[PATCH] bsp/beagle: Partial re-write of I2C driver.
list at c-mauderer.de list at c-mauderer.de
Mon Jun 24 20:16:59 UTC 2019
From: Christian Mauderer <christian.mauderer at embedded-brains.de>
The old driver worked well for EEPROMS with the RTEMS EEPROM driver. But
it had problems with a lot of other situations. Although it's not a
direct port, the new driver is heavily modeled after the FreeBSD ti_i2c
driver.
 bsps/arm/beagle/i2c/bbb-i2c.c     | 646 ++++++++++++++++--------------
 bsps/arm/beagle/include/bsp/i2c.h |  84 +---
 bsps/arm/include/libcpu/am335x.h  |  35 +-
 3 files changed, 370 insertions(+), 395 deletions(-)
diff --git a/bsps/arm/beagle/i2c/bbb-i2c.c b/bsps/arm/beagle/i2c/bbb-i2c.c
index 3a8637d457..37b88864b9 100644
--- a/bsps/arm/beagle/i2c/bbb-i2c.c
+++ b/bsps/arm/beagle/i2c/bbb-i2c.c
@@ -9,17 +9,14 @@
  * Copyright (c) 2016 Punit Vara <punitvara at gmail.com>
  * Copyright (c) 2017 Sichen Zhao <zsc19940506 at gmail.com>
+ * Copyright (c) 2019 Christian Mauderer <christian.mauderer at embedded-brains.de>
  * The license and distribution terms for this file may be
  * found in the file LICENSE in this distribution or at
  * http://www.rtems.org/license/LICENSE.
- * Modified on Punit Vara<punitvara at gmail.com> works, currently
- * the i2c file is working on the Beaglebone Black board(AM335x)
+#include <rtems/bspIo.h>
 #include <bsp/i2c.h>
 #include <libcpu/am335x.h>
@@ -27,26 +24,114 @@
 #include <rtems/counter.h>
 #include <bsp/bbb-gpio.h>
+#include <dev/i2c/i2c.h>
-static void am335x_i2c0_pinmux( bbb_i2c_bus *bus )
+typedef struct bbb_i2c_bus {
+  i2c_bus base;
+  volatile bbb_i2c_regs *regs;
+  struct {
+    volatile uint32_t *ctrl_clkctrl;
+    volatile uint32_t *i2c_clkctrl;
+    volatile uint32_t *clkstctrl;
+  } clkregs;
+  struct {
+    volatile uint32_t *conf_sda;
+    uint32_t mmode_sda;
+    volatile uint32_t *conf_scl;
+    uint32_t mmode_scl;
+  } pinregs;
+  rtems_id task_id;
+  rtems_vector_number irq;
+  i2c_msg *buffer;
+  size_t buffer_pos;
+  int error;
+  uint32_t con_reg;
+} bbb_i2c_bus;
+#define TRANSFER_TIMEOUT_COUNT 100
+#define FIFO_THRESHOLD 5
+#define min(l,r) ((l) < (r) ? (l) : (r))
+#if 0
+#define debug_print(fmt, args...) printk("bbb-i2c: " fmt, ## args)
+#else
+#endif
+static int am335x_i2c_fill_registers(
+  bbb_i2c_bus *bus,
+  uintptr_t register_base
-  REG( bus->regs + AM335X_CONF_I2C0_SDA ) =
-    ( BBB_RXACTIVE | BBB_SLEWCTRL | BBB_PU_EN );
+  /* FIXME: The pin handling should be replaced by a proper pin handling during
+   * initialization. This one is heavily board specific. */
+#if ! IS_AM335X
+  printk ("The I2C driver currently only works on Beagle Bone. Please add your pin configs.")
+  return EINVAL;
+#endif
+  bus->regs = (volatile bbb_i2c_regs *) register_base;
+  switch ((intptr_t) bus->regs) {
+  case AM335X_I2C0_BASE:
+    bus->clkregs.ctrl_clkctrl = &REG(AM335X_SOC_CM_WKUP_REGS +
+                                 AM335X_CM_WKUP_CONTROL_CLKCTRL);
+    bus->clkregs.i2c_clkctrl = &REG(AM335X_SOC_CM_WKUP_REGS +
+                                 AM335X_CM_WKUP_I2C0_CLKCTRL);
+    bus->clkregs.clkstctrl = &REG(AM335X_SOC_CM_WKUP_REGS +
+                                   AM335X_CM_WKUP_CLKSTCTRL);
+    bus->pinregs.conf_sda = &REG(AM335X_PADCONF_BASE + AM335X_CONF_I2C0_SDA);
+    bus->pinregs.mmode_sda = 0;
+    bus->pinregs.conf_scl = &REG(AM335X_PADCONF_BASE + AM335X_CONF_I2C0_SCL);
+    bus->pinregs.mmode_scl = 0;
+    break;
+  case AM335X_I2C1_BASE:
+    bus->clkregs.i2c_clkctrl = &REG(AM335X_CM_PER_ADDR +
+                                 AM335X_CM_PER_I2C1_CLKCTRL);
+    bus->clkregs.clkstctrl = NULL;
+    bus->pinregs.conf_sda = &REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D1);
+    bus->pinregs.mmode_sda = 2;
+    bus->pinregs.conf_scl = &REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_CS0);
+    bus->pinregs.mmode_scl = 2;
+    break;
+  case AM335X_I2C2_BASE:
+                                 AM335X_CM_PER_I2C2_CLKCTRL);
+    bus->pinregs.conf_sda = &REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_CTSN);
+    bus->pinregs.mmode_sda = 3;
