[PATCH] user: Split the ARM BSPs source into separate files.
chrisj at rtems.org
chrisj at rtems.org
Fri Jun 14 06:42:23 UTC 2019
user/bsps/bsp-altera-cyclone-v.rst | 83 ++++++
user/bsps/bsp-atsam.rst | 8 +
user/bsps/bsp-beagle.rst | 8 +
user/bsps/bsp-csb336.rst | 8 +
user/bsps/bsp-csb337.rst | 8 +
user/bsps/bsp-edb7312.rst | 8 +
user/bsps/bsp-gdbarmsim.rst | 8 +
user/bsps/bsp-gumstix.rst | 8 +
user/bsps/bsp-imx.rst | 149 +++++++++++
user/bsps/bsp-lm3s69xx.rst | 8 +
user/bsps/bsp-lpc176x.rst | 8 +
user/bsps/bsp-lpc24xx.rst | 78 ++++++
user/bsps/bsp-raspberrypi.rst | 8 +
user/bsps/bsp-realview-pbx-a9.rst | 8 +
user/bsps/bsp-rtl22xx.rst | 8 +
user/bsps/bsp-smdk2410.rst | 8 +
user/bsps/bsp-stm32f4.rst | 8 +
user/bsps/bsp-tms570.rst | 8 +
user/bsps/bsp-xilinx-zynq.rst | 8 +
user/bsps/bsps-arm.rst | 402 ++---------------------------
20 files changed, 458 insertions(+), 382 deletions(-)
create mode 100644 user/bsps/bsp-altera-cyclone-v.rst
create mode 100644 user/bsps/bsp-atsam.rst
create mode 100644 user/bsps/bsp-beagle.rst
create mode 100644 user/bsps/bsp-csb336.rst
create mode 100644 user/bsps/bsp-csb337.rst
create mode 100644 user/bsps/bsp-edb7312.rst
create mode 100644 user/bsps/bsp-gdbarmsim.rst
create mode 100644 user/bsps/bsp-gumstix.rst
create mode 100644 user/bsps/bsp-imx.rst
create mode 100644 user/bsps/bsp-lm3s69xx.rst
create mode 100644 user/bsps/bsp-lpc176x.rst
create mode 100644 user/bsps/bsp-lpc24xx.rst
create mode 100644 user/bsps/bsp-raspberrypi.rst
create mode 100644 user/bsps/bsp-realview-pbx-a9.rst
create mode 100644 user/bsps/bsp-rtl22xx.rst
create mode 100644 user/bsps/bsp-smdk2410.rst
create mode 100644 user/bsps/bsp-stm32f4.rst
create mode 100644 user/bsps/bsp-tms570.rst
create mode 100644 user/bsps/bsp-xilinx-zynq.rst
diff --git a/user/bsps/bsp-altera-cyclone-v.rst b/user/bsps/bsp-altera-cyclone-v.rst
new file mode 100644
index 0000000..14c026c
--- /dev/null
+++ b/user/bsps/bsp-altera-cyclone-v.rst
@@ -0,0 +1,83 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2017, 2019 embedded brains GmbH
+.. Copyright (C) 2017, 2019 Sebastian Huber
+altera-cyclone-v (Intel Cyclone V)
+This BSP offers only one variant, the `altcycv_devkit`. This variant supports
+the Intel Cyclone V system on chip. The basic hardware initialization is not
+performed by the BSP. A boot loader with device tree support must be used to
+start the BSP, e.g. U-Boot.
