[PATCH] Write event stream in file
Ravindra Meena rmeena840 at gmail.com
Thu Jun 20 12:17:40 UTC 2019
 misc/record/record-main.c | 27 +++++++++++++++++++++++++++
 1 file changed, 27 insertions(+)
diff --git a/misc/record/record-main.c b/misc/record/record-main.c
index 742428b..eccf291 100644
--- a/misc/record/record-main.c
+++ b/misc/record/record-main.c
@@ -67,6 +67,13 @@ typedef struct client_item {
   uint64_t                     counter;
 } client_item;
+typedef struct ctf_event {
+  uint64_t                     ns;
+  uint32_t                     cpu;
+  rtems_record_event           event;
+  uint64_t                     data;
+} ctf_event;
 typedef struct client_context {
   uint64_t                       ns_threshold;
   uint64_t                       last_ns;
@@ -135,12 +142,16 @@ static int connect_client( const char *host, uint16_t port )
 static void print_item( FILE *f, const client_item *item )
+  ctf_event *ctf_item;
+  uint32_t ns;
   if ( item->ns != 0 ) {
     uint32_t seconds;
     uint32_t nanoseconds;
     seconds = (uint32_t) ( item->ns / 1000000000 );
     nanoseconds = (uint32_t) ( item->ns % 1000000000 );
+    ns=nanoseconds;
     fprintf( f, "%" PRIu32 ".%09" PRIu32 ":", seconds, nanoseconds );
   } else {
     fprintf( f, "*:" );
@@ -153,6 +164,22 @@ static void print_item( FILE *f, const client_item *item )
     rtems_record_event_text( item->event ),
     item->data
+  FILE *fptr = fopen("event", "a");
+  if (fptr == NULL)
+       printf("Could not open file");
+       return 0;
+  ctf_item->cpu=item->cpu;
+  ctf_item->event=item->event;
+  ctf_item->data=item->data;
+  ctf_item->ns=ns;
+  fprintf(fptr,ctf_item);
+  fclose(fptr);
 static void flush_items( client_context *cctx )
2.7.4
