[PATCH v3 8/8] misc/boot-image: Add a tool to create boot images.
chrisj at rtems.org chrisj at rtems.org
Tue Jun 11 11:08:26 UTC 2019
- FreeBSD support.
- MacOS support.
- Linux support.
- Support for 1st and 2nd loaders.
- Support uenv templates and uenv.txt support.
 misc/rtems-boot-image            |   42 ++
 misc/tools/boot.py               | 1156 ++++++++++++++++++++++++++++++
 misc/tools/cmd-boot-image.py     |   44 ++
 misc/tools/config/rtems-boot.ini |  158 ++++
 misc/wscript                     |   14 +
 5 files changed, 1414 insertions(+)
 create mode 100755 misc/rtems-boot-image
 create mode 100644 misc/tools/boot.py
 create mode 100755 misc/tools/cmd-boot-image.py
 create mode 100644 misc/tools/config/rtems-boot.ini
diff --git a/misc/rtems-boot-image b/misc/rtems-boot-image
new file mode 100755
index 0000000..aa23b2e
--- /dev/null
+++ b/misc/rtems-boot-image
@@ -0,0 +1,42 @@
+#! /bin/sh
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2019 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+set -e
+base=$(dirname $(dirname $0))
+cmd=misc/tools/cmd-boot-image.py
+PYTHON_WRAPPER=rtemstoolkit/python-wrapper.sh
+if test -f ${base}/${PYTHON_WRAPPER}; then
+  PYTHON_CMD=${base}/${cmd}
+  . ${base}/${PYTHON_WRAPPER}
+elif test -f ${base}/share/rtems/${PYTHON_WRAPPER}; then
+  PYTHON_CMD=${base}/share/rtems/${cmd}
+  . ${base}/share/rtems/${PYTHON_WRAPPER}
+fi
+echo "error: RTEMS Toolkit python wrapper not found, please report"
diff --git a/misc/tools/boot.py b/misc/tools/boot.py
new file mode 100644
index 0000000..8d6afd1
--- /dev/null
+++ b/misc/tools/boot.py
@@ -0,0 +1,1156 @@
+# Permission to use, copy, modify, and/or distribute this software for any
+# purpose with or without fee is hereby granted, provided that the above
+# copyright notice and this permission notice appear in all copies.
+# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
+# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
+# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
+# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
+# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
+# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
+# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+# This code builds a bootloader image for an SD card for a range of
+# boards on a range of hosts.
+from __future__ import print_function
+import argparse
+import copy
+import datetime
+import os
+import sys
+import tempfile
+from rtemstoolkit import check
+from rtemstoolkit import configuration
+from rtemstoolkit import error
+from rtemstoolkit import execute
+from rtemstoolkit import host
+from rtemstoolkit import log
+from rtemstoolkit import macros
+from rtemstoolkit import path
+from rtemstoolkit import version
+def _check_exes(exes):
+    ok = True
+    first = True
+    for exe in exes:
+        log.output('check exe: %s' % (exe))
+        if not check.check_exe(None, exe):
+            if first:
+                log.notice('Host executable(s) not found:')
+                first = False
+            log.notice(' %s' % (exe))
+            ok = False
+    return ok
+def _command(cmd, cwd):
+    e = execute.capture_execution()
+    cwd = path.abspath(cwd)
+    log.output('>> cwd: %s' % (cwd))
+    log.output('> %s' % (cmd))
+    exit_code, proc, output = e.shell(cmd, cwd = path.host(cwd))
+    output_split = output.split(os.linesep)
+    if len(output_split) >= 1 and len(output_split[0]) > 0:
+        log.output(['> ' + l for l in output_split])
+    log.output('> exit: %d' % (exit_code))
+    if exit_code != 0:
+        err = 'executing failure: (exit:%d) %s' % (exit_code, cmd)
+        raise error.general(err)
+    return output
+siunits = { 'g': 1024 * 1024 * 1024,
+            'm': 1024 * 1024,
+            'k': 1024 }
+def si_units(self, units):
+    if units not in siunits:
+        raise error.general('invalid SI unit: %s' % (units))
+    return siunits[units]
+def _si_parse_size(size):
+    orig = size
+    units = 1
+    suffix = ''
+    if size[-1].isalpha():
+        suffix = size[-1]
+        if suffix not in list(siunits.keys()):
+            err = 'invalid SI unit (k, m, g): %s: %s' % (suffix, size)
+        units = siunits[suffix]
+        size = size[:-1]
+    if not size.isdigit():
+        raise error.general('invalid size: %s' % (orig))
+    size = int(size)
+    return size, suffix, size * units
+def _si_size(size):
+    si_s, si_u, size = _si_parse_size(size)
+    return size
+def _si_size_units(size):
+    return si_s, si_u
+def _si_from_size(size):
+    if isinstance(size, str):
+        value = int(size)
+        if str(value) != size:
+            return size
+        size = int(size)
+    for u in siunits:
+        value = int(size / siunits[u])
+        if value != 0:
+            return '%d%s' % (value, u)
+    return str(size)
+class bootloader(object):
+    mandatory_configs = [
+        'image_size',
+        'part_type',
+        'part_label',
+        'fs_format',
+        'fs_size',
+        'fs_alignment',
+        'tool_prefix',
+        'bootloaders'
+    def __init__(self, command_path, bootloader = None):
+        # Check if there is a defaults.mc file under the command path. If so
+        # this is the tester being run from within the git repo. If not found
+        # assume the tools have been installed and the defaults is in the
+        # install prefix.