+The BSP is known to run on these boards:
+* `Cyclone V SoC Development Kit <https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/kit-cyclone-v-soc.html>`_
+* `Enclustra Mars MA3 SoC Module <https://www.enclustra.com/en/products/system-on-chip-modules/mars-ma3/>`_
+* `Terasic DE10-Standard Development Kit <https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=1081>`_
+Boot via U-Boot
+The application executable file (ELF file) must be converted to an U-Boot
+image. Use the following commands:
+.. code-block:: none
+ arm-rtems5-objcopy -O binary app.exe app.bin
+ gzip -9 -f -c app.bin > app.bin.gz
+ mkimage -A arm -O linux -T kernel -a 0x00300000 -e 0x00300000 -n RTEMS -d app.bin.gz app.img
+Use the following U-Boot commands to boot an application via TFTP download:
+ tftpboot ${loadaddr} app.img && run loadfdt && bootm ${loadaddr} - ${fdt_addr} ; reset
+The ``loadfdt`` command may be not defined in your U-Boot environment. Just
+replace it with the appropriate commands to load the device tree at
+``${fdt_addr}``.
+Clock Driver
+The clock driver uses the `Cortex-A9 MPCore Global Timer`.
+Console Driver
+The console driver supports up to two on-chip NS16550 UARTs. The console
+driver does not configure the pins.
+I2C Driver
+There is a legacy I2C driver. It should be converted to the I2C driver framework.
+Network Interface Driver
+The network interface driver is provided by the `libbsd`. It is initialized
+according to the device tree. It supports checksum offload.
+MMC/SDCard Driver
+The MMC/SDCard driver is provided by the `libbsd`. It is
+initialized according to the device tree. Pin re-configuration according to
+the serial clock frequency is not supported. DMA transfers are supported.
+USB Host Driver
+The USB host driver is provided by the `libbsd`. It is initialized according
+to the device tree. The driver works in polled mode.
+Caveats
+The clock and pin configuration support is quite rudimentary and mostly relies
+on the boot loader.
diff --git a/user/bsps/bsp-atsam.rst b/user/bsps/bsp-atsam.rst
index 0000000..db65026
--- /dev/null
+++ b/user/bsps/bsp-atsam.rst
@@ -0,0 +1,8 @@
+.. Copyright (C) 2019 TBD
+atsam
+TODO.
diff --git a/user/bsps/bsp-beagle.rst b/user/bsps/bsp-beagle.rst
index 0000000..a36efde
--- /dev/null
+++ b/user/bsps/bsp-beagle.rst
@@ -0,0 +1,8 @@
+beagle
+TODO.
diff --git a/user/bsps/bsp-csb336.rst b/user/bsps/bsp-csb336.rst
index 0000000..7894f45
--- /dev/null
+++ b/user/bsps/bsp-csb336.rst
@@ -0,0 +1,8 @@
+csb336
+TODO.
diff --git a/user/bsps/bsp-csb337.rst b/user/bsps/bsp-csb337.rst
index 0000000..6f7d927
--- /dev/null
+++ b/user/bsps/bsp-csb337.rst
@@ -0,0 +1,8 @@
+csb337
+TODO.
diff --git a/user/bsps/bsp-edb7312.rst b/user/bsps/bsp-edb7312.rst
index 0000000..8d91a34
--- /dev/null
+++ b/user/bsps/bsp-edb7312.rst
@@ -0,0 +1,8 @@
+edb7312
+TODO.
diff --git a/user/bsps/bsp-gdbarmsim.rst b/user/bsps/bsp-gdbarmsim.rst
index 0000000..26ea90c
--- /dev/null
+++ b/user/bsps/bsp-gdbarmsim.rst
@@ -0,0 +1,8 @@
+gdbarmsim
+TODO.
diff --git a/user/bsps/bsp-gumstix.rst b/user/bsps/bsp-gumstix.rst
index 0000000..6ab98ae
--- /dev/null
+++ b/user/bsps/bsp-gumstix.rst
@@ -0,0 +1,8 @@
+gumstix
+TODO.
diff --git a/user/bsps/bsp-imx.rst b/user/bsps/bsp-imx.rst
index 0000000..bc93ae3
--- /dev/null
+++ b/user/bsps/bsp-imx.rst
@@ -0,0 +1,149 @@
+imx (NXP i.MX)
+This BSP offers only one variant, the `imx7`. This variant supports the i.MX
+7Dual processor. The basic hardware initialization is not performed by the
+BSP. A boot loader with device tree support must be used to start the BSP,
+e.g. U-Boot.
