[PATCH] Add Testsuite for PSXINTTYPES01
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Wed Jun 12 18:17:21 UTC 2019
Ok, will do that.
On Wed, Jun 12, 2019, 10:10 PM Aditya Upadhyay <aadit0402 at gmail.com> wrote:
> Hi Vaibhav,
> RTEMS does not use // for comment. Just make this little change and send
> the
> next version of this patch.
> On Wed, Jun 12, 2019 at 3:09 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > testsuites/psxtests/Makefile.am | 7 +
> > testsuites/psxtests/configure.ac | 1 +
> > testsuites/psxtests/psxinttypes01/init.c | 233 ++++++++++++++++++
> > .../psxtests/psxinttypes01/psxinttypes01.doc | 70 ++++++
> > .../psxtests/psxinttypes01/psxinttypes01.scn | 44 ++++
> > 5 files changed, 355 insertions(+)
> > create mode 100644 testsuites/psxtests/psxinttypes01/init.c
> > create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.docs
> > create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> > diff --git a/testsuites/psxtests/Makefile.am
> b/testsuites/psxtests/Makefile.am
> > index 1e354c0df7..59c9f2085b 100755
> > --- a/testsuites/psxtests/Makefile.am
> > +++ b/testsuites/psxtests/Makefile.am
> > @@ -523,6 +523,13 @@ psxintrcritical01_CPPFLAGS = $(AM_CPPFLAGS) \
> > endif
> > endif
> > +if TEST_psxinttypes01
> > +psx_tests += psxinttypes01
> > +psxinttypes01_SOURCES = psxinttypes01/init.c
> > +psxinttypes01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxinttypes01) \
> > + $(support_includes)
> > +endif
> > if HAS_POSIX
> > if TEST_psxitimer
> > psx_tests += psxitimer
> > diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
> configure.ac
> > index cdd6ee7e4e..85559e4aa5 100644
> > --- a/testsuites/psxtests/configure.ac
> > +++ b/testsuites/psxtests/configure.ac
> > @@ -91,6 +91,7 @@ RTEMS_TEST_CHECK([psxid01])
> > RTEMS_TEST_CHECK([psximfs01])
> > RTEMS_TEST_CHECK([psximfs02])
> > RTEMS_TEST_CHECK([psxintrcritical01])
> > +RTEMS_TEST_CHECK([psxinttypes01])
> > RTEMS_TEST_CHECK([psxitimer])
> > RTEMS_TEST_CHECK([psxkey01])
> > RTEMS_TEST_CHECK([psxkey02])
> > diff --git a/testsuites/psxtests/psxinttypes01/init.c
> b/testsuites/psxtests/psxinttypes01/init.c
> > new file mode 100644
> > index 0000000000..8eafae11ac
> > --- /dev/null
> > +++ b/testsuites/psxtests/psxinttypes01/init.c
> > @@ -0,0 +1,233 @@
> > + * @file
> > + * @brief Test suite for inttypes.h methods
> > + * SPDX-License-Identifier: BSD-2-Clause
> > + * Copyright (C) 2019, Aditya Upadhyay and Vaibhav Gupta
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + * notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + * notice, this list of conditions and the following disclaimer in
> the
> > + * documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +#ifdef HAVE_CONFIG_H
> > +#include "config.h"
> > +#endif
> > +#include <rtems/test.h>
> > +#include <inttypes.h>
> > +#include <stdio.h>
> > +#include <errno.h>
> > +#include <tmacros.h>
> > +#include <stdint.h>
> > +#include <stddef.h>
> > +const char rtems_test_name[] = "PSXINTTYPE 01";
> > +/* forward declarations to avoid warnings */
> > +rtems_task Init(rtems_task_argument ignored);
> > + int base = 10;
> > + int invalid_base = 40;
> > + char *nptr1_p = "123abc";
> //char* pointing to string with positive number
> > + char *nptr1_p_errange = "9999999999999999999999";
> //char* pointing to string with positive number that is out of range
> > + char *nptr1_n = "-123abc"; //char*
> pointing to string with negative number
> > + char *nptr1_n_errange = "-9999999999999999999999";
> //char* pointing to string with negative number that is out of range
> > + char *endptr1 = NULL;
> > + wchar_t *nptr2_p = L"123junk";
> //wchar_t* pointing to string with positive number
> > + wchar_t *nptr2_p_errange = L"9999999999999999999999";
> //wchar_t* pointing to string with positive number that is out of range
> > + wchar_t *nptr2_n = L"-123junk";
> //wchar_t* pointing to string with negative number
> > + wchar_t *nptr2_n_errange = L"-9999999999999999999999";
> //wchar_t* pointing to string with negative number that is out of range
> > + wchar_t *endptr2 = NULL;
> > + intmax_t result_strtoimax;
> > + uintmax_t result_strtoumax;
> > + TEST_BEGIN();
> > + /*Test for strtoimax */
> > + puts( "\nstrtoimax Testcases...." );
> > + puts( "Valid Inputs - Positive Number" );
> > + result_strtoimax = strtoimax( nptr1_p, &endptr1, base );
> > + rtems_test_assert( result_strtoimax == 123 );
> > + puts( "Final string pointed by endptr" );
> > + rtems_test_assert( endptr1 == ( nptr1_p + 3 ) );
> > + puts( "Valid Inputs - Negative Number" );
> > + result_strtoimax = strtoimax( nptr1_n, &endptr1, base );
> > + rtems_test_assert( result_strtoimax == -123 );
> > + rtems_test_assert( endptr1 == ( nptr1_n + 4 ) );
> > + puts( "Valid Input - Positive Number - Number out of Range" );
> > + result_strtoimax = strtoimax( nptr1_p_errange, &endptr1, base );
> > + rtems_test_assert( result_strtoimax == INTMAX_MAX );
