[PATCH] user/bsps: Add beagle BSP
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun Jun 9 13:58:07 UTC 2019
user/bsps/bsps-arm.rst | 68 +++++++++++++++++++++++++++++++++++++++++-
1 file changed, 67 insertions(+), 1 deletion(-)
diff --git a/user/bsps/bsps-arm.rst b/user/bsps/bsps-arm.rst
index eb972c6..290a6fc 100644
--- a/user/bsps/bsps-arm.rst
+++ b/user/bsps/bsps-arm.rst
@@ -93,7 +93,73 @@ TODO.
beagle
-TODO.
+This BSP supports four variants, `beagleboardorig`, `beagleboardxm`, `beaglebonewhite`
+and `beagleboneblack`. The basic hardware initialization is not performed by
+the BSP. A boot loader with device tree support must be used to start the BSP,
+e.g. U-Boot.
+TODO(These drivers are present but not documented yet):
+* Clock driver.
+* Network Interface Driver.
+* SDcard driver.
+* GPIO Driver.
+* Console driver.
+* PWM Driver.
+* RTC driver.
+Boot via U-Boot
+To boot via uboot, the ELF must be converted to a U-Boot image like below:
+.. code-block:: none
+ arm-rtems5-objcopy hello.exe -O app.bin
+ gzip 9 app.bin
+ mkimage -A arm -O linux -T kernel -a 0x80000000 -e 0x80000000 -n RTEMS -d app.bin.gz rtems-app.img
+Getting the Device Tree Blob
+The Device Tree Blob(dtb) is needed to load the device tree while starting up
+the kernel. Currently the dtb is built using the linux `device-tree-rebasing
+<https://github.com/RobertCNelson/device-tree-rebasing>`_
+repository.
+Writing the uEnv.txt file
+The uEnv.txt file is needed to set any environment variable before the kernel is
+loaded. Each line is a u-boot command that the uboot will execute during
+starting up.
+Add the following to a file named uEnv.txt:
+ setenv bootdelay 5
+ uenvcmd=run boot
+ boot=fatload mmc 0 0x80800000 rtems-app.img ; fatload mmc 0 0x88000000 am335x-boneblack.dtb ; bootm 0x80800000 - 0x88000000
+I2C Driver
+This BSP uses the I2C framework and is registered using
+``am335x_i2c_bus_register()`` the function prototype is given below:
+.. code-block:: C
+ int am335x_i2c_bus_register(
+ const char *bus_path,
+ uintptr_t register_base,
+ uint32_t input_clock,
+ rtems_vector_number irq
+This function is needed only while registering with custom path with custom
+values. For registering the `i2c-0`, a wrapper function is provided,
+``bbb_register_i2c_0()`` and this will be used generally.
+SPI Driver
+The SPI device `/dev/spi-0` can be registered with ``bbb_register_spi_0()```
csb336
2.20.1
