[PATCH] Add Testsuite for PSXINTTYPES01
Wed Jun 12 22:25:00 UTC 2019
On Wed, Jun 12, 2019 at 12:17 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
> Ok, will do that.
> On Wed, Jun 12, 2019, 10:10 PM Aditya Upadhyay <aadit0402 at gmail.com> wrote:
>> Hi Vaibhav,
>> RTEMS does not use // for comment. Just make this little change and send the
>> next version of this patch.
Speaking of patch versions, please use the -v option of
git-format-patch to generate version-numbrered patches. this one
should have been maybe -v2, and next one would be -v3, etc...
>> On Wed, Jun 12, 2019 at 3:09 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>> >  testsuites/psxtests/Makefile.am               |   7 +
>> >  testsuites/psxtests/configure.ac              |   1 +
>> >  testsuites/psxtests/psxinttypes01/init.c      | 233 ++++++++++++++++++
>> >  .../psxtests/psxinttypes01/psxinttypes01.doc  |  70 ++++++
>> >  .../psxtests/psxinttypes01/psxinttypes01.scn  |  44 ++++
>> >  5 files changed, 355 insertions(+)
>> >  create mode 100644 testsuites/psxtests/psxinttypes01/init.c
>> >  create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.docs
>> >  create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.scn
>> > diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
>> > index 1e354c0df7..59c9f2085b 100755
>> > --- a/testsuites/psxtests/Makefile.am
>> > +++ b/testsuites/psxtests/Makefile.am
>> > @@ -523,6 +523,13 @@ psxintrcritical01_CPPFLAGS = $(AM_CPPFLAGS) \
>> >  endif
>> >  endif
>> > +if TEST_psxinttypes01
>> > +psx_tests += psxinttypes01
>> > +psxinttypes01_SOURCES = psxinttypes01/init.c
>> > +psxinttypes01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxinttypes01) \
>> > +       $(support_includes)
>> > +endif
>> >  if HAS_POSIX
>> >  if TEST_psxitimer
>> >  psx_tests += psxitimer
>> > diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
>> > index cdd6ee7e4e..85559e4aa5 100644
>> > --- a/testsuites/psxtests/configure.ac
>> > +++ b/testsuites/psxtests/configure.ac
>> > @@ -91,6 +91,7 @@ RTEMS_TEST_CHECK([psxid01])
>> >  RTEMS_TEST_CHECK([psximfs01])
>> >  RTEMS_TEST_CHECK([psximfs02])
>> >  RTEMS_TEST_CHECK([psxintrcritical01])
>> > +RTEMS_TEST_CHECK([psxinttypes01])
>> >  RTEMS_TEST_CHECK([psxitimer])
>> >  RTEMS_TEST_CHECK([psxkey01])
>> >  RTEMS_TEST_CHECK([psxkey02])
>> > diff --git a/testsuites/psxtests/psxinttypes01/init.c b/testsuites/psxtests/psxinttypes01/init.c
>> > new file mode 100644
>> > index 0000000000..8eafae11ac
>> > --- /dev/null
>> > +++ b/testsuites/psxtests/psxinttypes01/init.c
>> > @@ -0,0 +1,233 @@
>> > + *  @file
>> > + *  @brief Test suite for inttypes.h methods
>> > + * SPDX-License-Identifier: BSD-2-Clause
>> > + * Copyright (C) 2019, Aditya Upadhyay and Vaibhav Gupta
>> > + * Redistribution and use in source and binary forms, with or without
>> > + * modification, are permitted provided that the following conditions
>> > + * are met:
>> > + * 1. Redistributions of source code must retain the above copyright
>> > + *    notice, this list of conditions and the following disclaimer.
>> > + * 2. Redistributions in binary form must reproduce the above copyright
>> > + *    notice, this list of conditions and the following disclaimer in the
>> > + *    documentation and/or other materials provided with the distribution.
>> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
>> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
>> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>> > + * POSSIBILITY OF SUCH DAMAGE.
