Fwd: Build Linux: FAILED 6/rtems-sparc.bset on x86_64-linux-gnu (sparc-rtems6-gdb-6f5601c4d0-x86_64-linux-gnu-1)
Joel Sherrill
joel at rtems.org
Thu Jun 20 12:45:31 UTC 2019
Hi
It looks like gdb is now using something that the gcc shipped with CentOS 7
doesn't like. I reported this to the gdb community.
--joel
---------- Forwarded message ---------
Date: Wed, Jun 19, 2019 at 11:48 PM
Subject: Build Linux: FAILED 6/rtems-sparc.bset on x86_64-linux-gnu
To: <build at rtems.org>
RTEMS Source Builder - Set Builder, 5 (e8f182037b69)
Host: Linux-3.10.0-862.11.6.el7.x86_64-x86_64-with-centos-7.6.1810-Core
Linux rtbf64c.rtems.com 3.10.0-862.11.6.el7.x86_64 #1 SMP Tue Aug 14
21:49:04 UTC 2018 x86_64 x86_64
Build Time: 0:31:29.769000
Build FAILED: sparc-rtems6-gdb-6f5601c4d0-x86_64-linux-gnu-1
from
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/dwarf-index-write.h:24,
from
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/dwarf-index-cache.c:28:
/usr/include/c++/4.8.2/bits/hashtable_policy.h:1070:12: error: invalid use
of incomplete type 'struct std::hash<sect_offset>'
struct _Hash_code_base<_Key, _Value, _ExtractKey, _H1, _H2,
In file included from /usr/include/c++/4.8.2/bits/basic_string.h:3033:0,
from /usr/include/c++/4.8.2/string:52,
from
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/common/common-utils.h:23,
from
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/common/common-defs.h:122,
from
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/defs.h:28,
from
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/dwarf-index-cache.c:20:
/usr/include/c++/4.8.2/bits/functional_hash.h:58:12: error: declaration of
struct hash;
In file included from /usr/include/c++/4.8.2/bits/hashtable.h:35:0,
from /usr/include/c++/4.8.2/unordered_map:47,
from
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/dwarf2read.h:23,
from
from
/usr/include/c++/4.8.2/bits/hashtable_policy.h:1082:53: error: invalid use
using __ebo_h1 = _Hashtable_ebo_helper<1, _H1>;
from
from
from
from
struct hash;
from
from
from
from
from
from
from
struct hash;
CXX dwarf2read.o
CXX elfread.o
from
from
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/dwarf-index-write.c:32:
/usr/include/c++/4.8.2/bits/hashtable_policy.h: In instantiation of 'struct
std::__detail::_Hash_code_base<sect_offset, std::pair<const sect_offset,
std::vector<sect_offset> >, std::__detail::_Select1st,
std::hash<sect_offset>, std::__detail::_Mod_range_hashing,
std::__detail::_Default_ranged_hash, true>':
/usr/include/c++/4.8.2/bits/hashtable_policy.h:1402:10: required from
'struct std::__detail::_Hashtable_base<sect_offset, std::pair<const
sect_offset, std::vector<sect_offset> >, std::__detail::_Select1st,
std::equal_to<sect_offset>, std::hash<sect_offset>,
std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash,
std::__detail::_Hashtable_traits<true, false, true> >'
/usr/include/c++/4.8.2/bits/hashtable.h:174:11: required from 'class
std::_Hashtable<sect_offset, std::pair<const sect_offset,
std::vector<sect_offset> >, std::allocator<std::pair<const sect_offset,
std::vector<sect_offset> > >, std::__detail::_Select1st,
std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true,
false, true> >'
/usr/include/c++/4.8.2/bits/unordered_map.h:100:18: required from 'class
std::unordered_map<sect_offset, std::vector<sect_offset> >'
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/dwarf2read.h:260:5:
required from here
from
from
from
from
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/dwarf-index-write.c:20:
struct hash;
from
from
from
from
from
from
struct hash;
from
from
from
from
from
from
struct hash;
from
from
from
from
from
from
struct hash;
make[2]: *** [dwarf-index-cache.o] Error 1
make[2]: *** Waiting for unfinished jobs....
