GSoC Project | Basic Support for Trace Compass
Ravindra Kumar Meena
rmeena840 at gmail.com
Mon Jun 24 16:00:14 UTC 2019
> https://diamon.org/ctf/#spec7 - "Magic number (CTF magic number:
> 0xC1FC1FC1) specifies that this is a CTF packet. This magic number is
> optional ... Stream ID, used as reference to stream description in
> metadata. This field is optional if there is only one stream
> description"
> These errors are caused by the metadata mismatch from the stream file,
> not by babeltrace. You need to write the metadata to match the trace
> data / stream.
The native trace stream in HEX currently looks like this
0400 0000 ed65 7e3d 0d00 010a 6231 5443
5e00 0000 5e00 0000 5e00 0000 0010 0000
0000 0000 0100 0000 0000 0000 0400 0000
61a3 813d 0000 0000 0d00 010a 5e00 0000
5e00 0000 1100 0000 0100 0000 0000 0000
0400 0000 3bb2 843d da0e 0300 0d00 010a
Above one is not CTF stream because it does not have CTF magic number
So it should look like this in HEX
c11f fcc1 0000 0000 0000 0000 0000 0000
All the example on [1] have this thing in common. I modified the stream
file and added magic number(0xc11fcc1) in it. Then, I parsed both stream
file and metadata. Babeltrace was able to read the stream file.
[1] https://diamon.org/ctf/
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190624/bff216f1/attachment.html>
