Add newlib patch to RTEMS RSB
Joel Sherrill
joel at rtems.org
Thu Jun 20 22:21:07 UTC 2019
Chris. can you provide some patch and RSB guidance? Please
On Thu, Jun 20, 2019 at 2:07 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> On Fri, Jun 21, 2019 at 12:13 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Jun 20, 2019 at 11:32 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>> wrote:
>> > I checked that erc32 is using rtems-sparc.bset file
>> > Inside it i found, it is using
>> rsb/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f file
>> > I added following lines to
>> rsb/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg
>> > %prep
>> > %patch setup newlib -p1
>> > %patch add newlib file://0001-Port-ndbm.patch
>> > %hash sha512 0001-Port-ndbm.patch
>> 0e05d97d0a6f8a436a233fe4fb3cbda7c0cfeab11cfda1c155d8aa5b80289f386896b0e8c28e5858e1d7409fd22c8d1cbaaccb181bc376845fe6d50b16359db6
>> > And when I tried to build the tool-chain again using the command:
>> ../source-builder/sb-set-builder --prefix=/home/varodek/development/rtems/5
>> 5/rtems-sparc
>> > It generated the following error report
>> > RTEMS Tools Project - Source Builder Error Report
>> > Build: error: building
>> sparc-rtems5-gcc-7.4.0-newlib-1d35a003f-x86_64-linux-gnu-1
>> > Command Line: ../source-builder/sb-set-builder
>> --prefix=/home/varodek/development/rtems/5 5/rtems-sparc
>> > Python: 2.7.16 (default, Mar 11 2019, 18:59:25) [GCC 8.2.1 20181127]
>> > git://
>> git.rtems.org/rtems-source-builder.git/origin/780a2cf36c9c69e5e4c2393f8c0bbcf3854bbacf-modified
>> > Linux varodek 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20 15:00:46
>> UTC 2019 x86_64
>> > Tail of the build log:
>> > -rw-rw-r-- bodrato/bodrato 8702 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/pentium/mmx/lshift.asm
>> > -rw-rw-r-- bodrato/bodrato 9481 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/pentium/mmx/rshift.asm
>> > -rw-rw-r-- bodrato/bodrato 8228 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/pentium/mmx/mul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 9336 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k8/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 9888 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/bd1/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 6385 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/aors_n.asm
>> > drwxrwxr-x bodrato/bodrato 0 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/k62mmx/
>> > -rw-rw-r-- bodrato/bodrato 12512 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/mul_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 3379 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/pre_mod_1.asm
>> > -rw-rw-r-- bodrato/bodrato 5161 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/mul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 14082 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/sqr_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 3928 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/mod_34lsub1.asm
>> > -rw-rw-r-- bodrato/bodrato 7537 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 9827 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/aorsmul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 4030 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/mode1o.asm
>> > -rw-rw-r-- bodrato/bodrato 4504 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/divrem_1.asm
>> > -rw-rw-r-- bodrato/bodrato 6418 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/gcd_1.asm
>> > -rwxrwxr-x bodrato/bodrato 5944 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/cross.pl
>> gmp-6.1.0/mpn/x86/k6/mmx/
>> > -rw-rw-r-- bodrato/bodrato 8639 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/README
>> > -rw-rw-r-- bodrato/bodrato 2318 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/mmx/com.asm
>> > -rw-rw-r-- bodrato/bodrato 2717 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/mmx/rshift.asm
>> > -rw-rw-r-- bodrato/bodrato 2701 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/mmx/lshift.asm
>> > -rw-rw-r-- bodrato/bodrato 6336 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/mmx/logops_n.asm
>> > -rw-rw-r-- bodrato/bodrato 5466 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/mmx/dive_1.asm
>> > -rw-rw-r-- bodrato/bodrato 4481 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/mmx/popham.asm
>> > -rw-rw-r-- bodrato/bodrato 5647 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/k62mmx/lshift.asm
>> > -rw-rw-r-- bodrato/bodrato 5687 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/k62mmx/rshift.asm
>> > -rw-rw-r-- bodrato/bodrato 3070 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/k6/k62mmx/copyd.asm