from
from
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/dwarf2-frame.c:38:
false, true> >'
required from here
from
from
from
from
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/dwarf2-frame.c:22:
struct hash;
from
from
from
from
from
from
struct hash;
from
from
from
from
from
from
struct hash;
from
from
from
from
from
from
struct hash;
from
from
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/dwarf2read.c:32:
false, true> >'
required from here
from
from
from
from
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/dwarf2read.c:31:
struct hash;
from
from
from
from
from
from
struct hash;
from
from
from
from
from
from
struct hash;
from
from
from
from
from
from
struct hash;
make[2]: *** [dwarf2-frame.o] Error 1
from
from
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/dwarf2loc.c:39:
false, true> >'
required from here
from
from
from
from
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/dwarf2loc.c:22:
struct hash;
from
from
from
from
from
from
struct hash;
from
from
from
from
from
from
struct hash;
from
from
from
from
from
from
struct hash;
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/dwarf2read.c: In
constructor 'std::unordered_map<_Key, _Tp, _Hash, _Pred,
_Alloc>::unordered_map(std::unordered_map<_Key, _Tp, _Hash, _Pred,
_Alloc>::size_type, const hasher&, const key_equal&, const allocator_type&)
[with _Key = sect_offset; _Tp = std::vector<sect_offset>; _Hash =
std::hash<sect_offset>; _Pred = std::equal_to<sect_offset>; _Alloc =
std::allocator<std::pair<const sect_offset, std::vector<sect_offset> > >;
std::unordered_map<_Key, _Tp, _Hash, _Pred, _Alloc>::size_type = long
unsigned int; std::unordered_map<_Key, _Tp, _Hash, _Pred, _Alloc>::hasher =
std::hash<sect_offset>; std::unordered_map<_Key, _Tp, _Hash, _Pred,
_Alloc>::key_equal = std::equal_to<sect_offset>; std::unordered_map<_Key,
_Tp, _Hash, _Pred, _Alloc>::allocator_type = std::allocator<std::pair<const
sect_offset, std::vector<sect_offset> > >]':
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/dwarf2read.c:2139:22:
error: invalid use of incomplete type 'std::unordered_map<sect_offset,
std::vector<sect_offset> >::hasher {aka struct std::hash<sect_offset>}'
: objfile (objfile_)
from
from
from
from
'std::unordered_map<sect_offset, std::vector<sect_offset> >::hasher {aka
struct hash;
note: when instantiating default argument for call to
make[2]: *** [dwarf-index-write.o] Error 1
make[2]: *** [dwarf2loc.o] Error 1
from
from
'std::__detail::_Hash_code_base<_Key, _Value, _ExtractKey, _H1, _H2,
std::__detail::_Default_ranged_hash, true>::__hash_code
std::__detail::_Default_ranged_hash, true>::_M_hash_code(const _Key&) const
[with _Key = sect_offset; _Value = std::pair<const sect_offset,
std::vector<sect_offset> >; _ExtractKey = std::__detail::_Select1st; _H1 =
std::hash<sect_offset>; _H2 = std::__detail::_Mod_range_hashing;
std::__detail::_Default_ranged_hash, true>::__hash_code = long unsigned
int]':
/usr/include/c++/4.8.2/bits/hashtable_policy.h:487:49: required from
'std::__detail::_Map_base<_Key, _Pair, _Alloc, std::__detail::_Select1st,
_Equal, _H1, _H2, _Hash, _RehashPolicy, _Traits, true>::mapped_type&
_Equal, _H1, _H2, _Hash, _RehashPolicy, _Traits, true>::operator[](const
key_type&) [with _Key = sect_offset; _Pair = std::pair<const sect_offset,
std::vector<sect_offset> >; _Alloc = std::allocator<std::pair<const
sect_offset, std::vector<sect_offset> > >; _Equal =
std::equal_to<sect_offset>; _H1 = std::hash<sect_offset>; _H2 =
std::__detail::_Mod_range_hashing; _Hash =
std::__detail::_Default_ranged_hash; _RehashPolicy =
std::__detail::_Prime_rehash_policy; _Traits =
std::__detail::_Hashtable_traits<true, false, true>;
_Equal, _H1, _H2, _Hash, _RehashPolicy, _Traits, true>::mapped_type =
std::vector<sect_offset>; std::__detail::
_Map_base<_Key, _Pair, _Alloc, std::__detail::_Select1st, _Equal, _H1,
_H2, _Hash, _RehashPolicy, _Traits, true>::key_type = sect_offset]'
