[PATCH] Port ndbm
Vaibhav Gupta vaibhavgupta40 at gmail.com
Fri Jun 7 01:52:13 UTC 2019
 newlib/libc/include/ndbm.h    |  86 ++++++++++++++
 newlib/libc/posix/Makefile.am |   4 +-
 newlib/libc/posix/ndbm.c      | 214 ++++++++++++++++++++++++++++++++++
 3 files changed, 302 insertions(+), 2 deletions(-)
 create mode 100644 newlib/libc/include/ndbm.h
 create mode 100644 newlib/libc/posix/ndbm.c
diff --git a/newlib/libc/include/ndbm.h b/newlib/libc/include/ndbm.h
new file mode 100644
index 000000000..1fd5e5198
--- /dev/null
+++ b/newlib/libc/include/ndbm.h
@@ -0,0 +1,86 @@
+ * SPDX-License-Identifier: BSD-3-Clause
+ * Copyright (c) 1990, 1993
+ *	The Regents of the University of California.  All rights reserved.
+ * This code is derived from software contributed to Berkeley by
+ * Margo Seltzer.
+ * are met:
+ * 3. Neither the name of the University nor the names of its contributors
+ *    may be used to endorse or promote products derived from this software
+ *    without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ *	@(#)ndbm.h	8.1 (Berkeley) 6/2/93
+ * $FreeBSD$
+#ifndef _NDBM_H_
+#define	_NDBM_H_
+#ifndef __DBINTERFACE_PRIVATE
+#define __DBINTERFACE_PRIVATE
+#endif
+#include <db_local.h>
+/* Map dbm interface onto db(3). */
+#define DBM_RDONLY	O_RDONLY
+/* Flags to dbm_store(). */
+#define DBM_INSERT      0
+#define DBM_REPLACE     1
+ * The db(3) support for ndbm always appends this suffix to the
+ * file name to avoid overwriting the user's original database.
+#define	DBM_SUFFIX	".db"
+typedef struct {
+	void *dptr;
+	int dsize;	/* XXX Should be size_t according to 1003.1-2008. */
+} datum;
+typedef DB DBM;
+#define	dbm_pagfno(a)	DBM_PAGFNO_NOT_AVAILABLE
+__BEGIN_DECLS
+int	 dbm_clearerr(DBM *);
+void	 dbm_close(DBM *);
+int	 dbm_delete(DBM *, datum);
+int	 dbm_error(DBM *);
+datum	 dbm_fetch(DBM *, datum);
+datum	 dbm_firstkey(DBM *);
+#if __BSD_VISIBLE
+long	 dbm_forder(DBM *, datum);
+#endif
+datum	 dbm_nextkey(DBM *);
+DBM	*dbm_open(const char *, int, mode_t);
+int	 dbm_store(DBM *, datum, datum, int);
+#if __BSD_VISIBLE
+int	 dbm_dirfno(DBM *);
+#endif
+__END_DECLS
+#endif /* !_NDBM_H_ */
diff --git a/newlib/libc/posix/Makefile.am b/newlib/libc/posix/Makefile.am
index 6cdee1df0..01334c7fa 100644
--- a/newlib/libc/posix/Makefile.am
+++ b/newlib/libc/posix/Makefile.am
@@ -2,12 +2,12 @@
 AUTOMAKE_OPTIONS = cygnus
-INCLUDES = $(NEWLIB_CFLAGS) $(CROSS_CFLAGS) $(TARGET_CFLAGS)
+INCLUDES = -I$(srcdir)/../search $(NEWLIB_CFLAGS) $(CROSS_CFLAGS) $(TARGET_CFLAGS)
 GENERAL_SOURCES = \
 	closedir.c collate.c collcmp.c creat.c dirfd.c \
 	fnmatch.c glob.c _isatty.c isatty.c \
-	opendir.c readdir.c readdir_r.c \
+	ndbm.c opendir.c readdir.c readdir_r.c \
 	regcomp.c regerror.c regexec.c regfree.c \
 	rewinddir.c sleep.c usleep.c \
 	telldir.c
diff --git a/newlib/libc/posix/ndbm.c b/newlib/libc/posix/ndbm.c
index 000000000..63e54df37
--- /dev/null
+++ b/newlib/libc/posix/ndbm.c
@@ -0,0 +1,214 @@
+ * Margo Seltzer.