>> > -rw-rw-r-- bodrato/bodrato 2352 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86/i486/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 13769 2015-11-01 20:49
>> gmp-6.1.0/mpn/lisp/gmpasm-mode.el
>> > -rw-rw-r-- bodrato/bodrato 3237 2015-11-01 20:49
>> gmp-6.1.0/mpn/power/addmul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 3030 2015-11-01 20:49
>> gmp-6.1.0/mpn/power/mul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 2587 2015-11-01 20:49
>> gmp-6.1.0/mpn/power/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 2823 2015-11-01 20:49
>> gmp-6.1.0/mpn/power/add_n.asm
>> > -rw-rw-r-- bodrato/bodrato 1245 2015-11-01 20:49
>> gmp-6.1.0/mpn/power/sdiv.asm
>> > -rw-rw-r-- bodrato/bodrato 2894 2015-11-01 20:49
>> gmp-6.1.0/mpn/power/sub_n.asm
>> > -rw-rw-r-- bodrato/bodrato 3449 2015-11-01 20:49
>> gmp-6.1.0/mpn/power/submul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 1299 2015-11-01 20:49
>> gmp-6.1.0/mpn/power/umul.asm
>> > -rw-rw-r-- bodrato/bodrato 2035 2015-11-01 20:49
>> gmp-6.1.0/mpn/power/rshift.asm
>> > -rw-rw-r-- bodrato/bodrato 2016 2015-11-01 20:49
>> gmp-6.1.0/mpn/power/lshift.asm
>> > -rw-rw-r-- bodrato/bodrato 20943 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/aors_n.asm
>> > -rw-rw-r-- bodrato/bodrato 9372 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/README
>> > -rw-rw-r-- bodrato/bodrato 3389 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/sec_tabselect.asm
>> > -rw-rw-r-- bodrato/bodrato 15213 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/mul_2.asm
>> > -rw-rw-r-- bodrato/bodrato 8416 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/lshiftc.asm
>> > -rw-rw-r-- bodrato/bodrato 1587 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/aorsorrlsh2_n.asm
>> > -rw-rw-r-- bodrato/bodrato 3404 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/copyi.asm
>> gmp-6.1.0/mpn/ia64/aorsorrlsh1_n.asm
>> > -rw-rw-r-- bodrato/bodrato 10809 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/divrem_1.asm
>> > -rw-rw-r-- bodrato/bodrato 4738 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/sqr_diag_addlsh1.asm
>> > -rw-rw-r-- bodrato/bodrato 8349 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/add_n_sub_n.asm
>> > -rw-rw-r-- bodrato/bodrato 17852 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/addmul_2.asm
>> > -rw-rw-r-- bodrato/bodrato 6598 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/cnd_aors_n.asm
>> > -rw-rw-r-- bodrato/bodrato 11463 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/rsh1aors_n.asm
>> > -rw-rw-r-- bodrato/bodrato 7110 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/lorrshift.asm
>> > -rw-rw-r-- bodrato/bodrato 7158 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/gcd_1.asm
>> > -rw-rw-r-- bodrato/bodrato 13304 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/addmul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 9691 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 4543 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/popcount.asm
>> > -rw-rw-r-- bodrato/bodrato 6524 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/divrem_2.asm
>> > -rw-rw-r-- bodrato/bodrato 6782 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/dive_1.asm
>> > -rw-rw-r-- bodrato/bodrato 4167 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/ia64-defs.m4
>> > -rw-rw-r-- bodrato/bodrato 7174 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/logops_n.asm
>> > -rw-rw-r-- bodrato/bodrato 11349 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/mode1o.asm
>> > -rw-rw-r-- bodrato/bodrato 12629 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/submul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 3055 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/invert_limb.asm
>> > -rw-rw-r-- bodrato/bodrato 9313 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/bdiv_dbm1c.asm
>> > -rw-rw-r-- bodrato/bodrato 3568 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/copyd.asm
>> > -rw-rw-r-- bodrato/bodrato 8357 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/hamdist.asm
>> > -rw-rw-r-- bodrato/bodrato 9925 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/aorsorrlshC_n.asm
>> > -rw-rw-r-- bodrato/bodrato 11545 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/mul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 5115 2015-11-01 20:49
>> gmp-6.1.0/mpn/ia64/mod_34lsub1.asm
>> gmp-6.1.0/mpn/x86_64/bobcat/
>> > -rw-rw-r-- bodrato/bodrato 6455 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/divrem_1.asm
>> > -rw-rw-r-- bodrato/bodrato 3930 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/mul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 3022 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/invert_limb.asm
>> > -rw-rw-r-- bodrato/bodrato 3500 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/sublsh1_n.asm