/usr/include/c++/4.8.2/bits/unordered_map.h:596:20: required from
'std::unordered_map<_Key, _Tp, _Hash, _Pred, _Alloc>::mapped_type&
std::unordered_map<_Key, _Tp, _Hash, _Pred, _Alloc>::operator[](const
key_type&) [with _Key = sect_offset; _Tp = std::vector<sect_offset>; _Hash
= std::hash<sect_offset>; _Pred = std::equal_to<sect_offset>; _Alloc =
std::unordered_map<_Key, _Tp, _Hash, _Pred, _Alloc>::mapped_type =
std::vector<sect_offset>; std::unordered_map<_Key, _Tp, _Hash, _Pred,
_Alloc>::key_type = sect_offset]'
../../sourceware-mirror-binutils-gdb-6f5601c4d0/gdb/dwarf2read.c:14291:53:
required from here
/usr/include/c++/4.8.2/bits/hashtable_policy.h:1103:22: error: no match for
call to '(const std::hash<sect_offset>) (const sect_offset&)'
{ return _M_h1()(__k); }
std::__detail::_Default_ranged_hash, true>::_Hash_code_base(const
_ExtractKey&, const _H1&, const _H2&, const
std::__detail::_Default_ranged_hash&) [with _Key = sect_offset; _Value =
std::pair<const sect_offset, std::vector<sect_offset> >; _ExtractKey =
std::__detail::_Select1st; _H1 = std::hash<sect_offset>; _H2 =
std::__detail::_Mod_range_hashing]':
/usr/include/c++/4.8.2/bits/hashtable_policy.h:1463:65: required from
'std::__detail::_Hashtable_base<_Key, _Value, _ExtractKey, _Equal, _H1,
_H2, _Hash, _Traits>::_Hashtable_base(const _ExtractKey&, const _H1&, const
_H2&, const _Hash&, const _Equal&) [with _Key = sect_offset; _Value =
std::__detail::_Select1st; _Equal = std::equal_to<sect_offset>; _H1 =
std::hash<sect_offset>; _H2 = std::__detail::_Mod_range_hashing; _Hash =
std::__detail::_Default_ranged_hash; _Traits =
std::__detail::_Hashtable_traits<true, false, true>]'
/usr/include/c++/4.8.2/bits/hashtable.h:828:24: required from
'std::_Hashtable<_Key, _Value, _Alloc, _ExtractKey, _Equal, _H1, _H2,
_Hash, _RehashPolicy, _Traits>::_Hashtable(std::_Hashtable<_Key, _Value,
_Alloc, _ExtractKey, _Equal, _H1, _H2, _Hash, _RehashPolicy,
_Traits>::size_type, const _H1&, const _H2&, const _Hash&, const _Equal&,
const _ExtractKey&, const allocator_type&) [with _Key = sect_offset; _Value
= std::pair<const sect_offset, std::vector<sect_offset> >; _Alloc =
_ExtractKey = std::__detail::_Select1st; _Equal =
std::__detail::_Hashtable_traits<true, false, true>; std::_Hashtable<_Key,
_Value, _Alloc, _ExtractKey, _Equal, _H1, _H2, _Hash, _RehashPolicy,
_Traits>::size_type = long unsigned i
nt; std::_Hashtable<_Key, _Value, _Alloc, _ExtractKey, _Equal, _H1, _H2,
_Hash, _RehashPolicy, _Traits>::allocator_type =
std::allocator<std::pair<const sect_offset, std::vector<sect_offset> > >]'
/usr/include/c++/4.8.2/bits/hashtable.h:397:26: required from
_Traits>::size_type, const _H1&, const key_equal&, const allocator_type&)
sect_offset, std::vector<sect_offset> > >; _ExtractKey =
_Traits>::size_type = long unsigned int; std::_Hashtable<_Key, _Value,
_Alloc, _
ExtractKey, _Equal, _H1, _H2, _Hash, _RehashPolicy, _Traits>::key_equal =
std::equal_to<sect_offset>; std::_Hashtable<_Key, _Value, _Alloc,
_Traits>::allocator_type = std::allocator<std::pair<const sect_offset,
/usr/include/c++/4.8.2/bits/unordered_map.h:142:35: required from
required from here
/usr/include/c++/4.8.2/bits/hashtable_policy.h:1099:63: error: invalid use
: __ebo_extract_key(__ex), __ebo_h1(__h1), __ebo_h2(__h2) { }
from
from
from
from
struct hash;
from
from
from
from
from
from
struct hash;
make[2]: *** [dwarf2read.o] Error 1
make[2]: Leaving directory
`/data/home/joel/rtems-cron/rtems-source-builder/rtems/build/sparc-rtems6-gdb-6f5601c4d0-x86_64-linux-gnu-1/build/gdb'
make[1]: *** [all-gdb] Error 2
make[1]: Leaving directory
`/data/home/joel/rtems-cron/rtems-source-builder/rtems/build/sparc-rtems6-gdb-6f5601c4d0-x86_64-linux-gnu-1/build'
make: *** [all] Error 2
shell cmd failed: /bin/sh -ex
/data/home/joel/rtems-cron/rtems-source-builder/rtems/build/sparc-rtems6-gdb-6f5601c4d0-x86_64-linux-gnu-1/do-build
error: building sparc-rtems6-gdb-6f5601c4d0-x86_64-linux-gnu-1
