[PATCH v3 1/5] iicbus: Import from FreeBSD
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Wed Jun 12 12:34:46 UTC 2019
 freebsd/sys/dev/iicbus/iic.c        | 506 ++++++++++++++++++++++++++
 freebsd/sys/dev/iicbus/iic.h        |  72 ++++
 freebsd/sys/dev/iicbus/iicbus.c     | 378 ++++++++++++++++++++
 freebsd/sys/dev/iicbus/iicbus.h     |  83 +++++
 freebsd/sys/dev/iicbus/iiconf.c     | 527 ++++++++++++++++++++++++++++
 freebsd/sys/dev/iicbus/iiconf.h     | 162 +++++++++
 freebsd/sys/dev/iicbus/ofw_iicbus.c | 242 +++++++++++++
 7 files changed, 1970 insertions(+)
 create mode 100644 freebsd/sys/dev/iicbus/iic.c
 create mode 100644 freebsd/sys/dev/iicbus/iic.h
 create mode 100644 freebsd/sys/dev/iicbus/iicbus.c
 create mode 100644 freebsd/sys/dev/iicbus/iicbus.h
 create mode 100644 freebsd/sys/dev/iicbus/iiconf.c
 create mode 100644 freebsd/sys/dev/iicbus/iiconf.h
 create mode 100644 freebsd/sys/dev/iicbus/ofw_iicbus.c
diff --git a/freebsd/sys/dev/iicbus/iic.c b/freebsd/sys/dev/iicbus/iic.c
new file mode 100644
index 00000000..dc9c06f9
--- /dev/null
+++ b/freebsd/sys/dev/iicbus/iic.c
@@ -0,0 +1,506 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 1998, 2001 Nicolas Souchu
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#include <sys/param.h>
+#include <sys/bus.h>
+#include <sys/conf.h>
+#include <sys/fcntl.h>
+#include <sys/lock.h>
+#include <sys/kernel.h>
+#include <sys/malloc.h>
+#include <sys/module.h>
+#include <sys/sx.h>
+#include <sys/systm.h>
+#include <sys/uio.h>
+#include <sys/errno.h>
+#include <dev/iicbus/iiconf.h>
+#include <dev/iicbus/iicbus.h>
+#include <dev/iicbus/iic.h>
+#include <rtems/bsd/local/iicbus_if.h>
+struct iic_softc {
+	device_t sc_dev;
+	struct cdev *sc_devnode;
+struct iic_cdevpriv {
+	struct sx lock;
+	struct iic_softc *sc;
+	bool started;
+	uint8_t addr;
+#define	IIC_LOCK(cdp)			sx_xlock(&(cdp)->lock)
+#define	IIC_UNLOCK(cdp)			sx_xunlock(&(cdp)->lock)
+static MALLOC_DEFINE(M_IIC, "iic", "I2C device data");
+static int iic_probe(device_t);
+static int iic_attach(device_t);
+static int iic_detach(device_t);
+static void iic_identify(driver_t *driver, device_t parent);
+static void iicdtor(void *data);
+static int iicuio_move(struct iic_cdevpriv *priv, struct uio *uio, int last);
+static int iicuio(struct cdev *dev, struct uio *uio, int ioflag);
+static int iicrdwr(struct iic_cdevpriv *priv, struct iic_rdwr_data *d, int flags);
+static devclass_t iic_devclass;
+static device_method_t iic_methods[] = {
+	/* device interface */
+	DEVMETHOD(device_identify,	iic_identify),
+	DEVMETHOD(device_probe,		iic_probe),
+	DEVMETHOD(device_attach,	iic_attach),
+	DEVMETHOD(device_detach,	iic_detach),
+	/* iicbus interface */
+	DEVMETHOD(iicbus_intr,		iicbus_generic_intr),
+	{ 0, 0 }
+static driver_t iic_driver = {
+	"iic",
+	iic_methods,
+	sizeof(struct iic_softc),
+static	d_open_t	iicopen;
+static	d_ioctl_t	iicioctl;
+static struct cdevsw iic_cdevsw = {
+	.d_version =	D_VERSION,
+	.d_open =	iicopen,
+	.d_read =	iicuio,
+	.d_write =	iicuio,
+	.d_ioctl =	iicioctl,
+	.d_name =	"iic",
+static void
+iic_identify(driver_t *driver, device_t parent)
+	if (device_find_child(parent, "iic", -1) == NULL)
+		BUS_ADD_CHILD(parent, 0, "iic", -1);
+static int
+iic_probe(device_t dev)
+	if (iicbus_get_addr(dev) > 0)
+		return (ENXIO);
+	device_set_desc(dev, "I2C generic I/O");
+	return (0);
+static int
+iic_attach(device_t dev)
+	sc = device_get_softc(dev);
+	sc->sc_dev = dev;
+	sc->sc_devnode = make_dev(&iic_cdevsw, device_get_unit(dev),
+			UID_ROOT, GID_WHEEL,
+			0600, "iic%d", device_get_unit(dev));
+	if (sc->sc_devnode == NULL) {
+		device_printf(dev, "failed to create character device\n");
+		return (ENXIO);
+	sc->sc_devnode->si_drv1 = sc;
+	return (0);
+static int
+iic_detach(device_t dev)
+	if (sc->sc_devnode)
+		destroy_dev(sc->sc_devnode);
+	return (0);
+static int
+iicopen(struct cdev *dev, int flags, int fmt, struct thread *td)
+	struct iic_cdevpriv *priv;
+	int error;
+	priv = malloc(sizeof(*priv), M_IIC, M_WAITOK | M_ZERO);
+	sx_init(&priv->lock, "iic");
+	priv->sc = dev->si_drv1;
+	error = devfs_set_cdevpriv(priv, iicdtor);
+	if (error != 0)
+		free(priv, M_IIC);
+	return (error);
+static void
+iicdtor(void *data)
+	device_t iicdev, parent;
+	priv = data;
+	KASSERT(priv != NULL, ("iic cdevpriv should not be NULL!"));
+	iicdev = priv->sc->sc_dev;
+	parent = device_get_parent(iicdev);
+	if (priv->started) {
+		iicbus_stop(parent);
+		iicbus_reset(parent, IIC_UNKNOWN, 0, NULL);
+		iicbus_release_bus(parent, iicdev);
+	sx_destroy(&priv->lock);
+static int
+iicuio_move(struct iic_cdevpriv *priv, struct uio *uio, int last)
+	device_t parent;
+	int error, num_bytes, transferred_bytes, written_bytes;
+	char buffer[128];
+	parent = device_get_parent(priv->sc->sc_dev);
+	error = 0;
+	 * We can only transfer up to sizeof(buffer) bytes in 1 shot, so loop until
+	 * everything has been transferred.