+    bus->pinregs.conf_scl = &REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_RTSN);
+    bus->pinregs.mmode_scl = 3;
+    break;
+  default:
+    return EINVAL;
+  return 0;
-  REG( bus->regs + AM335X_CONF_I2C0_SCL ) =
+static void am335x_i2c_pinmux( bbb_i2c_bus *bus )
+  *bus->pinregs.conf_sda =
+    ( BBB_RXACTIVE | BBB_SLEWCTRL | bus->pinregs.mmode_sda);
+  *bus->pinregs.conf_scl =
+    ( BBB_RXACTIVE | BBB_SLEWCTRL | bus->pinregs.mmode_scl);
-static void I2C0ModuleClkConfig( void )
+static void am335x_i2c_module_clk_enable( bbb_i2c_bus *bus )
+  volatile uint32_t *ctrl_clkctrl = bus->clkregs.ctrl_clkctrl;
+  volatile uint32_t *i2c_clkctrl = bus->clkregs.i2c_clkctrl;
+  volatile uint32_t *clkstctrl = bus->clkregs.clkstctrl;
   /* Writing to MODULEMODE field of AM335X_CM_WKUP_I2C0_CLKCTRL register. */
-  REG( AM335X_SOC_CM_WKUP_REGS + AM335X_CM_WKUP_I2C0_CLKCTRL ) |=
-    AM335X_CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE;
+  *i2c_clkctrl |= AM335X_CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE;
   /* Waiting for MODULEMODE field to reflect the written value. */
   while ( AM335X_CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE !=
-          ( REG( AM335X_SOC_CM_WKUP_REGS + AM335X_CM_WKUP_I2C0_CLKCTRL ) &
-            AM335X_CM_WKUP_I2C0_CLKCTRL_MODULEMODE ) ) ;
+          ( *i2c_clkctrl & AM335X_CM_WKUP_I2C0_CLKCTRL_MODULEMODE ) )
+  { /* busy wait */ }
    * Waiting for IDLEST field in AM335X_CM_WKUP_CONTROL_CLKCTRL
@@ -54,16 +139,18 @@ static void I2C0ModuleClkConfig( void )
   while ( ( AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC <<
             AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT ) !=
-          ( REG( AM335X_SOC_CM_WKUP_REGS + AM335X_CM_WKUP_CONTROL_CLKCTRL ) &
-            AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST ) ) ;
-   * Waiting for CLKACTIVITY_I2C0_GFCLK field in AM335X_CM_WKUP_CLKSTCTRL
-   * register to attain desired value.
-  while ( AM335X_CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK !=
-          ( REG( AM335X_SOC_CM_WKUP_REGS + AM335X_CM_WKUP_CLKSTCTRL ) &
-            AM335X_CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK ) ) ;
+          ( *ctrl_clkctrl & AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST ) )
+  if ( clkstctrl != NULL ) {
+     * Waiting for CLKACTIVITY_I2C0_GFCLK field in AM335X_CM_WKUP_CLKSTCTRL
+     * register to attain desired value.
+    while ( AM335X_CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK !=
+            ( *clkstctrl & AM335X_CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK ) )
    * Waiting for IDLEST field in AM335X_CM_WKUP_I2C0_CLKCTRL register to attain
@@ -71,333 +158,286 @@ static void I2C0ModuleClkConfig( void )
   while ( ( AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC <<
             AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT ) !=
-            AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST ) ) ;
-static void am335x_i2c_reset( bbb_i2c_bus *bus )
-  volatile bbb_i2c_regs *regs = bus->regs;
-  int                    timeout = I2C_TIMEOUT;
-  if ( REG( &regs->BBB_I2C_CON ) & BBB_I2C_CON_EN ) {
-    REG( &regs->BBB_I2C_CON ) = BBB_I2C_CON_CLR;
-    udelay( 50000 );
-  REG( &regs->BBB_I2C_SYSC ) = BBB_I2C_SYSC_SRST; /* for ES2 after soft reset */
-  udelay( 1000 );
-  REG( &regs->BBB_I2C_CON ) = BBB_I2C_CON_EN;
-  while ( !( REG( &regs->BBB_I2C_SYSS ) & BBB_I2C_SYSS_RDONE ) && timeout-- ) {
-    if ( timeout <= 0 ) {
-      puts( "ERROR: Timeout in soft-reset\n" );
-      return;
-    udelay( 1000 );
+          ( *i2c_clkctrl & AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST ) ) ;
- * Possible values for msg->flag
- * - @ref I2C_M_TEN,
- * - @ref I2C_M_RD,
- * - @ref I2C_M_STOP,
- * - @ref I2C_M_NOSTART,
- * - @ref I2C_M_REV_DIR_ADDR,
- * - @ref I2C_M_IGNORE_NAK,
- * - @ref I2C_M_NO_RD_ACK, and
- * - @ref I2C_M_RECV_LEN.
-static void am335x_i2c_set_address_size(
-  const i2c_msg         *msgs,
+static int am335x_i2c_set_clock(
+  i2c_bus      *base,
+  unsigned long clock
-   * Can be configured multiple modes here.