See error report:
rsb-report-sparc-rtems6-gdb-6f5601c4d0-x86_64-linux-gnu-1.txt
Sizes
Maximum build usage: 8.790GB
Total size: 2.689GB
Installed : 1.650GB
Sources: 1.038GB
Patches: 538.757KB
Output
config: tools/rtems-autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-linux-gnu-1
building: autoconf-2.69-x86_64-linux-gnu-1
sizes: autoconf-2.69-x86_64-linux-gnu-1: 10.516MB (installed: 3.021MB)
cleaning: autoconf-2.69-x86_64-linux-gnu-1
reporting: tools/rtems-autoconf-2.69-1.cfg ->
autoconf-2.69-x86_64-linux-gnu-1.txt
autoconf-2.69-x86_64-linux-gnu-1.xml
config: tools/rtems-automake-1.12.6-1.cfg
package: automake-1.12.6-x86_64-linux-gnu-1
building: automake-1.12.6-x86_64-linux-gnu-1
sizes: automake-1.12.6-x86_64-linux-gnu-1: 10.353MB (installed: 2.264MB)
cleaning: automake-1.12.6-x86_64-linux-gnu-1
reporting: tools/rtems-automake-1.12.6-1.cfg ->
automake-1.12.6-x86_64-linux-gnu-1.txt
automake-1.12.6-x86_64-linux-gnu-1.xml
installing: autoconf-2.69-x86_64-linux-gnu-1 ->
/home/joel/rtems-cron/tools/6
installing: automake-1.12.6-x86_64-linux-gnu-1 ->
Build Sizes: usage: 15.801MB total: 1.044GB (sources: 1.038GB, patches:
538.757KB, installed 5.285MB)
Build Set: Time 0:00:16.395131
Build Set: Time 0:00:25.341287
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-linux-gnu-1
building: expat-2.1.0-x86_64-linux-gnu-1
sizes: expat-2.1.0-x86_64-linux-gnu-1: 7.457MB (installed: 1.432MB)
cleaning: expat-2.1.0-x86_64-linux-gnu-1
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.txt
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.xml
config: tools/rtems-gdb-head.cfg
package: sparc-rtems6-gdb-6f5601c4d0-x86_64-linux-gnu-1
building: sparc-rtems6-gdb-6f5601c4d0-x86_64-linux-gnu-1
Build FAILED
See error report:
config: tools/rtems-binutils-head.cfg
package: sparc-rtems6-binutils-6f5601c4d0-x86_64-linux-gnu-1
building: sparc-rtems6-binutils-6f5601c4d0-x86_64-linux-gnu-1
sizes: sparc-rtems6-binutils-6f5601c4d0-x86_64-linux-gnu-1: 601.531MB
(installed: 120.257MB)
cleaning: sparc-rtems6-binutils-6f5601c4d0-x86_64-linux-gnu-1
reporting: tools/rtems-binutils-head.cfg ->
sparc-rtems6-binutils-6f5601c4d0-x86_64-linux-gnu-1.txt
sparc-rtems6-binutils-6f5601c4d0-x86_64-linux-gnu-1.xml
config: tools/rtems-gcc-head-newlib-head.cfg
package: sparc-rtems6-gcc-20a381c444d-newlib-ad101bcb0-x86_64-linux-gnu-1
building: sparc-rtems6-gcc-20a381c444d-newlib-ad101bcb0-x86_64-linux-gnu-1
sizes: sparc-rtems6-gcc-20a381c444d-newlib-ad101bcb0-x86_64-linux-gnu-1:
7.140GB (installed: 1.475GB)
cleaning: sparc-rtems6-gcc-20a381c444d-newlib-ad101bcb0-x86_64-linux-gnu-1
reporting: tools/rtems-gcc-head-newlib-head.cfg ->
sparc-rtems6-gcc-20a381c444d-newlib-ad101bcb0-x86_64-linux-gnu-1.txt
sparc-rtems6-gcc-20a381c444d-newlib-ad101bcb0-x86_64-linux-gnu-1.xml
config: tools/rtems-tools-5-1.cfg
package: rtems-tools-98f2f02f1293daccfa6a2d464ce0d2591a3b4d0b-1
building: rtems-tools-98f2f02f1293daccfa6a2d464ce0d2591a3b4d0b-1
sizes: rtems-tools-98f2f02f1293daccfa6a2d464ce0d2591a3b4d0b-1: 217.627MB
(installed: 57.897MB)
cleaning: rtems-tools-98f2f02f1293daccfa6a2d464ce0d2591a3b4d0b-1
reporting: tools/rtems-tools-5-1.cfg ->
rtems-tools-98f2f02f1293daccfa6a2d464ce0d2591a3b4d0b-1.txt
rtems-tools-98f2f02f1293daccfa6a2d464ce0d2591a3b4d0b-1.xml
Build Sizes: usage: 8.790GB total: 2.689GB (sources: 1.038GB, patches:
538.757KB, installed 1.650GB)
Mailing report: build at rtems.org
Report
RTEMS Tools Project <users at rtems.org> Wed Jun 19 23:17:11 2019
Report: devel/expat-2.1.0-1.cfg
RTEMS Source Builder Repository Status
Remotes:
1: origin: git://git.rtems.org/rtems-source-builder.git
Status:
Clean
Head:
Commit: e8f182037b69401220d68d51cb78f7991a358ba1
Build Set: (1) devel/expat-2.1.0-1.cfg
Build Set: (2) devel/expat-2.1.0-1.cfg
Package: expat-2.1.0-x86_64-linux-gnu-1
Config: devel/expat-2.1.0-1.cfg
Summary:
Expat XML Parser v2.1.0 for target sparc-rtems6 on host x86_64-linux-gnu
