PlantUML and rtems-docs
Tue Jun 11 08:34:22 UTC 2019
On 11/6/19 6:27 pm, Sebastian Huber wrote:
> On 11/06/2019 10:21, Chris Johns wrote:
>> On 11/6/19 5:04 pm, Sebastian Huber wrote:
>>> I noticed also that we don't use the sphinxcontrib-plantuml extension:
>>> https://pypi.org/project/sphinxcontrib-plantuml/
>>> Should we use it? It would enable the use of images in *.pdf format for the
>>> Latex output. The PNGs are quite ugly in the Latex output.
>> Sure, it looks good. Does it support ditaa?
> I had some problems to set it up. It didn't work with the Node.js "puml"
> command.
OK.
> I had to use the Java archive.
I wanted to avoid using the Java archive but if someone can make work I am fine
with it being directly used.
> I didn't test the ditaa input so far.
I think it is embedded in PlanetUML so it should work.