+	while ((error == 0) && (uio->uio_resid > 0)) {
+		num_bytes = MIN(uio->uio_resid, sizeof(buffer));
+		transferred_bytes = 0;
+		if (uio->uio_rw == UIO_WRITE) {
+			error = uiomove(buffer, num_bytes, uio);
+			while ((error == 0) && (transferred_bytes < num_bytes)) {
+				written_bytes = 0;
+				error = iicbus_write(parent, &buffer[transferred_bytes],
+				    num_bytes - transferred_bytes, &written_bytes, 0);
+				transferred_bytes += written_bytes;
+		} else if (uio->uio_rw == UIO_READ) {
+			error = iicbus_read(parent, buffer,
+			    num_bytes, &transferred_bytes,
+			    ((uio->uio_resid <= sizeof(buffer)) ? last : 0), 0);
+			if (error == 0)
+				error = uiomove(buffer, transferred_bytes, uio);
+	return (error);
+static int
+iicuio(struct cdev *dev, struct uio *uio, int ioflag)
+	device_t parent;
+	int error;
+	uint8_t addr;
+	priv = NULL;
+	error = devfs_get_cdevpriv((void**)&priv);
+	if (error != 0)
+		return (error);
+	IIC_LOCK(priv);
+	if (priv->started || (priv->addr == 0)) {
+		IIC_UNLOCK(priv);
+		return (ENXIO);
+	error = iicbus_request_bus(parent, priv->sc->sc_dev,
+	    (ioflag & O_NONBLOCK) ? IIC_DONTWAIT : (IIC_WAIT | IIC_INTR));
+	if (error != 0) {
+		IIC_UNLOCK(priv);
+		return (error);
+	if (uio->uio_rw == UIO_READ)
+		addr = priv->addr | LSB;
+	else
+		addr = priv->addr & ~LSB;
+	error = iicbus_start(parent, addr, 0);
+	if (error != 0)
+		iicbus_release_bus(parent, priv->sc->sc_dev);
+		IIC_UNLOCK(priv);
+		return (error);
+	error = iicuio_move(priv, uio, IIC_LAST_READ);
+	IIC_UNLOCK(priv);
+	return (error);
+static int
+iicrdwr(struct iic_cdevpriv *priv, struct iic_rdwr_data *d, int flags)
+	struct iic_msg *buf, *m;
+	void **usrbufs;
+	int error;
+	uint32_t i;
+	error = 0;
+	if (d->nmsgs > IIC_RDRW_MAX_MSGS)
+		return (EINVAL);
+	buf = malloc(sizeof(*d->msgs) * d->nmsgs, M_IIC, M_WAITOK);
+	error = copyin(d->msgs, buf, sizeof(*d->msgs) * d->nmsgs);
+	if (error != 0) {
+		free(buf, M_IIC);
+		return (error);
+	/* Alloc kernel buffers for userland data, copyin write data */
+	usrbufs = malloc(sizeof(void *) * d->nmsgs, M_IIC, M_WAITOK | M_ZERO);
+	for (i = 0; i < d->nmsgs; i++) {
+		m = &(buf[i]);
+		usrbufs[i] = m->buf;
+		 * At least init the buffer to NULL so we can safely free() it later.
+		 * If the copyin() to buf failed, don't try to malloc bogus m->len.
+		m->buf = NULL;
+		if (error != 0)
+			continue;
+		/* m->len is uint16_t, so allocation size is capped at 64K. */
+		m->buf = malloc(m->len, M_IIC, M_WAITOK);
+		if (!(m->flags & IIC_M_RD))
+			error = copyin(usrbufs[i], m->buf, m->len);
+	if (error == 0)
+		error = iicbus_request_bus(parent, iicdev,
+		    (flags & O_NONBLOCK) ? IIC_DONTWAIT : (IIC_WAIT | IIC_INTR));
+	if (error == 0) {
+		error = iicbus_transfer(iicdev, buf, d->nmsgs);
+	/* Copyout all read segments, free up kernel buffers */
+		m = &(buf[i]);
+		if ((error == 0) && (m->flags & IIC_M_RD))
+			error = copyout(m->buf, usrbufs[i], m->len);
+		free(m->buf, M_IIC);
+	free(usrbufs, M_IIC);
+	free(buf, M_IIC);
+	return (error);
+static int
+iicioctl(struct cdev *dev, u_long cmd, caddr_t data, int flags, struct thread *td)
+	device_t parent, iicdev;
+	struct iiccmd *s;
+	struct uio ubuf;
+	struct iovec uvec;
+	int error;
+	s = (struct iiccmd *)data;
+	if (error != 0)
+		return (error);
+	IIC_LOCK(priv);
+	switch (cmd) {
+	case I2CSTART:
+			error = EINVAL;
+			break;
+		if (error == 0)
+			error = iicbus_start(parent, s->slave, 0);
+		if (error == 0) {
+			priv->addr = s->slave;
+			priv->started = true;
+		} else
+		break;
+	case I2CSTOP:
+			error = iicbus_stop(parent);
+			priv->started = false;
+		break;
+	case I2CRSTCARD:
+		 * Bus should be owned before we reset it.
+		 * We allow the bus to be already owned as the result of an in-progress
+		 * sequence; however, bus reset will always be followed by release
+		 * (a new start is presumably needed for I/O anyway). */
+		if (!priv->started)
+		if (error == 0) {
+			error = iicbus_reset(parent, IIC_UNKNOWN, 0, NULL);
+			 * Ignore IIC_ENOADDR as it only means we have a master-only
+			 * controller.
+			if (error == IIC_ENOADDR)
+				error = 0;
+		break;
+	case I2CWRITE:
+		if (!priv->started) {
+			error = EINVAL;
+			break;
+		uvec.iov_base = s->buf;
+		uvec.iov_len = s->count;
+		ubuf.uio_iov = &uvec;
+		ubuf.uio_iovcnt = 1;
+		ubuf.uio_segflg = UIO_USERSPACE;
+		ubuf.uio_td = td;
+		ubuf.uio_resid = s->count;
+		ubuf.uio_offset = 0;
+		ubuf.uio_rw = UIO_WRITE;
+		error = iicuio_move(priv, &ubuf, 0);
+		break;
+	case I2CREAD:
+			error = EINVAL;
+			break;
+		ubuf.uio_td = td;
+		ubuf.uio_rw = UIO_READ;
+		error = iicuio_move(priv, &ubuf, s->last);
+		break;
+	case I2CRDWR:
+		 * The rdwr list should be a self-contained set of
+		 * transactions.  Fail if another transaction is in progress.
