[PATCH v2 1/5] iicbus: Import from FreeBSD
Christian Mauderer list at c-mauderer.de
Mon Jun 10 12:36:40 UTC 2019
Hello Vijay,
the patch set works fine on the Beagle (except for the i2c tool - but as
discussed that will work after the next libbsd update). The patches look
OK for me.
Best regards
Christian
On 08/06/2019 14:49, Vijay Kumar Banerjee wrote:
>  freebsd/sys/dev/iicbus/iic.c        | 506 ++++++++++++++++++++++++++
>  freebsd/sys/dev/iicbus/iic.h        |  72 ++++
>  freebsd/sys/dev/iicbus/iicbus.c     | 378 ++++++++++++++++++++
>  freebsd/sys/dev/iicbus/iicbus.h     |  83 +++++
>  freebsd/sys/dev/iicbus/iiconf.c     | 527 ++++++++++++++++++++++++++++
>  freebsd/sys/dev/iicbus/iiconf.h     | 162 +++++++++
>  freebsd/sys/dev/iicbus/ofw_iicbus.c | 242 +++++++++++++
>  7 files changed, 1970 insertions(+)
>  create mode 100644 freebsd/sys/dev/iicbus/iic.c
>  create mode 100644 freebsd/sys/dev/iicbus/iic.h
>  create mode 100644 freebsd/sys/dev/iicbus/iicbus.c
>  create mode 100644 freebsd/sys/dev/iicbus/iicbus.h
>  create mode 100644 freebsd/sys/dev/iicbus/iiconf.c
>  create mode 100644 freebsd/sys/dev/iicbus/iiconf.h
>  create mode 100644 freebsd/sys/dev/iicbus/ofw_iicbus.c
> diff --git a/freebsd/sys/dev/iicbus/iic.c b/freebsd/sys/dev/iicbus/iic.c
> new file mode 100644
> index 00000000..dc9c06f9
> --- /dev/null
> +++ b/freebsd/sys/dev/iicbus/iic.c
> @@ -0,0 +1,506 @@
> +#include <machine/rtems-bsd-kernel-space.h>
> + * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
> + * Copyright (c) 1998, 2001 Nicolas Souchu
> + * All rights reserved.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> + * SUCH DAMAGE.
> + * $FreeBSD$
> +#include <sys/param.h>
> +#include <sys/bus.h>
> +#include <sys/conf.h>
> +#include <sys/fcntl.h>
> +#include <sys/lock.h>
> +#include <sys/kernel.h>
> +#include <sys/malloc.h>
> +#include <sys/module.h>
> +#include <sys/sx.h>
> +#include <sys/systm.h>
> +#include <sys/uio.h>
> +#include <sys/errno.h>
> +#include <dev/iicbus/iiconf.h>
> +#include <dev/iicbus/iicbus.h>
> +#include <dev/iicbus/iic.h>
> +#include <rtems/bsd/local/iicbus_if.h>
> +struct iic_softc {
> +	device_t sc_dev;
> +	struct cdev *sc_devnode;
> +struct iic_cdevpriv {
> +	struct sx lock;
> +	struct iic_softc *sc;
> +	bool started;
> +	uint8_t addr;
> +#define	IIC_LOCK(cdp)			sx_xlock(&(cdp)->lock)
> +#define	IIC_UNLOCK(cdp)			sx_xunlock(&(cdp)->lock)
> +static MALLOC_DEFINE(M_IIC, "iic", "I2C device data");
> +static int iic_probe(device_t);
> +static int iic_attach(device_t);
> +static int iic_detach(device_t);
> +static void iic_identify(driver_t *driver, device_t parent);
> +static void iicdtor(void *data);
> +static int iicuio_move(struct iic_cdevpriv *priv, struct uio *uio, int last);
> +static int iicuio(struct cdev *dev, struct uio *uio, int ioflag);
> +static int iicrdwr(struct iic_cdevpriv *priv, struct iic_rdwr_data *d, int flags);
> +static devclass_t iic_devclass;
> +static device_method_t iic_methods[] = {
> +	/* device interface */
> +	DEVMETHOD(device_identify,	iic_identify),
> +	DEVMETHOD(device_probe,		iic_probe),
> +	DEVMETHOD(device_attach,	iic_attach),
> +	DEVMETHOD(device_detach,	iic_detach),
> +	/* iicbus interface */
> +	DEVMETHOD(iicbus_intr,		iicbus_generic_intr),
> +	{ 0, 0 }
> +static driver_t iic_driver = {
> +	"iic",
> +	iic_methods,
> +	sizeof(struct iic_softc),
> +static	d_open_t	iicopen;
> +static	d_ioctl_t	iicioctl;
> +static struct cdevsw iic_cdevsw = {
> +	.d_version =	D_VERSION,
> +	.d_open =	iicopen,
> +	.d_read =	iicuio,
> +	.d_write =	iicuio,
> +	.d_ioctl =	iicioctl,
> +	.d_name =	"iic",
> +static void
> +iic_identify(driver_t *driver, device_t parent)
> +	if (device_find_child(parent, "iic", -1) == NULL)
> +		BUS_ADD_CHILD(parent, 0, "iic", -1);
> +static int
> +iic_probe(device_t dev)
> +	if (iicbus_get_addr(dev) > 0)
> +		return (ENXIO);
> +	device_set_desc(dev, "I2C generic I/O");
> +	return (0);
> +static int
> +iic_attach(device_t dev)
> +	sc = device_get_softc(dev);
> +	sc->sc_dev = dev;
> +	sc->sc_devnode = make_dev(&iic_cdevsw, device_get_unit(dev),
> +			UID_ROOT, GID_WHEEL,
> +			0600, "iic%d", device_get_unit(dev));
> +	if (sc->sc_devnode == NULL) {
> +		device_printf(dev, "failed to create character device\n");
> +		return (ENXIO);
> +	sc->sc_devnode->si_drv1 = sc;
> +	return (0);
> +static int
> +iic_detach(device_t dev)
> +	if (sc->sc_devnode)
> +		destroy_dev(sc->sc_devnode);
> +	return (0);
> +static int
> +iicopen(struct cdev *dev, int flags, int fmt, struct thread *td)
> +	struct iic_cdevpriv *priv;
> +	int error;
> +	priv = malloc(sizeof(*priv), M_IIC, M_WAITOK | M_ZERO);
> +	sx_init(&priv->lock, "iic");
> +	priv->sc = dev->si_drv1;
> +	error = devfs_set_cdevpriv(priv, iicdtor);
> +	if (error != 0)
> +		free(priv, M_IIC);
> +	return (error);
> +static void
> +iicdtor(void *data)
> +	device_t iicdev, parent;
> +	priv = data;
> +	KASSERT(priv != NULL, ("iic cdevpriv should not be NULL!"));
> +	iicdev = priv->sc->sc_dev;
> +	parent = device_get_parent(iicdev);
> +	if (priv->started) {
> +		iicbus_stop(parent);
> +		iicbus_reset(parent, IIC_UNKNOWN, 0, NULL);
> +		iicbus_release_bus(parent, iicdev);
> +	sx_destroy(&priv->lock);
> +static int
> +iicuio_move(struct iic_cdevpriv *priv, struct uio *uio, int last)
> +	device_t parent;
> +	int error, num_bytes, transferred_bytes, written_bytes;
> +	char buffer[128];
> +	parent = device_get_parent(priv->sc->sc_dev);
> +	error = 0;
> +	 * We can only transfer up to sizeof(buffer) bytes in 1 shot, so loop until
> +	 * everything has been transferred.