-   * Need to think about own address modes
-  if ( ( msgs->flags & I2C_M_TEN ) == 0 ) {
-    /* 7-bit mode slave address mode */
-    REG( &regs->BBB_I2C_CON ) = AM335X_I2C_CFG_7BIT_SLAVE_ADDR;
-  } else {
-    /* 10-bit slave address mode */
-    REG( &regs->BBB_I2C_CON ) = AM335X_I2C_CFG_10BIT_SLAVE_ADDR;
-static void am335x_i2c_next_byte( bbb_i2c_bus *bus )
-  i2c_msg *msg;
+  bbb_i2c_bus           *bus = (bbb_i2c_bus *) base;
+  uint32_t               prescaler, divider;
-  ++bus->msgs;
-  --bus->msg_todo;
-  msg = &bus->msgs[ 0 ];
-  bus->current_msg_todo = msg->len;
-  bus->current_msg_byte = msg->buf;
+  prescaler = ( BBB_I2C_SYSCLK / BBB_I2C_INTERNAL_CLK ) - 1;
+  bus->regs->BBB_I2C_PSC = prescaler;
+  divider = BBB_I2C_INTERNAL_CLK / ( 2 * clock );
+  bus->regs->BBB_I2C_SCLL = ( divider - 7 );
+  bus->regs->BBB_I2C_SCLH = ( divider - 5 );
-static void am335x_i2c_masterint_enable(
-  volatile bbb_i2c_regs *regs,
-  unsigned int           flag
-  REG( &regs->BBB_I2C_IRQENABLE_SET ) |= flag;
+  return 0;
-static void am335x_i2c_masterint_disable(
-  unsigned int           flag
+static int am335x_i2c_reset( bbb_i2c_bus *bus )
-  REG( &regs->BBB_I2C_IRQENABLE_CLR ) = flag;
+  volatile bbb_i2c_regs *regs = bus->regs;
+  int                    timeout = 100;
+  int                    err;
-static void am335x_int_clear(
-  unsigned int           flag
-  REG( &regs->BBB_I2C_IRQSTATUS ) = flag;
+  bus->con_reg = 0;
+  regs->BBB_I2C_CON = bus->con_reg;
+  udelay( 50000 );
-static void am335x_clean_interrupts( volatile bbb_i2c_regs *regs )
-  am335x_i2c_masterint_enable( regs, BBB_I2C_ALL_FLAGS );
-  am335x_int_clear( regs, BBB_I2C_ALL_FLAGS );
-  am335x_i2c_masterint_disable( regs, BBB_I2C_ALL_FLAGS );
-static void am335x_i2c_setup_read_transfer(
-  bbb_i2c_bus           *bus,
-  bool                   send_stop
-  REG( &regs->BBB_I2C_CNT ) = bus->current_msg_todo;
+  regs->BBB_I2C_SYSC = AM335X_I2C_SYSC_SRST;
+  udelay( 1000 );
+  regs->BBB_I2C_CON = AM335X_I2C_CON_I2C_EN;
-  REG( &regs->BBB_I2C_CON ) = AM335X_I2C_CFG_MST_RX | AM335X_I2C_CON_I2C_EN;
+  while ( !( regs->BBB_I2C_SYSS & AM335X_I2C_SYSS_RDONE )
+          && timeout >= 0 ) {
+    --timeout;
+    udelay( 100 );
-  if ( send_stop ) {
-    REG( &regs->BBB_I2C_CON ) |= AM335X_I2C_CON_START | AM335X_I2C_CON_STOP;
-  } else {
-    REG( &regs->BBB_I2C_CON ) |= AM335X_I2C_CON_START;
+  if ( timeout <= 0 ) {
+    puts( "ERROR: Timeout in soft-reset\n" );
+    return ETIMEDOUT;
-  am335x_i2c_masterint_enable( regs, AM335X_I2C_INT_RECV_READY |
-    AM335X_I2C_IRQSTATUS_ARDY );
+  /* Disable again after reset */
-static void am335x_i2c_continue_read_transfer(
-  bbb_i2c_bus           *bus,
-  bus->current_msg_byte[ bus->already_transferred ] =
-    REG( &regs->BBB_I2C_DATA );
+  err = am335x_i2c_set_clock( &bus->base, I2C_BUS_CLOCK_DEFAULT );
+  if (err) {
+    return err;
-  bus->already_transferred++;
+  regs->BBB_I2C_BUF = AM335X_I2C_BUF_TXTRSH(FIFO_THRESHOLD) |
+                              AM335X_I2C_BUF_RXTRSH(FIFO_THRESHOLD);
-  REG( &regs->BBB_I2C_IRQSTATUS ) = AM335X_I2C_INT_RECV_READY;
+  /* Enable the I2C controller in master mode. */
+  bus->con_reg |= AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_MST;
-  if ( bus->already_transferred == bus->current_msg_todo - 1 ) {
-    REG( &regs->BBB_I2C_CON ) |= AM335X_I2C_CON_STOP;
+  regs->BBB_I2C_IRQENABLE_SET =
+      AM335X_I2C_IRQSTATUS_XDR | AM335X_I2C_IRQSTATUS_XRDY |
+      AM335X_I2C_IRQSTATUS_RDR | AM335X_I2C_IRQSTATUS_RRDY |
+      AM335X_I2C_IRQSTATUS_ARDY | AM335X_I2C_IRQSTATUS_NACK |
+      AM335X_I2C_IRQSTATUS_AL;
-static void am335x_i2c_continue_write(
-  bbb_i2c_bus           *bus,
