[PATCH] user: Add the boot image tool command.
chrisj at rtems.org
chrisj at rtems.org
Wed Jun 12 04:20:06 UTC 2019
user/tools/boot-image.rst | 445 ++++++++++++++++++++++++++++++++++++++
user/tools/index.rst | 1 +
2 files changed, 446 insertions(+)
create mode 100644 user/tools/boot-image.rst
diff --git a/user/tools/boot-image.rst b/user/tools/boot-image.rst
new file mode 100644
index 0000000..6e76a2d
--- /dev/null
+++ b/user/tools/boot-image.rst
@@ -0,0 +1,445 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2019 Chris Johns <chrisj at rtems.org>
+.. _RTEMSExecutableInfomation:
+RTEMS Boot Image
+.. index:: Tools, rtems-boot-image
+The RTEMS Boot Image (:program:`rtems-boot-image`) command is an RTEMS
+tool to create disk images suitable for SD cards to boot RTEMS on a
+range of boards. The supported hosts are:
+- FreeBSD
+- Linux
+- MacOS
+The tool captures the specific details for a host operating system to
+create a bootable disk image as well as capturing the specific detail
+of the boards that are supported. The tool brings these detail
+together under a sigle command line interface that is portable across
+the supported hosts.
+The boot image tool can:
+- Create a disk image to boot an RTEMS executable
+- Create a disk image to network boot an RTEMS executable
+- Convert an RTEMS executable into the format a board's bootloader
+ can load.
+The disk images are suitable for booting a range of hardware that have
+media interfaces, such as an SD card. The default partition type is
+the Master Boot Record (MRB) and a single root DOS-FS partition is
+created.
+Boot Loaders
+The boot image tool supports the following boot loaders:
+- U-boot
+U-Boot
+The U-Boot boards supported are:
+- BeagleBone (`arm-ti-am335x_evm`)
+- Zedboard (`arm-xilinx-zynq-common`)
+These boards can be booted with executable and Flat Device Tree (FDT)
+blobs on disk or view a network if supported by the boards.
+The boot image tool can create the following boot configurations for
+U-Boot:
+- **Executable**
+ A kernel executable is copied in the disk image, loaded by U-Boot
+ and control is passed to the kernel. A reset is performed if the
+ load fails or the kernel returns control to U-Boot.
+- **Executable and FDT**
+ A kernel executable and FDT blob are copied to the disk image,
+ loaded by U-boot and control is passed to the kernel. A reset is
+ performed if the load fails or the kernel returns control to U-Boot.
+- **Network DHCP and Executable**
+ The board's network interface is initialised, a DHCP request made
+ and a kernel image loaded using TFTP. The loaded kernel is passed
+ control. A reset is performed if the load fails or the kernel
+ returns control to U-Boot.
+- **Network DHCP, Executable and FDT**
+ The FDT can be installed in and disk image and loaded from it on
+ each boot.
+- **Network Static IP and Executable**
+ The board's network interface is initialised with a static IP
+ address and a kernel image loaded using TFTP. The loaded kernel is
+ passed control. A reset is performed if the load fails or the kernel
+- **Network Static IP, Executable and FDT**
+ each boot.
+Hosts
+The hosts each require specific set up to run the boot image
+buildier. The tool creates special devices to access the image as a
+disk and runs file system partitioning and formatting tools. These
+tools typically require super user or root access. It is not good
+practice to run commands like this one as root and so the tool
+dispatches any specific command that needs higher privileges via
+``sudo``. If you see a password prompt please enter your password, not
+a root password if you have one confgiured.
+FreeBSD
+Install the ``sudo`` package. All commands used are in standard
+operating system paths and should not require any specific
+configurations.
+Linux
+The loop back kernel module needs to be loaded.
+MacOS
+All command used are part of the base OS. No external packages are
+required.
+Configuration
+The boot image tool is configured by the file :file:`rtems-boot.ini`
+that is installed in the
+Command
+The :program:`rtems-boot-image` tool creates a boot disk image for a
+specified board. The command line options are:
+:program:`rtems-boot-image`
+.. option:: -h, --help
+ Display the command line help.
