[PATCH v2] Write event stream in file
Ravindra Meena
rmeena840 at gmail.com
Fri Jun 21 11:12:37 UTC 2019
misc/record/record-main.c | 30 ++++++++++++++----------------
1 file changed, 14 insertions(+), 16 deletions(-)
diff --git a/misc/record/record-main.c b/misc/record/record-main.c
index eccf291..9e9eaa3 100644
--- a/misc/record/record-main.c
+++ b/misc/record/record-main.c
@@ -83,6 +83,7 @@ typedef struct client_context {
uint64_t counter;
SLIST_HEAD( , client_item ) free_items;
RB_HEAD( active, client_item ) active_items;
+ FILE *event_stream;
} client_context;
static inline int item_cmp( const void *pa, const void *pb )
@@ -142,7 +143,7 @@ static int connect_client( const char *host, uint16_t port )
static void print_item( FILE *f, const client_item *item )
- ctf_event *ctf_item;
+ ctf_event ctf_item;
uint32_t ns;
if ( item->ns != 0 ) {
@@ -165,21 +166,13 @@ static void print_item( FILE *f, const client_item *item )
item->data
- FILE *fptr = fopen("event", "a");
+ ctf_item.cpu=item->cpu;
+ ctf_item.event=item->event;
+ ctf_item.data=item->data;
+ ctf_item.ns=ns;
- if (fptr == NULL)
- printf("Could not open file");
- return 0;
- ctf_item->cpu=item->cpu;
- ctf_item->event=item->event;
- ctf_item->data=item->data;
- ctf_item->ns=ns;
+ fwrite( &ctf_item, sizeof( ctf_item ), 1, f );
- fprintf(fptr,ctf_item);
- fclose(fptr);
static void flush_items( client_context *cctx )
@@ -215,7 +208,9 @@ static void flush_items( client_context *cctx )
RB_REMOVE( active, &cctx->active_items, x );
SLIST_INSERT_HEAD( &cctx->free_items, x, free_node );
- print_item( stdout, x );
+ print_item( cctx->event_stream, x);
@@ -337,6 +332,9 @@ int main( int argc, char **argv )
SLIST_INIT( &cctx.free_items );
RB_INIT( &cctx.active_items );
+ FILE *event_stream=fopen("event","wb");
+ cctx.event_stream=event_stream;
items = calloc( n, sizeof( *items ) );
assert( items != NULL );
@@ -358,7 +356,7 @@ int main( int argc, char **argv )
break;
+ fclose(event_stream);
rv = close( fd );
assert( rv == 0 );
2.7.4