+Build Configuration Options
+The following options are available at the configure command line.
+``BSP_PRESS_KEY_FOR_RESET``
+ If defined to a non-zero value, then print a message and wait until pressed
+ before resetting board when application terminates.
+``BSP_RESET_BOARD_AT_EXIT``
+ If defined to a non-zero value, then reset the board when the application
+ terminates.
+``BSP_PRINT_EXCEPTION_CONTEXT``
+ If defined to a non-zero value, then print the exception context when an
+ unexpected exception occurs.
+``BSP_FDT_BLOB_SIZE_MAX``
+ The maximum size of the device tree blob in bytes (default is 262144).
+``CONSOLE_USE_INTERRUPTS``
+ Use interrupt driven mode for console devices (enabled by default).
+``IMX_CCM_IPG_HZ``
+ The IPG clock frequency in Hz (default is 67500000).
+``IMX_CCM_UART_HZ``
+ The UART clock frequency in Hz (default is 24000000).
+``IMX_CCM_AHB_HZ``
+ The AHB clock frequency in Hz (default is 135000000).
+Boot via U-Boot
+ mkimage -A arm -O linux -T kernel -a 0x80200000 -e 0x80200000 -n RTEMS -d app.bin.gz app.img
+``${fdt_addr}``.
+Clock Driver
+The clock driver uses the `ARMv7-AR Generic Timer`.
+Console Driver
+The console driver supports up to seven on-chip UARTs. They are initialized
+according to the device tree. The console driver does not configure the pins.
+I2C Driver
+I2C drivers are registered by the ``i2c_bus_register_imx()`` function. The I2C
+.. code-block:: c
+ #include <assert.h>
+ #include <bsp.h>
+ void i2c_init(void)
+ int rv;
+ rv = i2c_bus_register_imx("/dev/i2c-0", "i2c0");
+ assert(rv == 0);
+SPI Driver
+SPI drivers are registered by the ``spi_bus_register_imx()`` function. The SPI
+driver configures the pins according to the ``pinctrl-0`` device tree property.
+SPI transfers with a continuous chip select are limited by the FIFO size of 64
+bytes. The driver has no DMA support.
+.. code-block:: c
+ #include <bsp.h>
+ void spi_init(void)
+ int rv;
+ rv = spi_bus_register_imx("/dev/spi-0", "spi0");
+ assert(rv == 0);
+according to the device tree. It supports checksum offload and interrupt
+coalescing. IPv6 transmit checksum offload is not implemented. The interrupt
+coalescing uses the MII/GMII clocks and can be controlled by the following
+system controls:
+ * ``dev.ffec.<unit>.int_coal.rx_time``
+ * ``dev.ffec.<unit>.int_coal.rx_count``
+ * ``dev.ffec.<unit>.int_coal.tx_time``
+ * ``dev.ffec.<unit>.int_coal.tx_count``
+A value of zero for the time or count disables the interrupt coalescing in the
+corresponding direction.
+MMC/SDCard Driver
+The MMC/SDCard driver (uSDHC module) is provided by the `libbsd`. It is
+the serial clock frequency is not supported. Data transfers are extremely
+slow. This is probably due to the missing DMA support.
