[PATCH v2] user/bsps: Add beagle BSP
Christian Mauderer list at c-mauderer.de
Mon Jun 10 12:43:42 UTC 2019
On 09/06/2019 16:57, Vijay Kumar Banerjee wrote:
>  user/bsps/bsps-arm.rst | 69 +++++++++++++++++++++++++++++++++++++++++-
>  1 file changed, 68 insertions(+), 1 deletion(-)
> diff --git a/user/bsps/bsps-arm.rst b/user/bsps/bsps-arm.rst
> index eb972c6..e6826cd 100644
> --- a/user/bsps/bsps-arm.rst
> +++ b/user/bsps/bsps-arm.rst
> @@ -93,7 +93,74 @@ TODO.
>  beagle
> -TODO.
> +This BSP supports four variants, `beagleboardorig`, `beagleboardxm`, `beaglebonewhite`
> +and `beagleboneblack`. The basic hardware initialization is not performed by
> +the BSP.  A boot loader with device tree support must be used to start the BSP,
> +e.g. U-Boot.
> +TODO(These drivers are present but not documented yet):
> +* Clock driver.
> +* Network Interface Driver.
> +* SDcard driver.
> +* GPIO Driver.
> +* Console driver.
> +* PWM Driver.
> +* RTC driver.
> +Boot via U-Boot
> +To boot via uboot, the ELF must be converted to a U-Boot image like below:
> +.. code-block:: none
> +    arm-rtems5-objcopy hello.exe -O app.bin
> +    gzip 9 app.bin
> +    mkimage -A arm -O linux -T kernel -a 0x80000000 -e 0x80000000 -n RTEMS -d app.bin.gz rtems-app.img
> +Getting the Device Tree Blob
> +The Device Tree Blob(dtb) is needed to load the device tree while starting up
> +the kernel. Currently the dtb is built using the linux `device-tree-rebasing
> +<https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasing.git/tree/>`_
Sorry that I have to nag about that again. I know I suggested that tree.
But it seems that there is a problem with it: If I build the tree from
that source, neither SD nor your I2C overlay driver works. I haven't had
a look at it yet what has been changed.
So either we would have to suggest a (working) branch of that repo or we
should link to some other repo. Most likely the dts files from FreeBSD
would be best source to document for usage with libbsd.
Please wait with sending a v3 for at least a day or two. Maybe someone
else has a good idea for a source.
> +repository.
> +Writing the uEnv.txt file
> +The uEnv.txt file is needed to set any environment variable before the kernel is
> +loaded. Each line is a u-boot command that the uboot will execute during
> +starting up.
> +Add the following to a file named uEnv.txt:
> +   setenv bootdelay 5
> +   uenvcmd=run boot
> +   boot=fatload mmc 0 0x80800000 rtems-app.img ; fatload mmc 0 0x88000000 am335x-boneblack.dtb ; bootm 0x80800000 - 0x88000000
> +I2C Driver
> +This BSP uses the I2C framework and is registered using
> +``am335x_i2c_bus_register()`` the function prototype is given below:
> +.. code-block:: C
> +   int am335x_i2c_bus_register(
> +   const char         *bus_path,
> +   uintptr_t           register_base,
> +   uint32_t            input_clock,
> +   rtems_vector_number irq
> +This function is needed only while registering with custom path with custom
> +values. For registering the `/dev/i2c-0` device, a wrapper function is provided,
> +``bbb_register_i2c_0()`` similarly ``bbb_register_i2c_1()`` and
> +``bbb_register_i2c_2()`` are respectively used to register `i2c-1` and `i2c-2`.
> +SPI Driver
> +The SPI device `/dev/spi-0` can be registered with ``bbb_register_spi_0()```
>  csb336
