[PATCH v1] Port ndbm
Vaibhav Gupta vaibhavgupta40 at gmail.com
Fri Jun 21 17:02:00 UTC 2019
On Fri, Jun 21, 2019, 9:46 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Jun 21, 2019 at 4:25 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > Hello Gedare,
> > As you suggested, I have placed   nbm.c    in    libc/search
>  directory. This directory contains   hash.h, db_local.h, hash.c. And all
> these are required by ndbm.
> > Here newlib got successfully compiled and It was generating function
> symbols.
> > After that when i added the patch to RSB, and tried to compile a test to
> check if ndbm is ported successfully or not.
> > It gave me error:
> > mv -f fileio/.deps/fileio-init.Tpo fileio/.deps/fileio-init.Po
> > sparc-rtems5-gcc -DHAVE_CONFIG_H -I.
> -I/home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples
>  -I.
> -I/home/varodek/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/include
> -I/home/varodek/development/rtems/kernel/rtems/cpukit/include
> -I/home/varodek/development/rtems/kernel/rtems/cpukit/score/cpu/sparc/include
> -I/home/varodek/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/lib/libbsp/sparc/erc32/include
> -I/home/varodek/development/rtems/kernel/rtems/bsps/include
> -I/home/varodek/development/rtems/kernel/rtems/bsps/sparc/include
> -I/home/varodek/development/rtems/kernel/rtems/bsps/sparc/erc32/include
> -DT_FILE_NAME='"init.c"'
> -I/home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/../support/include
>  -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections -Wall
> -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
> -Wnested-externs -MT hello/hello-init.o -MD -MP -MF
> hello/.deps/hello-init.Tpo -c -o hello/hello-init.o `test -f 'hello/init.c'
> || echo
> '/home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/'`hello/init.c
> > In file included from
> /home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/hello/init.c:17:0:
> > /home/varodek/development/rtems/5/sparc-rtems5/include/ndbm.h:43:10:
> fatal error: db_local.h: No such file or directory
> >  #include <db_local.h>
> > I found that     db_local.h    is not present in    rtems/5    directory.
> I suspect that the headers in search/ are not installed, they are only
> to be included during compilation of newlib, and probably should be
> included by #include "db_local.h" for example. I also find it likely
ndbm.h     is in   libc/include,   db_local.h    is in libc/search.
I will have to use   #include"../search/db_local.h"      which itself is a
very bad way to do so.
> that you should not be including these non-installed headers from
> installed headers inside of libc/include.
> So, you might need to rewrite the ndbm.h so that it does not rely on
> some internal headers of newlib.... Just my two cents. Not sure if I'm
> right. :)
I can do one thing. db_local.h    contains some data structures. Also it
contains some function declarations, definitions of which are present in
hash.h.
So i can put those declarations and data structures directly in    ndbm.h,
so won't need to call    db_local.h
Will this be practical?
> > Thank you
> > Vaibhav Gupta
> > On Fri, Jun 21, 2019 at 1:57 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> >>  newlib/libc/include/ndbm.h     |  84 +++++++++++++
> >>  newlib/libc/search/Makefile.am |   1 +
> >>  newlib/libc/search/ndbm.c      | 214 +++++++++++++++++++++++++++++++++
> >>  3 files changed, 299 insertions(+)
> >>  create mode 100644 newlib/libc/include/ndbm.h
> >>  create mode 100644 newlib/libc/search/ndbm.c
> >> diff --git a/newlib/libc/include/ndbm.h b/newlib/libc/include/ndbm.h
> >> new file mode 100644
> >> index 000000000..f89f97dd0
> >> --- /dev/null
> >> +++ b/newlib/libc/include/ndbm.h
> >> @@ -0,0 +1,84 @@
> >> + * SPDX-License-Identifier: BSD-3-Clause
> >> + * Copyright (c) 1990, 1993
> >> + *     The Regents of the University of California.  All rights
> reserved.
> >> + * This code is derived from software contributed to Berkeley by
> >> + * Margo Seltzer.
> >> + * Redistribution and use in source and binary forms, with or without
> >> + * modification, are permitted provided that the following conditions
> >> + * are met:
> >> + * 1. Redistributions of source code must retain the above copyright
> >> + *    notice, this list of conditions and the following disclaimer.