-  if ( bus->already_transferred == bus->msg_todo ) {
-    REG( &regs->BBB_I2C_DATA ) =
-      bus->current_msg_byte[ bus->already_transferred ];
-    REG( &regs->BBB_I2C_IRQSTATUS ) = AM335X_I2C_IRQSTATUS_XRDY;
-    am335x_i2c_masterint_disable( regs, AM335X_I2C_IRQSTATUS_XRDY );
-  } else {
-    writeb( bus->current_msg_byte[ bus->already_transferred ],
-      &regs->BBB_I2C_DATA );
-static void am335x_i2c_setup_write_transfer(
-  bbb_i2c_bus           *bus,
-  volatile unsigned int no_bytes;
-  no_bytes = REG( &regs->BBB_I2C_CNT );
-  (void) no_bytes; /* indicate we know that no_bytes is not referenced again */
-  REG( &regs->BBB_I2C_SA ) = msgs->addr;
-  REG( &regs->BBB_I2C_CON ) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN;
-  am335x_clean_interrupts( regs );
-  am335x_i2c_masterint_enable( regs, AM335X_I2C_IRQSTATUS_XRDY );
+  return 0;
-static void am335x_i2c_setup_transfer(
-  bbb_i2c_bus           *bus,
+/* Return true if done. */
+static bool am335x_i2c_transfer_intr(bbb_i2c_bus *bus, uint32_t status)
-  const i2c_msg *msgs = bus->msgs;
-  uint32_t       msg_todo = bus->msg_todo;
-  bool           send_stop = false;
-  uint32_t       i;
+  size_t i;
+  size_t amount = 0;
-  bus->current_todo = msgs[ 0 ].len;
+  /* Handle errors */
+  if ((status & AM335X_I2C_IRQSTATUS_NACK) != 0) {
+    debug_print("NACK\n");
+    regs->BBB_I2C_IRQSTATUS = AM335X_I2C_IRQSTATUS_NACK;
+    bus->error = ENXIO;
+  } else if ((status & AM335X_I2C_IRQSTATUS_AL) != 0) {
+    debug_print("Arbitration lost\n");
+    regs->BBB_I2C_IRQSTATUS = AM335X_I2C_IRQSTATUS_AL;
-  for ( i = 1; i < msg_todo && ( msgs[ i ].flags & I2C_M_NOSTART ) != 0;
-        ++i ) {
-    bus->current_todo += msgs[ i ].len;
+  /* Transfer finished? */
+  if ((status & AM335X_I2C_IRQSTATUS_ARDY) != 0) {
+    debug_print("ARDY transaction complete\n");
+    if (bus->error != 0 && (bus->buffer->flags & I2C_M_STOP) == 0) {
+      regs->BBB_I2C_CON = bus->con_reg | AM335X_I2C_CON_STOP;
+    regs->BBB_I2C_IRQSTATUS = AM335X_I2C_IRQSTATUS_ARDY |
+                              AM335X_I2C_IRQSTATUS_RRDY |
+                              AM335X_I2C_IRQSTATUS_XRDY;
+    return true;
-  regs = bus->regs;
-  REG( &bus->regs->BBB_I2C_BUF ) |= AM335X_I2C_BUF_TXFIFO_CLR;
-  REG( &bus->regs->BBB_I2C_BUF ) |= AM335X_I2C_BUF_RXFIFO_CLR;
-  am335x_i2c_set_address_size( msgs, regs );
-  bus->read = ( msgs->flags & I2C_M_RD ) != 0;
-  bus->already_transferred = ( bus->read == true ) ? 0 : 1;
+  if (bus->buffer->flags & I2C_M_RD) {
+    if (status & AM335X_I2C_IRQSTATUS_RDR) {
+      debug_print("RDR\n");
+      /* last data received */
+      amount = bus->buffer->len - bus->buffer_pos;
+    } else if (status & AM335X_I2C_IRQSTATUS_RRDY) {
+      debug_print("RRDY\n");
+      /* FIFO threshold reached */
+      amount = min(FIFO_THRESHOLD, bus->buffer->len - bus->buffer_pos);
-  if ( bus->read ) {
-    if ( bus->current_msg_todo == 1 ) {
-      send_stop = true;
+    debug_print("Read %d bytes\n", amount);
+    for (i = 0; i < amount; i++) {
+      bus->buffer->buf[bus->buffer_pos] = (uint8_t)(regs->BBB_I2C_DATA);
+      ++bus->buffer_pos;
-    am335x_i2c_setup_read_transfer( bus, regs, msgs, send_stop );
+      regs->BBB_I2C_IRQSTATUS =AM335X_I2C_IRQSTATUS_RDR;
+    if (status & AM335X_I2C_IRQSTATUS_RRDY) {
+      regs->BBB_I2C_IRQSTATUS =AM335X_I2C_IRQSTATUS_RRDY;
   } else {
-    am335x_i2c_setup_write_transfer( bus, regs, msgs );
+    if (status & AM335X_I2C_IRQSTATUS_XDR) {
+      debug_print("XDR\n");
+      /* Remaining TX data won't reach the FIFO threshold. */
+    } else if (status & AM335X_I2C_IRQSTATUS_XRDY) {
+      debug_print("XRDY\n");