+Caveats
+on the boot loader. For a pin group configuration see
+``imx_iomux_configure_pins()``. There is no power management support.
diff --git a/user/bsps/bsp-lm3s69xx.rst b/user/bsps/bsp-lm3s69xx.rst
index 0000000..15101ba
--- /dev/null
+++ b/user/bsps/bsp-lm3s69xx.rst
@@ -0,0 +1,8 @@
+lm3s69xx
+TODO.
diff --git a/user/bsps/bsp-lpc176x.rst b/user/bsps/bsp-lpc176x.rst
index 0000000..663fe4e
--- /dev/null
+++ b/user/bsps/bsp-lpc176x.rst
@@ -0,0 +1,8 @@
+lpc176x
+TODO.
diff --git a/user/bsps/bsp-lpc24xx.rst b/user/bsps/bsp-lpc24xx.rst
index 0000000..ecf1d84
--- /dev/null
+++ b/user/bsps/bsp-lpc24xx.rst
@@ -0,0 +1,78 @@
+lpc24xx (NXP LPC17XX/LPC24XX/LPC40XX)
+This BSP offers only several variants. The following variants support the
+`Embedded Artits LPC4088 Developer's Kit <https://www.embeddedartists.com/products/lpc4088-developers-kit/>`_
+and earlier board generations:
+* lpc17xx_ea_ram
+* lpc17xx_ea_rom_int
+* lpc24xx_ea
+* lpc40xx_ea_ram
+* lpc40xx_ea_rom_int
+They can be used as a base line for customization. The basic hardware
+initialization is performed by the BSP. It can be customized via configuration
+options and configuration tables. See also
+`<bsp/start-config.h> <https://git.rtems.org/rtems/tree/bsps/arm/lpc24xx/include/bsp/start-config.h>`_.
+Clock Driver
+The clock driver of the Cortex-M variants uses the `ARMv7-M Systick`. The
+older ARM7TDMI variants use the `TMR0` timer module.
+Console Driver
+The console driver supports up to four on-chip UARTs. Initialization can be
+customized via the ``lpc24xx_uart_probe_1()``, ``lpc24xx_uart_probe_2()`` and
+``lpc24xx_uart_probe_3()`` functions.
+I2C Bus Driver
+I2C bus drivers are registered by the ``lpc24xx_register_i2c_0()``,
+``lpc24xx_register_i2c_1()`` and ``lpc24xx_register_i2c_2()`` functions. The
+I2C driver does not configure the pins. See also
+`<bsp/i2c.h> <https://git.rtems.org/rtems/tree/bsps/arm/lpc24xx/include/bsp/i2c.h>`_.
+SPI Bus Driver
+SPI bus drivers are registered by the ``lpc24xx_register_ssp_0()``,
+``lpc24xx_register_ssp_1()`` and ``lpc24xx_register_ssp_2()`` functions. The
+SSP driver does not configure the pins. See also
+`<bsp/ssp.h> <https://git.rtems.org/rtems/tree/bsps/arm/lpc24xx/include/bsp/ssp.h>`_.
+Only a legacy network driver is support. For a `libbsd` base driver the
+platform support is missing, see
+`if_lpe.c <https://git.rtems.org/rtems-libbsd/tree/rtemsbsd/sys/arm/lpc/if_lpe.c>`_.
+USB Driver
+The USB host driver (OHCI) is provided by the `libbsd`.
+Framebuffer Driver
+For a custom framebuffer driver see
+`<bsp/lcd.h> <https://git.rtems.org/rtems/tree/bsps/arm/lpc24xx/include/bsp/lcd.h>`_.
+RTC Driver
+There is a standard RTC driver available using the on-chip RTC module.
diff --git a/user/bsps/bsp-raspberrypi.rst b/user/bsps/bsp-raspberrypi.rst
index 0000000..4ef75bd
--- /dev/null
+++ b/user/bsps/bsp-raspberrypi.rst
@@ -0,0 +1,8 @@
+raspberrypi
+TODO.
diff --git a/user/bsps/bsp-realview-pbx-a9.rst b/user/bsps/bsp-realview-pbx-a9.rst
index 0000000..96710a0
--- /dev/null
+++ b/user/bsps/bsp-realview-pbx-a9.rst
@@ -0,0 +1,8 @@
+realview-pbx-a9
+TODO.