> +	while ((error == 0) && (uio->uio_resid > 0)) {
> +		num_bytes = MIN(uio->uio_resid, sizeof(buffer));
> +		transferred_bytes = 0;
> +		if (uio->uio_rw == UIO_WRITE) {
> +			error = uiomove(buffer, num_bytes, uio);
> +			while ((error == 0) && (transferred_bytes < num_bytes)) {
> +				written_bytes = 0;
> +				error = iicbus_write(parent, &buffer[transferred_bytes],
> +				    num_bytes - transferred_bytes, &written_bytes, 0);
> +				transferred_bytes += written_bytes;
> +		} else if (uio->uio_rw == UIO_READ) {
> +			error = iicbus_read(parent, buffer,
> +			    num_bytes, &transferred_bytes,
> +			    ((uio->uio_resid <= sizeof(buffer)) ? last : 0), 0);
> +			if (error == 0)
> +				error = uiomove(buffer, transferred_bytes, uio);
> +	return (error);
> +static int
> +iicuio(struct cdev *dev, struct uio *uio, int ioflag)
> +	device_t parent;
> +	int error;
> +	uint8_t addr;
> +	priv = NULL;
> +	error = devfs_get_cdevpriv((void**)&priv);
> +	if (error != 0)
> +		return (error);
> +	IIC_LOCK(priv);
> +	if (priv->started || (priv->addr == 0)) {
> +		IIC_UNLOCK(priv);
> +		return (ENXIO);
> +	error = iicbus_request_bus(parent, priv->sc->sc_dev,
> +	    (ioflag & O_NONBLOCK) ? IIC_DONTWAIT : (IIC_WAIT | IIC_INTR));
> +	if (error != 0) {
> +		IIC_UNLOCK(priv);
> +		return (error);
> +	if (uio->uio_rw == UIO_READ)
> +		addr = priv->addr | LSB;
> +	else
> +		addr = priv->addr & ~LSB;
> +	error = iicbus_start(parent, addr, 0);
> +	if (error != 0)
> +		iicbus_release_bus(parent, priv->sc->sc_dev);
> +		IIC_UNLOCK(priv);
> +		return (error);
> +	error = iicuio_move(priv, uio, IIC_LAST_READ);
> +	IIC_UNLOCK(priv);
> +	return (error);
> +static int
> +iicrdwr(struct iic_cdevpriv *priv, struct iic_rdwr_data *d, int flags)
> +	struct iic_msg *buf, *m;
> +	void **usrbufs;
> +	int error;
> +	uint32_t i;
> +	error = 0;
> +	if (d->nmsgs > IIC_RDRW_MAX_MSGS)
> +		return (EINVAL);
> +	buf = malloc(sizeof(*d->msgs) * d->nmsgs, M_IIC, M_WAITOK);
> +	error = copyin(d->msgs, buf, sizeof(*d->msgs) * d->nmsgs);
> +	if (error != 0) {
> +		free(buf, M_IIC);
> +		return (error);
> +	/* Alloc kernel buffers for userland data, copyin write data */
> +	usrbufs = malloc(sizeof(void *) * d->nmsgs, M_IIC, M_WAITOK | M_ZERO);
> +	for (i = 0; i < d->nmsgs; i++) {
> +		m = &(buf[i]);
> +		usrbufs[i] = m->buf;
> +		 * At least init the buffer to NULL so we can safely free() it later.
> +		 * If the copyin() to buf failed, don't try to malloc bogus m->len.
> +		m->buf = NULL;
> +		if (error != 0)
> +			continue;
> +		/* m->len is uint16_t, so allocation size is capped at 64K. */
> +		m->buf = malloc(m->len, M_IIC, M_WAITOK);
> +		if (!(m->flags & IIC_M_RD))
> +			error = copyin(usrbufs[i], m->buf, m->len);
> +	if (error == 0)
> +		error = iicbus_request_bus(parent, iicdev,
> +		    (flags & O_NONBLOCK) ? IIC_DONTWAIT : (IIC_WAIT | IIC_INTR));
> +	if (error == 0) {
> +		error = iicbus_transfer(iicdev, buf, d->nmsgs);
> +	/* Copyout all read segments, free up kernel buffers */
> +		m = &(buf[i]);
> +		if ((error == 0) && (m->flags & IIC_M_RD))
> +			error = copyout(m->buf, usrbufs[i], m->len);
> +		free(m->buf, M_IIC);
> +	free(usrbufs, M_IIC);
> +	free(buf, M_IIC);
> +	return (error);
> +static int
> +iicioctl(struct cdev *dev, u_long cmd, caddr_t data, int flags, struct thread *td)
> +	device_t parent, iicdev;
> +	struct iiccmd *s;
> +	struct uio ubuf;
> +	struct iovec uvec;
> +	int error;
> +	s = (struct iiccmd *)data;
> +	if (error != 0)
> +		return (error);
> +	IIC_LOCK(priv);
> +	switch (cmd) {
> +	case I2CSTART:
> +			error = EINVAL;
> +			break;
> +		if (error == 0)
> +			error = iicbus_start(parent, s->slave, 0);
> +		if (error == 0) {
> +			priv->addr = s->slave;
> +			priv->started = true;
> +		} else
> +		break;
> +	case I2CSTOP:
> +			error = iicbus_stop(parent);
> +			priv->started = false;
> +		break;
> +	case I2CRSTCARD:
> +		 * Bus should be owned before we reset it.
> +		 * We allow the bus to be already owned as the result of an in-progress
> +		 * sequence; however, bus reset will always be followed by release
> +		 * (a new start is presumably needed for I/O anyway). */
> +		if (!priv->started)
> +		if (error == 0) {
> +			error = iicbus_reset(parent, IIC_UNKNOWN, 0, NULL);
> +			 * Ignore IIC_ENOADDR as it only means we have a master-only
> +			 * controller.
> +			if (error == IIC_ENOADDR)
> +				error = 0;
> +		break;
> +	case I2CWRITE:
> +		if (!priv->started) {
> +			error = EINVAL;
> +			break;
> +		uvec.iov_base = s->buf;
> +		uvec.iov_len = s->count;
> +		ubuf.uio_iov = &uvec;
> +		ubuf.uio_iovcnt = 1;
> +		ubuf.uio_segflg = UIO_USERSPACE;
> +		ubuf.uio_td = td;
> +		ubuf.uio_resid = s->count;
> +		ubuf.uio_offset = 0;
> +		ubuf.uio_rw = UIO_WRITE;
> +		error = iicuio_move(priv, &ubuf, 0);
> +		break;
> +	case I2CREAD:
> +			error = EINVAL;
> +			break;
> +		ubuf.uio_td = td;
> +		ubuf.uio_rw = UIO_READ;
> +		error = iicuio_move(priv, &ubuf, s->last);
> +		break;
> +	case I2CRDWR:
> +		 * The rdwr list should be a self-contained set of
> +		 * transactions.  Fail if another transaction is in progress.
