[PATCH] CTF few event added
Ravindra Meena
rmeena840 at gmail.com
Wed Jun 19 13:02:26 UTC 2019
misc/CTF/record-ctf.ref | 73 ------------------------
misc/ctf/metadata | 145 ++++++++++++++++++++++++++++++++++++++++++++++++
2 files changed, 145 insertions(+), 73 deletions(-)
delete mode 100644 misc/CTF/record-ctf.ref
create mode 100644 misc/ctf/metadata
diff --git a/misc/CTF/record-ctf.ref b/misc/CTF/record-ctf.ref
deleted file mode 100644
index bdb9648..0000000
--- a/misc/CTF/record-ctf.ref
+++ /dev/null
@@ -1,73 +0,0 @@
-/* CTF 1.8 */
- * typealias
- * The "typealias" declaration can be used to give a name to a type.
- * Typealias is a superset of "typedef": it also allows assignment of a
- * simple variable identifier to a type.
-typealias integer { size = 8; align = 8; signed = false; } := uint8_t;
-typealias integer { size = 16; align = 8; signed = false; } := uint16_t;
-typealias integer { size = 32; align = 8; signed = false; } := uint32_t;
-typealias integer { size = 64; align = 8; signed = false; } := uint64_t;
-typealias integer { size = 5; align = 1; signed = false; } := uint5_t;
-typealias integer { size = 27; align = 1; signed = false; } := uint27_t;
-trace {
- major = 1; /* CTF spec version major number */
- minor = 8; /* CTF spec version minor number */
- byte_order = le; /* little endian byte-order */
- packet.header := struct {
- uint32_t magic; /* specifies that this is a CTF packet */
- uint32_t stream_id; /* used as reference to stream description in metadata */
-clock {
- name = ctf_clock; /* name of montonic clock */
- freq = 1000; /* frequency, in HZ */
- offset_s = 1421703448;
- * A reference to the clock added within an integer type
- size = 64;
- map = clock.ctf_clock.value;
-} := ctf_clock_int_t;
- * Trace stream packet having header and context.
- * @param event.header includes id(unique identifier of stream) and timestamp.
- * @param packet.context includes clock timestamp, cpu id, event and event data.
-stream {
- id = 0;
- event.header := struct {
- uint32_t id;
- ctf_clock_int_t timestamp;
- packet.context := struct {
- uint32_t cpu;
- uint32_t event;
- uint64_t data;
-event {
- id = 0; /* event id
- name = "ctf_event"; /* event name */
- stream_id = 0; /* signifies stream id which event is supposed to concat with events */
- fields := struct {
- uint32_t a; /*event 1*/
- uint16_t b; /*event 2*/
- string c; /*event 3*/
diff --git a/misc/ctf/metadata b/misc/ctf/metadata
new file mode 100644
index 0000000..0e7dca4
--- /dev/null
+++ b/misc/ctf/metadata
@@ -0,0 +1,145 @@
+/* CTF 1.8 */
+ * typealias
+ * The "typealias" declaration can be used to give a name to a type.
+ * Typealias is a superset of "typedef": it also allows assignment of a
+ * simple variable identifier to a type.
+typealias integer { size = 8; align = 8; signed = false; } := uint8_t;
+typealias integer { size = 16; align = 8; signed = false; } := uint16_t;
+typealias integer { size = 32; align = 8; signed = false; } := uint32_t;
+typealias integer { size = 64; align = 8; signed = false; } := uint64_t;
+typealias integer { size = 5; align = 1; signed = false; } := uint5_t;
+typealias integer { size = 27; align = 1; signed = false; } := uint27_t;
+trace {
+ major = 1; /* CTF spec version major number */
+ minor = 8; /* CTF spec version minor number */
+ byte_order = le; /* little endian byte-order */
+ packet.header := struct {
+ uint32_t magic; /* specifies that this is a CTF packet */
+ uint8_t uuid[16]; /* Unique Universal Identifier, ensure the event
+ packet match the metadata used */
+ uint32_t stream_id; /* used as reference to stream description in
+ metadata */
+clock {
+ name = "monotonic"; /* name of montonic clock */
+ description = "Monotonic Clock";
+ freq = 1000; /* frequency, in HZ */
+ * A reference to the clock added within an unsigned integer type
+ size = 64; align = 8; signed = false;
+ map = clock.monotonic.value;
+} := uint64_clock_monotonic_t;
+ size = 32; align = 8; signed = false;
+} := uint32_clock_monotonic_t;
+ size = 27; align = 1; signed = false;
+} := uint27_clock_monotonic_t;
+ * packet.context containing timestamp, cpu, event, data;
+struct packet_context {
+ uint64_clock_monotonic_t timestamp;
+ uint32_t cpu;
+ uint32_t event;
+ uint64_t data;
+ * event.header type for few event IDS
+struct event_header_compact {
+ enum : uint5_t { compact = 0 ... 30, extended = 31 } id;
+ variant <id> {
+ struct {
+ uint27_clock_monotonic_t timestamp;
+ } compact;
+ struct {
+ uint32_t id;
+ } extended;
+ } v;
+} align(8);
+ * event.header type for many event IDS
+struct event_header_large {
+ enum : uint16_t { compact = 0 ... 65534, extended = 65535 } id;
+ variant <id> {
+ struct {
+ uint32_clock_monotonic_t timestamp;
+ } compact;
+ struct {
+ uint32_t id;
+ } extended;
+ } v;
+} align(8);
+ * stream containing header and context.
+stream {
+ id = 0;
+ event.header := struct event_header_compact; /* sturct defined above */
+ packet.context := struct packet_context; /* sturct defined above */
+ * event recording events
+event {
+ name = "EMPTY";
+ id = 0;
+ stream_id = 0;
+ fields := struct {
+ integer {
+ size = 32;
+ align = 8;
+ signed = false;
+ byte_order = le;
+ base = 10;
+ encoding = none;
+ } my_field;
+event {
+ name = "VERSION";
+ id = 1;
+ stream_id = 0;
+ integer {
+ size = 32;
+ align = 8;
+ signed = false;
+ byte_order = le;
+ base = 10;
+ encoding = none;
+ } my_field;
2.7.4
