[PATCH v1] Port ndbm
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Thu Jun 20 20:27:06 UTC 2019
newlib/libc/include/ndbm.h | 84 +++++++++++++
newlib/libc/search/Makefile.am | 1 +
newlib/libc/search/ndbm.c | 214 +++++++++++++++++++++++++++++++++
3 files changed, 299 insertions(+)
create mode 100644 newlib/libc/include/ndbm.h
create mode 100644 newlib/libc/search/ndbm.c
diff --git a/newlib/libc/include/ndbm.h b/newlib/libc/include/ndbm.h
new file mode 100644
index 000000000..f89f97dd0
--- /dev/null
+++ b/newlib/libc/include/ndbm.h
@@ -0,0 +1,84 @@
+ * SPDX-License-Identifier: BSD-3-Clause
+ * Copyright (c) 1990, 1993
+ * The Regents of the University of California. All rights reserved.
+ * This code is derived from software contributed to Berkeley by
+ * Margo Seltzer.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * 3. Neither the name of the University nor the names of its contributors
+ * may be used to endorse or promote products derived from this software
+ * without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * @(#)ndbm.h 8.1 (Berkeley) 6/2/93
+ * $FreeBSD$
+#ifndef _NDBM_H_
+#define _NDBM_H_
+#define __DBINTERFACE_PRIVATE
+#include <db_local.h>
+/* Map dbm interface onto db(3). */
+#define DBM_RDONLY O_RDONLY
+/* Flags to dbm_store(). */
+#define DBM_INSERT 0
+#define DBM_REPLACE 1
+ * The db(3) support for ndbm always appends this suffix to the
+ * file name to avoid overwriting the user's original database.
+#define DBM_SUFFIX ".db"
+typedef struct {
+ void *dptr;
+ int dsize; /* XXX Should be size_t according to 1003.1-2008. */
+} datum;
+typedef DB DBM;
+#define dbm_pagfno(a) DBM_PAGFNO_NOT_AVAILABLE
+__BEGIN_DECLS
+int dbm_clearerr(DBM *);
+void dbm_close(DBM *);
+int dbm_delete(DBM *, datum);
+int dbm_error(DBM *);
+datum dbm_fetch(DBM *, datum);
+datum dbm_firstkey(DBM *);
+#if __BSD_VISIBLE
+long dbm_forder(DBM *, datum);
+#endif
+datum dbm_nextkey(DBM *);
+DBM *dbm_open(const char *, int, mode_t);
+int dbm_store(DBM *, datum, datum, int);
+#if __BSD_VISIBLE
+int dbm_dirfno(DBM *);
+#endif
+__END_DECLS
+#endif /* !_NDBM_H_ */
diff --git a/newlib/libc/search/Makefile.am b/newlib/libc/search/Makefile.am
index 98920c3f4..a61107fb9 100644
--- a/newlib/libc/search/Makefile.am
+++ b/newlib/libc/search/Makefile.am
@@ -9,6 +9,7 @@ GENERAL_SOURCES = \
db_local.h \
extern.h \
hash.h \
+ ndbm.c \
page.h \
qsort.c
diff --git a/newlib/libc/search/ndbm.c b/newlib/libc/search/ndbm.c
index 000000000..bd9c71e4f
--- /dev/null
+++ b/newlib/libc/search/ndbm.c
@@ -0,0 +1,214 @@
+ * Margo Seltzer.
+ * are met:
+ * SUCH DAMAGE.
+#if defined(LIBC_SCCS) && !defined(lint)
+static char sccsid[] = "@(#)ndbm.c 8.4 (Berkeley) 7/21/94";
+#endif /* LIBC_SCCS and not lint */
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+ * This package provides a dbm compatible interface to the new hashing
+ * package described in db(3).
+#include <sys/param.h>
+#include <stdio.h>
+#include <string.h>
+#include <errno.h>
+#include <ndbm.h>
+#include "hash.h"
+ * Returns:
+ * *DBM on success
+ * NULL on failure
+extern DBM *
+dbm_open(const char *file, int flags, mode_t mode)
+ HASHINFO info;
+ char path[MAXPATHLEN];
+ info.bsize = 4096;
+ info.ffactor = 40;
+ info.nelem = 1;
+ info.cachesize = 0;
+ info.hash = NULL;
+ info.lorder = 0;
+ if( strlen(file) >= sizeof(path) - strlen(DBM_SUFFIX)) {
+ errno = ENAMETOOLONG;
+ return(NULL);
+ (void)strcpy(path, file);
+ (void)strcat(path, DBM_SUFFIX);
+ return ((DBM *)__hash_open(path, flags, mode, 0, &info));
+extern void
+dbm_close(DBM *db)
+ (void)(db->close)(db);
+ * Returns:
+ * DATUM on success
+ * NULL on failure
+extern datum
+dbm_fetch(DBM *db, datum key)
+ datum retdata;
+ int status;
+ DBT dbtkey, dbtretdata;
+ dbtkey.data = key.dptr;
+ dbtkey.size = key.dsize;
+ status = (db->get)(db, &dbtkey, &dbtretdata, 0);
+ if (status) {
+ dbtretdata.data = NULL;
+ dbtretdata.size = 0;
+ retdata.dptr = dbtretdata.data;
+ retdata.dsize = dbtretdata.size;
+ return (retdata);
+ * Returns:
+ * NULL on failure
+extern datum
+dbm_firstkey(DBM *db)
+ int status;
+ datum retkey;
+ DBT dbtretkey, dbtretdata;
+ status = (db->seq)(db, &dbtretkey, &dbtretdata, R_FIRST);
+ if (status)
+ dbtretkey.data = NULL;
+ retkey.dptr = dbtretkey.data;
+ retkey.dsize = dbtretkey.size;
+ return (retkey);
+ * Returns:
+ * NULL on failure
+extern datum
+dbm_nextkey(DBM *db)
+ int status;
+ datum retkey;
+ status = (db->seq)(db, &dbtretkey, &dbtretdata, R_NEXT);
+ if (status)
+ return (retkey);
+ * Returns:
+ * 0 on success
+ * <0 failure
+extern int
+dbm_delete(DBM *db, datum key)
+ int status;
+ DBT dbtkey;
+ status = (db->del)(db, &dbtkey, 0);
+ if (status)
+ return (-1);
+ else
+ return (0);
+ * Returns:
+ * 0 on success
+ * <0 failure
+ * 1 if DBM_INSERT and entry exists
+extern int
+dbm_store(DBM *db, datum key, datum data, int flags)
+ DBT dbtkey, dbtdata;
+ dbtdata.data = data.dptr;
+ dbtdata.size = data.dsize;
+ return ((db->put)(db, &dbtkey, &dbtdata,
+ (flags == DBM_INSERT) ? R_NOOVERWRITE : 0));
+extern int
+dbm_error(DBM *db)
+ HTAB *hp;
+ hp = (HTAB *)db->internal;
+ return (hp->error);
+extern int
+dbm_clearerr(DBM *db)
+ HTAB *hp;
+ hp->error = 0;
+ return (0);
+extern int
+dbm_dirfno(DBM *db)
+ return(((HTAB *)db->internal)->fp);
2.21.0