+        boot_ini = 'tools/config/rtems-boot.ini'
+        if path.exists(path.join(command_path, boot_ini)):
+            rtdir = command_path
+        else:
+            rtdir = '%{_prefix}/share/rtems'
+        boot_ini = '%s/%s' % (rtdir, boot_ini)
+        self.build = 'build'
+        self.macros = macros.macros(rtdir = rtdir, show_minimal = True)
+        self.config = configuration.configuration(raw = False)
+        self.load_config(bootloader, self.macros.expand(boot_ini))
+        self.clean = True
+    def __getitem__(self, key):
+        if self.macros.has_key(key) and self.macros[key] != 'None':
+            r = self.macros.expand('%%{%s}' % (key))
+            if r == '1':
+                return True
+            elif r == '0':
+                return False
+            else:
+                return r
+        return None
+    def __setitem__(self, key, value):
+        if value is None:
+            value = 'None'
+        if isinstance(value, int):
+            value = str(int)
+        self.macros[key] = value
+    def get_mandatory_configs(self):
+        return self.mandatory_configs
+    def check_mandatory_configs(self):
+        for c in self.get_mandatory_configs():
+            if not self.macros.has_key(c):
+                raise error.general('boot config missing: %s' % (c))
+    def load_config(self, bootloader, config):
+        self.config.load(config)
+        # Check the config file has the basic data and structure.
+        bootloaders = self.config.comma_list('default', 'bootloaders')
+        for bl in bootloaders:
+            if not self.config.has_section(bl):
+                raise error.general('boot config: missing bootloader section: %s' % (bl))
+            for b in self.config.comma_list(bl, 'boards'):
+                if not self.config.has_section(b):
+                    raise error.general('boot config: missing board section: %s' % (b))
+        # Is the bootloader valid?
+        if bootloader is not None and bootloader not in bootloaders:
+            raise error.general('boot config: unknown bootloader: %s' % (bootloader))
+        self.macros['bootloader'] = str(bootloader)
+        self.macros['version_str'] = version.string()
+        self.macros['version'] = str(version.version())
+        self.macros['revision'] = str(version.revision())
+        if version.released():
+            self.macros['released'] = '1'
+        # Map the config to macros. The [default] section is global. The
+        # remaining sections are added as macro maps so the specalised
+        # bootloaders can enable reading from a macro map to provide specific
+        # values for a specific config such as a board.
+        for s in self.config.get_sections():
+            if s != 'default':
+                self.macros.set_write_map(s, add = True)
+            for i in self.config.get_items(s):
+                self.macros[i[0]] = i[1]
+            self.macros.unset_write_map()
+        self.macros.set_read_map('global')
+        if bootloader is not None:
+            self.macros.set_read_map(bootloader)
+    def list_boards(self):
+        boards = { }
+        for bl in self.config.comma_list('default', 'bootloaders'):
+            boards[bl] = self.config.comma_list(bl, 'boards')
+        return boards
+    def section_macro_map(self, section, nesting_level = 0):
+        nesting_level += 1
+        if nesting_level >= 100:
+            err = 'boot config: too many map levels (looping?): %s' % (section)
+        if section not in self.macros.maps():
+            raise error.general('boot config: maps section not found: %s' % (section))
+        self.macros.set_read_map(section)
+        for s in self.config.comma_list(section, 'uses', err = False):
+            self.section_macro_map(s, nesting_level)
+    def boards(self):
+         return self.config.comma_list(self['bootloader'], 'boards')
+    def log(self):
+        log.output('Configuration:')
+        log.output('    Bootloader: {0}'.format(self.macros['bootloader']))
+        log.output('         Image: {0}'.format(self.macros['output']))
+        log.output('    Image Size: {0}'.format(self.macros['image_size']))
+        log.output('     Part Type: {0}'.format(self.macros['part_type']))
+        log.output('     FS Format: {0}'.format(self.macros['fs_format']))
+        log.output('       FS Size: {0}'.format(self.macros['fs_size']))
+        log.output('      FS Align: {0}'.format(self.macros['fs_alignment']))
+        log.output('        Kernel: {0}'.format(self.macros['kernel']))
+        log.output('           FDT: {0}'.format(self.macros['fdt']))
+        log.output('      Net DHCP: {0}'.format(self.macros['net_dhcp']))
+        log.output('        Net IP: {0}'.format(self.macros['net_ip']))
+        log.output(' Net Server IP: {0}'.format(self.macros['net_server_ip']))
+        log.output('      Net File: {0}'.format(self.macros['net_exe']))
+        log.output('       Net FDT: {0}'.format(self.macros['net_fdt']))
+        log.output('         Files: {0}'.format(len(self.files())))
+        log.output('Macros:')
+        macro_str = str(self.macros).split(os.linesep)
+        log.output(os.linesep.join([' ' + l for l in macro_str]))
+    def get_exes(self):
+        return []
+    def check_exes(self):
+        return _check_exes(self.get_exes())
+    def files(self):
+        return [f.strip() for f in self.comma_split(self['files']) if len(f) > 0]
+    def install_files(self, image, mountpoint):
+        pass
+    def install_configuration(self, image, mountpoint):
+        pass
+    def kernel_image(self):
+        return self['kernel_image'].replace('@KERNEL@', path.basename(self['kernel']))
+    def fdt_image(self):
+        return self['fdt_image'].replace('@FDT@', path.basename(self['fdt']))
+    def filter_text(self, lines):
+        out = []
+        for line in lines:
+            if '@KERNEL@' in line:
+                line = line.replace('@KERNEL@', path.basename(self['kernel']))
+            if '@KERNEL_IMAGE@' in line:
+                line = line.replace('@KERNEL_IMAGE@', self.kernel_image())
+            if '@FDT@' in line:
+                line = line.replace('@FDT@', path.basename(self['fdt']))
+            if '@FDT_IMAGE@' in line:
+                line = line.replace('@FDT_IMAGE@', self.fdt_image())
+            if '@NET_SERVER_IP@' in line and self['net_server_ip']is not None:
