[RSB PATCH 1/2] Add bare target to build standalone sis (devel/sis)
Jiri Gaisler jiri at gaisler.se
Fri Jun 14 22:00:56 UTC 2019
 bare/config/devel/sis-2-1.cfg     | 18 +++++++++
 bare/config/devel/sis.bset        |  8 ++++
 source-builder/config/sis-2-1.cfg | 66 +++++++++++++++++++++++++++++++
 3 files changed, 92 insertions(+)
 create mode 100644 bare/config/devel/sis-2-1.cfg
 create mode 100644 bare/config/devel/sis.bset
 create mode 100644 source-builder/config/sis-2-1.cfg
diff --git a/bare/config/devel/sis-2-1.cfg b/bare/config/devel/sis-2-1.cfg
new file mode 100644
index 0000000..ad6e527
--- /dev/null
+++ b/bare/config/devel/sis-2-1.cfg
@@ -0,0 +1,18 @@
+# Sis emulator 2.16
+%if %{release} == %{nil}
+%define release 1
+%endif
+%include %{_configdir}/base.cfg
+%define sis_version 2.16
+%hash sha256 sis-%{sis_version}.tar.bz2 37cdb8f5cc1255e273423f580f5c76755e5851dabb677f6bc1100f27557b8dce
+# The sis build instructions. We use 2.15
+%include %{_configdir}/sis-2-1.cfg
diff --git a/bare/config/devel/sis.bset b/bare/config/devel/sis.bset
index 0000000..50ffbae
--- /dev/null
+++ b/bare/config/devel/sis.bset
@@ -0,0 +1,8 @@
+# Build set for sis emulator
+%define release 1
+devel/sis-2-1
diff --git a/source-builder/config/sis-2-1.cfg b/source-builder/config/sis-2-1.cfg
index 0000000..a07b2db
--- /dev/null
+++ b/source-builder/config/sis-2-1.cfg
@@ -0,0 +1,66 @@
+# Sis 2.xx Version 1.
+# This configuration file configure's, make's and install's sis
+Name:      sis-%{sis_version}-%{_host}-%{release}
+Summary:   Sis v%{sis_version} for host %{_host}
+Version:   %{sis_version}
+Release:   %{release}
+#URL: 	   http://www.gnu.org/software/sis/
+# Source
+%define sis_source sis-%{sis_version}
+%source set sis https://git.rtems.org/sis/snapshot/%{sis_source}.tar.bz2
+# Prepare the source code.
+%prep
+  build_top=$(pwd)
+  %source setup sis -q -n sis-%{sis_version}
+  cd ${build_top}
+%build
+  build_top=$(pwd)
+  cd sis-%{sis_version}
+  ac_prefix=%{_prefix}
+  if test "%{_build}" != "%{_host}" ; then
+    CFLAGS_FOR_BUILD="-g -O2 -Wall"
+  fi
+  export CFLAGS CFLAGS_FOR_BUILD CC
+  if test "%{_target}" != "" ; then
+    SIS_PREFIX="%{_target}-"
+  fi
+  CFLAGS="$SB_CFLAGS" \
+  ./configure \
+    --build=%{_build} --host=%{_host} \
+    --program-prefix="$SIS_PREFIX" \
+    --prefix=${ac_prefix}
+  %{__make} %{?_smp_mflags} all
+  unset CFLAGS_FOR_BUILD
+  cd ${build_top}
+%install
+  build_top=$(pwd)
+  export PATH="%{_bindir}:${PATH}"
+  %{__rmdir} $SB_BUILD_ROOT
+  %{__make} DESTDIR=$SB_BUILD_ROOT install
+  cd ${build_top}
2.17.1
