[PATCH v2] Comment added
Sun Jun 16 23:57:51 UTC 2019
On 17/6/19 4:13 am, Ravindra Meena wrote:
>  misc/CTF/record-ctf.ref | 55 +++++++++++++++++++++++++++++++++----------------
We should avoid uppercase or mix case in file names unless they are existing or
in imported code. We have some hosts that are case insensitive and our
experience over the years is this can cause problems. :)
Is this file for the rtems-tools repo? If it is not please ignore the following.
I wonder if there should be a top level trace directory to gather all the trace
pieces in one place. I think trace is important enough to have this status. So
this file could be ...
 trace/config/ctf/record-ctf.ref
or
 trace/config/record-ctf.ref
? This is only an example as I am not really sure what role this file plays.
Notes:
1) I have found in other parts of rtems-tools.git having the config directory of
files separated from the other sources makes installing into the shared tree
simpler.
2) The tools currently in rtems-tools.git can be run with the same command line
options from a built repo with an absolute path or when installed under a
prefix. This is something to consider when referencing configuration files.
Thanks
