Fwd: FYI about top-level config change
Joel Sherrill
joel at rtems.org
Fri Jun 14 18:31:56 UTC 2019
Hi
Others probably saw this but it looks like the kind of change which might
break builds so I thought I would forward it.
--joel
---------- Forwarded message ---------
Date: Fri, Jun 14, 2019, 2:26 PM
Subject: FYI about top-level config change
To: Binutils Development <binutils at sourceware.org>
Hi. I thought I'd send a note about an upcoming top-level build change
we're making for gdb.
I'm going to check in a patch to move gdb/gnulib to the top level.
If you configure with --disable-gdb, this should not affect you.
If you build with gdb enabled, you may want to do a clean build.
The patch is here:
https://sourceware.org/ml/gdb-patches/2019-06/msg00245.html
This move is part of an ongoing effort to eventually move gdbserver to
the top-level, so that it will no longer need its own unusual build
system. This will speed up gdb builds by a bit as well. Some info on
this is here:
https://sourceware.org/ml/gdb-patches/2019-05/msg00735.html
I'll be sending the top-level patches to gcc-patches as well.
Tom
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190614/bcf1f213/attachment.html>