> +			error = EINVAL;
> +			break;
> +		error = iicrdwr(priv, (struct iic_rdwr_data *)data, flags);
> +		break;
> +	case I2CRPTSTART:
> +			error = EINVAL;
> +			break;
> +		error = iicbus_repeated_start(parent, s->slave, 0);
> +		break;
> +	case I2CSADDR:
> +		priv->addr = *((uint8_t*)data);
> +		break;
> +	default:
> +		error = ENOTTY;
> +	IIC_UNLOCK(priv);
> +	return (error);
> +DRIVER_MODULE(iic, iicbus, iic_driver, iic_devclass, 0, 0);
> +MODULE_DEPEND(iic, iicbus, IICBUS_MINVER, IICBUS_PREFVER, IICBUS_MAXVER);
> +MODULE_VERSION(iic, 1);
> diff --git a/freebsd/sys/dev/iicbus/iic.h b/freebsd/sys/dev/iicbus/iic.h
> index 00000000..5ebf56a9
> --- /dev/null
> +++ b/freebsd/sys/dev/iicbus/iic.h
> @@ -0,0 +1,72 @@
> + * Copyright (c) 1998 Nicolas Souchu
> + * are met:
> + * SUCH DAMAGE.
> + * $FreeBSD$
> +#ifndef __IIC_H
> +#define __IIC_H
> +#include <sys/ioccom.h>
> +/* Designed to be compatible with linux's struct i2c_msg */
> +struct iic_msg
> +	uint16_t	slave;
> +	uint16_t	flags;
> +#define	IIC_M_WR	0	/* Fake flag for write */
> +#define	IIC_M_RD	0x0001	/* read vs write */
> +#define	IIC_M_NOSTOP	0x0002	/* do not send a I2C stop after message */
> +#define	IIC_M_NOSTART	0x0004	/* do not send a I2C start before message */
> +	uint16_t	len;	/* msg length */
> +	uint8_t *	buf;
> +struct iiccmd {
> +	u_char slave;
> +	int count;
> +	int last;
> +	char *buf;
> +struct iic_rdwr_data {
> +	struct iic_msg *msgs;
> +	uint32_t nmsgs;
> +#define IIC_RDRW_MAX_MSGS	42
> +#define I2CSTART	_IOW('i', 1, struct iiccmd)	/* start condition */
> +#define I2CSTOP		_IO('i', 2)			/* stop condition */
> +#define I2CRSTCARD	_IOW('i', 3, struct iiccmd)	/* reset the card */
> +#define I2CWRITE	_IOW('i', 4, struct iiccmd)	/* send data */
> +#define I2CREAD		_IOW('i', 5, struct iiccmd)	/* receive data */
> +#define I2CRDWR		_IOW('i', 6, struct iic_rdwr_data)	/* General read/write interface */
> +#define I2CRPTSTART	_IOW('i', 7, struct iiccmd)	/* repeated start */
> +#define I2CSADDR	_IOW('i', 8, uint8_t)		/* set slave address for future I/O */
> +#endif
> diff --git a/freebsd/sys/dev/iicbus/iicbus.c b/freebsd/sys/dev/iicbus/iicbus.c
> index 00000000..d1e55483
> --- /dev/null
> +++ b/freebsd/sys/dev/iicbus/iicbus.c
> @@ -0,0 +1,378 @@
> + * are met:
> + * SUCH DAMAGE.
> +#include <sys/cdefs.h>
> +__FBSDID("$FreeBSD$");
> + * Autoconfiguration and support routines for the Philips serial I2C bus
> +#include <sys/mutex.h>
> +#include <sys/rman.h>
> +#include <sys/sysctl.h>
> +/* See comments below for why auto-scanning is a bad idea. */
> +#define SCAN_IICBUS 0
> +static int
> +iicbus_probe(device_t dev)
> +	device_set_desc(dev, "Philips I2C bus");
> +	/* Allow other subclasses to override this driver. */
> +	return (BUS_PROBE_GENERIC);
> +#if SCAN_IICBUS
> +static int
> +iic_probe_device(device_t dev, u_char addr)
> +	int count;
> +	char byte;
> +	if ((addr & 1) == 0) {
> +		/* is device writable? */
> +		if (!iicbus_start(dev, (u_char)addr, 0)) {
> +			iicbus_stop(dev);
> +			return (1);
> +	} else {
> +		/* is device readable? */
> +		if (!iicbus_block_read(dev, (u_char)addr, &byte, 1, &count))
> +			return (1);
> +	return (0);
> +#endif
> + * We add all the devices which we know about.
> + * The generic attach routine will attach them if they are alive.
> +static int
> +iicbus_attach(device_t dev)
> +#if SCAN_IICBUS
> +	unsigned char addr;
> +#endif
> +	struct iicbus_softc *sc = IICBUS_SOFTC(dev);
> +	int strict;
> +	sc->dev = dev;
> +	mtx_init(&sc->lock, "iicbus", NULL, MTX_DEF);
> +	iicbus_init_frequency(dev, 0);
> +	iicbus_reset(dev, IIC_FASTEST, 0, NULL);
> +	if (resource_int_value(device_get_name(dev),
> +		device_get_unit(dev), "strict", &strict) == 0)
> +		sc->strict = strict;
> +	else
> +		sc->strict = 1;
> +	/* device probing is meaningless since the bus is supposed to be
> +	 * hot-plug. Moreover, some I2C chips do not appreciate random
> +	 * accesses like stop after start to fast, reads for less than
> +	 * x bytes...