> >> + * 2. Redistributions in binary form must reproduce the above copyright
> >> + *    notice, this list of conditions and the following disclaimer in
> the
> >> + *    documentation and/or other materials provided with the
> distribution.
> >> + * 3. Neither the name of the University nor the names of its
> contributors
> >> + *    may be used to endorse or promote products derived from this
> software
> >> + *    without specific prior written permission.
> >> + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS''
> AND
> >> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> >> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> >> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE
> LIABLE
> >> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> CONSEQUENTIAL
> >> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
> GOODS
> >> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> INTERRUPTION)
> >> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
> STRICT
> >> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
> ANY WAY
> >> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
> OF
> >> + * SUCH DAMAGE.
> >> + *     @(#)ndbm.h      8.1 (Berkeley) 6/2/93
> >> + * $FreeBSD$
> >> +#ifndef _NDBM_H_
> >> +#define        _NDBM_H_
> >> +#define __DBINTERFACE_PRIVATE
> >> +#include <db_local.h>
> >> +/* Map dbm interface onto db(3). */
> >> +#define DBM_RDONLY     O_RDONLY
> >> +/* Flags to dbm_store(). */
> >> +#define DBM_INSERT      0
> >> +#define DBM_REPLACE     1
> >> + * The db(3) support for ndbm always appends this suffix to the
> >> + * file name to avoid overwriting the user's original database.
> >> +#define        DBM_SUFFIX      ".db"
> >> +typedef struct {
> >> +       void *dptr;
> >> +       int dsize;      /* XXX Should be size_t according to
> 1003.1-2008. */
> >> +} datum;
> >> +typedef DB DBM;
> >> +#define        dbm_pagfno(a)   DBM_PAGFNO_NOT_AVAILABLE
> >> +__BEGIN_DECLS
> >> +int     dbm_clearerr(DBM *);
> >> +void    dbm_close(DBM *);
> >> +int     dbm_delete(DBM *, datum);
> >> +int     dbm_error(DBM *);
> >> +datum   dbm_fetch(DBM *, datum);
> >> +datum   dbm_firstkey(DBM *);
> >> +#if __BSD_VISIBLE
> >> +long    dbm_forder(DBM *, datum);
> >> +#endif
> >> +datum   dbm_nextkey(DBM *);
> >> +DBM    *dbm_open(const char *, int, mode_t);
> >> +int     dbm_store(DBM *, datum, datum, int);
> >> +#if __BSD_VISIBLE
> >> +int     dbm_dirfno(DBM *);
> >> +#endif
> >> +__END_DECLS
> >> +#endif /* !_NDBM_H_ */
> >> diff --git a/newlib/libc/search/Makefile.am
> b/newlib/libc/search/Makefile.am
> >> index 98920c3f4..a61107fb9 100644
> >> --- a/newlib/libc/search/Makefile.am
> >> +++ b/newlib/libc/search/Makefile.am
> >> @@ -9,6 +9,7 @@ GENERAL_SOURCES = \
> >>         db_local.h \
> >>         extern.h \
> >>         hash.h \
> >> +       ndbm.c \
> >>         page.h \
> >>         qsort.c
> >> diff --git a/newlib/libc/search/ndbm.c b/newlib/libc/search/ndbm.c
> >> index 000000000..bd9c71e4f
> >> --- /dev/null
> >> +++ b/newlib/libc/search/ndbm.c
> >> @@ -0,0 +1,214 @@
> reserved.
> >> + * Margo Seltzer.
> >> + * are met:
> the
> distribution.
> contributors
> software
> AND
> THE
> PURPOSE
> LIABLE
> CONSEQUENTIAL
> GOODS
> INTERRUPTION)
> STRICT
> ANY WAY
> OF
> >> + * SUCH DAMAGE.
> >> +#if defined(LIBC_SCCS) && !defined(lint)
> >> +static char sccsid[] = "@(#)ndbm.c     8.4 (Berkeley) 7/21/94";
> >> +#endif /* LIBC_SCCS and not lint */
> >> +#include <sys/cdefs.h>
> >> +__FBSDID("$FreeBSD$");
> >> + * This package provides a dbm compatible interface to the new hashing
> >> + * package described in db(3).