+			error = EINVAL;
+			break;
+		error = iicrdwr(priv, (struct iic_rdwr_data *)data, flags);
+		break;
+	case I2CRPTSTART:
+			error = EINVAL;
+			break;
+		error = iicbus_repeated_start(parent, s->slave, 0);
+		break;
+	case I2CSADDR:
+		priv->addr = *((uint8_t*)data);
+		break;
+	default:
+		error = ENOTTY;
+	IIC_UNLOCK(priv);
+	return (error);
+DRIVER_MODULE(iic, iicbus, iic_driver, iic_devclass, 0, 0);
+MODULE_DEPEND(iic, iicbus, IICBUS_MINVER, IICBUS_PREFVER, IICBUS_MAXVER);
+MODULE_VERSION(iic, 1);
diff --git a/freebsd/sys/dev/iicbus/iic.h b/freebsd/sys/dev/iicbus/iic.h
index 00000000..5ebf56a9
--- /dev/null
+++ b/freebsd/sys/dev/iicbus/iic.h
@@ -0,0 +1,72 @@
+ * Copyright (c) 1998 Nicolas Souchu
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef __IIC_H
+#define __IIC_H
+#include <sys/ioccom.h>
+/* Designed to be compatible with linux's struct i2c_msg */
+struct iic_msg
+	uint16_t	slave;
+	uint16_t	flags;
+#define	IIC_M_WR	0	/* Fake flag for write */
+#define	IIC_M_RD	0x0001	/* read vs write */
+#define	IIC_M_NOSTOP	0x0002	/* do not send a I2C stop after message */
+#define	IIC_M_NOSTART	0x0004	/* do not send a I2C start before message */
+	uint16_t	len;	/* msg length */
+	uint8_t *	buf;
+struct iiccmd {
+	u_char slave;
+	int count;
+	int last;
+	char *buf;
+struct iic_rdwr_data {
+	struct iic_msg *msgs;
+	uint32_t nmsgs;
+#define IIC_RDRW_MAX_MSGS	42
+#define I2CSTART	_IOW('i', 1, struct iiccmd)	/* start condition */
+#define I2CSTOP		_IO('i', 2)			/* stop condition */
+#define I2CRSTCARD	_IOW('i', 3, struct iiccmd)	/* reset the card */
+#define I2CWRITE	_IOW('i', 4, struct iiccmd)	/* send data */
+#define I2CREAD		_IOW('i', 5, struct iiccmd)	/* receive data */
+#define I2CRDWR		_IOW('i', 6, struct iic_rdwr_data)	/* General read/write interface */
+#define I2CRPTSTART	_IOW('i', 7, struct iiccmd)	/* repeated start */
+#define I2CSADDR	_IOW('i', 8, uint8_t)		/* set slave address for future I/O */
+#endif
diff --git a/freebsd/sys/dev/iicbus/iicbus.c b/freebsd/sys/dev/iicbus/iicbus.c
index 00000000..d1e55483
--- /dev/null
+++ b/freebsd/sys/dev/iicbus/iicbus.c
@@ -0,0 +1,378 @@
+ * are met:
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+ * Autoconfiguration and support routines for the Philips serial I2C bus
+#include <sys/mutex.h>
+#include <sys/rman.h>
+#include <sys/sysctl.h>
+/* See comments below for why auto-scanning is a bad idea. */
+#define SCAN_IICBUS 0
+static int
+iicbus_probe(device_t dev)
+	device_set_desc(dev, "Philips I2C bus");
+	/* Allow other subclasses to override this driver. */
+	return (BUS_PROBE_GENERIC);
+#if SCAN_IICBUS
+static int
+iic_probe_device(device_t dev, u_char addr)
+	int count;
+	char byte;
+	if ((addr & 1) == 0) {
+		/* is device writable? */
+		if (!iicbus_start(dev, (u_char)addr, 0)) {
+			iicbus_stop(dev);
+			return (1);
+	} else {
+		/* is device readable? */
+		if (!iicbus_block_read(dev, (u_char)addr, &byte, 1, &count))
+			return (1);
+	return (0);
+#endif
+ * We add all the devices which we know about.
+ * The generic attach routine will attach them if they are alive.
+static int
+iicbus_attach(device_t dev)
+#if SCAN_IICBUS
+	unsigned char addr;
+#endif
+	struct iicbus_softc *sc = IICBUS_SOFTC(dev);
+	int strict;
+	sc->dev = dev;
+	mtx_init(&sc->lock, "iicbus", NULL, MTX_DEF);
+	iicbus_init_frequency(dev, 0);
+	iicbus_reset(dev, IIC_FASTEST, 0, NULL);
+	if (resource_int_value(device_get_name(dev),
+		device_get_unit(dev), "strict", &strict) == 0)
+		sc->strict = strict;
+	else
+		sc->strict = 1;
+	/* device probing is meaningless since the bus is supposed to be
+	 * hot-plug. Moreover, some I2C chips do not appreciate random
+	 * accesses like stop after start to fast, reads for less than
+	 * x bytes...