>> > -rw-rw-r-- bodrato/bodrato 4074 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/div_qr_2u_pi1.asm
>> gmp-6.1.0/mpn/x86_64/bd1/
>> > -rw-rw-r-- bodrato/bodrato 3606 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/addmul_2.asm
>> gmp-6.1.0/mpn/x86_64/k8/
>> > -rw-rw-r-- bodrato/bodrato 3543 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/lshsub_n.asm
>> > -rw-rw-r-- bodrato/bodrato 2224 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/missing-inline.m4
>> > -rw-rw-r-- bodrato/bodrato 4225 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/mod_34lsub1.asm
>> > -rw-rw-r-- bodrato/bodrato 4526 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/mod_1_2.asm
>> > -rw-rw-r-- bodrato/bodrato 2242 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/darwin.m4
>> > -rw-rw-r-- bodrato/bodrato 2120 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/copyd.asm
>> gmp-6.1.0/mpn/x86_64/fastavx/
>> gmp-6.1.0/mpn/x86_64/fastsse/
>> > -rw-rw-r-- bodrato/bodrato 2697 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/README
>> > -rw-rw-r-- bodrato/bodrato 4496 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/div_qr_1n_pi1.asm
>> gmp-6.1.0/mpn/x86_64/skylake/
>> gmp-6.1.0/mpn/x86_64/bd2/
>> > -rw-rw-r-- bodrato/bodrato 3417 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/aorrlshC_n.asm
>> > -rw-rw-r-- bodrato/bodrato 2484 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/sqr_diag_addlsh1.asm
>> gmp-6.1.0/mpn/x86_64/lshift.asm
>> > -rw-rw-r-- bodrato/bodrato 2302 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bdiv_dbm1c.asm
>> > -rw-rw-r-- bodrato/bodrato 5082 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/mod_1_4.asm
>> > -rw-rw-r-- bodrato/bodrato 3834 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/rshift.asm
>> > -rw-rw-r-- bodrato/bodrato 3541 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/aors_n.asm
>> gmp-6.1.0/mpn/x86_64/nano/
>> > -rw-rw-r-- bodrato/bodrato 1414 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/missing-call.m4
>> gmp-6.1.0/mpn/x86_64/atom/
>> > -rw-rw-r-- bodrato/bodrato 4218 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/aors_err1_n.asm
>> > -rw-rw-r-- bodrato/bodrato 3666 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/sec_tabselect.asm
>> gmp-6.1.0/mpn/x86_64/mulx/
>> > -rw-rw-r-- bodrato/bodrato 4024 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/gcd_1.asm
>> gmp-6.1.0/mpn/x86_64/coreinhm/
>> > -rw-rw-r-- bodrato/bodrato 1670 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/aorrlsh2_n.asm
>> gmp-6.1.0/mpn/x86_64/coreihwl/
>> > -rw-rw-r-- bodrato/bodrato 3203 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/addaddmul_1msb0.asm
>> gmp-6.1.0/mpn/x86_64/pentium4/
>> > -rw-rw-r-- bodrato/bodrato 3736 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bdiv_q_1.asm
>> gmp-6.1.0/mpn/x86_64/coreibwl/
>> > -rw-rw-r-- bodrato/bodrato 3177 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/missing.asm
>> > -rw-rw-r-- bodrato/bodrato 3264 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/div_qr_2n_pi1.asm
>> > -rw-rw-r-- bodrato/bodrato 3080 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/aors_err3_n.asm
>> > -rw-rw-r-- bodrato/bodrato 3961 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/aorsmul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 3875 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/popham.asm
>> > -rw-rw-r-- bodrato/bodrato 3831 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/aorrlsh1_n.asm
>> > -rw-rw-r-- bodrato/bodrato 10572 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 9299 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/x86_64-defs.m4
>> > -rw-rw-r-- bodrato/bodrato 3974 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/mode1o.asm
>> > -rw-rw-r-- bodrato/bodrato 1539 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/invert_limb_table.asm
>> > -rw-rw-r-- bodrato/bodrato 4993 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/mod_1_1.asm
>> > -rw-rw-r-- bodrato/bodrato 2310 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/dos64.m4
>> > -rw-rw-r-- bodrato/bodrato 2128 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/com.asm
>> > -rw-rw-r-- bodrato/bodrato 4309 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/cnd_aors_n.asm
>> > -rw-rw-r-- bodrato/bodrato 2104 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/copyi.asm
>> > -rw-rw-r-- bodrato/bodrato 3506 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/dive_1.asm
>> > -rw-rw-r-- bodrato/bodrato 4120 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/rsh1aors_n.asm
>> gmp-6.1.0/mpn/x86_64/fat/
>> > -rw-rw-r-- bodrato/bodrato 3348 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/aors_err2_n.asm
