[PATCH] Write event stream in file
Fri Jun 21 07:09:44 UTC 2019
On 21/06/2019 08:57, Ravindra Kumar Meena wrote:
>      >     seconds = (uint32_t) ( item->ns / 1000000000 );
>      >     nanoseconds = (uint32_t) ( item->ns % 1000000000 );
>      > +    ns=nanoseconds;
>     Why not move the nanoseconds variable into the upper block?
> Okay
>      >     fprintf( f, "%" PRIu32 ".%09" PRIu32 ":", seconds, nanoseconds );
>      >   } else {
>     Which value has "ns" in this path?
> na does not have a unique value. It is changing eveytime print_item() is
> called upon
>      >     fprintf( f, "*:" );
>      > @@ -153,6 +164,22 @@ static void print_item( FILE *f, const
>     client_item *item )
>      >     rtems_record_event_text( item->event ),
>      >     item->data
>      > +  FILE *fptr = fopen("event", "a");
>     How often gets this file opened and closed? Do you think that
>     opening and closing a file is a cheap operation? Could there be a
>     more efficient solution?
> I would like to know your approach. I will implement that only. It's
> better to implement your approach instead of mine. It will save some time.
The
static void print_item( FILE *f, const client_item *item )
gets already a file, please use it.
The file is currently stdout.  This should be changed to an event stream
file.  Add the file pointer to client_context and open the file in main().
>      > +  if (fptr == NULL)
>      > +       printf("Could not open file");
>      > +       return 0;
>     Can void functions return something?
> Ooops. I didn't see the void.
You get also a compiler warning for this.
../misc/record/record-main.c: In function ‘print_item’:
../misc/record/record-main.c:173:15: warning: ‘return’ with a value, in
function returning void
         return 0;
>      > +  ctf_item->cpu=item->cpu;
>     To which object points the the ctf_item pointer here?
> Are you expecting pointer here?
The ctf_item pointer points to a random memory location. You get also a
warning for this:
../misc/record/record-main.c: In function ‘handler’:
../misc/record/record-main.c:181:3: warning: ‘ctf_item’ may be used
uninitialized in this function [-Wmaybe-uninitialized]
    fprintf(fptr,ctf_item);
It must be:
ctf_event ctf_item;
>      > +  ctf_item->event=item->event;
>      > +  ctf_item->data=item->data;
>      > +  ctf_item->ns=ns;
>      > +  fprintf(fptr,ctf_item);
>      > +  fclose(fptr);
>      > static void flush_items( client_context *cctx )
>      > 2.7.4
>     Did you compile and run the program with this patch?
> Yes the rtems-tools was building successfully but I was getting nothing
> in file.
A build with such warnings is not successful. You can use GDB to debug
your program.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
