[PATCH] Write event stream in file
Thu Jun 20 13:26:50 UTC 2019
----- Am 20. Jun 2019 um 14:17 schrieb Ravindra Kumar Meena rmeena840 at gmail.com:
> misc/record/record-main.c | 27 +++++++++++++++++++++++++++
> 1 file changed, 27 insertions(+)
> diff --git a/misc/record/record-main.c b/misc/record/record-main.c
> index 742428b..eccf291 100644
> --- a/misc/record/record-main.c
> +++ b/misc/record/record-main.c
> @@ -67,6 +67,13 @@ typedef struct client_item {
>   uint64_t                     counter;
> } client_item;
> +typedef struct ctf_event {
> +  uint64_t                     ns;
> +  uint32_t                     cpu;
> +  rtems_record_event           event;
> +  uint64_t                     data;
> +} ctf_event;
> typedef struct client_context {
>   uint64_t                       ns_threshold;
>   uint64_t                       last_ns;
> @@ -135,12 +142,16 @@ static int connect_client( const char *host, uint16_t port
> static void print_item( FILE *f, const client_item *item )
> +  ctf_event *ctf_item;
> +  uint32_t ns;
>   if ( item->ns != 0 ) {
>     uint32_t seconds;
>     uint32_t nanoseconds;
>     seconds = (uint32_t) ( item->ns / 1000000000 );
>     nanoseconds = (uint32_t) ( item->ns % 1000000000 );
> +    ns=nanoseconds;
Why not move the nanoseconds variable into the upper block?
>     fprintf( f, "%" PRIu32 ".%09" PRIu32 ":", seconds, nanoseconds );
>   } else {
Which value has "ns" in this path?
>     fprintf( f, "*:" );
> @@ -153,6 +164,22 @@ static void print_item( FILE *f, const client_item *item )
>     rtems_record_event_text( item->event ),
>     item->data
> +  FILE *fptr = fopen("event", "a");
How often gets this file opened and closed? Do you think that opening and closing a file is a cheap operation? Could there be a more efficient solution?
> +  if (fptr == NULL)
> +       printf("Could not open file");
> +       return 0;
Can void functions return something?
> +  ctf_item->cpu=item->cpu;
To which object points the the ctf_item pointer here?
> +  ctf_item->event=item->event;
> +  ctf_item->data=item->data;
> +  ctf_item->ns=ns;
> +  fprintf(fptr,ctf_item);
> +  fclose(fptr);
> static void flush_items( client_context *cctx )
> 2.7.4
Did you compile and run the program with this patch?