+#if SCAN_IICBUS
+	printf("Probing for devices on iicbus%d:", device_get_unit(dev));
+	/* probe any devices */
+	for (addr = 16; addr < 240; addr++) {
+		if (iic_probe_device(dev, (u_char)addr)) {
+			printf(" <%x>", addr);
+	printf("\n");
+#endif
+	bus_generic_probe(dev);
+	bus_enumerate_hinted_children(dev);
+	bus_generic_attach(dev);
+        return (0);
+static int
+iicbus_detach(device_t dev)
+	bus_generic_detach(dev);
+	device_delete_children(dev);
+	mtx_destroy(&sc->lock);
+	return (0);
+static int
+iicbus_print_child(device_t dev, device_t child)
+	struct iicbus_ivar *devi = IICBUS_IVAR(child);
+	int retval = 0;
+	retval += bus_print_child_header(dev, child);
+	if (devi->addr != 0)
+		retval += printf(" at addr %#x", devi->addr);
+	resource_list_print_type(&devi->rl, "irq", SYS_RES_IRQ, "%jd");
+	retval += bus_print_child_footer(dev, child);
+	return (retval);
+static void
+iicbus_probe_nomatch(device_t bus, device_t child)
+	device_printf(bus, "<unknown card> at addr %#x\n", devi->addr);
+static int
+iicbus_child_location_str(device_t bus, device_t child, char *buf,
+    size_t buflen)
+	snprintf(buf, buflen, "addr=%#x", devi->addr);
+	return (0);
+static int
+iicbus_child_pnpinfo_str(device_t bus, device_t child, char *buf,
+    size_t buflen)
+	*buf = '\0';
+	return (0);
+static int
+iicbus_read_ivar(device_t bus, device_t child, int which, uintptr_t *result)
+	switch (which) {
+	default:
+		return (EINVAL);
+	case IICBUS_IVAR_ADDR:
+		*result = devi->addr;
+		break;
+	case IICBUS_IVAR_NOSTOP:
+		*result = devi->nostop;
+		break;
+	return (0);
+static int
+iicbus_write_ivar(device_t bus, device_t child, int which, uintptr_t value)
+	switch (which) {
+	default:
+		return (EINVAL);
+			return (EINVAL);
+		devi->addr = value;
+		devi->nostop = value;
+		break;
+	return (0);
+static device_t
+iicbus_add_child(device_t dev, u_int order, const char *name, int unit)
+	device_t child;
+	struct iicbus_ivar *devi;
+	child = device_add_child_ordered(dev, order, name, unit);
+	if (child == NULL)
+		return (child);
+	devi = malloc(sizeof(struct iicbus_ivar), M_DEVBUF, M_NOWAIT | M_ZERO);
+	if (devi == NULL) {
+		device_delete_child(dev, child);
+		return (0);
+	resource_list_init(&devi->rl);
+	device_set_ivars(child, devi);
+	return (child);
+static void
+iicbus_hinted_child(device_t bus, const char *dname, int dunit)
+	device_t child;
+	int irq;
+	child = BUS_ADD_CHILD(bus, 0, dname, dunit);
+	devi = IICBUS_IVAR(child);
+	resource_int_value(dname, dunit, "addr", &devi->addr);
+	if (resource_int_value(dname, dunit, "irq", &irq) == 0) {
+		if (bus_set_resource(child, SYS_RES_IRQ, 0, irq, 1) != 0)
+			    "warning: bus_set_resource() failed\n");
+static struct resource_list *
+iicbus_get_resource_list(device_t bus __unused, device_t child)
+	return (&devi->rl);
+int
+iicbus_generic_intr(device_t dev, int event, char *buf)
+	return (0);
+int
+iicbus_null_callback(device_t dev, int index, caddr_t data)
+	return (0);
+int
+iicbus_null_repeated_start(device_t dev, u_char addr)
+	return (IIC_ENOTSUPP);
+void
+iicbus_init_frequency(device_t dev, u_int bus_freq)
+	 * If a bus frequency value was passed in, use it.  Otherwise initialize
+	 * it first to the standard i2c 100KHz frequency, then override that
+	 * from a hint if one exists.
+	if (bus_freq > 0)
+		sc->bus_freq = bus_freq;
+	else {
+		sc->bus_freq = 100000;
+		resource_int_value(device_get_name(dev), device_get_unit(dev),
+		    "frequency", (int *)&sc->bus_freq);
+	 * Set up the sysctl that allows the bus frequency to be changed.
+	 * It is flagged as a tunable so that the user can set the value in
+	 * loader(8), and that will override any other setting from any source.
+	 * The sysctl tunable/value is the one most directly controlled by the
+	 * user and thus the one that always takes precedence.
+	SYSCTL_ADD_UINT(device_get_sysctl_ctx(dev),
+	    SYSCTL_CHILDREN(device_get_sysctl_tree(dev)),
+	    OID_AUTO, "frequency", CTLFLAG_RW | CTLFLAG_TUN, &sc->bus_freq,
+	    sc->bus_freq, "Bus frequency in Hz");
+static u_int
+iicbus_get_frequency(device_t dev, u_char speed)
+	 * If the frequency has not been configured for the bus, or the request
+	 * is specifically for SLOW speed, use the standard 100KHz rate, else
+	 * use the configured bus speed.
+	if (sc->bus_freq == 0 || speed == IIC_SLOW)
+		return (100000);
+	return (sc->bus_freq);
+static device_method_t iicbus_methods[] = {
+	DEVMETHOD(device_probe,		iicbus_probe),
+	DEVMETHOD(device_attach,	iicbus_attach),
+	DEVMETHOD(device_detach,	iicbus_detach),
+	/* bus interface */
+	DEVMETHOD(bus_setup_intr,	bus_generic_setup_intr),
+	DEVMETHOD(bus_teardown_intr,	bus_generic_teardown_intr),
+	DEVMETHOD(bus_activate_resource, bus_generic_activate_resource),
+	DEVMETHOD(bus_deactivate_resource, bus_generic_deactivate_resource),
+	DEVMETHOD(bus_adjust_resource,	bus_generic_adjust_resource),