>> > -rw-rw-r-- bodrato/bodrato 3923 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/lshiftc.asm
>> > -rw-rw-r-- bodrato/bodrato 3870 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/aorrlsh_n.asm
>> > -rw-rw-r-- bodrato/bodrato 3876 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/divrem_2.asm
>> gmp-6.1.0/mpn/x86_64/coreisbr/
>> > -rw-rw-r-- bodrato/bodrato 3716 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/mul_2.asm
>> gmp-6.1.0/mpn/x86_64/k10/
>> > -rw-rw-r-- bodrato/bodrato 5083 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/logops_n.asm
>> gmp-6.1.0/mpn/x86_64/core2/
>> > -rw-rw-r-- bodrato/bodrato 1472 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/sublsh2_n.asm
>> > -rw-rw-r-- bodrato/bodrato 8230 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/redc_1.asm
>> > -rw-rw-r-- bodrato/bodrato 3249 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/lshiftc.asm
>> > -rw-rw-r-- bodrato/bodrato 1288 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/sec_tabselect.asm
>> gmp-6.1.0/mpn/x86_64/core2/aorrlsh1_n.asm
>> > -rw-rw-r-- bodrato/bodrato 10986 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 3767 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/rsh1aors_n.asm
>> gmp-6.1.0/mpn/x86_64/core2/copyd.asm
>> > -rw-rw-r-- bodrato/bodrato 1255 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/popcount.asm
>> > -rw-rw-r-- bodrato/bodrato 4176 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/aors_err1_n.asm
>> gmp-6.1.0/mpn/x86_64/core2/aorrlsh2_n.asm
>> gmp-6.1.0/mpn/x86_64/core2/sublsh1_n.asm
>> > -rw-rw-r-- bodrato/bodrato 1335 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/aorrlsh_n.asm
>> > -rw-rw-r-- bodrato/bodrato 4126 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/gcd_1.asm
>> > -rw-rw-r-- bodrato/bodrato 16719 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/mul_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 7748 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/mullo_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 3692 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/aorsmul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 3322 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/sublshC_n.asm
>> > -rw-rw-r-- bodrato/bodrato 3092 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/rshift.asm
>> > -rw-rw-r-- bodrato/bodrato 3162 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/lshift.asm
>> > -rw-rw-r-- bodrato/bodrato 3036 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/aors_n.asm
>> gmp-6.1.0/mpn/x86_64/core2/copyi.asm
>> > -rw-rw-r-- bodrato/bodrato 5007 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/divrem_1.asm
>> > -rw-rw-r-- bodrato/bodrato 17381 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/core2/sqr_basecase.asm
>> gmp-6.1.0/mpn/x86_64/k10/sec_tabselect.asm
>> > -rw-rw-r-- bodrato/bodrato 1305 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/k10/lshiftc.asm
>> > -rw-rw-r-- bodrato/bodrato 3288 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/k10/popcount.asm
>> > -rw-rw-r-- bodrato/bodrato 11388 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/k10/gmp-mparam.h
>> gmp-6.1.0/mpn/x86_64/k10/gcd_1.asm
>> > -rw-rw-r-- bodrato/bodrato 1302 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/k10/rshift.asm
>> gmp-6.1.0/mpn/x86_64/k10/lshift.asm
>> gmp-6.1.0/mpn/x86_64/k10/hamdist.asm
>> > -rw-rw-r-- bodrato/bodrato 3547 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/mul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 4083 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/rsh1aors_n.asm
>> > -rw-rw-r-- bodrato/bodrato 11362 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 7403 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/mul_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 3138 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/popcount.asm
>> gmp-6.1.0/mpn/x86_64/coreisbr/lshiftc.asm
>> > -rw-rw-r-- bodrato/bodrato 1778 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/aorrlsh1_n.asm
>> gmp-6.1.0/mpn/x86_64/coreisbr/rshift.asm
>> gmp-6.1.0/mpn/x86_64/coreisbr/lshift.asm
>> > -rw-rw-r-- bodrato/bodrato 4285 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/aors_n.asm
>> > -rw-rw-r-- bodrato/bodrato 8965 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/sqr_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 1857 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/aorrlsh2_n.asm
>> > -rw-rw-r-- bodrato/bodrato 4933 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/aorrlsh_n.asm
>> > -rw-rw-r-- bodrato/bodrato 6768 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/mullo_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 3880 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/aorrlshC_n.asm
