Add newlib patch to RTEMS RSB
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Fri Jun 21 14:21:48 UTC 2019
On Fri, Jun 21, 2019, 7:19 PM Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Jun 21, 2019 at 3:37 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> Hello,
>> I figured it out.
>> Below is the output given by shell
>> config: tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg
>> warning: rtems-gcc-7.4.0-newlib-1d35a003f.cfg:29: invalid format: '%setup
>> patch newlib -p'
>> *error: gcc-common-1.cfg:80: %patch already setup source: newlib -p1*
>> Build FAILED
>> Build Set: Time 0:06:29.257451
>> Build FAILED
>> I realized, the name of group of my patch and the source of newlib-source
>> was same in rtems-gcc-7.4.0-newlib-1d35a003f.cfg. Also, I had put
>> "%patch setup" statement before "%patch add" .
>> Here is the new git-diff. This got compiled successfully
> Great! How is the testing going?
I have placed ndbm.h in newlib/libc/include directory.
ndbm.h requires db.h (named as db_local.h in newlib), which is
present in newlib/libc/search directory.
This directory also contains hash.h and hash.c which is
required by ndbm.c
So gedare suggested me to place ndbm.c in this libc/search
directory.
Here, when I compiled newlib for sparc, it was successful and generates
function symbols.
But when I added this patch to RSB, and made a sample program calling ndbm
functions, just to check if it is successful port or not, its showing me
compile time error.
Error: https://lists.rtems.org/pipermail/devel/2019-June/026271.html
> For the RSB until the patch is merged upstream in newlib, it is preferred
> to get patches from tickets or mailing list posts. Since there is a ticket
> (2972) for adding ndbm, adding your patch to that and letting the RSB fetch
> it from there is the right approach.
> Also there is a ticket #2833 which lists POSIX .h files missing in newlib.
> It should be updated when all is merged.
>> diff --git a/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg
>> b/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg
>> index b28a4b1..5c5c346 100644
>> --- a/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg
>> +++ b/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg
>> @@ -23,6 +23,11 @@
>> %source set newlib --rsb-file=newlib-%{newlib_version}.tar.gz
>> https://codeload.github.com/RTEMS/sourceware-mirror-newlib-cygwin/tar.gz/%{newlib_version}
>> %hash sha512 newlib-%{newlib_version}.tar.gz
>> eb5943b207eca05fde4497c29491bbd3d07624e4becb410640ae8e177bd9212ca06cf726ee3882d6db5758cd03daf1462715e4b9b404abcc8f7cee5f811fd48b
>> +%patch add newlib_ndbm file://0001-Port-ndbm.patch
>> +%hash sha512 0001-Port-ndbm.patch
>> 0e05d97d0a6f8a436a233fe4fb3cbda7c0cfeab11cfda1c155d8aa5b80289f386896b0e8c28e5858e1d7409fd22c8d1cbaaccb181bc376845fe6d50b16359db6
>> +%patch setup newlib_ndbm -p1
>> %define isl_version 0.16.1
>> %hash sha512 isl-%{isl_version}.tar.bz2
>> c188667a84dc5bdddb4ab7c35f89c91bf15a8171f4fcaf41301cf285fb7328846d9a367c096012fec4cc69d244f0bc9e95d84c09ec097394cd4093076f2a041b
>> @@ -40,3 +45,4 @@
>> %define with_iconv 1
>> %include %{_configdir}/gcc-7.2-1.cfg
>> On Fri, Jun 21, 2019 at 4:25 AM Chris Johns <chrisj at rtems.org> wrote:
>>> On 21/6/19 4:43 am, Gedare Bloom wrote:
>>> > On Thu, Jun 20, 2019 at 11:32 AM Vaibhav Gupta <
>>> vaibhavgupta40 at gmail.com> wrote:
>>> >> + /bin/cat
>>> /home/varodek/development/rtems/rsb/rtems/patches/0001-Port-ndbm.patch
>>> >> + /usr/bin/patch -p3
>>> > This is the problem, the -p3 is wrong. I don't know where this is
>>> > coming from though.
>>> This must be from a `%patch` statement. The RSB has no preset patch
>>> options and
>>> there is no `-p3` in my repo.
>>> I suggest you run with --trace and then look at the macro maps to see
>>> where is
>>> it is coming from.
>>> Chris
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190621/1bfb2d0d/attachment.html>
