[PATCH v1] Port ndbm
Vaibhav Gupta vaibhavgupta40 at gmail.com
Mon Jun 24 07:12:06 UTC 2019
I will test it!
On Sat, Jun 22, 2019 at 2:02 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Jun 21, 2019 at 1:42 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > On Fri, Jun 21, 2019 at 11:38 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> On Fri, Jun 21, 2019 at 11:03 AM Vaibhav Gupta <
> vaibhavgupta40 at gmail.com> wrote:
> >> > On Fri, Jun 21, 2019, 9:46 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> >> On Fri, Jun 21, 2019 at 4:25 AM Vaibhav Gupta <
> >> >> > Hello Gedare,
> >> >> > As you suggested, I have placed   nbm.c    in    libc/search
>  directory. This directory contains   hash.h, db_local.h, hash.c. And all
> these are required by ndbm.
> >> >> > Here newlib got successfully compiled and It was generating
> function symbols.
> >> >> > After that when i added the patch to RSB, and tried to compile a
> test to check if ndbm is ported successfully or not.
> >> >> > It gave me error:
> >> >> > mv -f fileio/.deps/fileio-init.Tpo fileio/.deps/fileio-init.Po
> >> >> > sparc-rtems5-gcc -DHAVE_CONFIG_H -I.
> -I/home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples
>  -I.
> -I/home/varodek/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/include
> -I/home/varodek/development/rtems/kernel/rtems/cpukit/include
> -I/home/varodek/development/rtems/kernel/rtems/cpukit/score/cpu/sparc/include
> -I/home/varodek/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/lib/libbsp/sparc/erc32/include
> -I/home/varodek/development/rtems/kernel/rtems/bsps/include
> -I/home/varodek/development/rtems/kernel/rtems/bsps/sparc/include
> -I/home/varodek/development/rtems/kernel/rtems/bsps/sparc/erc32/include
> -DT_FILE_NAME='"init.c"'
> -I/home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/../support/include
>  -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections -Wall
> -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
> -Wnested-externs -MT hello/hello-init.o -MD -MP -MF
> hello/.deps/hello-init.Tpo -c -o hello/hello-init.o `test -f 'hello/init.c'
> || echo
> '/home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/'`hello/init.c
> >> >> > In file included from
> /home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/hello/init.c:17:0:
> /home/varodek/development/rtems/5/sparc-rtems5/include/ndbm.h:43:10: fatal
> error: db_local.h: No such file or directory
> >> >> >  #include <db_local.h>
> >> >> > I found that     db_local.h    is not present in    rtems/5
> directory.
> >> >> I suspect that the headers in search/ are not installed, they are
> only
> >> >> to be included during compilation of newlib, and probably should be
> >> >> included by #include "db_local.h" for example. I also find it likely
> >> > ndbm.h     is in   libc/include,   db_local.h    is in libc/search.
> >> > I will have to use   #include"../search/db_local.h"      which itself
> is a very bad way to do so.
> >> Definitely shouldn't do that.
> >> >> that you should not be including these non-installed headers from
> >> >> installed headers inside of libc/include.
> >> >> So, you might need to rewrite the ndbm.h so that it does not rely on
> >> >> some internal headers of newlib.... Just my two cents. Not sure if
> I'm
> >> >> right. :)
> >> > I can do one thing. db_local.h    contains some data structures. Also
> it contains some function declarations, definitions of which are present in
> hash.h.
> >> > So i can put those declarations and data structures directly in
> ndbm.h, so won't need to call    db_local.h
> >> It would be better if you can remove anything requiring db_local.h
> >> from ndbm.h so that you don't have to #include db_local.h. You could
> >> put those things into maybe db_local.h, or into some new file like
> >> search/ndbm_local.h or something. you might need some guidance from
> >> newlib maintainers about what is the right way to split the
> >> public/private sides of headers like this.
> > Actually ndbm.h has declarations of database functions. And all of them
> require a data-type (structure)
> > defined in db_local.h  . So there is nothing in ndbm.h which I can shift
> to db_local.h
> > or ndbm_local.h . If I transfer anything, ndbm.h will lose its meaning.
> What about forward declare the structures?
> > Okay I will ask in newlib. Haven't got reply from them for my previous
> mail though.