URL:
http://expat.sourceforge.net/
Version:
2.1.0
Release:
1
Sources: 1
1:
https://github.com/libexpat/libexpat/releases/download/R_2_1_0/expat-2.1.0.tar.gz
sha256:
823705472f816df21c8f6aa026dd162b280806838bb55b3432b0fb1fcca7eb86
Patches: 0
Preparation:
build_top=$(pwd)
%setup source expat -q -n expat-2.1.0
%setup patch expat -p1
cd ${build_top}
Build:
build_top=$(pwd)
cd expat-2.1.0
# Host and build flags, Cross build if host and build are different and
# Cxc build if target is deifned and also different.
# Note, gcc is not ready to be compiled with -std=gnu99 (this needs to be
checked).
if test "x86_64-linux-gnu" != "x86_64-linux-gnu" ; then
# Cross build
CC=$(echo "x86_64-linux-gnu-gcc" | sed -e 's,-std=gnu99 ,,')
CXX=$(echo "x86_64-linux-gnu-g++" | sed -e 's,-std=gnu99 ,,')
CPPFLAGS="${SB_HOST_CPPFLAGS}"
CFLAGS="${SB_HOST_CFLAGS}"
CXXFLAGS="${SB_HOST_CXXFLAGS}"
LDFLAGS="${SB_HOST_LDFLAGS}"
# Host
CPPFLAGS_FOR_HOST="${SB_HOST_CPPFLAGS}"
CFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
CXXFLAGS_FOR_HOST="${SB_HOST_CXXFLAGS}"
LDFLAGS_FOR_HOST="${SB_HOST_LDFLAGS}"
CXXFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
CC_FOR_HOST=$(echo "gcc ${SB_HOST_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
CXX_FOR_HOST=$(echo "g++ ${SB_HOST_CXXFLAGS}" | sed -e 's,-std=gnu99
# Build
CFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
CXXFLAGS_FOR_BUILD="${SB_BUILD_CXXFLAGS}"
LDFLAGS_FOR_BUILD="${SB_BUILD_LDFLAGS}"
CXXFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
CC_FOR_BUILD=$(echo "gcc ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
CXX_FOR_BUILD=$(echo "g++ ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99
else
LDFLAGS="${SB_BUILD_LDFLAGS}"
CC=$(echo "gcc ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
CXX=$(echo "g++ ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
CC_FOR_BUILD=${CC}
CXX_FOR_BUILD=${CXX}
fi
export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS
export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST
CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST
export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD
LDFLAGS_FOR_BUILD
./configure \
--build=x86_64-linux-gnu --host=x86_64-linux-gnu \
--verbose \
--prefix=/home/joel/rtems-cron/tools/6
--bindir=/home/joel/rtems-cron/tools/6/bin \
--exec-prefix=/home/joel/rtems-cron/tools/6 \
--includedir=/home/joel/rtems-cron/tools/6/include
--libdir=/home/joel/rtems-cron/tools/6/lib \
--mandir=/home/joel/rtems-cron/tools/6/share/man
--infodir=/home/joel/rtems-cron/tools/6/share/info
make -j 12 all
cd ${build_top}
Install:
build_top=$(pwd)
rm -rf $SB_BUILD_ROOT
cd expat-2.1.0
make DESTDIR=$SB_BUILD_ROOT install
cd ${build_top}
Remotes:
Status:
Clean
Head:
Summary:
URL:
Version:
2.1.0
Release:
1
Sources: 1
1:
sha256:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
cd expat-2.1.0
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
LDFLAGS_FOR_BUILD
./configure \
--verbose \
make -j 12 all
cd ${build_top}
Install:
build_top=$(pwd)
cd expat-2.1.0
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Wed Jun 19 23:19:01 2019
Report: tools/rtems-binutils-head.cfg
Remotes:
Status:
Clean
Head:
Build Set: (1) tools/rtems-binutils-head.cfg
Build Set: (2) tools/rtems-binutils-head.cfg
Package: sparc-rtems6-binutils-6f5601c4d0-x86_64-linux-gnu-1
Config: tools/rtems-binutils-head.cfg
Summary:
Binutils v6f5601c4d0 for target sparc-rtems6 on host x86_64-linux-gnu
URL:
http://sources.redhat.com/binutils
Version:
6f5601c4d0
Release:
1
Sources: 1
1: --rsb-file=sourceware-mirror-binutils-gdb-6f5601c4d0.tar.gz
https://codeload.github.com/RTEMS/sourceware-mirror-binutils-gdb/tar.gz/6f5601c4d0
No checksum
Patches: 0
Preparation:
build_top=$(pwd)
binutils_source=sourceware-mirror-binutils-gdb-6f5601c4d0
source_dir_binutils=${binutils_source}
%setup source binutils -q -n ${binutils_source}
%setup patch binutils -p1
cd ${build_top}
Build:
build_top=$(pwd)
