[PATCH] Add testsuite for psxinttypes01
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Mon Jun 10 10:46:14 UTC 2019
testsuites/psxtests/Makefile.am | 7 +
testsuites/psxtests/configure.ac | 1 +
testsuites/psxtests/psxinttypes01/init.c | 220 ++++++++++++++++++
.../psxtests/psxinttypes01/psxinttypes01.doc | 67 ++++++
.../psxtests/psxinttypes01/psxinttypes01.scn | 75 ++++++
5 files changed, 370 insertions(+)
create mode 100644 testsuites/psxtests/psxinttypes01/init.c
create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.doc
create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.scn
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 1e354c0df7..59c9f2085b 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -523,6 +523,13 @@ psxintrcritical01_CPPFLAGS = $(AM_CPPFLAGS) \
endif
endif
+if TEST_psxinttypes01
+psx_tests += psxinttypes01
+psxinttypes01_SOURCES = psxinttypes01/init.c
+psxinttypes01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxinttypes01) \
+ $(support_includes)
+endif
if HAS_POSIX
if TEST_psxitimer
psx_tests += psxitimer
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index cdd6ee7e4e..85559e4aa5 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -91,6 +91,7 @@ RTEMS_TEST_CHECK([psxid01])
RTEMS_TEST_CHECK([psximfs01])
RTEMS_TEST_CHECK([psximfs02])
RTEMS_TEST_CHECK([psxintrcritical01])
+RTEMS_TEST_CHECK([psxinttypes01])
RTEMS_TEST_CHECK([psxitimer])
RTEMS_TEST_CHECK([psxkey01])
RTEMS_TEST_CHECK([psxkey02])
diff --git a/testsuites/psxtests/psxinttypes01/init.c b/testsuites/psxtests/psxinttypes01/init.c
new file mode 100644
index 0000000000..7627e28195
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/init.c
@@ -0,0 +1,220 @@
+ * @file
+ * @brief Test suite for inttypes.h methods
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019, Aditya Upadhyay and Vaibhav Gupta
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/test.h>
+#include <inttypes.h>
+#include <stdio.h>
+#include <errno.h>
+#include <tmacros.h>
+#include <stdint.h>
+#include <stddef.h>
+const char rtems_test_name[] = "PSXINTTYPE 01";
+/* forward declarations to avoid warnings */
+rtems_task Init(rtems_task_argument ignored);
+ int base = 10;
+ int invalid_base = 40;
+ char *nptr1_p = "123abc"; //char* pointing to string with positive number
+ char *nptr1_n = "-123abc"; //char* pointing to string with negative number
+ char *endptr1 = NULL;
+ wchar_t *nptr2_p = L"123junk"; //wchar_t* pointing to string with positive number
+ wchar_t *nptr2_n = L"-123junk"; //wchar_t* pointing to string with negative number
+ wchar_t *endptr2 = NULL;
+ intmax_t result_strtoimax;
+ uintmax_t result_strtoumax;
+ TEST_BEGIN();
+ puts( "\nChecking invalid base value" );
+ rtems_test_assert( base >=2 && base <= 36 );
+ /*Test for strtoimax */
+ puts( "\nStrtoimax Testcases...." );
+ puts( "Generating Results" );
+ puts( "1 - Valid Inputs - Positive Number" );
+ result_strtoimax = strtoimax( nptr1_p, &endptr1, base );
+ puts( "Checking Results" );
+ rtems_test_assert( result_strtoimax == 123 );
+ puts( "PASS" );
+ puts( "2 - Valid Inputs - Negative Number" );
+ result_strtoimax = strtoimax( nptr1_n, &endptr1, base );
+ rtems_test_assert( result_strtoimax == -123 );
+ puts( "PASS" );
+ puts( "Checking Garbage end of endptr" );
+ rtems_test_assert( *endptr1 != '\0' );
+ puts( "PASS" );
+ puts( "3 - Invalid Input - Send NULL Pointer" );
+ result_strtoimax = strtoimax( NULL, &endptr1, base );
+ rtems_test_assert( result_strtoimax == 0 );
+ rtems_test_assert( errno == EINVAL );