> +#if SCAN_IICBUS
> +	printf("Probing for devices on iicbus%d:", device_get_unit(dev));
> +	/* probe any devices */
> +	for (addr = 16; addr < 240; addr++) {
> +		if (iic_probe_device(dev, (u_char)addr)) {
> +			printf(" <%x>", addr);
> +	printf("\n");
> +#endif
> +	bus_generic_probe(dev);
> +	bus_enumerate_hinted_children(dev);
> +	bus_generic_attach(dev);
> +        return (0);
> +static int
> +iicbus_detach(device_t dev)
> +	bus_generic_detach(dev);
> +	device_delete_children(dev);
> +	mtx_destroy(&sc->lock);
> +	return (0);
> +static int
> +iicbus_print_child(device_t dev, device_t child)
> +	struct iicbus_ivar *devi = IICBUS_IVAR(child);
> +	int retval = 0;
> +	retval += bus_print_child_header(dev, child);
> +	if (devi->addr != 0)
> +		retval += printf(" at addr %#x", devi->addr);
> +	resource_list_print_type(&devi->rl, "irq", SYS_RES_IRQ, "%jd");
> +	retval += bus_print_child_footer(dev, child);
> +	return (retval);
> +static void
> +iicbus_probe_nomatch(device_t bus, device_t child)
> +	device_printf(bus, "<unknown card> at addr %#x\n", devi->addr);
> +static int
> +iicbus_child_location_str(device_t bus, device_t child, char *buf,
> +    size_t buflen)
> +	snprintf(buf, buflen, "addr=%#x", devi->addr);
> +	return (0);
> +static int
> +iicbus_child_pnpinfo_str(device_t bus, device_t child, char *buf,
> +    size_t buflen)
> +	*buf = '\0';
> +	return (0);
> +static int
> +iicbus_read_ivar(device_t bus, device_t child, int which, uintptr_t *result)
> +	switch (which) {
> +	default:
> +		return (EINVAL);
> +	case IICBUS_IVAR_ADDR:
> +		*result = devi->addr;
> +		break;
> +	case IICBUS_IVAR_NOSTOP:
> +		*result = devi->nostop;
> +		break;
> +	return (0);
> +static int
> +iicbus_write_ivar(device_t bus, device_t child, int which, uintptr_t value)
> +	switch (which) {
> +	default:
> +		return (EINVAL);
> +			return (EINVAL);
> +		devi->addr = value;
> +		devi->nostop = value;
> +		break;
> +	return (0);
> +static device_t
> +iicbus_add_child(device_t dev, u_int order, const char *name, int unit)
> +	device_t child;
> +	struct iicbus_ivar *devi;
> +	child = device_add_child_ordered(dev, order, name, unit);
> +	if (child == NULL)
> +		return (child);
> +	devi = malloc(sizeof(struct iicbus_ivar), M_DEVBUF, M_NOWAIT | M_ZERO);
> +	if (devi == NULL) {
> +		device_delete_child(dev, child);
> +		return (0);
> +	resource_list_init(&devi->rl);
> +	device_set_ivars(child, devi);
> +	return (child);
> +static void
> +iicbus_hinted_child(device_t bus, const char *dname, int dunit)
> +	device_t child;
> +	int irq;
> +	child = BUS_ADD_CHILD(bus, 0, dname, dunit);
> +	devi = IICBUS_IVAR(child);
> +	resource_int_value(dname, dunit, "addr", &devi->addr);
> +	if (resource_int_value(dname, dunit, "irq", &irq) == 0) {
> +		if (bus_set_resource(child, SYS_RES_IRQ, 0, irq, 1) != 0)
> +			    "warning: bus_set_resource() failed\n");
> +static struct resource_list *
> +iicbus_get_resource_list(device_t bus __unused, device_t child)
> +	return (&devi->rl);
> +int
> +iicbus_generic_intr(device_t dev, int event, char *buf)
> +	return (0);
> +int
> +iicbus_null_callback(device_t dev, int index, caddr_t data)
> +	return (0);
> +int
> +iicbus_null_repeated_start(device_t dev, u_char addr)
> +	return (IIC_ENOTSUPP);
> +void
> +iicbus_init_frequency(device_t dev, u_int bus_freq)
> +	 * If a bus frequency value was passed in, use it.  Otherwise initialize
> +	 * it first to the standard i2c 100KHz frequency, then override that
> +	 * from a hint if one exists.
> +	if (bus_freq > 0)
> +		sc->bus_freq = bus_freq;
> +	else {
> +		sc->bus_freq = 100000;
> +		resource_int_value(device_get_name(dev), device_get_unit(dev),
> +		    "frequency", (int *)&sc->bus_freq);
> +	 * Set up the sysctl that allows the bus frequency to be changed.
> +	 * It is flagged as a tunable so that the user can set the value in
> +	 * loader(8), and that will override any other setting from any source.
> +	 * The sysctl tunable/value is the one most directly controlled by the
> +	 * user and thus the one that always takes precedence.
> +	SYSCTL_ADD_UINT(device_get_sysctl_ctx(dev),
> +	    SYSCTL_CHILDREN(device_get_sysctl_tree(dev)),
> +	    OID_AUTO, "frequency", CTLFLAG_RW | CTLFLAG_TUN, &sc->bus_freq,
> +	    sc->bus_freq, "Bus frequency in Hz");
> +static u_int
> +iicbus_get_frequency(device_t dev, u_char speed)
> +	 * If the frequency has not been configured for the bus, or the request
> +	 * is specifically for SLOW speed, use the standard 100KHz rate, else
> +	 * use the configured bus speed.
> +	if (sc->bus_freq == 0 || speed == IIC_SLOW)
> +		return (100000);
> +	return (sc->bus_freq);
> +static device_method_t iicbus_methods[] = {
> +	DEVMETHOD(device_probe,		iicbus_probe),
> +	DEVMETHOD(device_attach,	iicbus_attach),
> +	DEVMETHOD(device_detach,	iicbus_detach),
> +	/* bus interface */
> +	DEVMETHOD(bus_setup_intr,	bus_generic_setup_intr),
> +	DEVMETHOD(bus_teardown_intr,	bus_generic_teardown_intr),
> +	DEVMETHOD(bus_activate_resource, bus_generic_activate_resource),
> +	DEVMETHOD(bus_deactivate_resource, bus_generic_deactivate_resource),
> +	DEVMETHOD(bus_adjust_resource,	bus_generic_adjust_resource),
> +	DEVMETHOD(bus_alloc_resource,	bus_generic_rl_alloc_resource),
> +	DEVMETHOD(bus_get_resource,	bus_generic_rl_get_resource),
> +	DEVMETHOD(bus_release_resource, bus_generic_rl_release_resource),
> +	DEVMETHOD(bus_set_resource,	bus_generic_rl_set_resource),
> +	DEVMETHOD(bus_get_resource_list, iicbus_get_resource_list),
> +	DEVMETHOD(bus_add_child,	iicbus_add_child),
> +	DEVMETHOD(bus_print_child,	iicbus_print_child),
> +	DEVMETHOD(bus_probe_nomatch,	iicbus_probe_nomatch),
> +	DEVMETHOD(bus_read_ivar,	iicbus_read_ivar),
> +	DEVMETHOD(bus_write_ivar,	iicbus_write_ivar),
> +	DEVMETHOD(bus_child_pnpinfo_str, iicbus_child_pnpinfo_str),
> +	DEVMETHOD(bus_child_location_str, iicbus_child_location_str),
> +	DEVMETHOD(bus_hinted_child,	iicbus_hinted_child),
> +	DEVMETHOD(iicbus_transfer,	iicbus_transfer),
> +	DEVMETHOD(iicbus_get_frequency,	iicbus_get_frequency),
> +	DEVMETHOD_END
> +driver_t iicbus_driver = {
> +        "iicbus",
> +        iicbus_methods,
> +        sizeof(struct iicbus_softc),
> +devclass_t iicbus_devclass;
> +MODULE_VERSION(iicbus, IICBUS_MODVER);
> +DRIVER_MODULE(iicbus, iichb, iicbus_driver, iicbus_devclass, 0, 0);
> diff --git a/freebsd/sys/dev/iicbus/iicbus.h b/freebsd/sys/dev/iicbus/iicbus.h
> index 00000000..503305c7
> --- /dev/null
> +++ b/freebsd/sys/dev/iicbus/iicbus.h
> @@ -0,0 +1,83 @@
> + * are met:
> + * SUCH DAMAGE.