+                line = line.replace('@NET_SERVER_IP@', self['net_server_ip'])
+            if '@NET_IP@' in line and self['net_ip'] is not None:
+                line = line.replace('@NET_IP@', self['net_ip'])
+            if '@NET_BOOTEXE@' in line and self['net_exe'] is not None:
+                line = line.replace('@NET_BOOTEXE@', self['net_exe'])
+            if '@NET_BOOTFDT@' in line and self['net_fdt'] is not None:
+                line = line.replace('@NET_BOOTFDT@', self['net_fdt'])
+            out += [line]
+        return out
+    def comma_split(self, value):
+        if value is not None:
+            return [s.strip() for s in value.split(',')]
+        return []
+class uboot_bootloader(bootloader):
+    def __init__(self, command_path, convert_kernel, paths, board):
+        self.uboot = { 'paths': paths, 'board': board }
+        self.convert_kernel = convert_kernel
+        super(uboot_bootloader, self).__init__(command_path, 'u-boot')
+        if self.board() not in self.boards():
+            raise error.general('board not found: %s' %(self.board()))
+        log.output('Board: %s' % (self.board()))
+        self.section_macro_map(self.board())
+        self.macros.set_read_map(self['bootloader'] + '-templates')
+        self.macros.lock_read_map()
+        self._check_frist_second_stages()
+    def _check_frist_second_stages(self):
+        if self['first_stage'] is not None and \
+           not path.exists(self['first_stage']):
+            err = 'u-boot: first stage loader not found: %s' % \
+                (self['first_stage'])
+        if self['second_stage'] is not None and \
+           not path.exists(self['second_stage']):
+            err = 'u-boot: second stage loader not found: %s' % \
+                (self['second_stage'])
+        super(uboot_bootloader, self).load_config(bootloader, config)
+        if not self.convert_kernel:
+            paths_count = len(self.uboot['paths'])
+            if paths_count == 1:
+                self.macros['ubootdir'] = path.abspath(self.uboot['paths'][0])
+            elif paths_count == 2:
+                    self.macros['first_stage'] = self.uboot['paths'][0]
+                    self.macros['second_stage'] = self.uboot['paths'][1]
+            else:
+                raise error.general('u-boot: invalid number of paths')
+        self.macros['mkimage'] = 'mkimage'
+        cfgs = super(uboot_bootloader, self).get_mandatory_configs()
+        return cfgs + ['objcopy',
+                       'arch',
+                       'vendor',
+                       'board',
+                       'config_name',
+                       'first_stage',
+                       'second_stage',
+                       'kernel_converter']
+    def board(self):
+        return self.uboot['board']
+        exes = super(uboot_bootloader, self).get_exes()
+        if self['executables'] is not None:
+            exes += self.comma_split(self['executables'])
+        return exes
+        if self['kernel'] is not None:
+            kernel_image = self.kernel_convert(image, self['kernel'])
+            if self.convert_kernel:
+                path.copy(kernel_image, self['output'])
+            else:
+                image.install(kernel_image, mountpoint)
+        if self['fdt'] is not None:
+            fdt_image = self.fdt_convert(image, self['fdt'])
+            image.install(fdt_image, mountpoint)
+        uenv_txt = self['uenv_txt']
+        if uenv_txt is not None:
+            log.output('Uenv txt: %s' % (uenv_txt))
+            image.install(path.abspath(uenv_txt), mountpoint)
+        else:
+            template = None
+            if self['net_dhcp'] is not None or \
+               self['net_ip'] is not None:
+                if self['net_dhcp'] is not None:
+                    template = 'uenv_net_dhcp'
+                else:
+                    template = 'uenv_net_static'
+                if self['net_server_ip']:
+                    template += '_sip'
+                if self['net_fdt']:
+                    template += '_net_fdt'
+            else:
+                    template = 'uenv_exe'
+                elif self['fdt'] is not None:
+                    template = 'uenv'
+                    template += '_fdt'
+            if template is not None:
+                log.notice('Uenv template: %s' % (template))
+                uenv_start = self.comma_split(self['uenv_start'])
+                uenv_body = self.comma_split(self[template])
+                uenv_end = self.comma_split(self['uenv_end'])
+                uenv = uenv_start + uenv_body + uenv_end
+                image.install_text(self.filter_text(uenv),
+                                   path.join(mountpoint, self['boot_config']))
+    def kernel_convert(self, image, kernel):
+        dst = path.join(path.abspath(self['build']), path.basename(kernel))
+        self['kernel_build'] = dst
+        log.output('Copy (into build): %s -> %s' % (kernel, dst))
+        image.clean_path(dst)
+        path.copy(kernel, dst)
+        cmds = self.filter_text(self.comma_split(self['kernel_converter']))
+        for cmd in cmds:
+            _command(cmd, self['build'])
+        return self['kernel_image'].replace('@KERNEL@', dst)
+    def fdt_convert(self, image, fdt):
+        dst = path.join(path.abspath(self['build']), path.basename(fdt))
+        self['fdt_build'] = dst
+        log.output('Copy (into build): %s -> %s' % (fdt, dst))
+        path.copy(fdt, dst)
+        return self['fdt_image'].replace('@FDT@', dst)
+class image(object):
+    def __init__(self, bootloader):
+        self.loader = bootloader
+        self.detach_images = []
+        self.unmount_paths = []
+        self.remove_paths = []
+    def build(self):
+        # Cleanup if any goes wrong.
+        try:
+            # Ge the absolute paths to fixed locations.
+            output = path.abspath(self.loader['output'])
+            build = path.abspath(self.loader['build'])
+            mountpoint = path.join(build, 'mnt')
+            # Create any paths we need. They are removed when this object is
+            # deleted.
+            self.create_path(build)
+            # If only coverting a kernel no need to create an image.
+            if not self.loader.convert_kernel:
+                self.create_path(mountpoint)
+                # Create the blank image file. This is attached as a device,
+                # partitioned, formatted and the files written to it.