> > + rtems_test_assert( errno == ERANGE );
> > + puts( "Valid Input - Negative Number - Number out of Range" );
> > + result_strtoimax = strtoimax( nptr1_n_errange, &endptr1, base );
> > + rtems_test_assert( result_strtoimax == INTMAX_MIN );
> > + puts( "Invalid Input - Send NULL Pointer" );
> > + result_strtoimax = strtoimax( NULL, &endptr1, base );
> > + rtems_test_assert( result_strtoimax == 0 );
> > + rtems_test_assert( errno == EINVAL );
> > + puts( "Invalid Input - Invalid base - Use base = 40" );
> > + result_strtoimax = strtoimax( nptr1_p, &endptr1, invalid_base );
> > + /*Test for strtoumax */
> > + puts( "\nstrtoumax Testcases...." );
> > + result_strtoumax = strtoumax( nptr1_p, &endptr1, base );
> > + rtems_test_assert( result_strtoumax ==123 );
> > + result_strtoumax = strtoumax( nptr1_n, &endptr1, base );
> > + rtems_test_assert( result_strtoumax != 0 );
> > + result_strtoumax = strtoumax( nptr1_p_errange, &endptr1, base );
> > + rtems_test_assert( result_strtoumax == UINTMAX_MAX );
> > + result_strtoumax = strtoumax( nptr1_n_errange, &endptr1, base );
> > + result_strtoumax = strtoumax( NULL, &endptr1, base );
> > + rtems_test_assert( result_strtoumax == 0 );
> > + result_strtoumax = strtoumax( nptr1_p, &endptr1, invalid_base );
> > + /*Test for wcstoimax */
> > + puts( "\nwcstoimax Testcases...." );
> > + result_strtoimax = wcstoimax( nptr2_p, &endptr2, base );
> > + rtems_test_assert( endptr2 == ( nptr2_p + 3 ) );
> > + result_strtoimax = wcstoimax( nptr2_n, &endptr2, base );
> This should be like result_strtoimax == -123. ( one space between
> operator and and value)
> > + rtems_test_assert( endptr2 == ( nptr2_n + 4 ) );
> > + result_strtoimax = wcstoimax( nptr2_p_errange, &endptr2, base );
> > + result_strtoimax = wcstoimax( nptr2_n_errange, &endptr2, base );
> > + rtems_test_assert( result_strtoimax != 0 );
> > + result_strtoimax = wcstoimax( NULL, &endptr2, base );
> > + result_strtoimax = wcstoimax( nptr2_p, &endptr2, invalid_base );
> > + /*Test for wcstoumax */
> > + puts( "\nwcstoumax Testcases...." );
> > + result_strtoumax = wcstoumax( nptr2_p, &endptr2, base );
> > + rtems_test_assert( result_strtoumax == 123 );
> > + result_strtoumax = wcstoumax( nptr2_n, &endptr2, base );
> > + result_strtoumax = wcstoumax( nptr2_p_errange, &endptr2, base );
> > + result_strtoumax = wcstoumax( nptr2_n_errange, &endptr2, base );
> > + result_strtoumax = wcstoumax( NULL, &endptr2, base );
> > + result_strtoumax = wcstoumax( nptr2_p, &endptr2, invalid_base );
> > + TEST_END();
> > + rtems_test_exit(0);
> > +/* NOTICE: the clock driver is explicitly disabled */
> > +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> > +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> > +#define CONFIGURE_MAXIMUM_TASKS 1
> > +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> > +#include <rtems/confdefs.h>
> > diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> > index 0000000000..b5fd8e6d0e
> > --- /dev/null
> > +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> > @@ -0,0 +1,70 @@
> > + * Copyright (C) 2019, Vaibhav Gupta
> > + * are met:
> the
> distribution.
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +This File describes the concepts tested by this test suite.
> > +inttypes.h - fixed size integer types
> > +test suite name: PSXINTTYPE 01
> > +- Checks for invalid base value
> > +- Checks for Strtoimax Testcases
> > + - checks for output for string having a positive number
> > + - checks for output for string having a negative number
> > + - checks for output for string having a positive number - Number
> Out of Range
> > + - checks for output for string having a negative number - Number
> Out of Range
> > + - checks for final string pointed by endptr
> > + - checks for output for invalid argument - NULL Pointer
> > + - checks for output for invalid argument - Invalid Base
> > +- Checks for Strtoumax Test Cases
> Out of Range
> Out of Range
> > +- Checks for Wcstoimax Testcases
> Out of Range
> Out of Range
> > +- Checks for Wcstoumax Testcases
> Out of Range
> Out of Range
> > diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> > index 0000000000..33e82428f1
> > --- /dev/null
> > +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> > @@ -0,0 +1,44 @@
> > +*** PSXINTTYPE 01 TEST ***
> > +strtoimax Testcases....
> > +Valid Inputs - Positive Number
> > +Final string pointed by endptr
> > +Valid Inputs - Negative Number
> > +Valid Input - Positive Number - Number out of Range
> > +Valid Input - Negative Number - Number out of Range
> > +Invalid Input - Send NULL Pointer
> > +Invalid Input - Invalid base - Use base = 40
> > +strtoumax Testcases....
> > +wcstoimax Testcases....
> > +wcstoumax Testcases....
> > +*** END OF PSXINTTYPE 01 TEST ***
> > 2.21.0
> You can also look into this:
> http://man7.org/linux/man-pages/man3/strtol.3.html
> Thanks,
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190612/281b34e4/attachment-0001.html>