>> > +#ifdef HAVE_CONFIG_H
>> > +#include "config.h"
>> > +#endif
>> > +#include <rtems/test.h>
>> > +#include <inttypes.h>
>> > +#include <stdio.h>
>> > +#include <errno.h>
>> > +#include <tmacros.h>
>> > +#include <stdint.h>
>> > +#include <stddef.h>
>> > +const char rtems_test_name[] = "PSXINTTYPE 01";
>> > +/* forward declarations to avoid warnings */
>> > +rtems_task Init(rtems_task_argument ignored);
>> > +  int       base            = 10;
>> > +  int       invalid_base    = 40;
>> > +  char     *nptr1_p         = "123abc";                                //char* pointing to string with positive number
>> > +  char            *nptr1_p_errange = "9999999999999999999999";         //char* pointing to string with positive number that is out of range
>> > +  char     *nptr1_n         = "-123abc";                       //char* pointing to string with negative number
>> > +  char            *nptr1_n_errange = "-9999999999999999999999";        //char* pointing to string with negative number that is out of range
>> > +  char     *endptr1         = NULL;
>> > +  wchar_t  *nptr2_p         = L"123junk";                      //wchar_t* pointing to string with positive number
>> > +  wchar_t  *nptr2_p_errange = L"9999999999999999999999";       //wchar_t* pointing to string with positive number that is out of range
>> > +  wchar_t  *nptr2_n         = L"-123junk";                     //wchar_t* pointing to string with negative number
>> > +  wchar_t  *nptr2_n_errange = L"-9999999999999999999999";      //wchar_t* pointing to string with negative number that is out of range
Have a look at https://devel.rtems.org/wiki/Developer/Coding/Conventions
>> > +  wchar_t  *endptr2         = NULL;
>> > +  intmax_t  result_strtoimax;
>> > +  uintmax_t result_strtoumax;
>> > +  TEST_BEGIN();
>> > +  /*Test for strtoimax  */
>> > +  puts( "\nstrtoimax Testcases...." );
>> > +  puts( "Valid Inputs - Positive Number" );
>> > +  result_strtoimax = strtoimax( nptr1_p, &endptr1, base );
>> > +  rtems_test_assert( result_strtoimax == 123 );
>> > +  puts( "Final string pointed by endptr" );
>> > +  rtems_test_assert( endptr1 == ( nptr1_p + 3 ) );
>> > +  puts( "Valid Inputs - Negative Number" );
>> > +  result_strtoimax = strtoimax( nptr1_n, &endptr1, base );
>> > +  rtems_test_assert( result_strtoimax == -123 );
>> > +  rtems_test_assert( endptr1 == ( nptr1_n + 4 ) );
>> > +  puts( "Valid Input - Positive Number - Number out of Range" );
>> > +  result_strtoimax = strtoimax( nptr1_p_errange, &endptr1, base );
>> > +  rtems_test_assert( result_strtoimax == INTMAX_MAX );
>> > +  rtems_test_assert( errno == ERANGE );
>> > +  puts( "Valid Input - Negative Number - Number out of Range" );
>> > +  result_strtoimax = strtoimax( nptr1_n_errange, &endptr1, base );
>> > +  rtems_test_assert( result_strtoimax == INTMAX_MIN );
>> > +  puts( "Invalid Input - Send NULL Pointer" );
>> > +  result_strtoimax = strtoimax( NULL, &endptr1, base );
>> > +  rtems_test_assert( result_strtoimax == 0 );
>> > +  rtems_test_assert( errno == EINVAL );
>> > +  puts( "Invalid Input - Invalid base - Use base = 40" );
>> > +  result_strtoimax = strtoimax( nptr1_p, &endptr1, invalid_base );
>> > +  /*Test for strtoumax  */
>> > +  puts( "\nstrtoumax Testcases...." );
>> > +  result_strtoumax = strtoumax( nptr1_p, &endptr1, base );
>> > +  rtems_test_assert( result_strtoumax ==123 );
>> > +  result_strtoumax = strtoumax( nptr1_n, &endptr1, base );
>> > +  rtems_test_assert( result_strtoumax != 0 );
>> > +  result_strtoumax = strtoumax( nptr1_p_errange, &endptr1, base );
>> > +  rtems_test_assert( result_strtoumax == UINTMAX_MAX );
>> > +  result_strtoumax = strtoumax( nptr1_n_errange, &endptr1, base );
>> > +  result_strtoumax = strtoumax( NULL, &endptr1, base );
>> > +  rtems_test_assert( result_strtoumax == 0 );
>> > +  result_strtoumax = strtoumax( nptr1_p, &endptr1, invalid_base );
>> > +  /*Test for wcstoimax  */
>> > +  puts( "\nwcstoimax Testcases...." );
>> > +  result_strtoimax = wcstoimax( nptr2_p, &endptr2, base );
>> > +  rtems_test_assert( endptr2 == ( nptr2_p + 3 ) );
>> > +  result_strtoimax = wcstoimax( nptr2_n, &endptr2, base );
>> This should be like result_strtoimax == -123. ( one space between
>> operator and and value)
I think it does have one space between operator and value?
