D6B8 ldd [%g1 + 0x28], %i2 [0408CDC0 0406CE24]
463493612 4F06D6BC ldd [%g1 + 0x30], %i4 [00000001 00000003]
463493616 4F06D6C0 ldd [%g1 + 0x38], %fp [4F534B40 4F103868]
463493620 4F06D6C4 save [00000000]
463493622 4F06D6C8 mov %l0, %psr [F34000C6] <-- (1)
463493625 4F06D6CC nop [00000000]
463493702 4F06D6D0 nop [00000000]
463493703 4F06D6D4 nop [00000000]
463493717 4F06D6D8 ld [%g1 + 0x6C], %g1 [0408D148]
463493718 4F06D6DC jmp %l1 [4F06D6DC]
463493719 4F06D6E0 rett %l2 [4F102DC0]
463493722 4F102DBC fsubd %f8, %f14, %f8 [ TRAP ] <-- (2)
463493728 04000040 mov %psr, %l0 [F34000C6]
463493729 04000044 sethi %hi(0x4F06D800), %l4 [4F06D800]
463493730 04000048 jmp %l4 + 0x20 [04000048]
463493731 0400004C sethi %hi(0x1000), %l3 [00001000]
Here (1) we see that restored PSR[EF] == 0 and directly after return from
interrupt (2) we fall in lazy fp switch syscall
To be honest, I cant say that I fully understand how _ISR_Handler procedure
works, therefore your help would be very desirable.
When I get more debugging information, I'll provide it. But it takes some
time.
Best regards,
Maksim Kozlov
On Thu, 6 Jun 2019 at 16:13, Sebastian Huber <
> Hello Maksim,
> On 06/06/2019 14:43, Maksim Kozlov wrote:
> > On Thu, 6 Jun 2019 at 09:57, Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > On 05/06/2019 21:22, Maksim E. Kozlov wrote:
> > > cpukit/score/cpu/sparc/cpu_asm.S | 3 ++-
> > > 1 file changed, 2 insertions(+), 1 deletion(-)
> > > diff --git a/cpukit/score/cpu/sparc/cpu_asm.S
> > b/cpukit/score/cpu/sparc/cpu_asm.S
> > > index 2f3ad24510..69bbfb2748 100644
> > > --- a/cpukit/score/cpu/sparc/cpu_asm.S
> > > +++ b/cpukit/score/cpu/sparc/cpu_asm.S
> > > @@ -682,10 +682,11 @@ isr_dispatch:
> > > ld [%g6 + SPARC_PER_CPU_FP_OWNER_OFFSET], %l7
> > > cmp %l6, %l7
> > > bne .Ldisable_fp
> > > - andn %l0, %l5, %l0
> > > + nop
> > Wouldn't it be sufficient to change this to
> > bne,a .Ldisable_fp
> > andn %l0, %l5, %l0
> > Yes, you are right, this is my inattentiveness, and it is enough just
> > to set
> > an annul flag.
> > If it is needed, I attached modified patch, but if you prefer, you can
> > just add
> > this flag yourself.
> I still have problems to understand why this patch is necessary. The
> current code is like this:
> * If we are still the floating point unit owner, then reset the
> * floating point unit owner to NULL, otherwise clear PSR[EF]
> in the
> * interrupt frame and let the FP disabled system call do the
> floating
> * point context save/restore.
> cmp %l6, %l7
> bne .Ldisable_fp
> andn %l0, %l5, %l0
> ---> No matter what happens, the PSR[FP] is now cleared in %l0.
> ---> In this path we are the FPU owner and direct jump to ...
> ba .Lthread_dispatch_done
> st %g0, [%g6 + SPARC_PER_CPU_FP_OWNER_OFFSET]
> .Ldisable_fp:
> st %l0, [%fp + ISF_PSR_OFFSET]
> .Lnon_fp_thread_dispatch:
> call SYM(_Thread_Do_dispatch)
> mov %g6, %o0
> ---> ... here. From now on %l0 is no longer used and ...
> #if SPARC_HAS_FPU == 1
> .Lthread_dispatch_done:
> #endif
> [... %l0 not used ]
> ---> ... here it is loaded:
> ldd [%fp + ISF_PSR_OFFSET], %l0 ! restore psr, PC
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190606/f159e23e/attachment.html>