+ * are met:
+ * SUCH DAMAGE.
+#if defined(LIBC_SCCS) && !defined(lint)
+static char sccsid[] = "@(#)ndbm.c	8.4 (Berkeley) 7/21/94";
+#endif /* LIBC_SCCS and not lint */
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+ * This package provides a dbm compatible interface to the new hashing
+ * package described in db(3).
+#include <sys/param.h>
+#include <stdio.h>
+#include <string.h>
+#include <errno.h>
+#include <ndbm.h>
+#include <hash.h>
+ * Returns:
+ * 	*DBM on success
+ *	 NULL on failure
+extern DBM *
+dbm_open(const char *file, int flags, mode_t mode)
+	HASHINFO info;
+	char path[MAXPATHLEN];
+	info.bsize = 4096;
+	info.ffactor = 40;
+	info.nelem = 1;
+	info.cachesize = 0;
+	info.hash = NULL;
+	info.lorder = 0;
+	if( strlen(file) >= sizeof(path) - strlen(DBM_SUFFIX)) {
+		errno = ENAMETOOLONG;
+		return(NULL);
+	(void)strcpy(path, file);
+	(void)strcat(path, DBM_SUFFIX);
+	return ((DBM *)__hash_open(path, flags, mode, 0, &info));
+extern void
+dbm_close(DBM *db)
+	(void)(db->close)(db);
+ * Returns:
+ *	DATUM on success
+ *	NULL on failure
+extern datum
+dbm_fetch(DBM *db, datum key)
+	datum retdata;
+	int status;
+	DBT dbtkey, dbtretdata;
+	dbtkey.data = key.dptr;
+	dbtkey.size = key.dsize;
+	status = (db->get)(db, &dbtkey, &dbtretdata, 0);
+	if (status) {
+		dbtretdata.data = NULL;
+		dbtretdata.size = 0;
+	retdata.dptr = dbtretdata.data;
+	retdata.dsize = dbtretdata.size;
+	return (retdata);
+ * Returns:
+ *	NULL on failure
+extern datum
+dbm_firstkey(DBM *db)
+	int status;
+	datum retkey;
+	DBT dbtretkey, dbtretdata;
+	status = (db->seq)(db, &dbtretkey, &dbtretdata, R_FIRST);
+	if (status)
+		dbtretkey.data = NULL;
+	retkey.dptr = dbtretkey.data;
+	retkey.dsize = dbtretkey.size;
+	return (retkey);
+ * Returns:
+ *	NULL on failure
+extern datum
+dbm_nextkey(DBM *db)
+	int status;
+	datum retkey;
+	status = (db->seq)(db, &dbtretkey, &dbtretdata, R_NEXT);
+	if (status)
+	return (retkey);
+ * Returns:
+ *	 0 on success
+ *	<0 failure
+extern int
+dbm_delete(DBM *db, datum key)
+	int status;
+	DBT dbtkey;
+	status = (db->del)(db, &dbtkey, 0);
+	if (status)
+		return (-1);
+	else
+		return (0);
+ * Returns:
+ *	 0 on success
+ *	<0 failure
+ *	 1 if DBM_INSERT and entry exists
+extern int
+dbm_store(DBM *db, datum key, datum data, int flags)
+	DBT dbtkey, dbtdata;
+	dbtdata.data = data.dptr;
+	dbtdata.size = data.dsize;
+	return ((db->put)(db, &dbtkey, &dbtdata,
+	    (flags == DBM_INSERT) ? R_NOOVERWRITE : 0));
+extern int
+dbm_error(DBM *db)
+	HTAB *hp;
+	hp = (HTAB *)db->internal;
+	return (hp->error);
+extern int
+dbm_clearerr(DBM *db)
+	HTAB *hp;
+	hp->error = 0;
+	return (0);
+extern int
+dbm_dirfno(DBM *db)
+	return(((HTAB *)db->internal)->fp);
2.21.0