>> > -rw-rw-r-- bodrato/bodrato 10034 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/redc_1.asm
>> > -rw-rw-r-- bodrato/bodrato 4272 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/aorsmul_1.asm
>> gmp-6.1.0/mpn/x86_64/coreisbr/sec_tabselect.asm
>> > -rw-rw-r-- bodrato/bodrato 4433 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/addmul_2.asm
>> > -rw-rw-r-- bodrato/bodrato 3408 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/mul_2.asm
>> > -rw-rw-r-- bodrato/bodrato 1278 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreisbr/divrem_1.asm
>> > -rw-rw-r-- bodrato/bodrato 1059 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fat/redc_1.c
>> > -rw-rw-r-- bodrato/bodrato 1063 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fat/mod_1.c
>> > -rw-rw-r-- bodrato/bodrato 5648 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fat/fat_entry.asm
>> gmp-6.1.0/mpn/x86_64/fat/redc_2.c
>> > -rw-rw-r-- bodrato/bodrato 2807 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fat/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 1075 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fat/mullo_basecase.c
>> > -rw-rw-r-- bodrato/bodrato 11578 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fat/fat.c
>> > -rw-rw-r-- bodrato/bodrato 1071 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fat/sqr_basecase.c
>> gmp-6.1.0/mpn/x86_64/fat/mul_basecase.c
>> > -rw-rw-r-- bodrato/bodrato 7012 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreibwl/mul_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 4161 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreibwl/mul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 11059 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreibwl/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 4539 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreibwl/addmul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 16373 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreibwl/sqr_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 3711 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/pentium4/lshiftc.asm
>> > -rw-rw-r-- bodrato/bodrato 1256 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/pentium4/popcount.asm
>> > -rw-rw-r-- bodrato/bodrato 11243 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/pentium4/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 1675 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/pentium4/aorslsh2_n.asm
>> > -rw-rw-r-- bodrato/bodrato 3369 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/pentium4/mod_34lsub1.asm
>> > -rw-rw-r-- bodrato/bodrato 6608 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/pentium4/rsh1aors_n.asm
>> gmp-6.1.0/mpn/x86_64/pentium4/aorslsh1_n.asm
>> > -rw-rw-r-- bodrato/bodrato 4172 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/pentium4/aors_n.asm
>> > -rw-rw-r-- bodrato/bodrato 3545 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/pentium4/lshift.asm
>> > -rw-rw-r-- bodrato/bodrato 3580 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/pentium4/rshift.asm
>> > -rw-rw-r-- bodrato/bodrato 4146 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/pentium4/aorslshC_n.asm
>> gmp-6.1.0/mpn/x86_64/pentium4/sec_tabselect.asm
>> > -rw-rw-r-- bodrato/bodrato 4108 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreihwl/aorsmul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 3296 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreihwl/mul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 9556 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreihwl/sqr_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 12256 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreihwl/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 7507 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreihwl/mul_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 9057 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreihwl/redc_1.asm
>> > -rw-rw-r-- bodrato/bodrato 4302 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreihwl/addmul_2.asm
>> > -rw-rw-r-- bodrato/bodrato 7490 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreihwl/mullo_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 3523 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreihwl/mul_2.asm
>> > -rw-rw-r-- bodrato/bodrato 11384 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreinhm/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 1294 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreinhm/popcount.asm
>> > -rw-rw-r-- bodrato/bodrato 1291 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreinhm/hamdist.asm
>> gmp-6.1.0/mpn/x86_64/coreinhm/sec_tabselect.asm
>> > -rw-rw-r-- bodrato/bodrato 4825 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreinhm/aorrlsh_n.asm