> >> The basic idea is, how to make it so that #include <ndbm.h> doesn't
> >> need to include db_local.h? Instead, you can modify ndbm.c to do
> >> something lilke #include "db_local.h" and #include "ndbm_local.h"
> >> itself. This way, the ndbm.h header file does not need to "leak" the
> >> details of db_local.h to userland.
> >> Gedare
> >> > Will this be practical?
> >> >> > Thank you
> >> >> > Vaibhav Gupta
> >> >> > On Fri, Jun 21, 2019 at 1:57 AM Vaibhav Gupta <
> >> >> >>  newlib/libc/include/ndbm.h     |  84 +++++++++++++
> >> >> >>  newlib/libc/search/Makefile.am |   1 +
> >> >> >>  newlib/libc/search/ndbm.c      | 214
> >> >> >>  3 files changed, 299 insertions(+)
> >> >> >>  create mode 100644 newlib/libc/include/ndbm.h
> >> >> >>  create mode 100644 newlib/libc/search/ndbm.c
> >> >> >> diff --git a/newlib/libc/include/ndbm.h
> b/newlib/libc/include/ndbm.h
> >> >> >> new file mode 100644
> >> >> >> index 000000000..f89f97dd0
> >> >> >> --- /dev/null
> >> >> >> +++ b/newlib/libc/include/ndbm.h
> >> >> >> @@ -0,0 +1,84 @@
> >> >> >> + * SPDX-License-Identifier: BSD-3-Clause
> >> >> >> + * Copyright (c) 1990, 1993
> >> >> >> + *     The Regents of the University of California.  All rights
> reserved.
> >> >> >> + * This code is derived from software contributed to Berkeley by
> >> >> >> + * Margo Seltzer.
> >> >> >> + * Redistribution and use in source and binary forms, with or
> without
> >> >> >> + * modification, are permitted provided that the following
> conditions
> >> >> >> + * are met:
> >> >> >> + * 1. Redistributions of source code must retain the above
> copyright
> >> >> >> + *    notice, this list of conditions and the following
> disclaimer.
> >> >> >> + * 2. Redistributions in binary form must reproduce the above
> copyright
> disclaimer in the
> >> >> >> + *    documentation and/or other materials provided with the
> distribution.
> >> >> >> + * 3. Neither the name of the University nor the names of its
> contributors
> >> >> >> + *    may be used to endorse or promote products derived from
> this software
> >> >> >> + *    without specific prior written permission.
> >> >> >> + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS
> ``AS IS'' AND
> >> >> >> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> >> >> >> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> PARTICULAR PURPOSE
> >> >> >> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR
> CONTRIBUTORS BE LIABLE
> >> >> >> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> CONSEQUENTIAL
> >> >> >> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> SUBSTITUTE GOODS
> >> >> >> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> INTERRUPTION)
> >> >> >> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> CONTRACT, STRICT
> >> >> >> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> ARISING IN ANY WAY
> >> >> >> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> POSSIBILITY OF
> >> >> >> + * SUCH DAMAGE.
> >> >> >> + *     @(#)ndbm.h      8.1 (Berkeley) 6/2/93
> >> >> >> + * $FreeBSD$
> >> >> >> +#ifndef _NDBM_H_
> >> >> >> +#define        _NDBM_H_
> >> >> >> +#define __DBINTERFACE_PRIVATE
> >> >> >> +#include <db_local.h>
> >> >> >> +/* Map dbm interface onto db(3). */
> >> >> >> +#define DBM_RDONLY     O_RDONLY
> >> >> >> +/* Flags to dbm_store(). */
> >> >> >> +#define DBM_INSERT      0
> >> >> >> +#define DBM_REPLACE     1
> >> >> >> + * The db(3) support for ndbm always appends this suffix to the
> >> >> >> + * file name to avoid overwriting the user's original database.
