[PATCH] Port ndbm
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Fri Jun 7 17:24:07 UTC 2019
Sure! I will send the patch to newlib and ask them if they need updated set
of files inside libc/search.
On Fri, 7 Jun, 2019, 10:29 PM Gedare Bloom, <gedare at rtems.org> wrote:
> On Thu, Jun 6, 2019 at 8:02 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > Please review the code so that I can send it to newlib-devel.
> > On Fri, Jun 7, 2019 at 7:22 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> >> newlib/libc/include/ndbm.h | 86 ++++++++++++++
> >> newlib/libc/posix/Makefile.am | 4 +-
> >> newlib/libc/posix/ndbm.c | 214 ++++++++++++++++++++++++++++++++++
> >> 3 files changed, 302 insertions(+), 2 deletions(-)
> >> create mode 100644 newlib/libc/include/ndbm.h
> >> create mode 100644 newlib/libc/posix/ndbm.c
> >> diff --git a/newlib/libc/include/ndbm.h b/newlib/libc/include/ndbm.h
> >> new file mode 100644
> >> index 000000000..1fd5e5198
> >> --- /dev/null
> >> +++ b/newlib/libc/include/ndbm.h
> >> @@ -0,0 +1,86 @@
> >> + * SPDX-License-Identifier: BSD-3-Clause
> >> + * Copyright (c) 1990, 1993
> >> + * The Regents of the University of California. All rights
> reserved.
> >> + * This code is derived from software contributed to Berkeley by
> >> + * Margo Seltzer.
> >> + * Redistribution and use in source and binary forms, with or without
> >> + * modification, are permitted provided that the following conditions
> >> + * are met:
> >> + * 1. Redistributions of source code must retain the above copyright
> >> + * notice, this list of conditions and the following disclaimer.
> >> + * 2. Redistributions in binary form must reproduce the above copyright
> >> + * notice, this list of conditions and the following disclaimer in
> the
> >> + * documentation and/or other materials provided with the
> distribution.
> >> + * 3. Neither the name of the University nor the names of its
> contributors
> >> + * may be used to endorse or promote products derived from this
> software
> >> + * without specific prior written permission.
> >> + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS''
> AND
> >> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> >> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> >> + * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE
> LIABLE
> >> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> CONSEQUENTIAL
> >> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
> GOODS
> >> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> INTERRUPTION)
> >> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
> STRICT
> >> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
> ANY WAY
> >> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
> OF
> >> + * SUCH DAMAGE.
> >> + * @(#)ndbm.h 8.1 (Berkeley) 6/2/93
> >> + * $FreeBSD$
> >> +#ifndef _NDBM_H_
> >> +#define _NDBM_H_
> >> +#ifndef __DBINTERFACE_PRIVATE
> >> +#define __DBINTERFACE_PRIVATE
> >> +#endif
> > Included the above lines in ndbm.h, since __hash_open was under
> conditional compilation in db_local.h . Line 211 (
> https://github.com/VARoDeK/newlib/blob/master/newlib/libc/search/db_local.h
> >> +#include <db_local.h>
> >> +/* Map dbm interface onto db(3). */
> >> +#define DBM_RDONLY O_RDONLY
> >> +/* Flags to dbm_store(). */
> >> +#define DBM_INSERT 0
> >> +#define DBM_REPLACE 1
> >> + * The db(3) support for ndbm always appends this suffix to the
> >> + * file name to avoid overwriting the user's original database.
> >> +#define DBM_SUFFIX ".db"
> >> +typedef struct {
> >> + void *dptr;
> >> + int dsize; /* XXX Should be size_t according to
> 1003.1-2008. */
> >> +} datum;
> >> +typedef DB DBM;
> >> +#define dbm_pagfno(a) DBM_PAGFNO_NOT_AVAILABLE
> >> +__BEGIN_DECLS
> >> +int dbm_clearerr(DBM *);
> >> +void dbm_close(DBM *);
> >> +int dbm_delete(DBM *, datum);
> >> +int dbm_error(DBM *);
> >> +datum dbm_fetch(DBM *, datum);
> >> +datum dbm_firstkey(DBM *);
> >> +#if __BSD_VISIBLE
> >> +long dbm_forder(DBM *, datum);
> >> +#endif
> >> +datum dbm_nextkey(DBM *);
> >> +DBM *dbm_open(const char *, int, mode_t);
> >> +int dbm_store(DBM *, datum, datum, int);
> >> +#if __BSD_VISIBLE
> >> +int dbm_dirfno(DBM *);
> >> +#endif
> >> +__END_DECLS
> >> +#endif /* !_NDBM_H_ */
> >> diff --git a/newlib/libc/posix/Makefile.am
> b/newlib/libc/posix/Makefile.am
> >> index 6cdee1df0..01334c7fa 100644
> >> --- a/newlib/libc/posix/Makefile.am
> >> +++ b/newlib/libc/posix/Makefile.am
> >> @@ -2,12 +2,12 @@
> >> AUTOMAKE_OPTIONS = cygnus
> >> -INCLUDES = $(NEWLIB_CFLAGS) $(CROSS_CFLAGS) $(TARGET_CFLAGS)
> >> +INCLUDES = -I$(srcdir)/../search $(NEWLIB_CFLAGS) $(CROSS_CFLAGS)
> $(TARGET_CFLAGS)
> >> GENERAL_SOURCES = \
> >> closedir.c collate.c collcmp.c creat.c dirfd.c \
> >> fnmatch.c glob.c _isatty.c isatty.c \
> >> - opendir.c readdir.c readdir_r.c \
> >> + ndbm.c opendir.c readdir.c readdir_r.c \
> >> regcomp.c regerror.c regexec.c regfree.c \
> >> rewinddir.c sleep.c usleep.c \
> >> telldir.c
> >> diff --git a/newlib/libc/posix/ndbm.c b/newlib/libc/posix/ndbm.c
> >> index 000000000..63e54df37
> >> --- /dev/null
> >> +++ b/newlib/libc/posix/ndbm.c
> >> @@ -0,0 +1,214 @@
> reserved.