+.. option:: -l, --log
+ Set the log file name. The default is
+ :file:`rtems-log-boot-image.txt`.
+.. option:: -v, --trace
+ Enable trace or debug logging.
+.. option:: -s IMAGE_SIZE, --image-size IMAGE_SIZE
+ Set the image size. The size can be in SI units of ``k``, ``m``, or
+ ``g``. The size needs to be something the host's parition and
+ format tools will accept and it must be large enough to fit the
+ root partition plus any alignments. The default is ``64m``.
+.. option:: -F FS_FORMAT, --fs-format FS_FORMAT
+ Specify type type of format. The supported formats are ``fat16``
+ and ``fat32``. The default format is ``fat16``.
+.. option:: -S FS_SIZE, --fs-size FS_SIZE
+ Set the size of the first partition in the disk image. The
+ partition need to be less than the size of the image plus the
+ alignment. The default size is ``auto`` which will fill the image
+ with the partition.
+.. option:: -A FS_ALIGN, --fs-align FS_ALIGN
+ Set the alignment of the first partition. The default is ``1m``.
+.. option:: -k KERNEL, --kernel KERNEL
+ Optionally provide a kernel image that is copied into the root
+ partition of the disk image and loaded and run when the board
+ boots. The file is an RTEMS executable in the ELF format which is
+ converted to a format the boot loader can load.
+.. option:: -d FDT, --fdt FDT
+ Optionally provide a FDT blob that is copied into the root
+ partition of the disk image and loaded when the board boots. If a
+ kernel is provided or a kernel is loaded via a net boot a kernel
+ boot with FDT is executabled. The file is an FDT blob created by
+ the FDT compiler.
+.. option:: -f FILE, --file FILE
+ Optionally provide a file to be copied to the root partition of the
+ disk image. This option can be provided more than once if more than
+ one file needs to be installed.
+.. option:: --net-boot
+ Not used and will be removed.
+.. option:: --net-boot-dhcp
+ Configure a network boot using DHCP. The kernel will be loaded
+ using TFTP and the file request can be specific by the
+ ``--net-boot-file`` option.
+.. option:: --net-boot-ip NET_BOOT_IP
+ Configure a network boot using a static IP address. The kernel will
+ be loaded using TFTP and the file request can be specific by the
+ ``--net-boot-file`` option. A server IP needs to be specified using
+ the ``--net-boot-server``.
+.. option:: --net-boot-file NET_BOOT_FILE
+ Specify the kernel image file name requested using the TFTP
+ protocol. The default is :file:`rtems.img`.
+.. option:: --net-boot-fdt NET_BOOT_FDT
+ Optionally specify the file name of a FDT blob loaded using the
+ TFTP protocol. If a net boot FDT file is provide the kernel will be
+ executable with a suitable kernel and FDT boot command.
+.. option:: -U CUSTOM_UENV, --custom-uenv CUSTOM_UENV
+ Optionally provide a custom U-boot :file:`uEnv.txt` file that is
+ copied to into the root directory of the root partition of the disk
+ image.
+.. option:: -b BOARD, --board BOARD
+ Specify the board the disk image is built for. The default board is
+ ``list`` which lists the available board configurations.
+.. option:: --convert-kernel
+ Convert an RTEMS ELF executable into an image file the selected
+ board's bootloader can load. This option does not create a disk
+ image. The option can be used to create images that can be loaded
+ when network booting.
+.. option:: --no-clean
+ If provided the :file:`build` directory will not be removed after
+ the disk image has been created.
+.. option:: -o OUTPUT, --output OUTPUT
+ The output file name for the image. If the ``--convert-kernel``
+ option is used the conversion is written as this file name and if
+ it is not provided the output file is the built disk image.
+.. option:: paths [paths ...]
+ The required paths depend on the mix of other options.
+ If the ``--convert-kernel`` option is provided a single path to an
+ RTEMS executable file is required. If this option is not provided
+ the number of paths provided determine how they are processed.