>> > +  rtems_test_assert( endptr2 == ( nptr2_n + 4 ) );
>> > +  result_strtoimax = wcstoimax( nptr2_p_errange, &endptr2, base );
>> > +  result_strtoimax = wcstoimax( nptr2_n_errange, &endptr2, base );
>> > +  rtems_test_assert( result_strtoimax != 0 );
This looks wrong to me, please double check the spec for wcstoimax
>> > +  result_strtoimax = wcstoimax( NULL, &endptr2, base );
>> > +  result_strtoimax = wcstoimax( nptr2_p, &endptr2, invalid_base );
>> > +  /*Test for wcstoumax  */
>> > +  puts( "\nwcstoumax Testcases...." );
>> > +  result_strtoumax = wcstoumax( nptr2_p, &endptr2, base );
>> > +  rtems_test_assert( result_strtoumax == 123 );
>> > +  result_strtoumax = wcstoumax( nptr2_n, &endptr2, base );
>> > +  result_strtoumax = wcstoumax( nptr2_p_errange, &endptr2, base );
>> > +  result_strtoumax = wcstoumax( nptr2_n_errange, &endptr2, base );
>> > +  result_strtoumax = wcstoumax( NULL, &endptr2, base );
>> > +  result_strtoumax = wcstoumax( nptr2_p, &endptr2, invalid_base );
>> > +  TEST_END();
>> > +  rtems_test_exit(0);
>> > +/* NOTICE: the clock driver is explicitly disabled */
>> > +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
>> > +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> > +#define CONFIGURE_MAXIMUM_TASKS            1
>> > +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> > +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>> > +#include <rtems/confdefs.h>
>> > diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
>> > index 0000000000..b5fd8e6d0e
>> > --- /dev/null
>> > +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
>> > @@ -0,0 +1,70 @@
>> > + * Copyright (C) 2019, Vaibhav Gupta
>> > + * are met:
Thought I already said to get rid of this license block? I don't think
we include this in the .doc files...
>> > +This File describes the concepts tested by this test suite.
>> > +inttypes.h - fixed size integer types
>> > +test suite name: PSXINTTYPE 01
>> > +- Checks for invalid base value
>> > +- Checks for Strtoimax Testcases
>> > +       - checks for output for string having a positive number
>> > +       - checks for output for string having a negative number
>> > +       - checks for output for string having a positive number - Number Out of Range
>> > +       - checks for output for string having a negative number - Number Out of Range
>> > +       - checks for final string pointed by endptr
>> > +       - checks for output for invalid argument - NULL Pointer
>> > +       - checks for output for invalid argument - Invalid Base
>> > +- Checks for Strtoumax Test Cases
>> > +- Checks for Wcstoimax Testcases
>> > +- Checks for Wcstoumax Testcases
>> > diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
>> > index 0000000000..33e82428f1
>> > --- /dev/null
>> > +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
>> > @@ -0,0 +1,44 @@
>> > +*** PSXINTTYPE 01 TEST ***
>> > +strtoimax Testcases....
>> > +Valid Inputs - Positive Number
>> > +Final string pointed by endptr
>> > +Valid Inputs - Negative Number
>> > +Valid Input - Positive Number - Number out of Range
>> > +Valid Input - Negative Number - Number out of Range
>> > +Invalid Input - Send NULL Pointer
>> > +Invalid Input - Invalid base - Use base = 40
>> > +strtoumax Testcases....
>> > +wcstoimax Testcases....
>> > +wcstoumax Testcases....
>> > +*** END OF PSXINTTYPE 01 TEST ***
>> > 2.21.0
>> You can also look into this: http://man7.org/linux/man-pages/man3/strtol.3.html
>> Thanks,