+    debug_print("Write %d bytes\n", amount);
+      regs->BBB_I2C_DATA = bus->buffer->buf[bus->buffer_pos];
+      regs->BBB_I2C_IRQSTATUS = AM335X_I2C_IRQSTATUS_XDR;
+    if (status & AM335X_I2C_IRQSTATUS_XRDY) {
+      regs->BBB_I2C_IRQSTATUS = AM335X_I2C_IRQSTATUS_XRDY;
+  return false;
 static void am335x_i2c_interrupt( void *arg )
-  bbb_i2c_bus           *bus = arg;
+  bbb_i2c_bus *bus = arg;
-  /* Get status of enabled interrupts */
-  uint32_t irqstatus = REG( &regs->BBB_I2C_IRQSTATUS );
-  bool     done = false;
+  uint32_t status;
-   * Clear all enabled interrupt except receive ready
-   * and transmit ready interrupt in status register
-    ( irqstatus & ~( AM335X_I2C_IRQSTATUS_RRDY |
-                     AM335X_I2C_IRQSTATUS_XRDY ) );
+  status = regs->BBB_I2C_IRQSTATUS;
-  if ( irqstatus & AM335X_I2C_INT_RECV_READY ) {
-    am335x_i2c_continue_read_transfer( bus, regs );
-  if ( irqstatus & AM335X_I2C_IRQSTATUS_XRDY ) {
-    am335x_i2c_continue_write( bus, regs );
+  debug_print("interrupt: %08x\n", status);
-  if ( irqstatus & AM335X_I2C_IRQSTATUS_NACK ) {
-    done = true;
-    am335x_i2c_masterint_disable( regs, AM335X_I2C_IRQSTATUS_NACK );
+  if (status == 0) {
+    /* Why can this even happen? */
+    return;
-  if ( irqstatus & AM335X_I2C_IRQSTATUS_ARDY ) {
-    done = true;
-    REG( &regs->BBB_I2C_IRQSTATUS ) = BBB_I2C_STAT_ARDY;
+  if (bus->buffer == NULL) {
+    debug_print("Buffer is NULL\n");
+    bus->error = EINVAL;
-  if ( irqstatus & AM335X_I2C_IRQSTATUS_BF ) {
-    REG( &regs->BBB_I2C_IRQSTATUS ) = AM335X_I2C_IRQSTATUS_BF;
-  if ( done ) {
-    uint32_t err = irqstatus & BBB_I2C_IRQ_ERROR;
-    am335x_i2c_next_byte( bus );
-    if ( bus->msg_todo == 0 ) {
-      rtems_status_code sc;
-      am335x_i2c_masterint_disable( regs, ( AM335X_I2C_IRQSTATUS_RRDY |
-                                            AM335X_I2C_IRQSTATUS_XRDY |
-                                            AM335X_I2C_IRQSTATUS_BF ) );
-      REG( &regs->BBB_I2C_IRQSTATUS ) = err;
-      sc = rtems_event_transient_send( bus->task_id );
-      _Assert( sc == RTEMS_SUCCESSFUL );
-      (void) sc;
-    } else {
-      am335x_i2c_setup_transfer( bus, regs );
+  if (bus->buffer == NULL || am335x_i2c_transfer_intr(bus, status)) {
+    rtems_status_code sc;
+    sc = rtems_event_transient_send( bus->task_id );
+    _Assert( sc == RTEMS_SUCCESSFUL );
+    (void) sc; /* suppress warning in case of no assert */
 static int am335x_i2c_transfer(
   i2c_bus *base,
   i2c_msg *msgs,
-  uint32_t msg_count
+  uint32_t nmsgs
-  bbb_i2c_bus           *bus = (bbb_i2c_bus *) base;
-  volatile bbb_i2c_regs *regs;
-  uint32_t               i;
+  size_t i;
+  int err = 0;
+  bool repstart = false;
+  int timeout = 0;
+  uint32_t reg;
+  bus->task_id = rtems_task_self();
-  rtems_task_wake_after( 1 );
+  for (i = 0; i < nmsgs; i++) {
+    bus->buffer = &msgs[i];
+    bus->buffer_pos = 0;
+    bus->error = 0;
-  if ( msg_count < 1 ) {
-    return 1;
+    debug_print("processing %2d/%d: addr: 0x%04x, flags: 0x%04x, len: %d, buf: %p\n",
+        i, nmsgs, msgs[i].addr, msgs[i].flags, msgs[i].len, msgs[i].buf);
-  for ( i = 0; i < msg_count; ++i ) {
-    if ( ( msgs[ i ].flags & I2C_M_RECV_LEN ) != 0 ) {
-      return -EINVAL;
+    if (bus->buffer == NULL || bus->buffer->buf == NULL ||
+        bus->buffer->len == 0) {
+      err = EINVAL;
+      break;
-  bus->msgs = &msgs[ 0 ];
-  bus->msg_todo = msg_count;
-  bus->current_msg_todo = msgs[ 0 ].len;
-  bus->current_msg_byte = msgs[ 0 ].buf;
-  bus->task_id = rtems_task_self();
-  regs = bus->regs;
-  REG( &regs->BBB_I2C_IRQENABLE_SET ) = BBB_I2C_IRQ_USED;
+     * Send START when bus is busy on repeated starts.