> + * $FreeBSD$
> +#ifndef __IICBUS_H
> +#define __IICBUS_H
> +#include <sys/_lock.h>
> +#include <sys/_mutex.h>
> +#define IICBUS_IVAR(d) (struct iicbus_ivar *) device_get_ivars(d)
> +#define IICBUS_SOFTC(d) (struct iicbus_softc *) device_get_softc(d)
> +struct iicbus_softc
> +	device_t dev;		/* Myself */
> +	device_t owner;		/* iicbus owner device structure */
> +	u_int owncount;		/* iicbus ownership nesting count */
> +	u_char started;		/* address of the 'started' slave
> +				 * 0 if no start condition succeeded */
> +	u_char strict;		/* deny operations that violate the
> +				 * I2C protocol */
> +	struct mtx lock;
> +	u_int bus_freq;		/* Configured bus Hz. */
> +struct iicbus_ivar
> +	uint32_t	addr;
> +	struct resource_list	rl;
> +	bool		nostop;
> +enum {
> +	IICBUS_IVAR_ADDR,		/* Address or base address */
> +	IICBUS_IVAR_NOSTOP,		/* nostop defaults */
> +#define IICBUS_ACCESSOR(A, B, T)					\
> +	__BUS_ACCESSOR(iicbus, A, IICBUS, B, T)
> +IICBUS_ACCESSOR(addr,		ADDR,		uint32_t)
> +IICBUS_ACCESSOR(nostop,		NOSTOP,		bool)
> +#define	IICBUS_LOCK(sc)			mtx_lock(&(sc)->lock)
> +#define	IICBUS_UNLOCK(sc)      		mtx_unlock(&(sc)->lock)
> +#define	IICBUS_ASSERT_LOCKED(sc)       	mtx_assert(&(sc)->lock, MA_OWNED)
> +int  iicbus_generic_intr(device_t dev, int event, char *buf);
> +void iicbus_init_frequency(device_t dev, u_int bus_freq);
> +extern driver_t iicbus_driver;
> +extern devclass_t iicbus_devclass;
> +extern driver_t ofw_iicbus_driver;
> +extern devclass_t ofw_iicbus_devclass;
> +#endif
> diff --git a/freebsd/sys/dev/iicbus/iiconf.c b/freebsd/sys/dev/iicbus/iiconf.c
> index 00000000..afdce118
> --- /dev/null
> +++ b/freebsd/sys/dev/iicbus/iiconf.c
> @@ -0,0 +1,527 @@
> + * are met:
> + * SUCH DAMAGE.
> + * Translate IIC_Exxxxx status values to vaguely-equivelent errno values.
> +int
> +iic2errno(int iic_status)
> +	switch (iic_status) {
> +	case IIC_NOERR:         return (0);
> +	case IIC_EBUSERR:       return (EALREADY);
> +	case IIC_ENOACK:        return (EIO);
> +	case IIC_ETIMEOUT:      return (ETIMEDOUT);
> +	case IIC_EBUSBSY:       return (EWOULDBLOCK);
> +	case IIC_ESTATUS:       return (EPROTO);
> +	case IIC_EUNDERFLOW:    return (EIO);
> +	case IIC_EOVERFLOW:     return (EOVERFLOW);
> +	case IIC_ENOTSUPP:      return (EOPNOTSUPP);
> +	case IIC_ENOADDR:       return (EADDRNOTAVAIL);
> +	case IIC_ERESOURCE:     return (ENOMEM);
> +	default:                return (EIO);
> + * iicbus_intr()
> +void
> +iicbus_intr(device_t bus, int event, char *buf)
> +	struct iicbus_softc *sc = (struct iicbus_softc *)device_get_softc(bus);
> +	/* call owner's intr routine */
> +	if (sc->owner)
> +		IICBUS_INTR(sc->owner, event, buf);
> +	return;
> +static int
> +iicbus_poll(struct iicbus_softc *sc, int how)
> +	int error;
> +	IICBUS_ASSERT_LOCKED(sc);
> +	switch (how & IIC_INTRWAIT) {
> +	case IIC_WAIT | IIC_INTR:
> +		error = mtx_sleep(sc, &sc->lock, IICPRI|PCATCH, "iicreq", 0);
> +		break;
> +	case IIC_WAIT | IIC_NOINTR:
> +		error = mtx_sleep(sc, &sc->lock, IICPRI, "iicreq", 0);
> +		break;
> +	default:
> +		return (IIC_EBUSBSY);
> +	return (error);
> + * iicbus_request_bus()
> + * Allocate the device to perform transfers.
> + * how	: IIC_WAIT or IIC_DONTWAIT
> +int
> +iicbus_request_bus(device_t bus, device_t dev, int how)
> +	int error = 0;
> +	IICBUS_LOCK(sc);
> +	for (;;) {
> +		if (sc->owner == NULL)
> +			break;
> +		if ((how & IIC_RECURSIVE) && sc->owner == dev)
> +			break;
> +		if ((error = iicbus_poll(sc, how)) != 0)
> +			break;
> +	if (error == 0) {
> +		++sc->owncount;
> +		if (sc->owner == NULL) {
> +			sc->owner = dev;
> +			 * Drop the lock around the call to the bus driver, it
> +			 * should be allowed to sleep in the IIC_WAIT case.
> +			 * Drivers might also need to grab locks that would
> +			 * cause a LOR if our lock is held.