# Cross-build (Xc) if no target or the host and target match.
# Canadian-cross (Cxc) if build, host and target are all different.
if test -z "sparc-rtems6" -o "x86_64-linux-gnu" == "sparc-rtems6" ; then
build_dir="build-xc"
else
build_dir="build-cxc"
fi
else
build_dir="build"
fi
mkdir -p ${build_dir}
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
LDFLAGS_FOR_BUILD
../${source_dir_binutils}/configure \
--target=sparc-rtems6 \
--verbose --disable-nls \
--disable-gdb --disable-libdecnumber --disable-readline --disable-sim \
--enable-deterministic-archives \
--enable-64-bit-bfd \
--disable-lto \
--without-included-gettext \
--disable-win32-registry \
--disable-werror \
make -j 12 all
cd ${build_top}
Install:
cd ${build_top}
/bin/rm -rf $SB_BUILD_ROOT
cd ${build_dir}
/bin/rm -rf $SB_BUILD_ROOT/home/joel/rtems-cron/tools/6/share/info/
configure.info*
/bin/rm -f $SB_BUILD_ROOT/home/joel/rtems-cron/tools/6/share/info/dir
touch $SB_BUILD_ROOT/home/joel/rtems-cron/tools/6/share/info/dir
mkdir -p $SB_BUILD_ROOT/home/joel/rtems-cron/tools/6/share/locale
/bin/rm -f ${SB_BUILD_ROOT}/home/joel/rtems-cron/tools/6/lib/libiberty*
if test ! -f
${SB_BUILD_ROOT}/home/joel/rtems-cron/tools/6/bin/sparc-rtems6-dlltool; then
/bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron/tools/6/share/man/man1/sparc-rtems6-dlltool*
fi
if test ! -f
${SB_BUILD_ROOT}/home/joel/rtems-cron/tools/6/bin/sparc-rtems6-nlmconv; then
/bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron/tools/6/share/man/man1/sparc-rtems6-nlmconv*
fi
if test ! -f
${SB_BUILD_ROOT}/home/joel/rtems-cron/tools/6/bin/sparc-rtems6-windres; then
/bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron/tools/6/share/man/man1/sparc-rtems6-windres*
fi
if test ! -f
${SB_BUILD_ROOT}/home/joel/rtems-cron/tools/6/bin/sparc-rtems6-windmc; then
/bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron/tools/6/share/man/man1/sparc-rtems6-windmc*
fi
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Wed Jun 19 23:19:02 2019
Remotes:
Status:
Clean
Head:
Summary:
URL:
Version:
6f5601c4d0
Release:
1
Sources: 1
No checksum
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
LDFLAGS_FOR_BUILD
--disable-lto \
--disable-werror \
make -j 12 all
cd ${build_top}
Install:
cd ${build_top}
cd ${build_dir}
configure.info*
if test ! -f
/bin/rm -f
fi
if test ! -f
/bin/rm -f
fi
if test ! -f
/bin/rm -f
fi
if test ! -f
/bin/rm -f
fi
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Wed Jun 19 23:47:44 2019
Report: tools/rtems-gcc-head-newlib-head.cfg
Remotes:
Status:
Clean
Head:
Build Set: (1) tools/rtems-gcc-head-newlib-head.cfg
Build Set: (2) tools/rtems-gcc-head-newlib-head.cfg
Package: sparc-rtems6-gcc-20a381c444d-newlib-ad101bcb0-x86_64-linux-gnu-1
Config: tools/rtems-gcc-head-newlib-head.cfg
Summary:
GCC v20a381c444d and Newlib vad101bcb0 for target sparc-rtems6 on host
x86_64-linux-gnu
URL:
http://gcc.gnu.org/
Version:
20a381c444d
Release:
1
Sources: 6
1: --rsb-file=gnu-mirror-gcc-20a381c444d.tar.gz
https://codeload.github.com/RTEMS/gnu-mirror-gcc/tar.gz/20a381c444d
No checksum
2: https://ftp.gnu.org/gnu/mpc/mpc-1.0.3.tar.gz
sha512:
