[PATCH] Write event stream in file
Fri Jun 21 12:28:21 UTC 2019
On 21/06/2019 14:16, Ravindra Kumar Meena wrote:
> Hi,
> I tried to parse the event stream file and metadata file through
> babeltrace gives the following error:
> [error] Invalid magic number 0x30302E30 at packet 0 (file offset 0).
> [error] Stream index creation error.
> [error] Open file stream error.
> [warning] [Context] Cannot open_trace of format ctf at path ctf.
> [warning] [Context] cannot open trace "ctf" from ctf/ for reading.
> [error] Cannot open any trace for reading.
> [error] opening trace "ctf/" for reading.
> [error] none of the specified trace paths could be opened.
> I think the metadata file is not compatible with event stream generated.
Yes, indeed. I also think that the metadata doesn't describe the event
stream. The metadata should describe the struct ctf_item.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
