[PATCH v2 1/8] rtemstoolkit/check: Optionally check exe silently.
chrisj at rtems.org chrisj at rtems.org
Mon Jun 10 07:23:08 UTC 2019
 rtemstoolkit/check.py | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/rtemstoolkit/check.py b/rtemstoolkit/check.py
index 8d4a35c..1f18f72 100644
--- a/rtemstoolkit/check.py
+++ b/rtemstoolkit/check.py
@@ -143,12 +143,12 @@ def host_setup(opts):
     return sane
-def check_exe(label, exe):
-    return _check_exe(None, label, exe, None, True)
+def check_exe(label, exe, silent = True):
+    return _check_exe(None, label, exe, None, silent)
-def check_dir(label, path):
-    return _check_dir(None, label, path, 'required', True)
+def check_dir(label, path, silent = True):
+    return _check_dir(None, label, path, 'required', silent)
 def run(args):
2.20.1 (Apple Git-117)