+ If a single path a built U-boot directory is provided the board
+ configuration will automatically find and pick up the first and
+ second stage boot loader executables.
+ If two paths are provided they are paths to the first and second
+ stage boot loader executables. This can be used with loader images
+ they you have not built.
+Examples
+The examples show the output for FreeBSD. It may vary depending on
+your type of host, how it is configured and what is running.
+If the board option is not provided a list of boards is displayed:
+.. code-block:: none
+ $ rtems-boot-image -o sd-card.img u-boot
+ RTEMS Tools - Boot Image, 5.0.not_released
+ Board list: bootloaders (1)
+ u-boot: 2
+ u-boot-beaglebone
+ u-boot-zedboard
+Create a disk image from a built U-Boot sandbox:
+ $ rtems-boot-image -o sd-card.img -b u-boot-beaglebone u-boot
+ Create image: sd-card.img size 64m
+ Attach image to device: sd-card.img
+ Password:
+ Partition device: md0 as MBR
+ Format: /dev/md0s1 as fat16
+ Mount: /dev/md0s1
+ Install: MLO
+ Install: u-boot.img
+ Finished
+ Cleaning up
+Create a 32M byte SD card image with the testsuite's hello world
+executable (``hello.exe``):
+ $ rtems-boot-image -o sd-card.img -b u-boot-beaglebone -s 32m -k hello.exe u-boot
+ Create image: sd-card.img size 32m
+ Password:
+ Mount: /dev/md0s1
+ Install: MLO
+ Install: hello.exe.img
+ Uenv template: uenv_exe
+ Install: uEnv.txt
+ Finished
+ Cleaning up
+Build the same image using the first and second stage boot loaders:
+ $ rtems-boot-image -o sd-card.img -b u-boot-beaglebone -s 32m -k hello.exe MLO u-boot.img
+ Password:
+ Mount: /dev/md0s1
+ Install: MLO
+ Install: uEnv.txt
+ Finished
+ Cleaning up
+Install and load the TI standard FDT for the Beaglebone Black board
+with the LibBSD DHCP 01 test application:
+ $ rtems-boot-image -o sd-card.img -b u-boot-beaglebone -s 32m \
+ -k dhcpcd01.exe -d am335x-boneblack.dtb MLO u-boot.img
+ Password:
+ Mount: /dev/md0s1
+ Install: MLO
+ Install: dhcpcd01.exe.img
+ Install: am335x-boneblack.dtb
+ Uenv template: uenv_exe_fdt
+ Install: uEnv.txt
+ Finished
+ Cleaning up
+Create a DHCP network boot image where the TFTP client requests ``rtems.img``:
+ --net-boot-dhcp MLO u-boot.img
+ Password:
+ Mount: /dev/md0s1
+ Install: MLO
+ Uenv template: uenv_net_dhcp
+ Install: uEnv.txt
+ Finished
+ Cleaning up
+Select a specific kernel image to load using TFTP and load a FDT blob
+from the SD card:
+ --net-boot-dhcp --net-boot-file bbb1a.img \
+ -d am335x-boneblack.dtb MLO u-boot.img
+ Password:
+ Mount: /dev/md0s1
+ Install: MLO
+ Install: uEnv.txt
+ Finished
+ Cleaning up
+Create an image where a specific kernel image and FDT blob is loaded
+using the TFTP protocol:
+ --net-boot-fdt bbb/am335x-boneblack.dtb MLO u-boot.img
+ Password:
+ Mount: /dev/md0s1
+ Install: MLO
+ Uenv template: uenv_net_dhcp_net_fdt
+ Install: uEnv.txt
+ Finished
+ Cleaning up
diff --git a/user/tools/index.rst b/user/tools/index.rst
index 98cebc4..2ee619b 100644
--- a/user/tools/index.rst
+++ b/user/tools/index.rst
@@ -22,3 +22,4 @@ developers.
exeinfo
bsp-builder
tester
+ boot-image
2.19.1
