[PATCH v2] Comment added
Tue Jun 18 05:54:49 UTC 2019
On 17/06/2019 13:36, Sebastian Huber wrote:
>>      > +    offset_s = 1421703448;
>>     What is this for an offset?
>> This offset is a difference between the beginning of clock and the
>> actual start of the clock. The event will be recorded just after the
>> offset.
> Sorry, I don't know what this means. What is the beginning of the clock
> and what is the actual start?
 From the CTF specification we have:
"The offset_s and offset fields indicate the offset from POSIX.1 Epoch,
1970-01-01 00:00:00 +0000 (UTC), to the zero of value of the clock. The
offset_s field is in seconds. The offset field is in (1/freq) units."
https://diamon.org/ctf/#spec8
The CLOCK_MONOTONIC in RTEMS is based on the boot time. So, if you want
to give an offset value you have to figure out the CLOCK_REALTIME value
at boot time of the system. This is currently a secondary problem. I
would just omit the offset for now.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