> >> +#include <sys/param.h>
> >> +#include <stdio.h>
> >> +#include <string.h>
> >> +#include <errno.h>
> >> +#include <ndbm.h>
> >> +#include "hash.h"
> >> + * Returns:
> >> + *     *DBM on success
> >> + *      NULL on failure
> >> +extern DBM *
> >> +dbm_open(const char *file, int flags, mode_t mode)
> >> +       HASHINFO info;
> >> +       char path[MAXPATHLEN];
> >> +       info.bsize = 4096;
> >> +       info.ffactor = 40;
> >> +       info.nelem = 1;
> >> +       info.cachesize = 0;
> >> +       info.hash = NULL;
> >> +       info.lorder = 0;
> >> +       if( strlen(file) >= sizeof(path) - strlen(DBM_SUFFIX)) {
> >> +               errno = ENAMETOOLONG;
> >> +               return(NULL);
> >> +       (void)strcpy(path, file);
> >> +       (void)strcat(path, DBM_SUFFIX);
> >> +       return ((DBM *)__hash_open(path, flags, mode, 0, &info));
> >> +extern void
> >> +dbm_close(DBM *db)
> >> +       (void)(db->close)(db);
> >> + * Returns:
> >> + *     DATUM on success
> >> + *     NULL on failure
> >> +extern datum
> >> +dbm_fetch(DBM *db, datum key)
> >> +       datum retdata;
> >> +       int status;
> >> +       DBT dbtkey, dbtretdata;
> >> +       dbtkey.data = key.dptr;
> >> +       dbtkey.size = key.dsize;
> >> +       status = (db->get)(db, &dbtkey, &dbtretdata, 0);
> >> +       if (status) {
> >> +               dbtretdata.data = NULL;
> >> +               dbtretdata.size = 0;
> >> +       retdata.dptr = dbtretdata.data;
> >> +       retdata.dsize = dbtretdata.size;
> >> +       return (retdata);
> >> + * Returns:
> >> + *     NULL on failure
> >> +extern datum
> >> +dbm_firstkey(DBM *db)
> >> +       int status;
> >> +       datum retkey;
> >> +       DBT dbtretkey, dbtretdata;
> >> +       status = (db->seq)(db, &dbtretkey, &dbtretdata, R_FIRST);
> >> +       if (status)
> >> +               dbtretkey.data = NULL;
> >> +       retkey.dptr = dbtretkey.data;
> >> +       retkey.dsize = dbtretkey.size;
> >> +       return (retkey);
> >> + * Returns:
> >> + *     NULL on failure
> >> +extern datum
> >> +dbm_nextkey(DBM *db)
> >> +       int status;
> >> +       datum retkey;
> >> +       status = (db->seq)(db, &dbtretkey, &dbtretdata, R_NEXT);
> >> +       if (status)
> >> +       return (retkey);
> >> + * Returns:
> >> + *      0 on success
> >> + *     <0 failure
> >> +extern int
> >> +dbm_delete(DBM *db, datum key)
> >> +       int status;
> >> +       DBT dbtkey;
> >> +       status = (db->del)(db, &dbtkey, 0);
> >> +       if (status)
> >> +               return (-1);
> >> +       else
> >> +               return (0);
> >> + * Returns:
> >> + *      0 on success
> >> + *     <0 failure
> >> + *      1 if DBM_INSERT and entry exists
> >> +extern int
> >> +dbm_store(DBM *db, datum key, datum data, int flags)
> >> +       DBT dbtkey, dbtdata;
> >> +       dbtdata.data = data.dptr;
> >> +       dbtdata.size = data.dsize;
> >> +       return ((db->put)(db, &dbtkey, &dbtdata,
> >> +           (flags == DBM_INSERT) ? R_NOOVERWRITE : 0));
> >> +extern int
> >> +dbm_error(DBM *db)
> >> +       HTAB *hp;
> >> +       hp = (HTAB *)db->internal;
> >> +       return (hp->error);
> >> +extern int
> >> +dbm_clearerr(DBM *db)
> >> +       HTAB *hp;
> >> +       hp->error = 0;
> >> +       return (0);
> >> +extern int
> >> +dbm_dirfno(DBM *db)
> >> +       return(((HTAB *)db->internal)->fp);
> >> 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190621/9ee0f5b8/attachment-0001.html>
