[PATCH] Add testsuite for psxinttypes01
Mon Jun 10 16:31:28 UTC 2019
Hi Vaibhav,
This is getting better, see below for review comments.
On Mon, Jun 10, 2019 at 4:48 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>  testsuites/psxtests/Makefile.am               |   7 +
>  testsuites/psxtests/configure.ac              |   1 +
>  testsuites/psxtests/psxinttypes01/init.c      | 220 ++++++++++++++++++
>  .../psxtests/psxinttypes01/psxinttypes01.doc  |  67 ++++++
>  .../psxtests/psxinttypes01/psxinttypes01.scn  |  75 ++++++
>  5 files changed, 370 insertions(+)
>  create mode 100644 testsuites/psxtests/psxinttypes01/init.c
>  create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.doc
>  create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
> index 1e354c0df7..59c9f2085b 100755
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -523,6 +523,13 @@ psxintrcritical01_CPPFLAGS = $(AM_CPPFLAGS) \
>  endif
>  endif
> +if TEST_psxinttypes01
> +psx_tests += psxinttypes01
> +psxinttypes01_SOURCES = psxinttypes01/init.c
> +psxinttypes01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxinttypes01) \
> +       $(support_includes)
> +endif
>  if HAS_POSIX
>  if TEST_psxitimer
>  psx_tests += psxitimer
> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
> index cdd6ee7e4e..85559e4aa5 100644
> --- a/testsuites/psxtests/configure.ac
> +++ b/testsuites/psxtests/configure.ac
> @@ -91,6 +91,7 @@ RTEMS_TEST_CHECK([psxid01])
>  RTEMS_TEST_CHECK([psximfs01])
>  RTEMS_TEST_CHECK([psximfs02])
>  RTEMS_TEST_CHECK([psxintrcritical01])
> +RTEMS_TEST_CHECK([psxinttypes01])
>  RTEMS_TEST_CHECK([psxitimer])
>  RTEMS_TEST_CHECK([psxkey01])
>  RTEMS_TEST_CHECK([psxkey02])
> diff --git a/testsuites/psxtests/psxinttypes01/init.c b/testsuites/psxtests/psxinttypes01/init.c
> new file mode 100644
> index 0000000000..7627e28195
> --- /dev/null
> +++ b/testsuites/psxtests/psxinttypes01/init.c
> @@ -0,0 +1,220 @@
> + *  @file
> + *  @brief Test suite for inttypes.h methods
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2019, Aditya Upadhyay and Vaibhav Gupta
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/test.h>
> +#include <inttypes.h>
> +#include <stdio.h>
> +#include <errno.h>
> +#include <tmacros.h>
> +#include <stdint.h>
> +#include <stddef.h>
> +const char rtems_test_name[] = "PSXINTTYPE 01";
> +/* forward declarations to avoid warnings */
> +rtems_task Init(rtems_task_argument ignored);
> +  int       base         = 10;
> +  int       invalid_base = 40;
> +  char     *nptr1_p        = "123abc";                         //char* pointing to string with positive number
> +  char     *nptr1_n        = "-123abc";                                //char* pointing to string with negative number
> +  char     *endptr1      = NULL;
> +  wchar_t  *nptr2_p        = L"123junk";                       //wchar_t* pointing to string with positive number
> +  wchar_t  *nptr2_n        = L"-123junk";                      //wchar_t* pointing to string with negative number
> +  wchar_t  *endptr2      = NULL;
> +  intmax_t  result_strtoimax;
> +  uintmax_t result_strtoumax;
Only one blank line is needed.
> +  TEST_BEGIN();
> +  puts( "\nChecking invalid base value" );
> +  rtems_test_assert( base >=2 && base <= 36 );
This is an unnecessary print statement and assert.
> +  /*Test for strtoimax  */
> +  puts( "\nStrtoimax Testcases...." );
Don't capitalize the S.  Same below in other testcases.
> +  puts( "Generating Results" );
> +  puts( "1 - Valid Inputs - Positive Number" );
This is very "chatty" I think you can remove some print statements. At
least, "Generating Results" is unnecessary here, more below. You might
also consider removing the sequence numbers "1 - " and others below,
they're not really needed.
> +  result_strtoimax = strtoimax( nptr1_p, &endptr1, base );
> +  puts( "Checking Results" );
And "Checking Results" is not needed.
> +  rtems_test_assert( result_strtoimax == 123 );
> +  puts( "PASS" );
And "PASS" is not needed, it is implied by reaching the next print statement.
> +  puts( "2 - Valid Inputs - Negative Number" );
> +  result_strtoimax = strtoimax( nptr1_n, &endptr1, base );
> +  rtems_test_assert( result_strtoimax == -123 );
> +  puts( "PASS" );
Again get rid of "Checking Results" and "PASS" print statements.
Repeat as needed below.
> +  puts( "Checking Garbage end of endptr" );
I'd suggest you use the language from POSIX strtol, and say 'final
string' instead of 'Garbage'.
> +  rtems_test_assert( *endptr1 != '\0' );
Would it be more correct to check that *endptr1 == 'a', or that
(endptr1 == nptr1_n+4)?