+ puts( "PASS" );
+ puts( "4 - Invalid Input - Invalid base - Use base = 40" );
+ result_strtoimax = strtoimax( nptr1_p, &endptr1, invalid_base );
+ puts( "PASS" );
+ /*Test for strtoumax */
+ puts( "\nStrtoumax Testcases...." );
+ result_strtoumax = strtoumax( nptr1_p, &endptr1, base );
+ rtems_test_assert( result_strtoumax ==123 );
+ puts( "PASS" );
+ result_strtoumax = strtoumax( nptr1_n, &endptr1, base );
+ rtems_test_assert( result_strtoumax == ( UINTMAX_MAX - 123 + 1 ) );
+ puts( "PASS" );
+ puts( "PASS" );
+ result_strtoumax = strtoumax( NULL, &endptr1, base );
+ rtems_test_assert( result_strtoumax == 0 );
+ puts( "PASS" );
+ result_strtoumax = strtoumax( nptr1_p, &endptr1, invalid_base );
+ puts( "PASS" );
+ /*Test for wcstoimax */
+ puts( "\nWcstoimax Testcases...." );
+ result_strtoimax = wcstoimax( nptr2_p, &endptr2, base );
+ puts( "PASS" );
+ result_strtoimax = wcstoimax( nptr2_n, &endptr2, base );
+ puts( "PASS" );
+ rtems_test_assert( *endptr2 != '\0' );
+ puts( "PASS" );
+ result_strtoimax = wcstoimax( NULL, &endptr2, base );
+ puts( "PASS" );
+ result_strtoimax = wcstoimax( nptr2_p, &endptr2, invalid_base );
+ puts( "PASS" );
+ /*Test for wcstoumax */
+ puts( "\nWcstoumax Testcases...." );
+ result_strtoumax = wcstoumax( nptr2_p, &endptr2, base );
+ rtems_test_assert( result_strtoumax == 123 );
+ puts( "PASS" );
+ result_strtoumax = wcstoumax( nptr2_n, &endptr2, base );
+ puts( "PASS" );
+ puts( "PASS" );
+ result_strtoumax = wcstoumax( NULL, &endptr2, base );
+ puts( "PASS" );
+ result_strtoumax = wcstoumax( nptr2_p, &endptr2, invalid_base );
+ puts( "PASS" );
+ TEST_END();
+ rtems_test_exit(0);
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
index 0000000000..50962dd930
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
@@ -0,0 +1,67 @@
+ * @file
+ * @brief Doc for Test suite for inttypes.h methods
+ * Copyright (C) 2019, Vaibhav Gupta
+ * are met:
+This File describes the concepts tested by this test suite.
+inttypes.h - fixed size integer types
+test suite name: PSXINTTYPE 01
+- Checks for invalid base value
+- Checks for Strtoimax Testcases
+ - checks for output for string having a positive number
+ - checks for output for string having a negative number
+ - checks for Garbage end of endptr
+ - checks for output for invalid argument - NULL Pointer
+ - checks for output for invalid argument - Invalid Base
+- Checks for Strtoumax Test Cases
+- Checks for Wcstoimax Testcases
+- Checks for Wcstoumax Testcases
diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
index 0000000000..6d50e64672
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
@@ -0,0 +1,75 @@
+*** PSXINTTYPE 01 TEST ***
+Checking invalid base value
+Strtoimax Testcases....
+Generating Results
+1 - Valid Inputs - Positive Number
+Checking Results
+PASS
+2 - Valid Inputs - Negative Number
+Checking Results
+PASS
+Checking Garbage end of endptr
+PASS
+3 - Invalid Input - Send NULL Pointer
+Checking Results
+PASS
+4 - Invalid Input - Invalid base - Use base = 40
+Checking Results
+PASS
+Strtoumax Testcases....
+Generating Results
+Checking Results
+PASS
+Checking Results
+PASS
+PASS
+Checking Results
+PASS
+Checking Results
+PASS
+Wcstoimax Testcases....
+Generating Results
+Checking Results
+PASS
+Checking Results
+PASS
+PASS
+Checking Results
+PASS
+Checking Results
+PASS
+Wcstoumax Testcases....
+Generating Results
+Checking Results
+PASS
+Checking Results
+PASS
+PASS
+Checking Results
+PASS
+Checking Results
+PASS
+*** END OF PSXINTTYPE 01 TEST ***
2.21.0