+                log.notice('Create image: %s size %s' % (self.loader['output'],
+                                                         self.loader['image_size']))
+                self.image_create(output, self.loader['image_size'])
+                # Attach the image so it is a device.
+                log.notice('Attach image to device: %s' % (self.loader['output']))
+                device = self.image_attach(output)
+                # Partition the image. The device may change.
+                log.notice('Partition device: %s as %s' % (device,
+                                                           self.loader['part_type']))
+                device = self.partition(output,
+                                        device,
+                                        self.loader['part_type'],
+                                        self.loader['part_label'],
+                                        self.loader['fs_format'],
+                                        self.loader['fs_size'],
+                                        self.loader['fs_alignment'])
+                part = self.device_partition(device, 1)
+                # Format the first partition.
+                log.notice('Format: %s as %s' % (part, self.loader['fs_format']))
+                self.format_partition(part, self.loader['fs_format'])
+                # Mount the file system.
+                log.notice('Mount: %s' % (part))
+                self.mount(self.loader['fs_format'], part, mountpoint)
+                # Install the first stage and second stage boot loaders.
+                self.install(self.loader['first_stage'], mountpoint)
+                self.install(self.loader['second_stage'], mountpoint)
+            # Install the bootload files.
+            self.loader.install_files(self, mountpoint)
+                # Install the bootloader configuration.
+                self.loader.install_configuration(self, mountpoint)
+                # Install any user files if present.
+                for f in self.loader.files():
+                    self.install(f, mountpoint)
+            # Done.
+            log.notice('Finished')
+        finally:
+            self.cleanup()
+    def install(self, src, dst):
+        src_base = path.basename(src)
+        log.notice('Install: %s' % (src_base))
+        asrc = path.abspath(src)
+        adst =  path.join(path.abspath(dst), src_base)
+        log.output('Copy: %s -> %s' % (asrc, adst))
+        path.copy(asrc, adst)
+    def install_text(self, text, dst):
+        dst_base = path.basename(dst)
+        log.notice('Install: %s' % (dst_base))
+        adst =  path.abspath(dst)
+        log.output('Copy: text[%d] -> %s' % (len(text), adst))
+        log.output([' ] ' + l for l in text])
+        with open(adst, "w") as o:
+            o.write(os.linesep.join(text))
+    def image_create(self, path_, size):
+        self.host_image_create(path_, size, path.exists(path_))
+    def image_attach(self, path_):
+        device = self.host_image_attach(path_)
+        self.detach_images += [device]
+        return device
+    def image_detach(self, device):
+        if device in self.detach_images:
+            self.detach_images.remove(device)
+            self.host_image_detach(device)
+    def partition(self, image_, device, ptype, plabel, pformat, psize, palign):
+        return self.host_partition(image_, device,
+                                   ptype, plabel, pformat, psize, palign)
+    def format_partition(self, device, pformat):
+        self.host_format_partition(device, pformat)
+    def device_partition(self, device, pindex):
+        return self.host_device_partition(device, pindex)
+    def mount(self, pformat, device, path_):
+        if path_ not in self.unmount_paths:
+            self.host_mount(pformat, device, path_)
+            self.unmount_paths += [path_]
+    def unmount(self, path_):
+        if path_ in self.unmount_paths:
+            self.host_unmount(path_)
+            self.unmount_paths.remove(path_)
+    def cleanup(self):
+        log.notice('Cleaning up')
+        for m in self.unmount_paths:
+            log.output('unmount: %s' % (m))
+            self.unmount(m)
+        for i in self.detach_images:
+            log.output('detach: %s' % (i))
+            self.image_detach(i)
+        if self.loader.clean:
+            for r in self.remove_paths:
+                if path.exists(r):
+                    log.output('remove: %s' % (r))
+                    path.removeall(r)
+        return ['dd']
+    def clean_path(self, name):
+        self.remove_paths += [name]
+    def create_path(self, where, recreate = True, cleanup = True):
+        if path.exists(where):
+            log.output('remove: %s' % (where))
+            path.removeall(where)
+        try:
+            log.output('make: %s' % (where))
+            path.mkdir(where)
+        except:
+            raise error.general('cannot create build path: %s' % (where))
+        if not path.isreadable(where):
+            raise error.general('build path is not readable: %s' % (where))
+        if not path.iswritable(where):
+            raise error.general('build path is not writeable: %s' % (where))
+        if cleanup:
+            self.remove_paths += [where]
+    def command(self, cmd):
+        return _command(cmd, self.loader['build'])
+    def host_image_create(self, path_, size, exists):
+        img_size, img_units = _si_size_units(size)
+        self.command('dd if=/dev/zero of=%s bs=1%s count=%d' % (path_,
+        img_units,
+        img_size))
+    def host_image_attach(self, path_):
+        raise error.general('no platform support: host_image_attach')
+    def host_image_detach(self, device):
+        raise error.general('no platform support: host_image_detach')
+    def host_partition(self, image_, device, ptype, plabel, pformat, psize, palign):
+        raise error.general('no platform support: host_partition')
+    def host_format_partition(self, device, pformat):
+        raise error.general('no platform support: host_format_partition')
+    def host_device_partition(self, device, pindex):
+        raise error.general('no platform support: host_device_partition')
+    def host_mount(self, pformat, device, path_):
