PlantUML and rtems-docs
Tue Jun 11 08:27:56 UTC 2019
On 11/06/2019 10:21, Chris Johns wrote:
> On 11/6/19 5:04 pm, Sebastian Huber wrote:
>> I noticed also that we don't use the sphinxcontrib-plantuml extension:
>> https://pypi.org/project/sphinxcontrib-plantuml/
>> Should we use it? It would enable the use of images in *.pdf format for the
>> Latex output. The PNGs are quite ugly in the Latex output.
> Sure, it looks good. Does it support ditaa?
I had some problems to set it up. It didn't work with the Node.js "puml"
command. I had to use the Java archive. I didn't test the ditaa input so
far.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