> >> >> >> +#define        DBM_SUFFIX      ".db"
> >> >> >> +typedef struct {
> >> >> >> +       void *dptr;
> >> >> >> +       int dsize;      /* XXX Should be size_t according to
> 1003.1-2008. */
> >> >> >> +} datum;
> >> >> >> +typedef DB DBM;
> >> >> >> +#define        dbm_pagfno(a)   DBM_PAGFNO_NOT_AVAILABLE
> >> >> >> +__BEGIN_DECLS
> >> >> >> +int     dbm_clearerr(DBM *);
> >> >> >> +void    dbm_close(DBM *);
> >> >> >> +int     dbm_delete(DBM *, datum);
> >> >> >> +int     dbm_error(DBM *);
> >> >> >> +datum   dbm_fetch(DBM *, datum);
> >> >> >> +datum   dbm_firstkey(DBM *);
> >> >> >> +#if __BSD_VISIBLE
> >> >> >> +long    dbm_forder(DBM *, datum);
> >> >> >> +#endif
> >> >> >> +datum   dbm_nextkey(DBM *);
> >> >> >> +DBM    *dbm_open(const char *, int, mode_t);
> >> >> >> +int     dbm_store(DBM *, datum, datum, int);
> >> >> >> +#if __BSD_VISIBLE
> >> >> >> +int     dbm_dirfno(DBM *);
> >> >> >> +#endif
> >> >> >> +__END_DECLS
> >> >> >> +#endif /* !_NDBM_H_ */
> >> >> >> diff --git a/newlib/libc/search/Makefile.am
> b/newlib/libc/search/Makefile.am
> >> >> >> index 98920c3f4..a61107fb9 100644
> >> >> >> --- a/newlib/libc/search/Makefile.am
> >> >> >> +++ b/newlib/libc/search/Makefile.am
> >> >> >> @@ -9,6 +9,7 @@ GENERAL_SOURCES = \
> >> >> >>         db_local.h \
> >> >> >>         extern.h \
> >> >> >>         hash.h \
> >> >> >> +       ndbm.c \
> >> >> >>         page.h \
> >> >> >>         qsort.c
> >> >> >> diff --git a/newlib/libc/search/ndbm.c b/newlib/libc/search/ndbm.c
> >> >> >> index 000000000..bd9c71e4f
> >> >> >> --- /dev/null
> >> >> >> +++ b/newlib/libc/search/ndbm.c
> >> >> >> @@ -0,0 +1,214 @@
> reserved.
> >> >> >> + * Margo Seltzer.
> without
> conditions
> >> >> >> + * are met:
> copyright
> disclaimer.
> copyright
> disclaimer in the
> distribution.
> contributors
> this software
> ``AS IS'' AND
> TO, THE
> PARTICULAR PURPOSE
> CONSEQUENTIAL
> SUBSTITUTE GOODS
> INTERRUPTION)
> CONTRACT, STRICT
> ARISING IN ANY WAY
> POSSIBILITY OF
> >> >> >> + * SUCH DAMAGE.
> >> >> >> +#if defined(LIBC_SCCS) && !defined(lint)
> >> >> >> +static char sccsid[] = "@(#)ndbm.c     8.4 (Berkeley) 7/21/94";
> >> >> >> +#endif /* LIBC_SCCS and not lint */
> >> >> >> +#include <sys/cdefs.h>
> >> >> >> +__FBSDID("$FreeBSD$");
> >> >> >> + * This package provides a dbm compatible interface to the new
> hashing
> >> >> >> + * package described in db(3).