+     * Otherwise wait some time.
+    if (!repstart) {
+      timeout = 0;
+      while ((regs->BBB_I2C_IRQSTATUS_RAW & AM335X_I2C_IRQSTATUS_BB) != 0
+              && timeout <= TRANSFER_TIMEOUT_COUNT) {
+        ++timeout;
+        rtems_task_wake_after(RTEMS_MICROSECONDS_TO_TICKS(1000));
+      if (timeout > TRANSFER_TIMEOUT_COUNT) {
+        err = EBUSY;
+        break;
+      timeout = 0;
+    } else {
+      repstart = false;
+    if ((bus->buffer->flags & I2C_M_STOP) == 0) {
+      repstart = true;
-  sc = rtems_event_transient_receive( RTEMS_WAIT, bus->base.timeout );
+    regs->BBB_I2C_SA = bus->buffer->addr;
+    regs->BBB_I2C_CNT = bus->buffer->len;
-  if ( sc != RTEMS_SUCCESSFUL ) {
-    am335x_i2c_reset( bus );
-    rtems_event_transient_clear();
+    regs->BBB_I2C_BUF |= AM335X_I2C_BUF_RXFIFO_CLR | AM335X_I2C_BUF_TXFIFO_CLR;
-    return -ETIMEDOUT;
+    reg = bus->con_reg | AM335X_I2C_CON_START;
+    if (!repstart) {
+      reg |= AM335X_I2C_CON_STOP;
+    if ((bus->buffer->flags & I2C_M_RD) == 0) {
+      reg |= AM335X_I2C_CON_TRX;
+    /* Implicit stop on last message. */
+    if (i == nmsgs - 1) {
+    regs->BBB_I2C_CON = reg;
+    sc = rtems_event_transient_receive( RTEMS_WAIT, bus->base.timeout );
+    if ( sc != RTEMS_SUCCESSFUL ) {
+      rtems_event_transient_clear();
+      err = ETIMEDOUT;
+      break;
+    if (bus->error) {
+      err = bus->error;
+      break;
-  return 0;
+  if (timeout == 0) {
+      ++timeout;
-static int am335x_i2c_set_clock(
-  i2c_bus      *base,
-  unsigned long clock
-  uint32_t               prescaler, divider;
+  if ((regs->BBB_I2C_CON & AM335X_I2C_CON_MST) == 0) {
-  prescaler = ( BBB_I2C_SYSCLK / BBB_I2C_INTERNAL_CLK ) - 1;
-  REG( &bus->regs->BBB_I2C_PSC ) = prescaler;
-  divider = BBB_I2C_INTERNAL_CLK / ( 2 * clock );
-  REG( &bus->regs->BBB_I2C_SCLL ) = ( divider - 7 );
-  REG( &bus->regs->BBB_I2C_SCLH ) = ( divider - 5 );
+  bus->buffer = NULL;
-  return 0;
+  return -err;
 static void am335x_i2c_destroy( i2c_bus *base )
@@ -405,6 +445,8 @@ static void am335x_i2c_destroy( i2c_bus *base )
+  bus->regs->BBB_I2C_IRQENABLE_CLR = 0xFFFF;
+  bus->regs->BBB_I2C_CON = 0;
   sc = rtems_interrupt_handler_remove( bus->irq, am335x_i2c_interrupt, bus );
   (void) sc;
@@ -422,36 +464,36 @@ int am335x_i2c_bus_register(
   int               err;
-  /* Check bus number is >0 & <MAX */
+  (void) input_clock; /* FIXME: Unused. Left for compatibility. */
   bus = (bbb_i2c_bus *) i2c_bus_alloc_and_init( sizeof( *bus ) );
   if ( bus == NULL ) {
     return -1;
-  bus->regs = (volatile bbb_i2c_regs *) register_base;
-  I2C0ModuleClkConfig();
-  am335x_i2c0_pinmux( bus );
-  bus->input_clock = input_clock;
-  err = am335x_i2c_set_clock( &bus->base, I2C_BUS_CLOCK_DEFAULT );
+  bus->irq = irq;
-  if ( err != 0 ) {
+  err = am335x_i2c_fill_registers(bus, register_base);
+  if (err != 0) {
     ( *bus->base.destroy )( &bus->base );
-    rtems_set_errno_and_return_minus_one( -err );
+    rtems_set_errno_and_return_minus_one( err );
+  am335x_i2c_module_clk_enable(bus);
+  am335x_i2c_pinmux( bus );
+  err = am335x_i2c_reset( bus );
+  if (err != 0) {
+    ( *bus->base.destroy )( &bus->base );
-  bus->irq = irq;
-  REG( &bus->regs->BBB_I2C_IRQSTATUS ) = BBB_I2C_ALL_IRQ_FLAGS;
   sc = rtems_interrupt_handler_install(
-    irq,
+    bus->irq,
     "BBB_I2C",
     RTEMS_INTERRUPT_UNIQUE,
