[PATCH v2] Comment added
Ravindra Meena rmeena840 at gmail.com
Sun Jun 16 18:13:59 UTC 2019
 misc/CTF/record-ctf.ref | 55 +++++++++++++++++++++++++++++++++----------------
 1 file changed, 37 insertions(+), 18 deletions(-)
diff --git a/misc/CTF/record-ctf.ref b/misc/CTF/record-ctf.ref
index a27757c..bdb9648 100644
--- a/misc/CTF/record-ctf.ref
+++ b/misc/CTF/record-ctf.ref
@@ -1,5 +1,13 @@
 /* CTF 1.8 */
+ * typealias
+ * The "typealias" declaration can be used to give a name to a type.
+ * Typealias is a superset of "typedef": it also allows assignment of a
+ * simple variable identifier to a type.
 typealias integer { size = 8; align = 8; signed = false; } := uint8_t;
 typealias integer { size = 16; align = 8; signed = false; } := uint16_t;
 typealias integer { size = 32; align = 8; signed = false; } := uint32_t;
@@ -8,47 +16,58 @@ typealias integer { size = 5; align = 1; signed = false; } := uint5_t;
 typealias integer { size = 27; align = 1; signed = false; } := uint27_t;
 trace {
-    major = 1;
-    minor = 8;
-    byte_order = le;
+    major = 1; /* CTF spec version major number */
+    minor = 8; /* CTF spec version minor number */
+    byte_order = le; /* little endian byte-order */
     packet.header := struct {
-        uint32_t magic;
-        uint32_t stream_id;
+        uint32_t magic; /* specifies that this is a CTF packet */
+        uint32_t stream_id; /* used as reference to stream description in metadata */
 clock {
-    name = ctf_clock;
-    freq = 1000;
-    offset_s = 1421703448;
+    name = ctf_clock; /* name of montonic clock */
+    freq = 1000; /* frequency, in HZ */
+    offset_s = 1421703448;
+ *  A reference to the clock added within an integer type
 typealias integer {
     size = 64;
     map = clock.ctf_clock.value;
 } := ctf_clock_int_t;
+ * Trace stream packet having header and context.
+ * @param event.header includes id(unique identifier of stream) and timestamp.
+ * @param packet.context includes clock timestamp, cpu id, event and event data.
 stream {
     id = 0;
+    event.header := struct {
+        uint32_t id;
+        ctf_clock_int_t timestamp;
     packet.context := struct {
 		uint32_t cpu;
 		uint32_t event;
 		uint64_t data;
-    event.header := struct {
-        uint32_t id;
-        ctf_clock_int_t timestamp;
 event {
-    id = 0;
-    name = "ctf_event";
-    stream_id = 0;
+    id = 0; /* event id
+    name = "ctf_event"; /* event name */
+    stream_id = 0; /* signifies stream id which event is supposed to concat with events */
     fields := struct {
-        uint32_t a;
-        uint16_t b;
-        string c;
+        uint32_t a; /*event 1*/
+        uint16_t b; /*event 2*/
+        string c; /*event 3*/
2.7.4
