GSoC PRU: Texas Instruments License
Joel Sherrill
joel at rtems.org
Thu Jun 20 14:55:41 UTC 2019
Agreeing with Gedare.
My recollection is that long ago TI included language about only for use
with their hardware but that's gone.
Holder versus owner shouldn't matter but shows why you should always try to
use standard language
On Thu, Jun 20, 2019, 9:32 AM Gedare Bloom <gedare at rtems.org> wrote:
> The license is fine. 3-BSD is compatible for us to use.
> On Thu, Jun 20, 2019, 3:28 AM Christian Mauderer <list at c-mauderer.de>
> wrote:
>> On 20/06/2019 11:04, Nils Hölscher wrote:
>> > Hi,
>> > I would like to discuss the attached TI-license.
>> > Is it RTEMS compatible?
>> > As far as I can see It has no copy left, but the license has to be
>> > distributed with binarys.
>> > Best,
>> > Nils
>> > * prussdrv.c
>> > * User space driver for PRUSS
>> > * Copyright (C) 2012 Texas Instruments Incorporated -
>> http://www.ti.com/
>> > * Redistribution and use in source and binary forms, with or without
>> > * modification, are permitted provided that the following conditions
>> > * are met:
>> > * Redistributions of source code must retain the above copyright
>> > * notice, this list of conditions and the following disclaimer.
>> > * Redistributions in binary form must reproduce the above copyright
>> > * notice, this list of conditions and the following disclaimer in the
>> > * documentation and/or other materials provided with the
>> > * distribution.
>> > * Neither the name of Texas Instruments Incorporated nor the names of
>> > * its contributors may be used to endorse or promote products derived
>> > * from this software without specific prior written permission.
>> > * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>> > * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>> > * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
>> > * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
>> > * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
>> > * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
>> > * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
>> > * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
>> > * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
>> > * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
>> > * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
>> It looks like a default BSD-3-Clause license:
>> https://opensource.org/licenses/BSD-3-Clause
>> The only difference is that TI wrote "IN NO EVENT SHALL THE COPYRIGHT
>> OWNER ..." while opensource.org writes "IN NO EVENT SHALL THE COPYRIGHT
>> HOLDER ...". I don't think that's a relevant difference?
>> RTEMS wants to use 2-Clause-BSD for new code. To be honest: I really
>> have no idea whether the two are compatible.
>> Best regards
>> Christian
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190620/580f569a/attachment.html>
