[PATCH v3 4/8] rtemstoolkit/path: Merge RSB changes.
chrisj at rtems.org chrisj at rtems.org
Tue Jun 11 11:08:22 UTC 2019
 rtemstoolkit/path.py | 294 ++++++++++++++++++++++++++++++++++---------
 1 file changed, 233 insertions(+), 61 deletions(-)
diff --git a/rtemstoolkit/path.py b/rtemstoolkit/path.py
index 845dfe8..9401e99 100644
--- a/rtemstoolkit/path.py
+++ b/rtemstoolkit/path.py
@@ -40,37 +40,60 @@ import glob
 import os
 import shutil
 import string
+import sys
 from rtemstoolkit import error
 from rtemstoolkit import log
+windows_posix = sys.platform == 'msys'
 windows = os.name == 'nt'
+win_maxpath = 254
 def host(path):
     if path is not None:
         while '//' in path:
             path = path.replace('//', '/')
-        if windows and len(path) > 2:
-            if path[0] == '/' and path[2] == '/' and \
-                    (path[1] in string.ascii_lowercase or \
-                         path[1] in string.ascii_uppercase):
-                path = ('%s:%s' % (path[1], path[2:])).replace('/', '\\')
+        if windows:
+            if len(path) > 2 and \
+               path[0] == '/' and path[2] == '/' and \
+               (path[1] in string.ascii_lowercase or \
+                path[1] in string.ascii_uppercase):
+                path = '%s:%s' % (path[1], path[2:])
+            path = path.replace('/', '\\')
+            if len(path) > win_maxpath:
+                if path.startswith('\\\\?\\'):
+                    path = path[4:]
+                path = u'\\'.join([u'\\\\?', path])
     return path
 def shell(path):
+    if isinstance(path, bytes):
+        path = path.decode('ascii')
-        if windows and len(path) > 1 and path[1] == ':':
-            path = ('/%s%s' % (path[0], path[2:])).replace('\\', '/')
+        if windows or windows_posix:
+            path = path.encode('ascii', 'ignore').decode('ascii')
+                path = path[4:]
+            if len(path) > 1 and path[1] == ':':
+                path = '/%s%s' % (path[0].lower(), path[2:])
+            path = path.replace('\\', '/')
         while '//' in path:
     return path
 def basename(path):
+    path = shell(path)
     return shell(os.path.basename(path))
 def dirname(path):
     return shell(os.path.dirname(path))
+def is_abspath(path):
+    if path is not None and len(path) > 0:
+        return '/' == path[0]
+    return False
 def join(path, *args):
     path = shell(path)
     for arg in args:
@@ -81,36 +104,91 @@ def join(path, *args):
     return shell(path)
 def abspath(path):
     return shell(os.path.abspath(host(path)))
+def relpath(path, start = None):
+    if start is None:
+        path = os.path.relpath(host(path))
+    else:
+        path = os.path.relpath(host(path), start)
+    return shell(path)
 def splitext(path):
     root, ext = os.path.splitext(host(path))
     return shell(root), ext
+def listdir(path, error = True):
+    path = host(path)
+    files = []
+    if not os.path.exists(path):
+        if error:
+            raise error.general('path does not exist : %s' % (path))
+    elif not isdir(path):
+        if error:
+            raise error.general('path is not a directory: %s' % (path))
+    else:
+        if windows:
+            try:
+                files = os.listdir(host(path))
+            except IOError:
+                raise error.general('Could not list files: %s' % (path))
+            except OSError as e:
+                raise error.general('Could not list files: %s: %s' % (path, str(e)))
+            except WindowsError as e:
+        else:
+            try:
+            except IOError:
+    return files
 def exists(paths):
+    def _exists(p):
+        if not is_abspath(p):
+            p = shell(join(os.getcwd(), host(p)))
+        return basename(p) in ['.'] + listdir(dirname(p), error = False)
     if type(paths) == list:
         results = []
         for p in paths:
-            results += [os.path.exists(host(p))]
+            results += [_exists(shell(p))]
         return results
-    return os.path.exists(host(paths))
+    return _exists(shell(paths))
 def isdir(path):
     return os.path.isdir(host(path))
 def isfile(path):
     return os.path.isfile(host(path))
 def isabspath(path):
     return path[0] == '/'
+def isreadable(path):
+    return os.access(host(path), os.R_OK)
 def iswritable(path):
     return os.access(host(path), os.W_OK)
+def isreadwritable(path):
+    return isreadable(path) and iswritable(path)
 def ispathwritable(path):
     path = host(path)
     while len(path) != 0:
-        if os.path.exists(path):
+        if exists(path):
             return iswritable(path)
         path = os.path.dirname(path)
     return False
@@ -138,18 +216,55 @@ def mkdir(path):
                 raise error.general('cannot make directory: %s: %s' % (path, str(e)))
+def chdir(path):
+    os.chdir(host(path))
 def removeall(path):
+    # Perform the removal of the directory tree manually so we can
+    # make sure on Windows the files are correctly encoded to avoid
+    # the file name size limit. On Windows the os.walk fails once we
+    # get to the max path length.