> +			IICBUS_UNLOCK(sc);
> +			/* Ask the underlying layers if the request is ok */
> +			error = IICBUS_CALLBACK(device_get_parent(bus),
> +			    IIC_REQUEST_BUS, (caddr_t)&how);
> +			IICBUS_LOCK(sc);
> +			if (error != 0) {
> +				sc->owner = NULL;
> +				sc->owncount = 0;
> +				wakeup_one(sc);
> +	return (error);
> + * iicbus_release_bus()
> + * Release the device allocated with iicbus_request_dev()
> +int
> +iicbus_release_bus(device_t bus, device_t dev)
> +	IICBUS_LOCK(sc);
> +	if (sc->owner != dev) {
> +	if (--sc->owncount == 0) {
> +		/* Drop the lock while informing the low-level driver. */
> +		IICBUS_CALLBACK(device_get_parent(bus), IIC_RELEASE_BUS, NULL);
> +		IICBUS_LOCK(sc);
> +		sc->owner = NULL;
> +		wakeup_one(sc);
> +	return (0);
> + * iicbus_started()
> + * Test if the iicbus is started by the controller
> +int
> +iicbus_started(device_t bus)
> +	return (sc->started);
> + * iicbus_start()
> + * Send start condition to the slave addressed by 'slave'
> +int
> +iicbus_start(device_t bus, u_char slave, int timeout)
> +	int error = 0;
> +	if (sc->started)
> +		return (IIC_ESTATUS); /* protocol error, bus already started */
> +	if (!(error = IICBUS_START(device_get_parent(bus), slave, timeout)))
> +		sc->started = slave;
> +	else
> +		sc->started = 0;
> +	return (error);
> + * iicbus_repeated_start()
> +int
> +iicbus_repeated_start(device_t bus, u_char slave, int timeout)
> +	int error = 0;
> +	if (!sc->started)
> +		return (IIC_ESTATUS); /* protocol error, bus not started */
> +	if (!(error = IICBUS_REPEATED_START(device_get_parent(bus), slave, timeout)))
> +	else
> +		sc->started = 0;
> +	return (error);
> + * iicbus_stop()
> + * Send stop condition to the bus
> +int
> +iicbus_stop(device_t bus)
> +	int error = 0;
> +	if (!sc->started)
> +	error = IICBUS_STOP(device_get_parent(bus));
> +	/* refuse any further access */
> +	sc->started = 0;
> +	return (error);
> + * iicbus_write()
> + * Write a block of data to the slave previously started by
> + * iicbus_start() call
> +int
> +iicbus_write(device_t bus, const char *buf, int len, int *sent, int timeout)
> +	/* a slave must have been started for writing */
> +	if (sc->started == 0 || (sc->strict != 0 && (sc->started & LSB) != 0))
> +	return (IICBUS_WRITE(device_get_parent(bus), buf, len, sent, timeout));
> + * iicbus_read()
> + * Read a block of data from the slave previously started by
> + * iicbus_read() call
> +int
> +iicbus_read(device_t bus, char *buf, int len, int *read, int last, int delay)
> +	/* a slave must have been started for reading */
> +	if (sc->started == 0 || (sc->strict != 0 && (sc->started & LSB) == 0))
> +	return (IICBUS_READ(device_get_parent(bus), buf, len, read, last, delay));
> + * iicbus_write_byte()
> + * Write a byte to the slave previously started by iicbus_start() call
> +int
> +iicbus_write_byte(device_t bus, char byte, int timeout)
> +	struct iicbus_softc *sc = device_get_softc(bus);
> +	char data = byte;
> +	int sent;
> +	return (iicbus_write(bus, &data, 1, &sent, timeout));
> + * iicbus_read_byte()
> + * Read a byte from the slave previously started by iicbus_start() call
> +int
> +iicbus_read_byte(device_t bus, char *byte, int timeout)
> +	int read;
> +	return (iicbus_read(bus, byte, 1, &read, IIC_LAST_READ, timeout));
> + * iicbus_block_write()
> + * Write a block of data to slave ; start/stop protocol managed
> +int
> +iicbus_block_write(device_t bus, u_char slave, char *buf, int len, int *sent)
> +	u_char addr = slave & ~LSB;
> +	int error;
> +	if ((error = iicbus_start(bus, addr, 0)))
> +		return (error);
> +	error = iicbus_write(bus, buf, len, sent, 0);
> +	iicbus_stop(bus);
> +	return (error);
> + * iicbus_block_read()
> + * Read a block of data from slave ; start/stop protocol managed
> +int
> +iicbus_block_read(device_t bus, u_char slave, char *buf, int len, int *read)
> +	u_char addr = slave | LSB;
> +	int error;
> +		return (error);
> +	error = iicbus_read(bus, buf, len, read, IIC_LAST_READ, 0);
> +	iicbus_stop(bus);
> +	return (error);
> + * iicbus_transfer()
> + * Do an aribtrary number of transfers on the iicbus.  We pass these
> + * raw requests to the bridge driver.  If the bridge driver supports
> + * them directly, then it manages all the details.  If not, it can use
> + * the helper function iicbus_transfer_gen() which will do the
> + * transfers at a low level.
> + * Pointers passed in as part of iic_msg must be kernel pointers.
> + * Callers that have user addresses to manage must do so on their own.
> +int
> +iicbus_transfer(device_t bus, struct iic_msg *msgs, uint32_t nmsgs)
> +	return (IICBUS_TRANSFER(device_get_parent(bus), msgs, nmsgs));
> +int
> +iicbus_transfer_excl(device_t dev, struct iic_msg *msgs, uint32_t nmsgs,
> +    int how)
> +	device_t bus;
> +	int error;
> +	bus = device_get_parent(dev);
> +	error = iicbus_request_bus(bus, dev, how);
> +	if (error == 0)
> +		error = IICBUS_TRANSFER(bus, msgs, nmsgs);
> +	iicbus_release_bus(bus, dev);
> +	return (error);
> + * Generic version of iicbus_transfer that calls the appropriate
> + * routines to accomplish this.  See note above about acceptable
> + * buffer addresses.
> +int
> +iicbus_transfer_gen(device_t dev, struct iic_msg *msgs, uint32_t nmsgs)
> +	int i, error, lenread, lenwrote, nkid, rpstart, addr;
> +	device_t *children, bus;
> +	bool nostop, started;
> +	if ((error = device_get_children(dev, &children, &nkid)) != 0)
> +		return (IIC_ERESOURCE);
> +	if (nkid != 1) {
> +		free(children, M_TEMP);
> +	bus = children[0];
> +	rpstart = 0;
> +	nostop = iicbus_get_nostop(dev);
> +	started = false;
> +	for (i = 0, error = 0; i < nmsgs && error == 0; i++) {
> +		addr = msgs[i].slave;
> +		if (msgs[i].flags & IIC_M_RD)
> +			addr |= LSB;
> +		else
> +			addr &= ~LSB;
> +		if (!(msgs[i].flags & IIC_M_NOSTART)) {
> +			if (rpstart)
> +				error = iicbus_repeated_start(bus, addr, 0);
> +			else
> +				error = iicbus_start(bus, addr, 0);
> +			if (error != 0)
> +				break;
> +			started = true;
> +			error = iicbus_read(bus, msgs[i].buf, msgs[i].len,
> +			    &lenread, IIC_LAST_READ, 0);
> +		else
> +			error = iicbus_write(bus, msgs[i].buf, msgs[i].len,
> +			    &lenwrote, 0);
> +		if (error != 0)
> +			break;
> +		if ((msgs[i].flags & IIC_M_NOSTOP) != 0 ||
> +		    (nostop && i + 1 < nmsgs)) {
> +			rpstart = 1;	/* Next message gets repeated start */
> +		} else {
> +			rpstart = 0;
> +			iicbus_stop(bus);
> +	if (error != 0 && started)
> +		iicbus_stop(bus);
> +	return (error);
> +int
> +iicdev_readfrom(device_t slavedev, uint8_t regaddr, void *buffer,
> +    uint16_t buflen, int waithow)
> +	struct iic_msg msgs[2];
> +	uint8_t slaveaddr;
> +	 * Two transfers back to back with a repeat-start between them; first we
> +	 * write the address-within-device, then we read from the device.