>> > -rw-rw-r-- bodrato/bodrato 3861 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreinhm/aorsmul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 10069 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/coreinhm/redc_1.asm
>> > -rw-rw-r-- bodrato/bodrato 3673 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/mulx/aorsmul_1.asm
>> gmp-6.1.0/mpn/x86_64/mulx/adx/
>> > -rw-rw-r-- bodrato/bodrato 3344 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/mulx/mul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 3412 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/mulx/adx/addmul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 3743 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/atom/aorsmul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 3432 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/atom/mul_2.asm
>> > -rw-rw-r-- bodrato/bodrato 1301 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/atom/dive_1.asm
>> gmp-6.1.0/mpn/x86_64/atom/copyi.asm
>> > -rw-rw-r-- bodrato/bodrato 10466 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/atom/redc_1.asm
>> > -rw-rw-r-- bodrato/bodrato 3437 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/atom/addmul_2.asm
>> > -rw-rw-r-- bodrato/bodrato 1357 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/atom/aors_n.asm
>> > -rw-rw-r-- bodrato/bodrato 2590 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/atom/lshift.asm
>> > -rw-rw-r-- bodrato/bodrato 2526 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/atom/rshift.asm
>> > -rw-rw-r-- bodrato/bodrato 1238 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/atom/popcount.asm
>> > -rw-rw-r-- bodrato/bodrato 10240 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/atom/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 4042 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/atom/aorrlsh2_n.asm
>> > -rw-rw-r-- bodrato/bodrato 5538 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/atom/rsh1aors_n.asm
>> > -rw-rw-r-- bodrato/bodrato 2657 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/atom/lshiftc.asm
>> > -rw-rw-r-- bodrato/bodrato 4847 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/atom/sublsh1_n.asm
>> > -rw-rw-r-- bodrato/bodrato 5102 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/atom/aorrlsh1_n.asm
>> gmp-6.1.0/mpn/x86_64/atom/copyd.asm
>> gmp-6.1.0/mpn/x86_64/atom/com.asm
>> > -rw-rw-r-- bodrato/bodrato 2966 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/atom/mul_1.asm
>> gmp-6.1.0/mpn/x86_64/nano/copyd.asm
>> > -rw-rw-r-- bodrato/bodrato 3830 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/nano/dive_1.asm
>> gmp-6.1.0/mpn/x86_64/nano/copyi.asm
>> > -rw-rw-r-- bodrato/bodrato 11861 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/nano/gmp-mparam.h
>> gmp-6.1.0/mpn/x86_64/nano/popcount.asm
>> gmp-6.1.0/mpn/x86_64/nano/gcd_1.asm
>> > -rw-rw-r-- bodrato/bodrato 12816 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bd2/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 11156 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/skylake/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 4141 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fastsse/com.asm
>> > -rw-rw-r-- bodrato/bodrato 5762 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fastsse/copyd-palignr.asm
>> > -rw-rw-r-- bodrato/bodrato 603 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fastsse/README
>> > -rw-rw-r-- bodrato/bodrato 3929 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fastsse/copyd.asm
>> gmp-6.1.0/mpn/x86_64/fastsse/copyi-palignr.asm
>> > -rw-rw-r-- bodrato/bodrato 4656 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fastsse/lshiftc.asm
>> > -rw-rw-r-- bodrato/bodrato 4520 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fastsse/sec_tabselect.asm
>> > -rw-rw-r-- bodrato/bodrato 6834 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fastsse/com-palignr.asm
>> > -rw-rw-r-- bodrato/bodrato 4524 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fastsse/lshiftc-movdqu2.asm
>> > -rw-rw-r-- bodrato/bodrato 4368 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fastsse/lshift.asm
>> > -rw-rw-r-- bodrato/bodrato 4561 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fastsse/rshift-movdqu2.asm
>> > -rw-rw-r-- bodrato/bodrato 4335 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fastsse/lshift-movdqu2.asm
>> > -rw-rw-r-- bodrato/bodrato 4392 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fastsse/copyi.asm
>> gmp-6.1.0/mpn/x86_64/fastavx/copyi.asm
>> > -rw-rw-r-- bodrato/bodrato 3795 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/fastavx/copyd.asm