+        raise error.general('no platform support: host_mount')
+    def host_unmount(self, path_):
+        raise error.general('no platform support: host_unmount')
+class freebsd_image(image):
+    def __init__(self, loader):
+        super(freebsd_image, self).__init__(loader)
+        exes = super(freebsd_image, self).get_exes()
+        return exes + ['mdconfig',
+                       'gpart',
+                       'newfs_msdos',
+                       'mount',
+                       'umount']
+        return self.command('sudo mdconfig -f %s' % (path_))
+        self.command('sudo mdconfig -d -u %s' % (device))
+        types = { 'MBR': 'MBR' }
+        formats = { 'fat16': 'fat16',
+                    'fat32': 'fat32' }
+        if ptype not in types:
+            err = 'unknown type of partitioning: %s' % (ptype)
+        if pformat not in formats:
+            raise error.general('unknown format: %s' % (pformat))
+        self.command('sudo gpart create -s %s %s' % (types[ptype], device))
+        self.command('sudo gpart add -s %s -t %s -a %s %s' % (_si_from_size(psize),
+                                                              formats[pformat],
+                                                              palign,
+                                                              device))
+        self.command('sudo gpart set -a active -i 1 %s' % (device))
+        return device
+        formats = { 'fat16': ('newfs_msdos', '16'),
+                    'fat32': ('newfs_msdos', '32') }
+        self.command('sudo %s -F %s %s' % (formats[pformat][0],
+                                           formats[pformat][1],
+                                           device))
+        return '/dev/%ss%d' % (device, pindex)
+        formats = { 'fat16': 'msdos',
+                    'fat32': 'msdos' }
+        self.command('sudo mount -t %s %s %s' % (formats[pformat],
+                                                 device,
+                                                 path_))
+        self.command('sudo umount %s' % (path_))
+class linux_image(image):
+        super(linux_image, self).__init__(loader)
+        exes = super(linux_image, self).get_exes()
+        return exes + ['losetup',
+                       'fdisk',
+                       'mkfs.fat',
+                       'mount',
+                       'umount']
+        self.command('dd if=/dev/zero of=%s bs=%s count=%d' % (path_,
+                                                               _si_units(img_units),
+                                                               img_size))
+        return self.command('sudo losetup --partscan --find --show %s' % (path_))
+        self.command('sudo losetup --detach %s' % (device))
+    def host_partition(self, image_, device, ptype, pformat, psize, palign):
+        formats = { 'fat16': '6',
+                    'fat32': 'b' }
+        # Datch the loop back device, we use fdisk on the image to avoid any
+        # kernel errors related to re-reading the updated partition data.
+        # This awkward exchange is needed to script fdisk, hmmm.
+        with tempfile.NamedTemporaryFile() as tmp:
+            s = os.linesep.join(['o',   # create a new empty part table
+                                 'n',   # add a new partition
+                                 'p',   # primary
+                                 '1',   # partition 1
+                                 '%d' % (_si_size(palign) / 512),
+                                 '%d' % (_si_size(psize) / 512),
+                                 't',   # change a partition type
+                                 '%s' % (formats[pformat]), # hex code
+                                 'a',   # toggle a bootable flag
+                                 'p',   # print
+                                 'w',   # write table to disk and exit
+            log.output('fdisk script:')
+            log.output(s)
+            tmp.write(s.encode())
+            tmp.seek(0)
+            self.command('cat %s | fdisk -t %s %s' % (tmp.name,
+                                                      types[ptype],
+                                                      image_))
+        return self.host_image_attach(image_)
+        formats = { 'fat16': ('mkfs.fat', '16'),
+                    'fat32': ('mkfs.fat', '32') }
+                                           device))
+        return '%sp%d' % (device, pindex)
+        options = { 'fat16': '-o uid=%d' % (os.getuid()),
+                    'fat32': '-o uid=%d' % (os.getuid()) }
+        if pformat in options:
+            opts = options[pformat]
+        else:
+            opts = ''
+        self.command('sudo mount %s %s %s' % (opts, device, path_))
+class darwin_image(image):
+        super(darwin_image, self).__init__(loader)
+        if not self.loader['output'].endswith('.img'):
+            log.notice('Output file does not end with `.img`. ' + \
+                       'Needed on MacOS due to a bug (Id: 51283993)')
+            raise error.general('output file does not end with `.img`')
+        exes = super(darwin_image, self).get_exes()
+        return exes + ['hdiutil',
+                       'diskutil',
+                       'fdisk']
+        output = self.command('sudo hdiutil attach %s -nomount -nobrowse' % (path_))
+        if len(output.split(os.linesep)) != 1 or not output.startswith('/dev/'):
+            raise error.general('invalid hdiutil attach outputl; see log')
+        return output.strip()
+        self.command('sudo hdiutil detach %s' % (device))
+        formats = { 'fat16': 'MS-DOS FAT16',
+                    'fat32': 'MS-DOS FAT32' }
+        # Align the parition by adding free space before. Sign.
+        cmd  = "sudo diskutil partitionDisk %s 2 %s " % (device, types[ptype])
+        cmd += "'Free Space' '%%noformat%%' %s " % (palign)
+        cmd += "'%s' %s %s" % (formats[pformat], plabel, psize)
+        self.command(cmd)
+        # MacOS mounts the filesystem once the partitioning has finished,
+        # unmount it as we have no control over the mountpoint.
+        self.command('sudo diskutil unmountDisk %s' % (device))
+        # This awkward exchange is needed to set the active bit.