> +  puts( "PASS" );
> +  puts( "3 - Invalid Input - Send NULL Pointer" );
> +  result_strtoimax = strtoimax( NULL, &endptr1, base );
> +  rtems_test_assert( result_strtoimax == 0 );
> +  rtems_test_assert( errno == EINVAL );
> +  puts( "PASS" );
> +  puts( "4 - Invalid Input - Invalid base - Use base = 40" );
> +  result_strtoimax = strtoimax( nptr1_p, &endptr1, invalid_base );
> +  puts( "PASS" );
There should be tests for out-of-range. Pass a string with a larger
magnitude (positive and then negative) and check the return/errno.
> +  /*Test for strtoumax  */
> +  puts( "\nStrtoumax Testcases...." );
> +  result_strtoumax = strtoumax( nptr1_p, &endptr1, base );
> +  rtems_test_assert( result_strtoumax ==123 );
> +  puts( "PASS" );
> +  result_strtoumax = strtoumax( nptr1_n, &endptr1, base );
> +  rtems_test_assert( result_strtoumax == ( UINTMAX_MAX - 123 + 1 ) );
> +  puts( "PASS" );
Is it expected to convert the negative number correctly like this?
> +  puts( "PASS" );
> +  result_strtoumax = strtoumax( NULL, &endptr1, base );
> +  rtems_test_assert( result_strtoumax == 0 );
> +  puts( "PASS" );
> +  result_strtoumax = strtoumax( nptr1_p, &endptr1, invalid_base );
> +  puts( "PASS" );
> +  /*Test for wcstoimax  */
> +  puts( "\nWcstoimax Testcases...." );
> +  result_strtoimax = wcstoimax( nptr2_p, &endptr2, base );
> +  puts( "PASS" );
> +  result_strtoimax = wcstoimax( nptr2_n, &endptr2, base );
> +  puts( "PASS" );
> +  rtems_test_assert( *endptr2 != '\0' );
> +  puts( "PASS" );
> +  result_strtoimax = wcstoimax( NULL, &endptr2, base );
> +  puts( "PASS" );
> +  result_strtoimax = wcstoimax( nptr2_p, &endptr2, invalid_base );
> +  puts( "PASS" );
> +  /*Test for wcstoumax  */
> +  puts( "\nWcstoumax Testcases...." );
> +  result_strtoumax = wcstoumax( nptr2_p, &endptr2, base );
> +  rtems_test_assert( result_strtoumax == 123 );
> +  puts( "PASS" );
> +  result_strtoumax = wcstoumax( nptr2_n, &endptr2, base );
> +  puts( "PASS" );
> +  puts( "PASS" );
> +  result_strtoumax = wcstoumax( NULL, &endptr2, base );
> +  puts( "PASS" );
> +  result_strtoumax = wcstoumax( nptr2_p, &endptr2, invalid_base );
> +  puts( "PASS" );
Excess whitespace
> +  TEST_END();
> +  rtems_test_exit(0);
> +/* NOTICE: the clock driver is explicitly disabled */
> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_MAXIMUM_TASKS            1
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#include <rtems/confdefs.h>
> diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> index 0000000000..50962dd930
> --- /dev/null
> +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> @@ -0,0 +1,67 @@
> + *  @file
> + *  @brief Doc for Test suite for inttypes.h methods
Don't put in .doc file
> + * Copyright (C) 2019, Vaibhav Gupta
> + * are met:
ditto
> +This File describes the concepts tested by this test suite.
> +inttypes.h - fixed size integer types
> +test suite name: PSXINTTYPE 01
> +- Checks for invalid base value
Delete this line
> +- Checks for Strtoimax Testcases
> +       - checks for output for string having a positive number
> +       - checks for output for string having a negative number
> +       - checks for Garbage end of endptr
> +       - checks for output for invalid argument - NULL Pointer
> +       - checks for output for invalid argument - Invalid Base
> +- Checks for Strtoumax Test Cases
> +- Checks for Wcstoimax Testcases
> +- Checks for Wcstoumax Testcases
> diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> index 0000000000..6d50e64672
> --- /dev/null
> +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> @@ -0,0 +1,75 @@
> +*** PSXINTTYPE 01 TEST ***
> +Checking invalid base value
> +Strtoimax Testcases....
> +Generating Results
> +1 - Valid Inputs - Positive Number
> +Checking Results
> +PASS
> +2 - Valid Inputs - Negative Number
> +Checking Results
> +PASS
> +Checking Garbage end of endptr
> +PASS
> +3 - Invalid Input - Send NULL Pointer
> +Checking Results
> +PASS
> +4 - Invalid Input - Invalid base - Use base = 40
> +Checking Results
> +PASS
> +Strtoumax Testcases....
> +Generating Results
> +Checking Results
> +PASS
> +Checking Results
> +PASS
> +PASS
> +Checking Results
> +PASS
> +Checking Results
> +PASS
> +Wcstoimax Testcases....
> +Generating Results
> +Checking Results
> +PASS
> +Checking Results
> +PASS
> +PASS
> +Checking Results
> +PASS
> +Checking Results
> +PASS
> +Wcstoumax Testcases....
> +Generating Results
> +Checking Results
> +PASS
> +Checking Results
> +PASS
> +PASS
> +Checking Results
> +PASS
> +Checking Results
> +PASS
> +*** END OF PSXINTTYPE 01 TEST ***
Regenerate
> 2.21.0