>> > -rw-rw-r-- bodrato/bodrato 9575 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/k8/mulmid_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 4602 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/k8/div_qr_1n_pi1.asm
>> > -rw-rw-r-- bodrato/bodrato 11524 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/k8/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 4611 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/k8/aorrlsh_n.asm
>> > -rw-rw-r-- bodrato/bodrato 14488 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/k8/sqr_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 8007 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/k8/mullo_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 10545 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/k8/redc_1.asm
>> > -rw-rw-r-- bodrato/bodrato 8707 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/k8/mul_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 1328 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bd1/aorrlsh1_n.asm
>> gmp-6.1.0/mpn/x86_64/bd1/popcount.asm
>> > -rw-rw-r-- bodrato/bodrato 11949 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bd1/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 7587 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bd1/mul_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 3826 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bd1/aorsmul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 3813 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bd1/mul_1.asm
>> gmp-6.1.0/mpn/x86_64/bd1/copyd.asm
>> > -rw-rw-r-- bodrato/bodrato 1280 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bd1/sublsh1_n.asm
>> gmp-6.1.0/mpn/x86_64/bd1/hamdist.asm
>> gmp-6.1.0/mpn/x86_64/bd1/copyi.asm
>> > -rw-rw-r-- bodrato/bodrato 1282 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bd1/com.asm
>> > -rw-rw-r-- bodrato/bodrato 3654 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bd1/mul_2.asm
>> > -rw-rw-r-- bodrato/bodrato 478 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bd1/README
>> gmp-6.1.0/mpn/x86_64/bd1/gcd_1.asm
>> gmp-6.1.0/mpn/x86_64/bd1/sec_tabselect.asm
>> > -rw-rw-r-- bodrato/bodrato 3836 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bobcat/aorsmul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 8902 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bobcat/redc_1.asm
>> > -rw-rw-r-- bodrato/bodrato 2101 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bobcat/copyd.asm
>> gmp-6.1.0/mpn/x86_64/bobcat/mul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 10461 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bobcat/gmp-mparam.h
>> > -rw-rw-r-- bodrato/bodrato 3283 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bobcat/aors_n.asm
>> > -rw-rw-r-- bodrato/bodrato 2143 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bobcat/copyi.asm
>> > -rw-rw-r-- bodrato/bodrato 9865 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bobcat/sqr_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 8739 2015-11-01 20:49
>> gmp-6.1.0/mpn/x86_64/bobcat/mul_basecase.asm
>> > -rw-rw-r-- bodrato/bodrato 1577 2015-11-01 20:49
>> gmp-6.1.0/mpn/m88k/README
>> > -rw-rw-r-- bodrato/bodrato 2928 2015-11-01 20:49
>> gmp-6.1.0/mpn/m88k/add_n.s
>> > -rw-rw-r-- bodrato/bodrato 4316 2015-11-01 20:49
>> gmp-6.1.0/mpn/m88k/mul_1.s
>> > -rw-rw-r-- bodrato/bodrato 2998 2015-11-01 20:49
>> gmp-6.1.0/mpn/m88k/sub_n.s
>> gmp-6.1.0/mpn/m88k/mc88110/
>> > -rw-rw-r-- bodrato/bodrato 1823 2015-11-01 20:49
>> gmp-6.1.0/mpn/m88k/mc88110/mul_1.s
>> > -rw-rw-r-- bodrato/bodrato 1794 2015-11-01 20:49
>> gmp-6.1.0/mpn/m88k/mc88110/addmul_1.s
>> > -rw-rw-r-- bodrato/bodrato 6740 2015-11-01 20:49
>> gmp-6.1.0/mpn/m88k/mc88110/sub_n.S
>> > -rw-rw-r-- bodrato/bodrato 5059 2015-11-01 20:49
>> gmp-6.1.0/mpn/m88k/mc88110/add_n.S
>> > -rw-rw-r-- bodrato/bodrato 1653 2015-11-01 20:49
>> gmp-6.1.0/mpn/sh/add_n.asm
>> > -rw-rw-r-- bodrato/bodrato 1665 2015-11-01 20:49
>> gmp-6.1.0/mpn/sh/sub_n.asm
>> gmp-6.1.0/mpn/sh/sh2/
>> > -rw-rw-r-- bodrato/bodrato 1796 2015-11-01 20:49
>> gmp-6.1.0/mpn/sh/sh2/submul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 1696 2015-11-01 20:49
>> gmp-6.1.0/mpn/sh/sh2/mul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 1789 2015-11-01 20:49
>> gmp-6.1.0/mpn/sh/sh2/addmul_1.asm
>> > -rw-rw-r-- bodrato/bodrato 1309 2015-11-01 20:49
>> gmp-6.1.0/scanf/fscanf.c
>> > -rw-rw-r-- bodrato/bodrato 1747 2015-11-01 20:49
>> gmp-6.1.0/scanf/fscanffuns.c
>> > -rw-rw-r-- bodrato/bodrato 1822 2015-11-01 20:49
>> gmp-6.1.0/scanf/vsscanf.c
>> > -rw-rw-r-- bodrato/bodrato 1236 2015-11-01 20:49
>> gmp-6.1.0/scanf/vfscanf.c
>> > -rw-rw-r-- bodrato/bodrato 1441 2015-11-01 20:49
>> gmp-6.1.0/scanf/sscanf.c
>> > -rw-rw-r-- bodrato/bodrato 2546 2015-11-01 20:49
>> gmp-6.1.0/scanf/sscanffuns.c
>> > -rw-rw-r-- bodrato/bodrato 18681 2015-11-01 20:49
