[PATCH] Basic Support for Trace Compass
Tue Jun 11 08:32:24 UTC 2019
On 11/06/2019 10:22, Ravindra Kumar Meena wrote:
>     Yes, it would be good to have a worked out example, however, the
>     general
>     description should be independent of this.
> The trace stream received on the host was only possible after applying
> the two patches in the root directory of rtems-libbsd and rtems-tools. I
> mean it is not from the master branch of these two repositories.
> These patches are not the production side. Is it good to talk about
> patches here?
Just use your GSoC branches as a reference. In the end it should work
with the upstream master branches as is without external patches.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