+    def _isdir(path):
+        hpath = host(path)
+        return os.path.isdir(hpath) and not os.path.islink(hpath)
+    def _remove_node(path):
+        if not os.path.islink(hpath) and not os.access(hpath, os.W_OK):
+            os.chmod(hpath, stat.S_IWUSR)
+        if _isdir(path):
+            os.rmdir(hpath)
+        else:
+            os.unlink(hpath)
+    def _remove(path):
+        dirs = []
+        for name in listdir(path):
+            path_ = join(path, name)
+            hname = host(path_)
+            if _isdir(path_):
+                dirs += [name]
+            else:
+                _remove_node(path_)
+        for name in dirs:
+            dir = join(path, name)
+            _remove(dir)
+            _remove_node(dir)
-    def _onerror(function, path, excinfo):
-        print('removeall error: (%s) %s' % (excinfo, path))
-    path = host(path)
-    shutil.rmtree(path, onerror = _onerror)
+    if os.path.exists(hpath):
+        _remove(path)
+        _remove_node(path)
 def expand(name, paths):
     l = []
     for p in paths:
-        l += [join(p, name)]
+        l += [join(shell(p), name)]
     return l
 def expanduser(path):
@@ -157,33 +272,6 @@ def expanduser(path):
     path = os.path.expanduser(path)
     return shell(path)
-def listdir(path):
-    path = host(path)
-    files = []
-    if not exists(path):
-        raise error.general('path does not exist : %s' % (path))
-    elif not isdir(path):
-        raise error.general('path is not a directory: %s' % (path))
-    else:
-        if windows:
-            try:
-                files = os.listdir(host(path))
-            except IOError:
-                raise error.general('Could not list files: %s' % (path))
-            except OSError as e:
-                raise error.general('Could not list files: %s: %s' % (path, str(e)))
-            except WindowsError as e:
-        else:
-            try:
-            except IOError:
-    return files
 def collect_files(path_):