>> gmp-6.1.0/scanf/Makefile.in
>> > -rw-rw-r-- bodrato/bodrato 20908 2015-11-01 20:49
>> gmp-6.1.0/scanf/doscan.c
>> gmp-6.1.0/scanf/scanf.c
>> > -rw-rw-r-- bodrato/bodrato 1227 2015-11-01 20:49
>> gmp-6.1.0/scanf/vscanf.c
>> > -rw-rw-r-- bodrato/bodrato 1321 2015-11-01 20:49
>> gmp-6.1.0/scanf/Makefile.am
>> > -rw-rw-r-- bodrato/bodrato 9434 2015-11-01 20:49
>> gmp-6.1.0/rand/randlc2x.c
>> > -rw-rw-r-- bodrato/bodrato 2975 2015-11-01 20:49
>> gmp-6.1.0/rand/randlc2s.c
>> > -rw-rw-r-- bodrato/bodrato 2584 2015-11-01 20:49
>> gmp-6.1.0/rand/randmui.c
>> > -rw-rw-r-- bodrato/bodrato 1380 2015-11-01 20:49
>> gmp-6.1.0/rand/Makefile.am
>> > -rw-rw-r-- bodrato/bodrato 15761 2015-11-01 20:49
>> gmp-6.1.0/rand/randmt.c
>> > -rw-rw-r-- bodrato/bodrato 1404 2015-11-01 20:49
>> gmp-6.1.0/rand/rands.c
>> > -rw-rw-r-- bodrato/bodrato 1692 2015-11-01 20:49
>> gmp-6.1.0/rand/randbui.c
>> > -rw-rw-r-- bodrato/bodrato 18793 2015-11-01 20:49
>> gmp-6.1.0/rand/Makefile.in
>> > -rw-rw-r-- bodrato/bodrato 1261 2015-11-01 20:49
>> gmp-6.1.0/rand/randsd.c
>> > -rw-rw-r-- bodrato/bodrato 1223 2015-11-01 20:49
>> gmp-6.1.0/rand/randclr.c
>> > -rw-rw-r-- bodrato/bodrato 1498 2015-11-01 20:49
>> gmp-6.1.0/rand/rand.c
>> > -rw-rw-r-- bodrato/bodrato 1199 2015-11-01 20:49
>> gmp-6.1.0/rand/randdef.c
>> > -rw-rw-r-- bodrato/bodrato 1334 2015-11-01 20:49
>> gmp-6.1.0/rand/randsdui.c
>> > -rw-rw-r-- bodrato/bodrato 4499 2015-11-01 20:49
>> gmp-6.1.0/rand/randmts.c
>> > -rw-rw-r-- bodrato/bodrato 1250 2015-11-01 20:49
>> gmp-6.1.0/rand/randiset.c
>> > -rw-rw-r-- bodrato/bodrato 1662 2015-11-01 20:49
>> gmp-6.1.0/rand/randmt.h
>> > -rw-rw-r-- bodrato/bodrato 100 2015-11-01 20:50
>> gmp-6.1.0/doc/stamp-vti
>> > -rw-rw-r-- bodrato/bodrato 13299 2015-11-01 20:49
>> gmp-6.1.0/doc/configuration
>> > -rw-rw-r-- bodrato/bodrato 448954 2015-11-01 20:49
>> gmp-6.1.0/doc/gmp.texi
>> > -rw-rw-r-- bodrato/bodrato 298669 2015-11-01 20:50
>> gmp-6.1.0/doc/gmp.info-1
>> > -rw-rw-r-- bodrato/bodrato 5908 2015-11-01 20:50 gmp-6.1.0/doc/
>> gmp.info
>> > -rw-rw-r-- bodrato/bodrato 1235 2015-11-01 20:49
>> gmp-6.1.0/doc/Makefile.am
>> > -rw-rw-r-- bodrato/bodrato 51799 2015-11-01 20:49
>> gmp-6.1.0/doc/tasks.html
>> > -rw-rw-r-- bodrato/bodrato 23522 2015-11-01 20:49
>> gmp-6.1.0/doc/projects.html
>> > -rwxr-xr-x bodrato/bodrato 6047 2015-09-06 00:39
>> gmp-6.1.0/doc/mdate-sh
>> > -rw-rw-r-- bodrato/bodrato 212169 2015-11-01 20:50
>> gmp-6.1.0/doc/gmp.info-2
>> > -rw-rw-r-- bodrato/bodrato 27251 2015-11-01 20:49
>> gmp-6.1.0/doc/Makefile.in
>> > -rw-rw-r-- bodrato/bodrato 4945 2015-11-01 20:49
>> gmp-6.1.0/doc/isa_abi_headache
>> > -rw-r--r-- bodrato/bodrato 323102 2015-09-06 00:39
>> gmp-6.1.0/doc/texinfo.tex
>> gmp-6.1.0/doc/version.texi
>> > -rw-rw-r-- bodrato/bodrato 23559 2015-11-01 20:49
>> gmp-6.1.0/doc/fdl-1.3.texi
>> > + cd gmp-6.1.0
>> > + /bin/chmod -R a+rX,g-w,o-w .
>> > + cd
>> /home/varodek/development/rtems/rsb/rtems/build/sparc-rtems5-gcc-7.4.0-newlib-1d35a003f-x86_64-linux-gnu-1
>> > + /bin/rm -f gcc-7.4.0/gmp
>> > + ln -s
>> /home/varodek/development/rtems/rsb/rtems/build/sparc-rtems5-gcc-7.4.0-newlib-1d35a003f-x86_64-linux-gnu-1/gmp-6.1.0
>> gcc-7.4.0/gmp
>> > + echo 'RTEMS 5, RSB 780a2cf36c9c69e5e4c2393f8c0bbcf3854bbacf-modified,
>> Newlib 1d35a003f'
>> > + cd gcc-7.4.0
>> > + contrib/gcc_update --touch
>> > + cd
>> > + /bin/cat
>> /home/varodek/development/rtems/rsb/rtems/patches/0001-Port-ndbm.patch
>> > + /usr/bin/patch -p3
>> This is the problem, the -p3 is wrong. I don't know where this is
>> coming from though.
> I am also not able to resolve it, without it I wont be bale to check if
> ndbm port is working successfully in rtems or not.
> Also Testsuite won't run without it.
>> > patching file include/ndbm.h
>> > can't find file to patch at input line 108
>> > Perhaps you used the wrong -p or --strip option?
>> > The text leading up to this was:
>> > |diff --git a/newlib/libc/search/Makefile.am
>> b/newlib/libc/search/Makefile.am
>> > |index 98920c3f4..a61107fb9 100644
>> > |--- a/newlib/libc/search/Makefile.am
>> > |+++ b/newlib/libc/search/Makefile.am
>> > File to patch:
>> > Skip this patch? [y]
>> > Skipping patch.
>> > 1 out of 1 hunk ignored
>> > patching file search/ndbm.c
>> > shell cmd failed: /bin/sh -ex
>> /home/varodek/development/rtems/rsb/rtems/build/sparc-rtems5-gcc-7.4.0-newlib-1d35a003f-x86_64-linux-gnu-1/do-build
>> > error: building
>> > Help me out please
How did you generate the patch?
When testing newlib locally before submitting patches, I usually just built
it by hand and install it over the one built by the RSB. It saves the time
of building an entirely new toolset.
--joel
>> > Vaibhav Gupta
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190620/5fc64ca8/attachment-0001.html>
