CTF example
Ravindra Kumar Meena
rmeena840 at gmail.com
Fri Jun 21 16:10:16 UTC 2019
Hi,
Thanks for sharing the example.
I managed to store the RTEMs event stream in a file. I have also written
the metada for the same but babeltrace is not able to read CTF because
metadata is not compatible with it.
Do you have any example or approach to make metadata compatible with events?
This is CTF event I am storing in event stream file.
typedef struct ctf_event {
uint64_t ns;
uint32_t cpu;
rtems_record_event event;
uint64_t data;
} ctf_event;
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190621/9ee61c20/attachment.html>