+            s = os.linesep.join(['f 1', # flag toggle on partition 1
+                                 'w',   # write
+                                 'p',   # print
+                                 'q',   # quit
+            tmp.seek(0)
+            self.command('cat %s | sudo fdisk -y -e %s' % (tmp.name, device))
+        return device
+        log.output(' * No format stage; done when partitioning')
+        return '%ss%d' % (device, pindex)
+        self.command('sudo diskutil mount -mountPoint %s %s' % (path_, device))
+        self.command('sudo diskutil unmount %s' % (path_))
+builders = {
+    'freebsd': freebsd_image,
+    'linux'  : linux_image,
+    'darwin' : darwin_image
+def load_log(logfile):
+    log.default = log.log(streams = [logfile])
+def log_default():
+    return 'rtems-log-boot-image.txt'
+class valid_dir(argparse.Action):
+    def __call__(self, parser, namespace, values, option_string = None):
+        if type(values) is not list:
+            values = [values]
+        for value in values:
+            if not path.isdir(value):
+                raise argparse.ArgumentError(self,
+                                             'is not a valid directory: %s' % (value))
+            if not path.isreadable(value):
+                raise argparse.ArgumentError(self, 'is not readable: %s' % (value))
+            if not path.iswritable(value):
+                raise argparse.ArgumentError(self, 'is not writeable: %s' % (value))
+            setattr(namespace, self.dest, value)
+class valid_file(argparse.Action):
+    def __call__(self, parser, namespace, value, option_string = None):
+        current = getattr(namespace, self.dest)
+        if not isinstance(current, list) and current is not None:
+                                         ' already provided: %s, have %s' % (value,
+        current))
+        if not path.isfile(value):
+            raise argparse.ArgumentError(self, 'is not a valid file: %s' % (value))
+        if current is not None:
+            value = current + [value]
+class valid_file_if_exists(argparse.Action):
+        current))
+        if path.exists(value):
+class valid_paths(argparse.Action):
+        if current is None:
+            current = []
+        if isinstance(value, list):
+            values = value
+        else:
+            values = [values]
+            if not path.isfile(value) and not path.isdir(value):
+                err = 'is not a valid file or directory: %s' % (value)
+                raise argparse.ArgumentError(self, err)
+            current += [value]
+        setattr(namespace, self.dest, current)
+class valid_format(argparse.Action):
+        current))
+        if value not in ['fat16', 'fat32']:
+            raise argparse.ArgumentError(self, ' invalid format: %s' % (value))
+class valid_si(argparse.Action):
+        units = len(value)
+        if value[-1].isalpha():
+            if value[-1] not in ['k', 'm', 'g']:
+                                             'invalid SI (k, m, g): %s' % (value[-1]))
+            units = -1
+        if not value[:units].isdigit():
+            raise argparse.ArgumentError(self, 'invalid SI size: %s' % (value))
+class valid_ip(argparse.Action):
+        current))
+def run(args = sys.argv, command_path = None):
+    ec = 0
+    notice = None
+    builder = None
+    try:
+        description  = 'Provide one path to a u-boot build or provide two '
+        description += 'paths to the built the first and second stage loaders, '
+        description += 'for example a first stage loader is \'MLO\' and a second '
+        description += '\'u-boot.img\'. If converting a kernel only provide the '
+        description += 'executable\'s path.'
+        argsp = argparse.ArgumentParser(prog = 'rtems-boot-image',
+                                        description = description)
+        argsp.add_argument('-l', '--log',
+                           help = 'log file (default: %(default)s).',
+                           type = str, default = log_default())
+        argsp.add_argument('-v', '--trace',
+                           help = 'enable trace logging for debugging.',
+                           action = 'store_true')
+        argsp.add_argument('-s', '--image-size',
+                           help = 'image size in mega-bytes (default: %(default)s).',
+                           type = str, action = valid_si, default = '64m')
+        argsp.add_argument('-F', '--fs-format',
+                           help = 'root file system format (default: %(default)s).',
+                           type = str, action = valid_format, default = 'fat16')
+        argsp.add_argument('-S', '--fs-size',
+                           help = 'root file system size in SI units ' + \
+                                  '(default: %(default)s).',
+                           type = str, action = valid_si, default = 'auto')
+        argsp.add_argument('-A', '--fs-align',
+                           help = 'root file system alignment in SI units ' + \
+                           type = str, action = valid_si, default = '1m')
+        argsp.add_argument('-k', '--kernel',
+                           help = 'install the kernel (default: %(default)r).',
+                           type = str, action = valid_file, default = None)
+        argsp.add_argument('-d', '--fdt',
+                           help = 'Flat device tree source/blob (default: %(default)r).',
+        argsp.add_argument('-f', '--file',
+                           help = 'install the file (default: None).',
+                           type = str, action = valid_file, default = [])
+        argsp.add_argument('--net-boot',
+                           help = 'configure a network boot using TFTP ' + \
+                                  '(default: %(default)r).',
+        argsp.add_argument('--net-boot-dhcp',
+                           help = 'network boot using dhcp (default: %(default)r).',
+                           action = 'store_true', default = False)
+        argsp.add_argument('--net-boot-ip',
+                           help = 'network boot IP address (default: %(default)r).',
+                           type = str, action = valid_ip, default = None)
+        argsp.add_argument('--net-boot-server',
+                           help = 'network boot server IP address ' + \
+        argsp.add_argument('--net-boot-file',
+                           help = 'network boot file (default: %(default)r).',
+                           type = str, default = 'rtems.img')
+        argsp.add_argument('--net-boot-fdt',
+                           help = 'network boot load a fdt file (default: %(default)r).',
+                           type = str, default = None)
+        argsp.add_argument('-U', '--custom-uenv',
+                           help = 'install the custom uEnv.txt file ' + \
+        argsp.add_argument('-b', '--board',
+                           help = 'name of the board (default: %(default)r).',
+                           type = str, default = 'list')
+        argsp.add_argument('--convert-kernel',
+                           help = 'convert a kernel to a bootoader image ' + \
+        argsp.add_argument('--no-clean',
+                           help = 'do not clean when finished (default: %(default)r).',
+                           action = 'store_false', default = True)
+        argsp.add_argument('-o', '--output',
+                           help = 'image output file name',
+                           type = str, action = valid_file_if_exists, required = True)
+        argsp.add_argument('paths',
+                           help = 'files or paths, the number and type sets the mode.',
+                           nargs = '+', action = valid_paths)
+        argopts = argsp.parse_args(args[1:])
+        load_log(argopts.log)
+        log.notice('RTEMS Tools - Boot Image, %s' % (version.string()))
+        log.output(log.info(args))
+        log.tracing = argopts.trace
+        if argopts.net_boot_dhcp is not None or \
+           argopts.net_boot_ip is not None:
+            if argopts.convert_kernel:
+                raise error.general('net boot options not valid with kernel convert.')