diff --git a/user/bsps/bsp-rtl22xx.rst b/user/bsps/bsp-rtl22xx.rst
index 0000000..74b3235
--- /dev/null
+++ b/user/bsps/bsp-rtl22xx.rst
@@ -0,0 +1,8 @@
+rtl22xx
+TODO.
diff --git a/user/bsps/bsp-smdk2410.rst b/user/bsps/bsp-smdk2410.rst
index 0000000..ef3bbad
--- /dev/null
+++ b/user/bsps/bsp-smdk2410.rst
@@ -0,0 +1,8 @@
+smdk2410
+TODO.
diff --git a/user/bsps/bsp-stm32f4.rst b/user/bsps/bsp-stm32f4.rst
index 0000000..23e764e
--- /dev/null
+++ b/user/bsps/bsp-stm32f4.rst
@@ -0,0 +1,8 @@
+stm32f4
+TODO.
diff --git a/user/bsps/bsp-tms570.rst b/user/bsps/bsp-tms570.rst
index 0000000..593407a
--- /dev/null
+++ b/user/bsps/bsp-tms570.rst
@@ -0,0 +1,8 @@
+tms570
+TODO.
diff --git a/user/bsps/bsp-xilinx-zynq.rst b/user/bsps/bsp-xilinx-zynq.rst
index 0000000..909b23e
--- /dev/null
+++ b/user/bsps/bsp-xilinx-zynq.rst
@@ -0,0 +1,8 @@
+xilinx-zynq
+TODO.
diff --git a/user/bsps/bsps-arm.rst b/user/bsps/bsps-arm.rst
index eb972c6..8e1befd 100644
--- a/user/bsps/bsps-arm.rst
+++ b/user/bsps/bsps-arm.rst
@@ -6,385 +6,23 @@
arm (ARM)
-altera-cyclone-v (Intel Cyclone V)
-This BSP offers only one variant, the `altcycv_devkit`. This variant supports
-the Intel Cyclone V system on chip. The basic hardware initialization is not
-performed by the BSP. A boot loader with device tree support must be used to
-start the BSP, e.g. U-Boot.
-The BSP is known to run on these boards:
-* `Cyclone V SoC Development Kit <https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/kit-cyclone-v-soc.html>`_
-* `Enclustra Mars MA3 SoC Module <https://www.enclustra.com/en/products/system-on-chip-modules/mars-ma3/>`_
-* `Terasic DE10-Standard Development Kit <https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=1081>`_
-Boot via U-Boot
-The application executable file (ELF file) must be converted to an U-Boot
-image. Use the following commands:
-.. code-block:: none
- arm-rtems5-objcopy -O binary app.exe app.bin
- gzip -9 -f -c app.bin > app.bin.gz
- mkimage -A arm -O linux -T kernel -a 0x00300000 -e 0x00300000 -n RTEMS -d app.bin.gz app.img
-Use the following U-Boot commands to boot an application via TFTP download:
- tftpboot ${loadaddr} app.img && run loadfdt && bootm ${loadaddr} - ${fdt_addr} ; reset
-The ``loadfdt`` command may be not defined in your U-Boot environment. Just
-replace it with the appropriate commands to load the device tree at
-``${fdt_addr}``.
-Clock Driver
-The clock driver uses the `Cortex-A9 MPCore Global Timer`.
-Console Driver
-The console driver supports up to two on-chip NS16550 UARTs. The console
-driver does not configure the pins.
-I2C Driver
-There is a legacy I2C driver. It should be converted to the I2C driver framework.
-Network Interface Driver
-The network interface driver is provided by the `libbsd`. It is initialized
-according to the device tree. It supports checksum offload.
-MMC/SDCard Driver
-The MMC/SDCard driver is provided by the `libbsd`. It is
-initialized according to the device tree. Pin re-configuration according to
-the serial clock frequency is not supported. DMA transfers are supported.
-USB Host Driver
-The USB host driver is provided by the `libbsd`. It is initialized according
-to the device tree. The driver works in polled mode.