+	DEVMETHOD(bus_alloc_resource,	bus_generic_rl_alloc_resource),
+	DEVMETHOD(bus_get_resource,	bus_generic_rl_get_resource),
+	DEVMETHOD(bus_release_resource, bus_generic_rl_release_resource),
+	DEVMETHOD(bus_set_resource,	bus_generic_rl_set_resource),
+	DEVMETHOD(bus_get_resource_list, iicbus_get_resource_list),
+	DEVMETHOD(bus_add_child,	iicbus_add_child),
+	DEVMETHOD(bus_print_child,	iicbus_print_child),
+	DEVMETHOD(bus_probe_nomatch,	iicbus_probe_nomatch),
+	DEVMETHOD(bus_read_ivar,	iicbus_read_ivar),
+	DEVMETHOD(bus_write_ivar,	iicbus_write_ivar),
+	DEVMETHOD(bus_child_pnpinfo_str, iicbus_child_pnpinfo_str),
+	DEVMETHOD(bus_child_location_str, iicbus_child_location_str),
+	DEVMETHOD(bus_hinted_child,	iicbus_hinted_child),
+	DEVMETHOD(iicbus_transfer,	iicbus_transfer),
+	DEVMETHOD(iicbus_get_frequency,	iicbus_get_frequency),
+	DEVMETHOD_END
+driver_t iicbus_driver = {
+        "iicbus",
+        iicbus_methods,
+        sizeof(struct iicbus_softc),
+devclass_t iicbus_devclass;
+MODULE_VERSION(iicbus, IICBUS_MODVER);
+DRIVER_MODULE(iicbus, iichb, iicbus_driver, iicbus_devclass, 0, 0);
diff --git a/freebsd/sys/dev/iicbus/iicbus.h b/freebsd/sys/dev/iicbus/iicbus.h
index 00000000..503305c7
--- /dev/null
+++ b/freebsd/sys/dev/iicbus/iicbus.h
@@ -0,0 +1,83 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef __IICBUS_H
+#define __IICBUS_H
+#include <sys/_lock.h>
+#include <sys/_mutex.h>
+#define IICBUS_IVAR(d) (struct iicbus_ivar *) device_get_ivars(d)
+#define IICBUS_SOFTC(d) (struct iicbus_softc *) device_get_softc(d)
+struct iicbus_softc
+	device_t dev;		/* Myself */
+	device_t owner;		/* iicbus owner device structure */
+	u_int owncount;		/* iicbus ownership nesting count */
+	u_char started;		/* address of the 'started' slave
+				 * 0 if no start condition succeeded */
+	u_char strict;		/* deny operations that violate the
+				 * I2C protocol */
+	struct mtx lock;
+	u_int bus_freq;		/* Configured bus Hz. */
+struct iicbus_ivar
+	uint32_t	addr;
+	struct resource_list	rl;
+	bool		nostop;
+enum {
+	IICBUS_IVAR_ADDR,		/* Address or base address */
+	IICBUS_IVAR_NOSTOP,		/* nostop defaults */
+#define IICBUS_ACCESSOR(A, B, T)					\
+	__BUS_ACCESSOR(iicbus, A, IICBUS, B, T)
+IICBUS_ACCESSOR(addr,		ADDR,		uint32_t)
+IICBUS_ACCESSOR(nostop,		NOSTOP,		bool)
+#define	IICBUS_LOCK(sc)			mtx_lock(&(sc)->lock)
+#define	IICBUS_UNLOCK(sc)      		mtx_unlock(&(sc)->lock)
+#define	IICBUS_ASSERT_LOCKED(sc)       	mtx_assert(&(sc)->lock, MA_OWNED)
+int  iicbus_generic_intr(device_t dev, int event, char *buf);
+void iicbus_init_frequency(device_t dev, u_int bus_freq);
+extern driver_t iicbus_driver;
+extern devclass_t iicbus_devclass;
+extern driver_t ofw_iicbus_driver;
+extern devclass_t ofw_iicbus_devclass;
+#endif
diff --git a/freebsd/sys/dev/iicbus/iiconf.c b/freebsd/sys/dev/iicbus/iiconf.c
index 00000000..afdce118
--- /dev/null
+++ b/freebsd/sys/dev/iicbus/iiconf.c
@@ -0,0 +1,527 @@
+ * are met:
+ * SUCH DAMAGE.
+ * Translate IIC_Exxxxx status values to vaguely-equivelent errno values.
+int
+iic2errno(int iic_status)
+	switch (iic_status) {
+	case IIC_NOERR:         return (0);
+	case IIC_EBUSERR:       return (EALREADY);
+	case IIC_ENOACK:        return (EIO);
+	case IIC_ETIMEOUT:      return (ETIMEDOUT);
+	case IIC_EBUSBSY:       return (EWOULDBLOCK);
+	case IIC_ESTATUS:       return (EPROTO);
+	case IIC_EUNDERFLOW:    return (EIO);
+	case IIC_EOVERFLOW:     return (EOVERFLOW);
+	case IIC_ENOTSUPP:      return (EOPNOTSUPP);
+	case IIC_ENOADDR:       return (EADDRNOTAVAIL);
+	case IIC_ERESOURCE:     return (ENOMEM);
+	default:                return (EIO);
+ * iicbus_intr()
+void
+iicbus_intr(device_t bus, int event, char *buf)
+	struct iicbus_softc *sc = (struct iicbus_softc *)device_get_softc(bus);
+	/* call owner's intr routine */
+	if (sc->owner)
+		IICBUS_INTR(sc->owner, event, buf);
+	return;
+static int
+iicbus_poll(struct iicbus_softc *sc, int how)
+	int error;
+	IICBUS_ASSERT_LOCKED(sc);
+	switch (how & IIC_INTRWAIT) {
+	case IIC_WAIT | IIC_INTR:
+		error = mtx_sleep(sc, &sc->lock, IICPRI|PCATCH, "iicreq", 0);
+		break;
+	case IIC_WAIT | IIC_NOINTR:
+		error = mtx_sleep(sc, &sc->lock, IICPRI, "iicreq", 0);
+		break;
+	default:
+		return (IIC_EBUSBSY);
+	return (error);
+ * iicbus_request_bus()
+ * Allocate the device to perform transfers.
+ * how	: IIC_WAIT or IIC_DONTWAIT
+int
+iicbus_request_bus(device_t bus, device_t dev, int how)
+	int error = 0;
+	IICBUS_LOCK(sc);
+	for (;;) {
+		if (sc->owner == NULL)
+			break;
+		if ((how & IIC_RECURSIVE) && sc->owner == dev)
+			break;
+		if ((error = iicbus_poll(sc, how)) != 0)
+			break;
+	if (error == 0) {
+		++sc->owncount;
+		if (sc->owner == NULL) {
+			sc->owner = dev;
+			 * Drop the lock around the call to the bus driver, it
+			 * should be allowed to sleep in the IIC_WAIT case.
+			 * Drivers might also need to grab locks that would
+			 * cause a LOR if our lock is held.
