[PATCH] Write event stream in file
Ravindra Kumar Meena
rmeena840 at gmail.com
Fri Jun 21 08:33:29 UTC 2019
> The
> static void print_item( FILE *f, const client_item *item )
> gets already a file, please use it.
> The file is currently stdout. This should be changed to an event stream
> file. Add the file pointer to client_context and open the file in main().
> Are you suggesting to change the client_context from
typedef struct client_context {
uint64_t ns_threshold;
uint64_t last_ns;
uint32_t last_cpu;
bool flush;
bool only_one_cpu;
uint64_t counter;
SLIST_HEAD( , client_item ) free_items;
RB_HEAD( active, client_item ) active_items;
} client_context;
to
uint64_t last_ns;
uint32_t last_cpu;
bool flush;
bool only_one_cpu;
uint64_t counter;
FILE *fptr;
} client_context;
In this case, I have to create global client_context variable to store the
file pointer in it. Is that good?
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190621/add01eb5/attachment.html>