-Caveats
-The clock and pin configuration support is quite rudimentary and mostly relies
-on the boot loader.
-atsam
-TODO.
-beagle
-TODO.
-csb336
-TODO.
-csb337
-TODO.
-edb7312
-TODO.
-gdbarmsim
-TODO.
-gumstix
-TODO.
-imx (NXP i.MX)
-This BSP offers only one variant, the `imx7`. This variant supports the i.MX
-7Dual processor. The basic hardware initialization is not performed by the
-BSP. A boot loader with device tree support must be used to start the BSP,
-e.g. U-Boot.
-Build Configuration Options
-The following options are available at the configure command line.
-``BSP_PRESS_KEY_FOR_RESET``
- If defined to a non-zero value, then print a message and wait until pressed
- before resetting board when application terminates.
-``BSP_RESET_BOARD_AT_EXIT``
- If defined to a non-zero value, then reset the board when the application
- terminates.
-``BSP_PRINT_EXCEPTION_CONTEXT``
- If defined to a non-zero value, then print the exception context when an
- unexpected exception occurs.
-``BSP_FDT_BLOB_SIZE_MAX``
- The maximum size of the device tree blob in bytes (default is 262144).
-``CONSOLE_USE_INTERRUPTS``
- Use interrupt driven mode for console devices (enabled by default).
-``IMX_CCM_IPG_HZ``
- The IPG clock frequency in Hz (default is 67500000).
-``IMX_CCM_UART_HZ``
- The UART clock frequency in Hz (default is 24000000).
-``IMX_CCM_AHB_HZ``
- The AHB clock frequency in Hz (default is 135000000).
-Boot via U-Boot
- mkimage -A arm -O linux -T kernel -a 0x80200000 -e 0x80200000 -n RTEMS -d app.bin.gz app.img
-``${fdt_addr}``.
-Clock Driver
-The clock driver uses the `ARMv7-AR Generic Timer`.
-Console Driver
-The console driver supports up to seven on-chip UARTs. They are initialized
-according to the device tree. The console driver does not configure the pins.
-I2C Driver
-I2C drivers are registered by the ``i2c_bus_register_imx()`` function. The I2C
-.. code-block:: c
- #include <assert.h>
- #include <bsp.h>
- void i2c_init(void)
- int rv;
- rv = i2c_bus_register_imx("/dev/i2c-0", "i2c0");
- assert(rv == 0);
-SPI Driver
-SPI drivers are registered by the ``spi_bus_register_imx()`` function. The SPI
-driver configures the pins according to the ``pinctrl-0`` device tree property.
-SPI transfers with a continuous chip select are limited by the FIFO size of 64
-bytes. The driver has no DMA support.
-.. code-block:: c
- #include <bsp.h>
- void spi_init(void)
- int rv;
- rv = spi_bus_register_imx("/dev/spi-0", "spi0");
- assert(rv == 0);
-according to the device tree. It supports checksum offload and interrupt
-coalescing. IPv6 transmit checksum offload is not implemented. The interrupt
-coalescing uses the MII/GMII clocks and can be controlled by the following
-system controls:
- * ``dev.ffec.<unit>.int_coal.rx_time``
- * ``dev.ffec.<unit>.int_coal.rx_count``
- * ``dev.ffec.<unit>.int_coal.tx_time``
- * ``dev.ffec.<unit>.int_coal.tx_count``
-A value of zero for the time or count disables the interrupt coalescing in the
-corresponding direction.
-MMC/SDCard Driver
-The MMC/SDCard driver (uSDHC module) is provided by the `libbsd`. It is
-the serial clock frequency is not supported. Data transfers are extremely
-slow. This is probably due to the missing DMA support.
-Caveats
-on the boot loader. For a pin group configuration see
-``imx_iomux_configure_pins()``. There is no power management support.
-lm3s69xx
-TODO.
-lpc176x
-TODO.