> +	slaveaddr = iicbus_get_addr(slavedev);
> +	msgs[0].slave = slaveaddr;
> +	msgs[0].flags = IIC_M_WR | IIC_M_NOSTOP;
> +	msgs[0].len   = 1;
> +	msgs[0].buf   = ®addr;
> +	msgs[1].slave = slaveaddr;
> +	msgs[1].flags = IIC_M_RD;
> +	msgs[1].len   = buflen;
> +	msgs[1].buf   = buffer;
> +	return (iicbus_transfer_excl(slavedev, msgs, nitems(msgs), waithow));
> +int iicdev_writeto(device_t slavedev, uint8_t regaddr, void *buffer,
> +	 * Two transfers back to back with no stop or start between them; first
> +	 * we write the address then we write the data to that address, all in a
> +	 * single transfer from two scattered buffers.
> +	msgs[0].len   = 1;
> +	msgs[1].flags = IIC_M_WR | IIC_M_NOSTART;
> diff --git a/freebsd/sys/dev/iicbus/iiconf.h b/freebsd/sys/dev/iicbus/iiconf.h
> index 00000000..c264183e
> --- /dev/null
> +++ b/freebsd/sys/dev/iicbus/iiconf.h
> @@ -0,0 +1,162 @@
> + * are met:
> + * SUCH DAMAGE.
> + * $FreeBSD$
> +#ifndef __IICONF_H
> +#define __IICONF_H
> +#include <sys/queue.h>
> +#define IICPRI (PZERO+8)		/* XXX sleep/wakeup queue priority */
> +#define LSB 0x1
> + * Options affecting iicbus_request_bus()
> +#define IIC_DONTWAIT	0
> +#define IIC_NOINTR	0
> +#define IIC_WAIT	0x1
> +#define IIC_INTR	0x2
> +#define IIC_INTRWAIT	(IIC_INTR | IIC_WAIT)
> +#define IIC_RECURSIVE	0x4
> + * i2c modes
> +#define IIC_MASTER	0x1
> +#define IIC_SLAVE	0x2
> +#define IIC_POLLED	0x4
> + * i2c speed
> +#define IIC_UNKNOWN	0x0
> +#define IIC_SLOW	0x1
> +#define IIC_FAST	0x2
> +#define IIC_FASTEST	0x3
> +#define IIC_LAST_READ	0x1
> + * callback index
> +#define IIC_REQUEST_BUS	0x1
> +#define IIC_RELEASE_BUS	0x2
> + * interrupt events
> +#define INTR_GENERAL	0x1	/* general call received */
> +#define INTR_START	0x2	/* the I2C interface is addressed */
> +#define INTR_STOP	0x3	/* stop condition received */
> +#define INTR_RECEIVE	0x4	/* character received */
> +#define INTR_TRANSMIT	0x5	/* character to transmit */
> +#define INTR_ERROR	0x6	/* error */
> +#define INTR_NOACK	0x7	/* no ack from master receiver */
> + * adapter layer errors
> +#define	IIC_NOERR	0x0	/* no error occurred */
> +#define IIC_EBUSERR	0x1	/* bus error (hardware not in expected state) */
> +#define IIC_ENOACK	0x2	/* ack not received until timeout */
> +#define IIC_ETIMEOUT	0x3	/* timeout */
> +#define IIC_EBUSBSY	0x4	/* bus busy (reserved by another client) */
> +#define IIC_ESTATUS	0x5	/* status error */
> +#define IIC_EUNDERFLOW	0x6	/* slave ready for more data */
> +#define IIC_EOVERFLOW	0x7	/* too much data */
> +#define IIC_ENOTSUPP	0x8	/* request not supported */
> +#define IIC_ENOADDR	0x9	/* no address assigned to the interface */
> +#define IIC_ERESOURCE	0xa	/* resources (memory, whatever) unavailable */
> + * Note that all iicbus functions return IIC_Exxxxx status values,
> + * except iic2errno() (obviously) and iicbus_started() (returns bool).
> +extern int iic2errno(int);
> +extern int iicbus_request_bus(device_t, device_t, int);
> +extern int iicbus_release_bus(device_t, device_t);
> +extern device_t iicbus_alloc_bus(device_t);
> +extern void iicbus_intr(device_t, int, char *);
> +extern int iicbus_null_repeated_start(device_t, u_char);
> +extern int iicbus_null_callback(device_t, int, caddr_t);
> +#define iicbus_reset(bus,speed,addr,oldaddr) \
> +	(IICBUS_RESET(device_get_parent(bus), speed, addr, oldaddr))
> +/* basic I2C operations */
> +extern int iicbus_started(device_t);
> +extern int iicbus_start(device_t, u_char, int);
> +extern int iicbus_stop(device_t);
> +extern int iicbus_repeated_start(device_t, u_char, int);
> +extern int iicbus_write(device_t, const char *, int, int *, int);
> +extern int iicbus_read(device_t, char *, int, int *, int, int);
> +/* single byte read/write functions, start/stop not managed */
> +extern int iicbus_write_byte(device_t, char, int);
> +extern int iicbus_read_byte(device_t, char *, int);
> +/* Read/write operations with start/stop conditions managed */
> +extern int iicbus_block_write(device_t, u_char, char *, int, int *);
> +extern int iicbus_block_read(device_t, u_char, char *, int, int *);
> +/* vectors of iic operations to pass to bridge */
> +int iicbus_transfer(device_t bus, struct iic_msg *msgs, uint32_t nmsgs);
> +int iicbus_transfer_excl(device_t bus, struct iic_msg *msgs, uint32_t nmsgs,
> +    int how);
> +int iicbus_transfer_gen(device_t bus, struct iic_msg *msgs, uint32_t nmsgs);
> + * Simple register read/write routines, but the "register" can be any size.
> + * The transfers are done with iicbus_transfer_excl().  Reads use a repeat-start
> + * between sending the address and reading; writes use a single start/stop.