     # Convert to shell paths and return shell paths.
@@ -206,30 +294,59 @@ def collect_files(path_):
         files = [host(path_)]
     return sorted(files)
+def copy(src, dst):
+    src = shell(src)
+    dst = shell(dst)
+    hsrc = host(src)
+    hdst = host(dst)
+    try:
+        shutil.copy(hsrc, hdst)
+    except OSError as why:
+        if windows:
+            if WindowsError is not None and isinstance(why, WindowsError):
+                pass
+        else:
+            raise error.general('copying tree (1): %s -> %s: %s' % (hsrc, hdst, str(why)))
 def copy_tree(src, dst):
+    trace = False
     hsrc = host(src)
     hdst = host(dst)
-    if os.path.exists(src) and os.path.isdir(src):
+    if exists(src):
         names = listdir(src)
     else:
-        names = [basename(src)]
-        src = dirname(src)
-    if not os.path.isdir(dst):
-        os.makedirs(dst)
+        names = []
+    if trace:
+        print('path.copy_tree:')
+        print('   src: "%s"' % (src))
+        print('  hsrc: "%s"' % (hsrc))
+        print('   dst: "%s"' % (dst))
+        print('  hdst: "%s"' % (hdst))
+        print(' names: %r' % (names))
+    if not os.path.isdir(hdst):
+        if trace:
+            print(' mkdir: %s' % (hdst))
+        try:
+            os.makedirs(hdst)
+            raise error.general('copying tree: cannot create target directory %s: %s' % \
+                                (hdst, str(why)))
     for name in names:
-        srcname = os.path.join(src, name)
-        dstname = os.path.join(dst, name)
+        srcname = host(os.path.join(hsrc, name))
+        dstname = host(os.path.join(hdst, name))
         try:
             if os.path.islink(srcname):
                 linkto = os.readlink(srcname)
-                if os.path.exists(dstname):
+                if exists(shell(dstname)):
                     if os.path.islink(dstname):
                         dstlinkto = os.readlink(dstname)
                         if linkto != dstlinkto:
-                            log.warning('copying tree: update of link does not match: %s -> %s' % \
+                            log.warning('copying tree: link does not match: %s -> %s' % \
                                             (dstname, dstlinkto))
                             os.remove(dstname)
                     else:
@@ -241,20 +358,74 @@ def copy_tree(src, dst):
             elif os.path.isdir(srcname):
                 copy_tree(srcname, dstname)
             else:
-                shutil.copy2(srcname, dstname)
+                shutil.copyfile(host(srcname), host(dstname))
+                shutil.copystat(host(srcname), host(dstname))
         except shutil.Error as err:
-            raise error.general('copying tree: %s -> %s: %s' % (src, dst, str(err)))
+            raise error.general('copying tree (2): %s -> %s: %s' % \
+                                (hsrc, hdst, str(err)))
         except EnvironmentError as why:
-            raise error.general('copying tree: %s -> %s: %s' % (srcname, dstname, str(why)))
+            raise error.general('copying tree (3): %s -> %s: %s' % \
+                                (srcname, dstname, str(why)))
     try:
-        shutil.copystat(src, dst)
+        shutil.copystat(hsrc, hdst)
-        ok = False
         if windows:
-                ok = True
-        if not ok:
-            raise error.general('copying tree: %s -> %s: %s' % (src, dst, str(why)))
+                pass
+        else:
+            raise error.general('copying tree (4): %s -> %s: %s' % (hsrc, hdst, str(why)))
+def get_size(path, depth = -1):
+    # Get the size the directory tree manually to the required depth.
+    # This makes sure on Windows the files are correctly encoded to avoid
+    # get to the max path length on Windows.
+    def _isdir(path):
+    def _node_size(path):
+        size = 0
+        if not os.path.islink(hpath):
+            size = os.path.getsize(hpath)
+        return size
+    def _get_size(path, depth, level = 0):
+        level += 1
+        dirs = []
+        size = 0
+            path_ = join(path, shell(name))
+            if _isdir(path_):
+                dirs += [shell(name)]
+            else:
+                size += _node_size(path_)
+        if depth < 0 or level < depth:
+            for name in dirs:
+                size += _get_size(dir, depth, level)
+        return size
+    size = 0
+        size = _get_size(path, depth)
+    return size
+def get_humanize_size(path, depth = -1):
+    size = get_size(path, depth)
+    for unit in ['','K','M','G','T','P','E','Z']:
+        if abs(size) < 1024.0:
+            return "%5.3f%sB" % (size, unit)
+        size /= 1024.0
+    return "%.3f%sB" % (size, 'Y')
 if __name__ == '__main__':
     print(host('/a/b/c/d-e-f'))
@@ -271,3 +442,4 @@ if __name__ == '__main__':
     print(basename('x:/sd/df/fg/me.txt'))
     print(dirname('x:/sd/df/fg/me.txt'))
     print(join('s:/d/', '/g', '/tyty/fgfg'))
+    print(join('s:/d/e\\f/g', '/h', '/tyty/zxzx', '\\mm\\nn/p'))
2.19.1