0028b76df130720c1fad7de937a0d041224806ce5ef76589f19c7b49d956071a683e2f20d154c192a231e69756b19e48208f2889b0c13950ceb7b3cfaf059a43
3: --rsb-file=newlib-ad101bcb0.tar.gz
https://codeload.github.com/RTEMS/sourceware-mirror-newlib-cygwin/tar.gz/ad101bcb0
No checksum
4: https://gcc.gnu.org/pub/gcc/infrastructure/isl-0.18.tar.bz2
sha512:
85d0b40f4dbf14cb99d17aa07048cdcab2dc3eb527d2fbb1e84c41b2de5f351025370e57448b63b2b8a8cf8a0843a089c3263f9baee1542d5c2e1cb37ed39d94
5: https://ftp.gnu.org/gnu/gmp/gmp-6.1.0.tar.bz2
sha512:
3c82aeab9c1596d4da8afac2eec38e429e84f3211e1a572cf8fd2b546493c44c039b922a1133eaaa48bd7f3e11dbe795a384e21ed95cbe3ecc58d7ac02246117
6: https://ftp.gnu.org/gnu/mpfr/mpfr-3.1.4.tar.bz2
sha512:
51066066ff2c12ed2198605ecf68846b0c96b548adafa5b80e0c786d0df488411a5e8973358fce7192dc977ad4e68414cf14500e3c39746de62465eb145bb819
Patches: 0
Preparation:
build_top=$(pwd)
gcc_source=gnu-mirror-gcc-20a381c444d
source_dir_gcc=${gcc_source}
%setup source gcc -q -n ${gcc_source}
%setup patch gcc -p1
cd ${build_top}
source_dir_newlib=sourceware-mirror-newlib-cygwin-ad101bcb0
%setup source newlib -q -D -n ${source_dir_newlib}
%setup patch newlib -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/newlib
ln -s $PWD/${source_dir_newlib}/newlib ${source_dir_gcc}/newlib
source_dir_isl="isl-0.18"
%setup source isl -q -D -n isl-0.18
%setup patch isl -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/isl
ln -s $PWD/${source_dir_isl} ${source_dir_gcc}/isl
source_dir_mpfr="mpfr-3.1.4"
%setup source mpfr -q -D -n mpfr-3.1.4
%setup patch mpfr -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/mpfr
ln -s $PWD/${source_dir_mpfr} ${source_dir_gcc}/mpfr
source_dir_mpc="mpc-1.0.3"
%setup source mpc -q -D -n mpc-1.0.3
%setup patch mpc -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/mpc
ln -s $PWD/${source_dir_mpc} ${source_dir_gcc}/mpc
source_dir_gmp="gmp-6.1.0"
%setup source gmp -q -D -n gmp-6.1.0
%setup patch gmp -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/gmp
ln -s $PWD/${source_dir_gmp} ${source_dir_gcc}/gmp
echo "RTEMS 6, RSB e8f182037b69401220d68d51cb78f7991a358ba1, Newlib
ad101bcb0" > ${source_dir_gcc}/gcc/DEV-PHASE
cd ${source_dir_gcc}
contrib/gcc_update --touch
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
languages="c"
languages="$languages,c++"
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
LDFLAGS_FOR_BUILD
../${source_dir_gcc}/configure \
--prefix=/home/joel/rtems-cron/tools/6 \
--exec_prefix=/home/joel/rtems-cron/tools/6 \
--includedir=/home/joel/rtems-cron/tools/6/include \
--libexecdir=/home/joel/rtems-cron/tools/6/libexec \
--mandir=/home/joel/rtems-cron/tools/6/share/man \
--infodir=/home/joel/rtems-cron/tools/6/share/info \
--datadir=/home/joel/rtems-cron/tools/6/share \
--disable-libstdcxx-pch \
--with-gnu-as --with-gnu-ld --verbose \
--with-newlib \
--disable-nls --without-included-gettext \
--enable-version-specific-runtime-libs \
--disable-lto \
--enable-newlib-io-c99-formats \
--enable-newlib-iconv \
--enable-newlib-iconv-encodings=big5,cp775,cp850,cp852,cp855,\
cp866,euc_jp,euc_kr,euc_tw,iso_8859_1,iso_8859_10,iso_8859_11,\
iso_8859_13,iso_8859_14,iso_8859_15,iso_8859_2,iso_8859_3,\
