[PATCH] Write event stream in file
Fri Jun 21 12:26:31 UTC 2019
On 21/06/2019 13:20, Ravindra Kumar Meena wrote:
> Hi,
> I was able to store the event stream in file. I have sent the patch for
> the same. It has only one warning that I have to discuss with you.
> ../misc/record/record-main.c:172:14: warning: ‘ns’ may be used
> uninitialized in this function [-Wmaybe-uninitialized]
>     ctf_item.ns=ns;
> ../misc/record/record-main.c:147:12: note: ‘ns’ was declared here
>     uint32_t ns;
This is not a warning. It is an error. The ns variable is not set in the
else path.
It should look like this:
static void print_item( FILE *f, const client_item *item )
   ctf_event ctf_item;
   ctf_item.ns = item->ns;
   ctf_item.cpu = item->cpu;
   ctf_item.event = item->event;
   ctf_item.data = item->data;
   fwrite( &ctf_item, sizeof( ctf_item ), 1, f );
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