+            if argopts.custom_uenv is not None:
+                raise error.general('cannot set custom uenv and net boot options.')
+        host.load()
+        log.output('Platform: %s' % (host.name))
+        if argopts.board == 'list':
+            loader = bootloader(command_path)
+            boards = loader.list_boards()
+            log.notice(' Board list: bootloaders (%d)' % (len(boards)))
+            for bl in sorted(boards):
+                log.notice('  %s: %d' % (bl, len(boards[bl])))
+                for b in boards[bl]:
+                    log.notice('   ' + b)
+            raise error.exit()
+        loader = uboot_bootloader(command_path,
+                                  argopts.convert_kernel,
+                                  argopts.paths,
+                                  argopts.board)
+        loader.check_mandatory_configs()
+        if loader.convert_kernel:
+            if argopts.kernel is not None:
+                raise error.general('kernel convert does not use the kernel option.')
+            if len(argopts.paths) != 1:
+                raise error.general('kernel convert take a single path.')
+            argopts.kernel = argopts.paths[0]
+        else:
+            loader.clean = argopts.no_clean
+        loader['board'] = argopts.board
+        loader['output'] = argopts.output
+        loader['build'] = 'build'  # need an option for this at some point
+        loader['image_size'] = argopts.image_size
+        loader['fs_format'] = argopts.fs_format
+        loader['fs_size'] = argopts.fs_size
+        loader['fs_align'] = argopts.fs_align
+        loader['kernel'] = argopts.kernel
+        loader['fdt'] = argopts.fdt
+        loader['files'] = ','.join(argopts.file)
+        loader['net_dhcp'] = argopts.net_boot_dhcp
+        loader['net_ip'] = argopts.net_boot_ip
+        loader['net_server_ip'] = argopts.net_boot_server
+        loader['net_exe'] = argopts.net_boot_file
+        loader['net_fdt'] = argopts.net_boot_fdt
+        loader['uenv_txt'] = argopts.custom_uenv
+        loader.log()
+        if not loader.convert_kernel:
+            if loader['fs_size'] == 'auto':
+                loader['fs_size'] = \
+                    str(_si_size(loader['image_size']) - _si_size(loader['fs_align']))
+            elif _si_size(loader['image_size']) < \
+                 _si_size(loader['fs_align']) + _si_size(loader['fs_size']):
+                raise error.general('filesystem partition size larger than image size.')
+        if host.name not in builders:
+            err = 'no builder; platform not supported: %s' % (host.name)
+        builder = builders[host.name](loader)
+        if not loader.check_exes() or not builder.check_exes():
+            raise error.general('command(s) not found; please fix.')
+        builder.build()
+    except error.general as gerr:
+        notice = str(gerr)
+        ec = 1
+    except error.internal as ierr:
+        notice = str(ierr)
+        ec = 1
+    except error.exit as eerr:
+        pass
+    except KeyboardInterrupt:
+        notice = 'abort: user terminated'
+        ec = 1
+    except:
+        raise
+        notice = 'abort: unknown error'
+        ec = 1
+    if builder is not None:
+        del builder
+    if notice is not None:
+        log.stderr(notice)
+    sys.exit(ec)
+if __name__ == "__main__":
+    run()
diff --git a/misc/tools/cmd-boot-image.py b/misc/tools/cmd-boot-image.py
index 0000000..f17a91e
--- /dev/null
+++ b/misc/tools/cmd-boot-image.py
@@ -0,0 +1,44 @@
+import sys, os
+base = os.path.dirname(os.path.dirname(os.path.abspath(sys.argv[0])))
+rtems = os.path.dirname(base)
+sys.path = [rtems] + sys.path
+try:
+    import boot
+    boot.run(sys.argv[1:], command_path = base)
+except ImportError:
+    print("Incorrect RTEMS Tools installation", file = sys.stderr)
+    sys.exit(1)
diff --git a/misc/tools/config/rtems-boot.ini b/misc/tools/config/rtems-boot.ini
index 0000000..6370e35
--- /dev/null
+++ b/misc/tools/config/rtems-boot.ini
@@ -0,0 +1,158 @@
+; Bootloader Parameters
+[default]
+image_size = 64m
+part_type = MBR
+part_label = RTEMS
+fs_format = fat16
+fs_size = 63m
+fs_alignment = 1m
+tool_prefix = %{arch}-rtems%{version}-
+objcopy = %{tool_prefix}objcopy
+bootloaders = u-boot
+[u-boot]
+boards = u-boot-beaglebone,
+         u-boot-zedboard
+bootdelay = 5
+mkimage = %{ubootdir}/tools/mkimage
+executables = cat, gzip, %{mkimage}, %{objcopy}
+fdt_compiler = ftc
+boot_config = uEnv.txt
+[u-boot-beaglebone]
+uses = u-boot-arm-ti-am335x_evm
+[u-boot-zedboard]
+uses = u-boot-arm-xilinx-zynq-common
+[u-boot-arm-ti-am335x_evm]
+arch = arm
+vendor = ti
+board = am335x
+config_name = am335x_evm
+first_stage = %{ubootdir}/MLO
+boot_device = mmc 0
+second_stage = %{ubootdir}/u-boot.img
+start_address = 0x80000000
+entry_address = 0x80000000
+kernel_loadaddr = 0x82000000
+fdt_loadaddr = 0x88000000