-lpc24xx (NXP LPC17XX/LPC24XX/LPC40XX)
-This BSP offers only several variants. The following variants support the
-`Embedded Artits LPC4088 Developer's Kit <https://www.embeddedartists.com/products/lpc4088-developers-kit/>`_
-and earlier board generations:
-* lpc17xx_ea_ram
-* lpc17xx_ea_rom_int
-* lpc24xx_ea
-* lpc40xx_ea_ram
-* lpc40xx_ea_rom_int
-They can be used as a base line for customization. The basic hardware
-initialization is performed by the BSP. It can be customized via configuration
-options and configuration tables. See also
-`<bsp/start-config.h> <https://git.rtems.org/rtems/tree/bsps/arm/lpc24xx/include/bsp/start-config.h>`_.
-Clock Driver
-The clock driver of the Cortex-M variants uses the `ARMv7-M Systick`. The
-older ARM7TDMI variants use the `TMR0` timer module.
-Console Driver
-The console driver supports up to four on-chip UARTs. Initialization can be
-customized via the ``lpc24xx_uart_probe_1()``, ``lpc24xx_uart_probe_2()`` and
-``lpc24xx_uart_probe_3()`` functions.
-I2C Bus Driver
-I2C bus drivers are registered by the ``lpc24xx_register_i2c_0()``,
-``lpc24xx_register_i2c_1()`` and ``lpc24xx_register_i2c_2()`` functions. The
-I2C driver does not configure the pins. See also
-`<bsp/i2c.h> <https://git.rtems.org/rtems/tree/bsps/arm/lpc24xx/include/bsp/i2c.h>`_.
-SPI Bus Driver
-SPI bus drivers are registered by the ``lpc24xx_register_ssp_0()``,
-``lpc24xx_register_ssp_1()`` and ``lpc24xx_register_ssp_2()`` functions. The
-SSP driver does not configure the pins. See also
-`<bsp/ssp.h> <https://git.rtems.org/rtems/tree/bsps/arm/lpc24xx/include/bsp/ssp.h>`_.
-Only a legacy network driver is support. For a `libbsd` base driver the
-platform support is missing, see
-`if_lpe.c <https://git.rtems.org/rtems-libbsd/tree/rtemsbsd/sys/arm/lpc/if_lpe.c>`_.
-USB Driver
-The USB host driver (OHCI) is provided by the `libbsd`.
-Framebuffer Driver
-For a custom framebuffer driver see
-`<bsp/lcd.h> <https://git.rtems.org/rtems/tree/bsps/arm/lpc24xx/include/bsp/lcd.h>`_.
-RTC Driver
-There is a standard RTC driver available using the on-chip RTC module.
-lpc32xx
-TODO.
-raspberrypi
-TODO.
-realview-pbx-a9
-TODO.
-rtl22xx
-TODO.
-smdk2410
-TODO.
-stm32f4
-TODO.
-tms570
-TODO.
-xilinx-zynq
-TODO.
+.. include:: bsp-altera-cyclone-v.rst
+.. include:: bsp-atsam.rst
+.. include:: bsp-beagle.rst
+.. include:: bsp-csb336.rst
+.. include:: bsp-csb337.rst
+.. include:: bsp-edb7312.rst
+.. include:: bsp-gdbarmsim.rst
+.. include:: bsp-gumstix.rst
+.. include:: bsp-imx.rst
+.. include:: bsp-lm3s69xx.rst
+.. include:: bsp-lpc176x.rst
+.. include:: bsp-lpc32xx.rst
+.. include:: bsp-raspberrypi.rst
+.. include:: bsp-realview-pbx-a9.rst
+.. include:: bsp-rtl22xx.rst
+.. include:: bsp-smdk2410.rst
+.. include:: bsp-stm32f4.rst
+.. include:: bsp-tms570.rst
+.. include:: bsp-xilinx-zynq.rst
2.19.1