> >> >> >> +#include <sys/param.h>
> >> >> >> +#include <stdio.h>
> >> >> >> +#include <string.h>
> >> >> >> +#include <errno.h>
> >> >> >> +#include <ndbm.h>
> >> >> >> +#include "hash.h"
> >> >> >> + * Returns:
> >> >> >> + *     *DBM on success
> >> >> >> + *      NULL on failure
> >> >> >> +extern DBM *
> >> >> >> +dbm_open(const char *file, int flags, mode_t mode)
> >> >> >> +       HASHINFO info;
> >> >> >> +       char path[MAXPATHLEN];
> >> >> >> +       info.bsize = 4096;
> >> >> >> +       info.ffactor = 40;
> >> >> >> +       info.nelem = 1;
> >> >> >> +       info.cachesize = 0;
> >> >> >> +       info.hash = NULL;
> >> >> >> +       info.lorder = 0;
> >> >> >> +       if( strlen(file) >= sizeof(path) - strlen(DBM_SUFFIX)) {
> >> >> >> +               errno = ENAMETOOLONG;
> >> >> >> +               return(NULL);
> >> >> >> +       (void)strcpy(path, file);
> >> >> >> +       (void)strcat(path, DBM_SUFFIX);
> >> >> >> +       return ((DBM *)__hash_open(path, flags, mode, 0, &info));
> >> >> >> +extern void
> >> >> >> +dbm_close(DBM *db)
> >> >> >> +       (void)(db->close)(db);
> >> >> >> + * Returns:
> >> >> >> + *     DATUM on success
> >> >> >> + *     NULL on failure
> >> >> >> +extern datum
> >> >> >> +dbm_fetch(DBM *db, datum key)
> >> >> >> +       datum retdata;
> >> >> >> +       int status;
> >> >> >> +       DBT dbtkey, dbtretdata;
> >> >> >> +       dbtkey.data = key.dptr;
> >> >> >> +       dbtkey.size = key.dsize;
> >> >> >> +       status = (db->get)(db, &dbtkey, &dbtretdata, 0);
> >> >> >> +       if (status) {
> >> >> >> +               dbtretdata.data = NULL;
> >> >> >> +               dbtretdata.size = 0;
> >> >> >> +       retdata.dptr = dbtretdata.data;
> >> >> >> +       retdata.dsize = dbtretdata.size;
> >> >> >> +       return (retdata);
> >> >> >> + * Returns:
> >> >> >> + *     NULL on failure
> >> >> >> +extern datum
> >> >> >> +dbm_firstkey(DBM *db)
> >> >> >> +       int status;
> >> >> >> +       datum retkey;
> >> >> >> +       DBT dbtretkey, dbtretdata;
> >> >> >> +       status = (db->seq)(db, &dbtretkey, &dbtretdata, R_FIRST);
> >> >> >> +       if (status)
> >> >> >> +               dbtretkey.data = NULL;
> >> >> >> +       retkey.dptr = dbtretkey.data;
> >> >> >> +       retkey.dsize = dbtretkey.size;
> >> >> >> +       return (retkey);
> >> >> >> + * Returns:
> >> >> >> + *     NULL on failure
> >> >> >> +extern datum
> >> >> >> +dbm_nextkey(DBM *db)
> >> >> >> +       int status;
> >> >> >> +       datum retkey;
> >> >> >> +       status = (db->seq)(db, &dbtretkey, &dbtretdata, R_NEXT);
> >> >> >> +       if (status)
> >> >> >> +       return (retkey);
> >> >> >> + * Returns:
> >> >> >> + *      0 on success
> >> >> >> + *     <0 failure
> >> >> >> +extern int
> >> >> >> +dbm_delete(DBM *db, datum key)
> >> >> >> +       int status;
> >> >> >> +       DBT dbtkey;
> >> >> >> +       status = (db->del)(db, &dbtkey, 0);
> >> >> >> +       if (status)
> >> >> >> +               return (-1);
> >> >> >> +       else
> >> >> >> +               return (0);
> >> >> >> + * Returns:
> >> >> >> + *      0 on success
> >> >> >> + *     <0 failure
> >> >> >> + *      1 if DBM_INSERT and entry exists
> >> >> >> +extern int
> >> >> >> +dbm_store(DBM *db, datum key, datum data, int flags)
> >> >> >> +       DBT dbtkey, dbtdata;
> >> >> >> +       dbtdata.data = data.dptr;
> >> >> >> +       dbtdata.size = data.dsize;
> >> >> >> +       return ((db->put)(db, &dbtkey, &dbtdata,
> >> >> >> +           (flags == DBM_INSERT) ? R_NOOVERWRITE : 0));
> >> >> >> +extern int
> >> >> >> +dbm_error(DBM *db)
> >> >> >> +       HTAB *hp;
> >> >> >> +       hp = (HTAB *)db->internal;
> >> >> >> +       return (hp->error);
> >> >> >> +extern int
> >> >> >> +dbm_clearerr(DBM *db)
> >> >> >> +       HTAB *hp;
> >> >> >> +       hp->error = 0;
> >> >> >> +       return (0);
> >> >> >> +extern int
> >> >> >> +dbm_dirfno(DBM *db)
> >> >> >> +       return(((HTAB *)db->internal)->fp);
> >> >> >> 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190624/0387b653/attachment-0001.html>