+			IICBUS_UNLOCK(sc);
+			/* Ask the underlying layers if the request is ok */
+			error = IICBUS_CALLBACK(device_get_parent(bus),
+			    IIC_REQUEST_BUS, (caddr_t)&how);
+			IICBUS_LOCK(sc);
+			if (error != 0) {
+				sc->owner = NULL;
+				sc->owncount = 0;
+				wakeup_one(sc);
+	return (error);
+ * iicbus_release_bus()
+ * Release the device allocated with iicbus_request_dev()
+int
+iicbus_release_bus(device_t bus, device_t dev)
+	IICBUS_LOCK(sc);
+	if (sc->owner != dev) {
+	if (--sc->owncount == 0) {
+		/* Drop the lock while informing the low-level driver. */
+		IICBUS_CALLBACK(device_get_parent(bus), IIC_RELEASE_BUS, NULL);
+		IICBUS_LOCK(sc);
+		sc->owner = NULL;
+		wakeup_one(sc);
+	return (0);
+ * iicbus_started()
+ * Test if the iicbus is started by the controller
+int
+iicbus_started(device_t bus)
+	return (sc->started);
+ * iicbus_start()
+ * Send start condition to the slave addressed by 'slave'
+int
+iicbus_start(device_t bus, u_char slave, int timeout)
+	int error = 0;
+	if (sc->started)
+		return (IIC_ESTATUS); /* protocol error, bus already started */
+	if (!(error = IICBUS_START(device_get_parent(bus), slave, timeout)))
+		sc->started = slave;
+	else
+		sc->started = 0;
+	return (error);
+ * iicbus_repeated_start()
+int
+iicbus_repeated_start(device_t bus, u_char slave, int timeout)
+	int error = 0;
+	if (!sc->started)
+		return (IIC_ESTATUS); /* protocol error, bus not started */
+	if (!(error = IICBUS_REPEATED_START(device_get_parent(bus), slave, timeout)))
+	else
+		sc->started = 0;
+	return (error);
+ * iicbus_stop()
+ * Send stop condition to the bus
+int
+iicbus_stop(device_t bus)
+	int error = 0;
+	if (!sc->started)
+	error = IICBUS_STOP(device_get_parent(bus));
+	/* refuse any further access */
+	sc->started = 0;
+	return (error);
+ * iicbus_write()
+ * Write a block of data to the slave previously started by
+ * iicbus_start() call
+int
+iicbus_write(device_t bus, const char *buf, int len, int *sent, int timeout)
+	/* a slave must have been started for writing */
+	if (sc->started == 0 || (sc->strict != 0 && (sc->started & LSB) != 0))
+	return (IICBUS_WRITE(device_get_parent(bus), buf, len, sent, timeout));
+ * iicbus_read()
+ * Read a block of data from the slave previously started by
+ * iicbus_read() call
+int
+iicbus_read(device_t bus, char *buf, int len, int *read, int last, int delay)
+	/* a slave must have been started for reading */
+	if (sc->started == 0 || (sc->strict != 0 && (sc->started & LSB) == 0))
+	return (IICBUS_READ(device_get_parent(bus), buf, len, read, last, delay));
+ * iicbus_write_byte()
+ * Write a byte to the slave previously started by iicbus_start() call
+int
+iicbus_write_byte(device_t bus, char byte, int timeout)
+	struct iicbus_softc *sc = device_get_softc(bus);
+	char data = byte;
+	int sent;
+	return (iicbus_write(bus, &data, 1, &sent, timeout));
+ * iicbus_read_byte()
+ * Read a byte from the slave previously started by iicbus_start() call
+int
+iicbus_read_byte(device_t bus, char *byte, int timeout)
+	int read;
+	return (iicbus_read(bus, byte, 1, &read, IIC_LAST_READ, timeout));
+ * iicbus_block_write()
+ * Write a block of data to slave ; start/stop protocol managed
+int
+iicbus_block_write(device_t bus, u_char slave, char *buf, int len, int *sent)
+	u_char addr = slave & ~LSB;
+	int error;
+	if ((error = iicbus_start(bus, addr, 0)))
+		return (error);
+	error = iicbus_write(bus, buf, len, sent, 0);
+	iicbus_stop(bus);
+	return (error);
+ * iicbus_block_read()
+ * Read a block of data from slave ; start/stop protocol managed
+int
+iicbus_block_read(device_t bus, u_char slave, char *buf, int len, int *read)
+	u_char addr = slave | LSB;
+	int error;
+		return (error);
+	error = iicbus_read(bus, buf, len, read, IIC_LAST_READ, 0);
+	iicbus_stop(bus);
+	return (error);
+ * iicbus_transfer()
+ * Do an aribtrary number of transfers on the iicbus.  We pass these
+ * raw requests to the bridge driver.  If the bridge driver supports
+ * them directly, then it manages all the details.  If not, it can use
+ * the helper function iicbus_transfer_gen() which will do the
+ * transfers at a low level.
+ * Pointers passed in as part of iic_msg must be kernel pointers.
+ * Callers that have user addresses to manage must do so on their own.
+int
+iicbus_transfer(device_t bus, struct iic_msg *msgs, uint32_t nmsgs)
+	return (IICBUS_TRANSFER(device_get_parent(bus), msgs, nmsgs));
+int
+iicbus_transfer_excl(device_t dev, struct iic_msg *msgs, uint32_t nmsgs,
+    int how)
+	device_t bus;
+	int error;
+	bus = device_get_parent(dev);
+	error = iicbus_request_bus(bus, dev, how);
+	if (error == 0)
+		error = IICBUS_TRANSFER(bus, msgs, nmsgs);
+	iicbus_release_bus(bus, dev);
+	return (error);
+ * Generic version of iicbus_transfer that calls the appropriate
+ * routines to accomplish this.  See note above about acceptable
+ * buffer addresses.
+int
+iicbus_transfer_gen(device_t dev, struct iic_msg *msgs, uint32_t nmsgs)
+	int i, error, lenread, lenwrote, nkid, rpstart, addr;
+	device_t *children, bus;
+	bool nostop, started;
+	if ((error = device_get_children(dev, &children, &nkid)) != 0)
+		return (IIC_ERESOURCE);
+	if (nkid != 1) {
+		free(children, M_TEMP);
+	bus = children[0];
+	rpstart = 0;
+	nostop = iicbus_get_nostop(dev);
+	started = false;
+	for (i = 0, error = 0; i < nmsgs && error == 0; i++) {
+		addr = msgs[i].slave;
+		if (msgs[i].flags & IIC_M_RD)
+			addr |= LSB;
+		else
+			addr &= ~LSB;
+		if (!(msgs[i].flags & IIC_M_NOSTART)) {
+			if (rpstart)
+				error = iicbus_repeated_start(bus, addr, 0);
+			else
+				error = iicbus_start(bus, addr, 0);
+			if (error != 0)
+				break;
+			started = true;
+			error = iicbus_read(bus, msgs[i].buf, msgs[i].len,
+			    &lenread, IIC_LAST_READ, 0);
+		else
+			error = iicbus_write(bus, msgs[i].buf, msgs[i].len,
+			    &lenwrote, 0);
+		if (error != 0)
+			break;
+		if ((msgs[i].flags & IIC_M_NOSTOP) != 0 ||
+		    (nostop && i + 1 < nmsgs)) {
+			rpstart = 1;	/* Next message gets repeated start */
+		} else {
+			rpstart = 0;
+			iicbus_stop(bus);
+	if (error != 0 && started)
+		iicbus_stop(bus);
+	return (error);
+int
+iicdev_readfrom(device_t slavedev, uint8_t regaddr, void *buffer,
+    uint16_t buflen, int waithow)
+	struct iic_msg msgs[2];
+	uint8_t slaveaddr;
+	 * Two transfers back to back with a repeat-start between them; first we
+	 * write the address-within-device, then we read from the device.