     (rtems_interrupt_handler) am335x_i2c_interrupt,
     bus
diff --git a/bsps/arm/beagle/include/bsp/i2c.h b/bsps/arm/beagle/include/bsp/i2c.h
index 3ada3c4b0d..9d253406bf 100644
--- a/bsps/arm/beagle/include/bsp/i2c.h
+++ b/bsps/arm/beagle/include/bsp/i2c.h
@@ -24,76 +24,15 @@
 #define LIBBSP_ARM_BEAGLE_I2C_H
-#include <dev/i2c/i2c.h>
 #include <bsp.h>
 #ifdef __cplusplus
 extern "C" {
 #endif /* __cplusplus */
-/* I2C Configuration Register (I2C_CON): */
-#define BBB_I2C_CON_EN  (1 << 15)  /* I2C module enable */
-#define BBB_I2C_CON_BE  (1 << 14)  /* Big endian mode */
-#define BBB_I2C_CON_STB (1 << 11)  /* Start byte mode (master mode only) */
-#define BBB_I2C_CON_MST (1 << 10)  /* Master/slave mode */
-#define BBB_I2C_CON_TRX (1 << 9)   /* Transmitter/receiver mode */
-           /* (master mode only) */
-#define BBB_I2C_CON_XA  (1 << 8)   /* Expand address */
-#define BBB_I2C_CON_STP (1 << 1)   /* Stop condition (master mode only) */
-#define BBB_I2C_CON_STT (1 << 0)   /* Start condition (master mode only) */
-#define BBB_I2C_CON_CLR 0x0  /* Clear configuration register */
-/* I2C Status Register (I2C_STAT): */
-#define BBB_I2C_STAT_SBD  (1 << 15) /* Single byte data */
-#define BBB_I2C_STAT_BB (1 << 12) /* Bus busy */
-#define BBB_I2C_STAT_ROVR (1 << 11) /* Receive overrun */
-#define BBB_I2C_STAT_XUDF (1 << 10) /* Transmit underflow */
-#define BBB_I2C_STAT_AAS  (1 << 9)  /* Address as slave */
-#define BBB_I2C_STAT_GC (1 << 5)
-#define BBB_I2C_STAT_XRDY (1 << 4)  /* Transmit data ready */
-#define BBB_I2C_STAT_RRDY (1 << 3)  /* Receive data ready */
-#define BBB_I2C_STAT_ARDY (1 << 2)  /* Register access ready */
-#define BBB_I2C_STAT_NACK (1 << 1)  /* No acknowledgment interrupt enable */
-#define BBB_I2C_STAT_AL (1 << 0)  /* Arbitration lost interrupt enable */
-/* I2C Interrupt Enable Register (I2C_IE): */
-#define BBB_I2C_IE_GC_IE  (1 << 5)
-#define BBB_I2C_IE_XRDY_IE  (1 << 4) /* Transmit data ready interrupt enable */
-#define BBB_I2C_IE_RRDY_IE  (1 << 3) /* Receive data ready interrupt enable */
-#define BBB_I2C_IE_ARDY_IE  (1 << 2) /* Register access ready interrupt enable */
-#define BBB_I2C_IE_NACK_IE  (1 << 1) /* No acknowledgment interrupt enable */
-#define BBB_I2C_IE_AL_IE  (1 << 0) /* Arbitration lost interrupt enable */
-/* I2C SYSC Register (I2C_SYSC): */
-#define BBB_I2C_SYSC_SRST (1 << 1)
-#define BBB_I2C_TIMEOUT 1000
-#define BBB_I2C_SYSS_RDONE            (1 << 0)  /* Internel reset monitoring */
-#define BBB_CONFIG_SYS_I2C_SPEED    100000
-#define BBB_CONFIG_SYS_I2C_SLAVE    1
-#define BBB_I2C_ALL_FLAGS 0x7FFF
-#define BBB_I2C_ALL_IRQ_FLAGS 0xFFFF
 #define BBB_I2C_SYSCLK 48000000
 #define BBB_I2C_INTERNAL_CLK 12000000
-#define BBB_I2C_SPEED_CLK 100000
-#define BBB_I2C_IRQ_ERROR \
-  ( AM335X_I2C_IRQSTATUS_NACK \
-    | AM335X_I2C_IRQSTATUS_ROVR \
-    | AM335X_I2C_IRQSTATUS_AL \
-    | AM335X_I2C_IRQSTATUS_ARDY \
-    | AM335X_I2C_IRQSTATUS_RRDY \
-    | AM335X_I2C_IRQSTATUS_XRDY \
-    | AM335X_I2C_IRQSTATUS_XUDF )
-#define BBB_I2C_IRQ_USED \
-  ( AM335X_I2C_IRQSTATUS_ARDY \
-    | AM335X_I2C_IRQSTATUS_XRDY )
 #define BBB_I2C_0_BUS_PATH "/dev/i2c-0"
 #define BBB_I2C_1_BUS_PATH "/dev/i2c-1"
@@ -103,9 +42,6 @@ extern "C" {
 #define BBB_I2C1_IRQ 71
 #define BBB_I2C2_IRQ 30
-#define BBB_MODE2 2
-#define BBB_MODE3 3
 typedef enum {
   I2C0,
   I2C1,
@@ -151,26 +87,10 @@ typedef struct i2c_regs {
   uint32_t BBB_I2C_SBLOCK;
