CTF example
Fri Jun 7 17:09:32 UTC 2019
Hi Ravindra,
You can find both at https://github.com/gedare/raspberry_prov/tree/dev
I guess you could probably write a barectf program that uses the
linux-fs backend to generate CTF, reading an RTEMS trace and
generating a CTF event for each kind of RTEMS event, this seems a
little bit klunky. It would first be better to try to directly write a
babeltrace plugin.
Gedare
On Fri, Jun 7, 2019 at 4:13 AM Ravindra Kumar Meena <rmeena840 at gmail.com> wrote:
>> My examples won't be helpful after all. I have some notes and scripts
>> to convert from CTF to another format (PROV-DM), and I also have some
>> examples using barectf to generate CTF traces. Let me know if you end
>> up needing anything like that.
> Okay. Please share the barectf examples.
> Thanks
> Ravindra Kumar Meena,
> B. Tech. Computer Science and Engineering,
> Indian Institute of Technology (Indian School of Mines), Dhanbad