> >> + * Margo Seltzer.
> >> + * are met:
> the
> distribution.
> contributors
> software
> AND
> THE
> PURPOSE
> LIABLE
> CONSEQUENTIAL
> GOODS
> INTERRUPTION)
> STRICT
> ANY WAY
> OF
> >> + * SUCH DAMAGE.
> >> +#if defined(LIBC_SCCS) && !defined(lint)
> >> +static char sccsid[] = "@(#)ndbm.c 8.4 (Berkeley) 7/21/94";
> >> +#endif /* LIBC_SCCS and not lint */
> >> +#include <sys/cdefs.h>
> >> +__FBSDID("$FreeBSD$");
> >> + * This package provides a dbm compatible interface to the new hashing
> >> + * package described in db(3).
> >> +#include <sys/param.h>
> >> +#include <stdio.h>
> >> +#include <string.h>
> >> +#include <errno.h>
> >> +#include <ndbm.h>
> >> +#include <hash.h>
> >> + * Returns:
> >> + * *DBM on success
> >> + * NULL on failure
> >> +extern DBM *
> >> +dbm_open(const char *file, int flags, mode_t mode)
> >> + HASHINFO info;
> >> + char path[MAXPATHLEN];
> >> + info.bsize = 4096;
> >> + info.ffactor = 40;
> >> + info.nelem = 1;
> >> + info.cachesize = 0;
> >> + info.hash = NULL;
> >> + info.lorder = 0;
> >> + if( strlen(file) >= sizeof(path) - strlen(DBM_SUFFIX)) {
> >> + errno = ENAMETOOLONG;
> >> + return(NULL);
> >> + (void)strcpy(path, file);
> >> + (void)strcat(path, DBM_SUFFIX);
> >> + return ((DBM *)__hash_open(path, flags, mode, 0, &info));
> > In ndbm.c,
> > The original code was: return ((DBM *)__hash_open(path, flags, mode,
> &info, 0));
> > But the declaration of this function in db_local.h is: __hash_open(const
> char *, int, int, int, const HASHINFO *);
> > hence changed the original code to: return ((DBM *)__hash_open(path,
> Should db_local.h be updated? how about hash.h? Maybe, the entire
> search.h should be updated to newer FreeBSD sources? This is probably
> something to discuss at newlib ML...
> >> +extern void
> >> +dbm_close(DBM *db)
> >> + (void)(db->close)(db);
> >> + * Returns:
> >> + * DATUM on success
> >> + * NULL on failure
> >> +extern datum
> >> +dbm_fetch(DBM *db, datum key)
> >> + datum retdata;
> >> + int status;
> >> + DBT dbtkey, dbtretdata;
> >> + dbtkey.data = key.dptr;
> >> + dbtkey.size = key.dsize;
> >> + status = (db->get)(db, &dbtkey, &dbtretdata, 0);
> >> + if (status) {
> >> + dbtretdata.data = NULL;
> >> + dbtretdata.size = 0;
> >> + retdata.dptr = dbtretdata.data;
> >> + retdata.dsize = dbtretdata.size;
> >> + return (retdata);
> >> + * Returns:
> >> + * NULL on failure
> >> +extern datum
> >> +dbm_firstkey(DBM *db)
> >> + int status;
> >> + datum retkey;
> >> + DBT dbtretkey, dbtretdata;
> >> + status = (db->seq)(db, &dbtretkey, &dbtretdata, R_FIRST);
> >> + if (status)
> >> + dbtretkey.data = NULL;
> >> + retkey.dptr = dbtretkey.data;
> >> + retkey.dsize = dbtretkey.size;
> >> + return (retkey);
> >> + * Returns:
> >> + * NULL on failure
> >> +extern datum
> >> +dbm_nextkey(DBM *db)
> >> + int status;
> >> + datum retkey;
> >> + status = (db->seq)(db, &dbtretkey, &dbtretdata, R_NEXT);
> >> + if (status)
> >> + return (retkey);
> >> + * Returns:
> >> + * 0 on success
> >> + * <0 failure
> >> +extern int
> >> +dbm_delete(DBM *db, datum key)
> >> + int status;
> >> + DBT dbtkey;
> >> + status = (db->del)(db, &dbtkey, 0);
> >> + if (status)
> >> + return (-1);
> >> + else
> >> + return (0);
> >> + * Returns:
> >> + * 0 on success
> >> + * <0 failure
> >> + * 1 if DBM_INSERT and entry exists
> >> +extern int
> >> +dbm_store(DBM *db, datum key, datum data, int flags)
> >> + DBT dbtkey, dbtdata;
> >> + dbtdata.data = data.dptr;
> >> + dbtdata.size = data.dsize;
> >> + return ((db->put)(db, &dbtkey, &dbtdata,
> >> + (flags == DBM_INSERT) ? R_NOOVERWRITE : 0));
> >> +extern int
> >> +dbm_error(DBM *db)
> >> + HTAB *hp;
> >> + hp = (HTAB *)db->internal;
> >> + return (hp->error);
> >> +extern int
> >> +dbm_clearerr(DBM *db)
> >> + HTAB *hp;
> >> + hp->error = 0;
> >> + return (0);
> >> +extern int
> >> +dbm_dirfno(DBM *db)
> >> + return(((HTAB *)db->internal)->fp);
> >> 2.21.0
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190607/2faa4b9b/attachment-0001.html>