> +int iicdev_readfrom(device_t _slavedev, uint8_t _regaddr, void *_buffer,
> +    uint16_t _buflen, int _waithow);
> +int iicdev_writeto(device_t _slavedev, uint8_t _regaddr, void *_buffer,
> +#define IICBUS_MODVER	1
> +#define IICBUS_MINVER	1
> +#define IICBUS_MAXVER	1
> +#define IICBUS_PREFVER	IICBUS_MODVER
> +extern driver_t iicbb_driver;
> +extern devclass_t iicbb_devclass;
> +#define IICBB_MODVER	1
> +#define IICBB_MINVER	1
> +#define IICBB_MAXVER	1
> +#define IICBB_PREFVER	IICBB_MODVER
> +#endif
> diff --git a/freebsd/sys/dev/iicbus/ofw_iicbus.c b/freebsd/sys/dev/iicbus/ofw_iicbus.c
> index 00000000..cb31459e
> --- /dev/null
> +++ b/freebsd/sys/dev/iicbus/ofw_iicbus.c
> @@ -0,0 +1,242 @@
> + * Copyright (c) 2009, Nathan Whitehorn <nwhitehorn at FreeBSD.org>
> + * are met:
> + *    notice unmodified, this list of conditions, and the following
> + *    disclaimer.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
> + * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
> + * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
> + * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
> + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
> + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
> + * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
> + * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
> + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
> + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> +#include <sys/libkern.h>
> +#include <dev/ofw/ofw_bus.h>
> +#include <dev/ofw/ofw_bus_subr.h>
> +#include <dev/ofw/openfirm.h>
> +/* Methods */
> +static device_probe_t ofw_iicbus_probe;
> +static device_attach_t ofw_iicbus_attach;
> +static device_t ofw_iicbus_add_child(device_t dev, u_int order,
> +    const char *name, int unit);
> +static const struct ofw_bus_devinfo *ofw_iicbus_get_devinfo(device_t bus,
> +    device_t dev);
> +static device_method_t ofw_iicbus_methods[] = {
> +	/* Device interface */
> +	DEVMETHOD(device_probe,		ofw_iicbus_probe),
> +	DEVMETHOD(device_attach,	ofw_iicbus_attach),
> +	/* Bus interface */
> +	DEVMETHOD(bus_child_pnpinfo_str, ofw_bus_gen_child_pnpinfo_str),
> +	DEVMETHOD(bus_add_child,	ofw_iicbus_add_child),
> +	/* ofw_bus interface */
> +	DEVMETHOD(ofw_bus_get_devinfo,	ofw_iicbus_get_devinfo),
> +	DEVMETHOD(ofw_bus_get_compat,	ofw_bus_gen_get_compat),
> +	DEVMETHOD(ofw_bus_get_model,	ofw_bus_gen_get_model),
> +	DEVMETHOD(ofw_bus_get_name,	ofw_bus_gen_get_name),
> +	DEVMETHOD(ofw_bus_get_node,	ofw_bus_gen_get_node),
> +	DEVMETHOD(ofw_bus_get_type,	ofw_bus_gen_get_type),
> +	DEVMETHOD_END
> +struct ofw_iicbus_devinfo {
> +	struct iicbus_ivar	opd_dinfo;	/* Must be the first. */
> +	struct ofw_bus_devinfo	opd_obdinfo;
> +devclass_t ofw_iicbus_devclass;
> +DEFINE_CLASS_1(iicbus, ofw_iicbus_driver, ofw_iicbus_methods,
> +    sizeof(struct iicbus_softc), iicbus_driver);
> +EARLY_DRIVER_MODULE(ofw_iicbus, iicbb, ofw_iicbus_driver, ofw_iicbus_devclass,
> +    0, 0, BUS_PASS_BUS);
> +EARLY_DRIVER_MODULE(ofw_iicbus, iichb, ofw_iicbus_driver, ofw_iicbus_devclass,
> +EARLY_DRIVER_MODULE(ofw_iicbus, twsi, ofw_iicbus_driver, ofw_iicbus_devclass,
> +MODULE_VERSION(ofw_iicbus, 1);
> +MODULE_DEPEND(ofw_iicbus, iicbus, 1, 1, 1);
> +static int
> +ofw_iicbus_probe(device_t dev)
> +	if (ofw_bus_get_node(dev) == -1)
> +		return (ENXIO);
> +	device_set_desc(dev, "OFW I2C bus");
> +	return (0);
> +static int
> +ofw_iicbus_attach(device_t dev)
> +	struct ofw_iicbus_devinfo *dinfo;
> +	phandle_t child, node, root;
> +	pcell_t freq, paddr;
> +	device_t childdev;
> +	ssize_t compatlen;
> +	char compat[255];
> +	char *curstr;
> +	u_int iic_addr_8bit = 0;
> +	sc->dev = dev;
> +	 * If there is a clock-frequency property for the device node, use it as
> +	 * the starting value for the bus frequency.  Then call the common
> +	 * routine that handles the tunable/sysctl which allows the FDT value to
> +	 * be overridden by the user.
> +	node = ofw_bus_get_node(dev);
> +	freq = 0;
> +	OF_getencprop(node, "clock-frequency", &freq, sizeof(freq));
> +	iicbus_init_frequency(dev, freq);
> +	 * Check if we're running on a PowerMac, needed for the I2C
> +	 * address below.
> +	root = OF_peer(0);
> +	compatlen = OF_getprop(root, "compatible", compat,
> +				sizeof(compat));
> +	if (compatlen != -1) {
> +	    for (curstr = compat; curstr < compat + compatlen;
> +		curstr += strlen(curstr) + 1) {
> +		if (strncmp(curstr, "MacRISC", 7) == 0)
> +		    iic_addr_8bit = 1;
> +	 * Attach those children represented in the device tree.
> +	for (child = OF_child(node); child != 0; child = OF_peer(child)) {
> +		 * Try to get the I2C address first from the i2c-address
> +		 * property, then try the reg property.  It moves around
> +		 * on different systems.
> +		if (OF_getencprop(child, "i2c-address", &paddr,
> +		    sizeof(paddr)) == -1)
> +			if (OF_getencprop(child, "reg", &paddr,
> +				continue;
> +		 * Now set up the I2C and OFW bus layer devinfo and add it
> +		 * to the bus.
> +		dinfo = malloc(sizeof(struct ofw_iicbus_devinfo), M_DEVBUF,
> +		    M_NOWAIT | M_ZERO);
> +		if (dinfo == NULL)
> +			continue;
> +		 * FreeBSD drivers expect I2C addresses to be expressed as
> +		 * 8-bit values.  Apple OFW data contains 8-bit values, but
> +		 * Linux FDT data contains 7-bit values, so shift them up to
> +		 * 8-bit format.
> +		if (iic_addr_8bit)
> +		    dinfo->opd_dinfo.addr = paddr;
> +		else
> +		    dinfo->opd_dinfo.addr = paddr << 1;
> +		if (ofw_bus_gen_setup_devinfo(&dinfo->opd_obdinfo, child) !=
> +		    0) {
> +			free(dinfo, M_DEVBUF);
> +			continue;
> +		childdev = device_add_child(dev, NULL, -1);
> +		resource_list_init(&dinfo->opd_dinfo.rl);
> +		ofw_bus_intr_to_rl(childdev, child,
> +					&dinfo->opd_dinfo.rl, NULL);
> +		device_set_ivars(childdev, dinfo);
> +	/* Register bus */
> +	OF_device_register_xref(OF_xref_from_node(node), dev);
> +	return (bus_generic_attach(dev));
> +static device_t
> +ofw_iicbus_add_child(device_t dev, u_int order, const char *name, int unit)
> +	device_t child;
> +	struct ofw_iicbus_devinfo *devi;
> +		return (child);
> +	devi = malloc(sizeof(struct ofw_iicbus_devinfo), M_DEVBUF,
> +		return (0);
> +	 * NULL all the OFW-related parts of the ivars for non-OFW
> +	 * children.
> +	devi->opd_obdinfo.obd_node = -1;
> +	devi->opd_obdinfo.obd_name = NULL;
> +	devi->opd_obdinfo.obd_compat = NULL;
> +	devi->opd_obdinfo.obd_type = NULL;
> +	devi->opd_obdinfo.obd_model = NULL;
> +	return (child);
> +ofw_iicbus_get_devinfo(device_t bus, device_t dev)
> +	dinfo = device_get_ivars(dev);
> +	return (&dinfo->opd_obdinfo);