iso_8859_4,iso_8859_5,iso_8859_6,iso_8859_7,iso_8859_8,iso_8859_9,\
iso_ir_111,koi8_r,koi8_ru,koi8_u,koi8_uni,ucs_2,ucs_2_internal,\
ucs_2be,ucs_2le,ucs_4,ucs_4_internal,ucs_4be,ucs_4le,us_ascii,\
utf_16,utf_16be,utf_16le,utf_8,win_1250,win_1251,win_1252,\
win_1253,win_1254,win_1255,win_1256,win_1257,win_1258 \
--enable-threads \
--disable-plugin \
--enable-libgomp \
--enable-languages="$languages"
if test "%_host" != "%_build" ; then
mkdir -p gcc/include
cp ../${source_dir_gcc}/gcc/gsyslimits.h gcc/include/syslimits.h
fi
make -j 12 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
/bin/rm -f ${SB_BUILD_ROOT}/home/joel/rtems-cron/tools/6/lib/libiberty.a
/bin/rm -f
$SB_BUILD_ROOT/home/joel/rtems-cron/tools/6/bin/sparc-rtems6-c++filt
/bin/rm -f
$SB_BUILD_ROOT/home/joel/rtems-cron/tools/6/share/man/man3/*ffi*
/bin/rm -rf ${source_dir_gcc}/newlib
/bin/rm -rf ${source_dir_gcc}/mpfr
/bin/rm -rf ${source_dir_gcc}/mpc
/bin/rm -rf ${source_dir_gcc}/gmp
Remotes:
Status:
Clean
Head:
Summary:
x86_64-linux-gnu
URL:
http://gcc.gnu.org/
Version:
20a381c444d
Release:
1
Sources: 6
No checksum
sha512:
No checksum
sha512:
sha512:
sha512:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
cd ${build_top}
cd ${build_top}
cd ${build_top}
cd ${build_top}
cd ${build_top}
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
languages="c"
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
LDFLAGS_FOR_BUILD
--with-newlib \
--disable-lto \
--enable-threads \
--disable-plugin \
--enable-libgomp \
fi
make -j 12 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
/bin/rm -f
/bin/rm -f
RTEMS Tools Project <users at rtems.org> Wed Jun 19 23:47:58 2019
Report: tools/rtems-tools-5-1.cfg
Remotes:
Status:
Clean
Head:
Build Set: (1) tools/rtems-tools-5-1.cfg
Build Set: (2) tools/rtems-tools-5-1.cfg
Package: rtems-tools-98f2f02f1293daccfa6a2d464ce0d2591a3b4d0b-1
Config: tools/rtems-tools-5-1.cfg
Summary:
RTEMS Tools 98f2f02f1293daccfa6a2d464ce0d2591a3b4d0b for host
x86_64-linux-gnu
URL:
http://www.rtems.org/
Version:
Release:
1
Sources: 1
1:
https://git.rtems.org/rtems-tools/snapshot/rtems-tools-98f2f02f1293daccfa6a2d464ce0d2591a3b4d0b.tar.bz2
sha512:
aa5e3a945ad33c6d8c85f4c3fd3f69ed18e9f04fa41b89181175d828e12ad0acad3107d5760d062ca6402a35bdf659000dfded0317cadf78fbb632e9d0a4b244
Patches: 0
Preparation:
build_top=$(pwd)
rtems_tools_source=rtems-tools-98f2f02f1293daccfa6a2d464ce0d2591a3b4d0b
source_dir_rtems_tools=${rtems_tools_source}
%setup source rtems-tools -q -n ${rtems_tools_source}
%setup patch rtems-tools -p1
cd ${build_top}
Build:
build_top=$(pwd)
RT_HOST="--host=x86_64-linux-gnu"
else
RT_HOST=
fi
cd ${source_dir_rtems_tools}
./waf distclean configure ${RT_HOST}
./waf
cd ${build_top}
Install:
build_top=$(pwd)
SB_BUILD_ROOT_WAF=$SB_BUILD_ROOT
./waf --destdir=$SB_BUILD_ROOT_WAF install
cd ${build_top}
Remotes:
Status:
Clean
Head:
Summary:
x86_64-linux-gnu
URL:
Version:
Release:
1
Sources: 1
1:
sha512:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
else
RT_HOST=
fi
./waf
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_top}
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190620/ee9782f6/attachment-0001.html>