+	slaveaddr = iicbus_get_addr(slavedev);
+	msgs[0].slave = slaveaddr;
+	msgs[0].flags = IIC_M_WR | IIC_M_NOSTOP;
+	msgs[0].len   = 1;
+	msgs[0].buf   = ®addr;
+	msgs[1].slave = slaveaddr;
+	msgs[1].flags = IIC_M_RD;
+	msgs[1].len   = buflen;
+	msgs[1].buf   = buffer;
+	return (iicbus_transfer_excl(slavedev, msgs, nitems(msgs), waithow));
+int iicdev_writeto(device_t slavedev, uint8_t regaddr, void *buffer,
+	 * Two transfers back to back with no stop or start between them; first
+	 * we write the address then we write the data to that address, all in a
+	 * single transfer from two scattered buffers.
+	msgs[0].len   = 1;
+	msgs[1].flags = IIC_M_WR | IIC_M_NOSTART;
diff --git a/freebsd/sys/dev/iicbus/iiconf.h b/freebsd/sys/dev/iicbus/iiconf.h
index 00000000..c264183e
--- /dev/null
+++ b/freebsd/sys/dev/iicbus/iiconf.h
@@ -0,0 +1,162 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef __IICONF_H
+#define __IICONF_H
+#include <sys/queue.h>
+#define IICPRI (PZERO+8)		/* XXX sleep/wakeup queue priority */
+#define LSB 0x1
+ * Options affecting iicbus_request_bus()
+#define IIC_DONTWAIT	0
+#define IIC_NOINTR	0
+#define IIC_WAIT	0x1
+#define IIC_INTR	0x2
+#define IIC_INTRWAIT	(IIC_INTR | IIC_WAIT)
+#define IIC_RECURSIVE	0x4
+ * i2c modes
+#define IIC_MASTER	0x1
+#define IIC_SLAVE	0x2
+#define IIC_POLLED	0x4
+ * i2c speed
+#define IIC_UNKNOWN	0x0
+#define IIC_SLOW	0x1
+#define IIC_FAST	0x2
+#define IIC_FASTEST	0x3
+#define IIC_LAST_READ	0x1
+ * callback index
+#define IIC_REQUEST_BUS	0x1
+#define IIC_RELEASE_BUS	0x2
+ * interrupt events
+#define INTR_GENERAL	0x1	/* general call received */
+#define INTR_START	0x2	/* the I2C interface is addressed */
+#define INTR_STOP	0x3	/* stop condition received */
+#define INTR_RECEIVE	0x4	/* character received */
+#define INTR_TRANSMIT	0x5	/* character to transmit */
+#define INTR_ERROR	0x6	/* error */
+#define INTR_NOACK	0x7	/* no ack from master receiver */
+ * adapter layer errors
+#define	IIC_NOERR	0x0	/* no error occurred */
+#define IIC_EBUSERR	0x1	/* bus error (hardware not in expected state) */
+#define IIC_ENOACK	0x2	/* ack not received until timeout */
+#define IIC_ETIMEOUT	0x3	/* timeout */
+#define IIC_EBUSBSY	0x4	/* bus busy (reserved by another client) */
+#define IIC_ESTATUS	0x5	/* status error */
+#define IIC_EUNDERFLOW	0x6	/* slave ready for more data */
+#define IIC_EOVERFLOW	0x7	/* too much data */
+#define IIC_ENOTSUPP	0x8	/* request not supported */
+#define IIC_ENOADDR	0x9	/* no address assigned to the interface */
+#define IIC_ERESOURCE	0xa	/* resources (memory, whatever) unavailable */
+ * Note that all iicbus functions return IIC_Exxxxx status values,
+ * except iic2errno() (obviously) and iicbus_started() (returns bool).
+extern int iic2errno(int);
+extern int iicbus_request_bus(device_t, device_t, int);
+extern int iicbus_release_bus(device_t, device_t);
+extern device_t iicbus_alloc_bus(device_t);
+extern void iicbus_intr(device_t, int, char *);
+extern int iicbus_null_repeated_start(device_t, u_char);
+extern int iicbus_null_callback(device_t, int, caddr_t);
+#define iicbus_reset(bus,speed,addr,oldaddr) \
+	(IICBUS_RESET(device_get_parent(bus), speed, addr, oldaddr))
+/* basic I2C operations */
+extern int iicbus_started(device_t);
+extern int iicbus_start(device_t, u_char, int);
+extern int iicbus_stop(device_t);
+extern int iicbus_repeated_start(device_t, u_char, int);
+extern int iicbus_write(device_t, const char *, int, int *, int);
+extern int iicbus_read(device_t, char *, int, int *, int, int);
+/* single byte read/write functions, start/stop not managed */
+extern int iicbus_write_byte(device_t, char, int);
+extern int iicbus_read_byte(device_t, char *, int);
+/* Read/write operations with start/stop conditions managed */
+extern int iicbus_block_write(device_t, u_char, char *, int, int *);
+extern int iicbus_block_read(device_t, u_char, char *, int, int *);
+/* vectors of iic operations to pass to bridge */
+int iicbus_transfer(device_t bus, struct iic_msg *msgs, uint32_t nmsgs);
+int iicbus_transfer_excl(device_t bus, struct iic_msg *msgs, uint32_t nmsgs,
+    int how);
+int iicbus_transfer_gen(device_t bus, struct iic_msg *msgs, uint32_t nmsgs);
+ * Simple register read/write routines, but the "register" can be any size.
+ * The transfers are done with iicbus_transfer_excl().  Reads use a repeat-start
+ * between sending the address and reading; writes use a single start/stop.