+kernel_converter = %{objcopy} @KERNEL@ -O binary @KERNEL at .bin,
+                   cat @KERNEL at .bin | gzip -9 > @KERNEL at .gz,
+                   %{mkimage} -A arm -O Linux -T kernel -a %{start_address}
+                    -e %{entry_address} -n "RTEMS" -d @KERNEL at .gz @KERNEL at .img
+kernel_image = @KERNEL at .img
+fdt_image = @FDT@
+[u-boot-arm-xilinx-zynq-common]
+arch = arm
+vendor = xilinx
+board = zynq
+config_name = zynq-common
+first_stage = %{ubootdior}/spl/boot.bin
+second_state = %{ubootdir}/u-boot.img
+kernel_loadaddr = 0x02000000
+fdt_loadaddr = 0x08000000
+kernel_converter = %{objcopy} -R -S --strip-debug -O binary @KERNEL@ @KERNEL at .bin,
+                   cat @KERNEL at .bin | gzip -9 @KERNEL at .gz
+[u-boot-templates]
+uenv_start = setenv bootdelay %{bootdelay},
+             uenvcmd=run boot_rtems; reset;,
+             rtems_banner=echo "";
+             echo "RTEMS %{board} (%{arch}-%{vendor}-%{config_name})";
+             echo " rtems-boot-image v%{version_str}";
+             echo "";
+uenv_boot_exe = bootm %{kernel_loadaddr};
+uenv_boot_exe_fdt = bootm %{kernel_loadaddr} - %{fdt_loadaddr}
+uenv_exe_load = load %{boot_device} %{kernel_loadaddr} @KERNEL_IMAGE@
+uenv_fdt_load = echo "Loading @FDT_IMAGE@";
+                load %{boot_device} %{fdt_loadaddr} @FDT_IMAGE@
+uenv_tftp_exe = tftpboot %{kernel_loadaddr} @NET_BOOTEXE@
+uenv_tftp_fdt = tftpboot %{fdt_loadaddr} @NET_BOOTFDT@
+uenv_tftp_server = echo " Server: @NET_SERVER_IP@";
+                   set serverip @NET_SERVER_IP@
+uenv_dhcp = echo "Netboot: DHCP";
+            set autoload no;
+            dhcp;
+uenv_static_ip = echo "Netboot: STATIC";
+                 echo " IP: @NET_IP@";
+                 set autoload no;
+                 set ipaddr @NET_IP@;
+uenv_fdt = boot_rtems=run rtems_banner;
+           ${uenv_fdt_load}
+uenv_exe = boot_rtems=run rtems_banner;
+           echo "Loading @KERNEL_IMAGE@";
+           ${uenv_exe_load};
+           ${uenv_boot_exe}
+uenv_exe_fdt = boot_rtems=run rtems_banner;
+               ${uenv_fdt_load};
+               ${uenv_fdt_load};
+               ${uenv_boot_exe_fdt}
+uenv_net_dhcp = boot_rtems=run rtems_banner;
+                ${uenv_dhcp};
+                ${uenv_tftp_exe};
+                ${uenv_boot_exe}
+uenv_net_dhcp_fdt = boot_rtems=run rtems_banner;
+                    ${uenv_fdt_load};
+                    ${uenv_dhcp};
+                    ${uenv_tftp_exe};
+uenv_net_dhcp_net_fdt = boot_rtems=run rtems_banner;
+                        ${uenv_dhcp};
+                        ${uenv_tftp_exe};
+                        ${uenv_tftp_fdt};
+uenv_net_dhcp_sip = boot_rtems=run rtems_banner;
+                    ${uenv_tftp_server};
+                    ${uenv_dhcp};
+                    ${uenv_tftp_exe};
+                    ${uenv_boot_exe}
+uenv_net_dhcp_sip_fdt = boot_rtems=run rtems_banner;
+                        ${uenv_fdt_load};
+                        ${uenv_dhcp};
+                        ${uenv_tftp_exe};
+uenv_net_dhcp_sip_net_fdt = boot_rtems=run rtems_banner;
+                            ${uenv_dhcp};
+                            ${uenv_tftp_exe};
+                            ${uenv_tftp_fdt};
+uenv_net_static = boot_rtems=run rtems_banner;
+                  ${uenv_static_ip};
+                  ${uenv_tftp_exe};
+                  ${uenv_boot_exe}
+uenv_net_static_fdt = boot_rtems=run rtems_banner;
+                      ${uenv_fdt_load};
+                      ${uenv_tftp_exe};
+uenv_net_static_net_fdt = boot_rtems=run rtems_banner;
+                          ${uenv_tftp_exe};
+                          ${uenv_tftp_fdt};
+uenv_net_static_sip = boot_rtems=run rtems_banner;
+                      ${uenv_tftp_exe};
+                      ${uenv_boot_exe}
+uenv_net_static_sip_fdt = boot_rtems=run rtems_banner;
+                          ${uenv_fdt_load};
+                          ${uenv_tftp_exe};
+uenv_net_static_sip_net_fdt = boot_rtems=run rtems_banner;
+                              ${uenv_tftp_exe};
+                              ${uenv_tftp_fdt};
diff --git a/misc/wscript b/misc/wscript
index cd31091..f83c74b 100644
--- a/misc/wscript
+++ b/misc/wscript
@@ -70,5 +70,19 @@ def build(bld):
                 cflags = conf['cflags'] + conf['warningflags'],
                 linkflags = conf['linkflags'])
+    # Install the boot image code.
+    bld(features = 'py',
+        source = ['tools/boot.py',
+                  'tools/cmd-boot-image.py'],
+        install_from = '.',
+        install_path = '${PREFIX}/share/rtems/misc')
+    bld.install_files('${PREFIX}/bin',
+                      ['rtems-boot-image'],
+                      chmod = 0o755)
+    bld.install_files('${PREFIX}/share/rtems/tools/config',
+                      'tools/config/rtems-boot.ini')
 def tags(ctx):
     ctx.exec_command('etags $(find . -name \*.[sSch])', shell = True)
2.19.1