 } bbb_i2c_regs;
-typedef struct bbb_i2c_bus {
-  i2c_bus base;
-  i2c_msg *msgs;
-  uint32_t msg_todo;
-  uint32_t current_msg_todo;
-  uint8_t *current_msg_byte;
-  uint32_t current_todo;
-  bool read;
-  bool hold;
-  rtems_id task_id;
-  rtems_vector_number irq;
-  uint32_t input_clock;
-  uint32_t already_transferred;
-} bbb_i2c_bus;
   const char         *bus_path,
   uintptr_t           register_base,
-  uint32_t            input_clock,
+  uint32_t            input_clock, /* FIXME: Unused. Left for compatibility. */
diff --git a/bsps/arm/include/libcpu/am335x.h b/bsps/arm/include/libcpu/am335x.h
index a78cbd028d..b69c822d62 100644
--- a/bsps/arm/include/libcpu/am335x.h
+++ b/bsps/arm/include/libcpu/am335x.h
@@ -664,6 +664,9 @@
 #define AM335X_I2C_CON_MST   (0x00000400u)
 #define AM335X_I2C_CON_STB   (0x00000800u)
 #define AM335X_I2C_SYSC_AUTOIDLE   (0x00000001u)
+#define AM335X_I2C_SYSC_SRST       (0x00000002u)
+#define AM335X_I2C_SYSC_ENAWAKEUP  (0x00000004u)
+#define AM335X_I2C_SYSS_RDONE      (0x00000001u)
 /*I2C0 module clock registers*/
 #define AM335X_CM_WKUP_CONTROL_CLKCTRL   (0x4)
@@ -686,29 +689,39 @@
 #define AM335X_CM_PER_CONTROL_CLKCTRL_IDLEST   (0x00030000u)
+#define AM335X_I2C_BUF_TXTRSH_SHIFT (0)
+#define AM335X_I2C_BUF_TXTRSH_MASK  (0x0000003Fu)
+#define AM335X_I2C_BUF_TXTRSH(X)    (((X) << AM335X_I2C_BUF_TXTRSH_SHIFT) \
+                                     & AM335X_I2C_BUF_TXTRSH_MASK)
+#define AM335X_I2C_BUF_TXFIFO_CLR   (0x00000040u)
+#define AM335X_I2C_BUF_RXTRSH_SHIFT (8)
+#define AM335X_I2C_BUF_RXTRSH_MASK  (0x00003F00u)
+#define AM335X_I2C_BUF_RXTRSH(X)    (((X) << AM335X_I2C_BUF_RXTRSH_SHIFT) \
+                                     & AM335X_I2C_BUF_RXTRSH_MASK)
+#define AM335X_I2C_BUF_RXFIFO_CLR   (0x00004000u)
 /* I2C status Register */
+#define AM335X_I2C_IRQSTATUS_AL   (1 << 0)
 #define AM335X_I2C_IRQSTATUS_NACK (1 << 1)
-#define AM335X_I2C_IRQSTATUS_ROVR (1 << 11)
-#define AM335X_I2C_IRQSTATUS_AL   (1<<0)
 #define AM335X_I2C_IRQSTATUS_ARDY (1 << 2)
 #define AM335X_I2C_IRQSTATUS_RRDY (1 << 3)
 #define AM335X_I2C_IRQSTATUS_XRDY (1 << 4)
-#define AM335X_I2C_IRQSTATUS_XUDF (1 << 10)
-#define AM335X_I2C_BUF_TXFIFO_CLR   (0x00000040u)
-#define AM335X_I2C_BUF_RXFIFO_CLR   (0x00004000u)
-#define AM335X_I2C_IRQSTATUS_AAS  (1 << 9)
-#define AM335X_I2C_IRQSTATUS_BF  (1 << 8)
+#define AM335X_I2C_IRQSTATUS_GC   (1 << 5)
 #define AM335X_I2C_IRQSTATUS_STC  (1 << 6)
-#define AM335X_I2C_IRQSTATUS_GC (1 << 5)
-#define AM335X_I2C_IRQSTATUS_XDR (1 << 14)
-#define AM335X_I2C_IRQSTATUS_RDR (1 << 13)
+#define AM335X_I2C_IRQSTATUS_AERR (1 << 7)
+#define AM335X_I2C_IRQSTATUS_BF   (1 << 8)
+#define AM335X_I2C_IRQSTATUS_AAS  (1 << 9)
+#define AM335X_I2C_IRQSTATUS_XUDF (1 << 10)
+#define AM335X_I2C_IRQSTATUS_ROVR (1 << 11)
+#define AM335X_I2C_IRQSTATUS_BB   (1 << 12)
+#define AM335X_I2C_IRQSTATUS_RDR  (1 << 13)
+#define AM335X_I2C_IRQSTATUS_XDR  (1 << 14)
 #define AM335X_I2C_INT_RECV_READY AM335X_I2C_IRQSTATUS_RRDY
 #define AM335X_I2C_CON_STOP  (0x00000002u)
 #define AM335X_I2C_CON_START (0x00000001u)
 #define AM335X_I2C_CFG_MST_RX AM335X_I2C_CON_MST
 #define AM335X_I2C_CFG_MST_TX  (AM335X_I2C_CON_TRX | AM335X_I2C_CON_MST)
-#define AM335X_I2C_IRQSTATUS_RAW_BB   (0x00001000u)
 #define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK (0x00000020u)
 #define AM335X_I2C_INT_STOP_CONDITION AM335X_I2C_IRQSTATUS_BF
2.21.0