+int iicdev_readfrom(device_t _slavedev, uint8_t _regaddr, void *_buffer,
+    uint16_t _buflen, int _waithow);
+int iicdev_writeto(device_t _slavedev, uint8_t _regaddr, void *_buffer,
+#define IICBUS_MODVER	1
+#define IICBUS_MINVER	1
+#define IICBUS_MAXVER	1
+#define IICBUS_PREFVER	IICBUS_MODVER
+extern driver_t iicbb_driver;
+extern devclass_t iicbb_devclass;
+#define IICBB_MODVER	1
+#define IICBB_MINVER	1
+#define IICBB_MAXVER	1
+#define IICBB_PREFVER	IICBB_MODVER
+#endif
diff --git a/freebsd/sys/dev/iicbus/ofw_iicbus.c b/freebsd/sys/dev/iicbus/ofw_iicbus.c
index 00000000..cb31459e
--- /dev/null
+++ b/freebsd/sys/dev/iicbus/ofw_iicbus.c
@@ -0,0 +1,242 @@
+ * Copyright (c) 2009, Nathan Whitehorn <nwhitehorn at FreeBSD.org>
+ * are met:
+ *    notice unmodified, this list of conditions, and the following
+ *    disclaimer.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#include <sys/libkern.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#include <dev/ofw/openfirm.h>
+/* Methods */
+static device_probe_t ofw_iicbus_probe;
+static device_attach_t ofw_iicbus_attach;
+static device_t ofw_iicbus_add_child(device_t dev, u_int order,
+    const char *name, int unit);
+static const struct ofw_bus_devinfo *ofw_iicbus_get_devinfo(device_t bus,
+    device_t dev);
+static device_method_t ofw_iicbus_methods[] = {
+	/* Device interface */
+	DEVMETHOD(device_probe,		ofw_iicbus_probe),
+	DEVMETHOD(device_attach,	ofw_iicbus_attach),
+	/* Bus interface */
+	DEVMETHOD(bus_child_pnpinfo_str, ofw_bus_gen_child_pnpinfo_str),
+	DEVMETHOD(bus_add_child,	ofw_iicbus_add_child),
+	/* ofw_bus interface */
+	DEVMETHOD(ofw_bus_get_devinfo,	ofw_iicbus_get_devinfo),
+	DEVMETHOD(ofw_bus_get_compat,	ofw_bus_gen_get_compat),
+	DEVMETHOD(ofw_bus_get_model,	ofw_bus_gen_get_model),
+	DEVMETHOD(ofw_bus_get_name,	ofw_bus_gen_get_name),
+	DEVMETHOD(ofw_bus_get_node,	ofw_bus_gen_get_node),
+	DEVMETHOD(ofw_bus_get_type,	ofw_bus_gen_get_type),
+	DEVMETHOD_END
+struct ofw_iicbus_devinfo {
+	struct iicbus_ivar	opd_dinfo;	/* Must be the first. */
+	struct ofw_bus_devinfo	opd_obdinfo;
+devclass_t ofw_iicbus_devclass;
+DEFINE_CLASS_1(iicbus, ofw_iicbus_driver, ofw_iicbus_methods,
+    sizeof(struct iicbus_softc), iicbus_driver);
+EARLY_DRIVER_MODULE(ofw_iicbus, iicbb, ofw_iicbus_driver, ofw_iicbus_devclass,
+    0, 0, BUS_PASS_BUS);
+EARLY_DRIVER_MODULE(ofw_iicbus, iichb, ofw_iicbus_driver, ofw_iicbus_devclass,
+EARLY_DRIVER_MODULE(ofw_iicbus, twsi, ofw_iicbus_driver, ofw_iicbus_devclass,
+MODULE_VERSION(ofw_iicbus, 1);
+MODULE_DEPEND(ofw_iicbus, iicbus, 1, 1, 1);
+static int
+ofw_iicbus_probe(device_t dev)
+	if (ofw_bus_get_node(dev) == -1)
+		return (ENXIO);
+	device_set_desc(dev, "OFW I2C bus");
+	return (0);
+static int
+ofw_iicbus_attach(device_t dev)
+	struct ofw_iicbus_devinfo *dinfo;
+	phandle_t child, node, root;
+	pcell_t freq, paddr;
+	device_t childdev;
+	ssize_t compatlen;
+	char compat[255];
+	char *curstr;
+	u_int iic_addr_8bit = 0;
+	sc->dev = dev;
+	 * If there is a clock-frequency property for the device node, use it as
+	 * the starting value for the bus frequency.  Then call the common
+	 * routine that handles the tunable/sysctl which allows the FDT value to
+	 * be overridden by the user.
+	node = ofw_bus_get_node(dev);
+	freq = 0;
+	OF_getencprop(node, "clock-frequency", &freq, sizeof(freq));
+	iicbus_init_frequency(dev, freq);
+	 * Check if we're running on a PowerMac, needed for the I2C
+	 * address below.
+	root = OF_peer(0);
+	compatlen = OF_getprop(root, "compatible", compat,
+				sizeof(compat));
+	if (compatlen != -1) {
+	    for (curstr = compat; curstr < compat + compatlen;
+		curstr += strlen(curstr) + 1) {
+		if (strncmp(curstr, "MacRISC", 7) == 0)
+		    iic_addr_8bit = 1;
+	 * Attach those children represented in the device tree.
+	for (child = OF_child(node); child != 0; child = OF_peer(child)) {
+		 * Try to get the I2C address first from the i2c-address
+		 * property, then try the reg property.  It moves around
+		 * on different systems.
+		if (OF_getencprop(child, "i2c-address", &paddr,
+		    sizeof(paddr)) == -1)
+			if (OF_getencprop(child, "reg", &paddr,
+				continue;
+		 * Now set up the I2C and OFW bus layer devinfo and add it
+		 * to the bus.
+		dinfo = malloc(sizeof(struct ofw_iicbus_devinfo), M_DEVBUF,
+		    M_NOWAIT | M_ZERO);
+		if (dinfo == NULL)
+			continue;
+		 * FreeBSD drivers expect I2C addresses to be expressed as
+		 * 8-bit values.  Apple OFW data contains 8-bit values, but
+		 * Linux FDT data contains 7-bit values, so shift them up to
+		 * 8-bit format.
+		if (iic_addr_8bit)
+		    dinfo->opd_dinfo.addr = paddr;
+		else
+		    dinfo->opd_dinfo.addr = paddr << 1;
+		if (ofw_bus_gen_setup_devinfo(&dinfo->opd_obdinfo, child) !=
+		    0) {
+			free(dinfo, M_DEVBUF);
+			continue;
+		childdev = device_add_child(dev, NULL, -1);
+		resource_list_init(&dinfo->opd_dinfo.rl);
+		ofw_bus_intr_to_rl(childdev, child,
+					&dinfo->opd_dinfo.rl, NULL);
+		device_set_ivars(childdev, dinfo);
+	/* Register bus */
+	OF_device_register_xref(OF_xref_from_node(node), dev);
+	return (bus_generic_attach(dev));
+static device_t
+ofw_iicbus_add_child(device_t dev, u_int order, const char *name, int unit)
+	device_t child;
+	struct ofw_iicbus_devinfo *devi;
+		return (child);
+	devi = malloc(sizeof(struct ofw_iicbus_devinfo), M_DEVBUF,
+		return (0);
+	 * NULL all the OFW-related parts of the ivars for non-OFW
+	 * children.
+	devi->opd_obdinfo.obd_node = -1;
+	devi->opd_obdinfo.obd_name = NULL;
+	devi->opd_obdinfo.obd_compat = NULL;
+	devi->opd_obdinfo.obd_type = NULL;
+	devi->opd_obdinfo.obd_model = NULL;
+	return (child);
+ofw_iicbus_get_devinfo(device_t bus, device_t dev)
+	dinfo = device_get_ivars(dev);
+	return (&dinfo->opd_obdinfo);
2.20.1
