[PATCH] Generated event stream metadata file
Ravindra Meena rmeena840 at gmail.com
Tue Jun 25 04:58:30 UTC 2019
 misc/ctf/metadata | 1059 +++++++++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 1059 insertions(+)
 create mode 100644 misc/ctf/metadata
diff --git a/misc/ctf/metadata b/misc/ctf/metadata
new file mode 100644
index 0000000..068e4ba
--- /dev/null
+++ b/misc/ctf/metadata
@@ -0,0 +1,1059 @@
+/* CTF 1.8 */
+typealias integer { size = 8; align = 8; signed = false; } := uint8_t;
+typealias integer { size = 16; align = 8; signed = false; } := uint16_t;
+typealias integer { size = 32; align = 8; signed = false; } := uint32_t;
+typealias integer { size = 64; align = 8; signed = false; } := uint64_t;
+typealias integer { size = 64; align = 8; signed = false; } := timestamp_t;
+/* 1024 events are defined. The events are taking values from 0 to 1023. */
+typedef enum events_e : uint64_t {
+  RTEMS_RECORD_EMPTY,
+  RTEMS_RECORD_VERSION,
+  RTEMS_RECORD_ACCEPT_ENTRY,
+  RTEMS_RECORD_ACCEPT_EXIT,
+  RTEMS_RECORD_BIND_ENTRY,
+  RTEMS_RECORD_BIND_EXIT,
+  RTEMS_RECORD_BUFFER,
+  RTEMS_RECORD_CHOWN_ENTRY,
+  RTEMS_RECORD_CHOWN_EXIT,
+  RTEMS_RECORD_CLOSE_ENTRY,
+  RTEMS_RECORD_CLOSE_EXIT,
+  RTEMS_RECORD_CONNECT_ENTRY,
+  RTEMS_RECORD_CONNECT_EXIT,
+  RTEMS_RECORD_ETHER_INPUT,
+  RTEMS_RECORD_ETHER_OUTPUT,
+  RTEMS_RECORD_FCHMOD_ENTRY,
+  RTEMS_RECORD_FCHMOD_EXIT,
+  RTEMS_RECORD_FCNTL_ENTRY,
+  RTEMS_RECORD_FCNTL_EXIT,
+  RTEMS_RECORD_FDATASYNC_ENTRY,
+  RTEMS_RECORD_FDATASYNC_EXIT,
+  RTEMS_RECORD_FREQUENCY,
+  RTEMS_RECORD_FSTAT_ENTRY,
+  RTEMS_RECORD_FSTAT_EXIT,
+  RTEMS_RECORD_FSYNC_ENTRY,
+  RTEMS_RECORD_FSYNC_EXIT,
+  RTEMS_RECORD_FTRUNCATE_ENTRY,
+  RTEMS_RECORD_FTRUNCATE_EXIT,
+  RTEMS_RECORD_GETSOCKOPT_ENTRY,
+  RTEMS_RECORD_GETSOCKOPT_EXIT,
+  RTEMS_RECORD_GIT_HASH,
+  RTEMS_RECORD_HEAP_ALLOC,
+  RTEMS_RECORD_HEAP_FREE,
+  RTEMS_RECORD_HEAP_SIZE,
+  RTEMS_RECORD_HEAP_USAGE,
+  RTEMS_RECORD_INTERRUPT_ENTRY,
+  RTEMS_RECORD_INTERRUPT_EXIT,
+  RTEMS_RECORD_INTERRUPT_INSTALL,
+  RTEMS_RECORD_INTERRUPT_REMOVE,
+  RTEMS_RECORD_INTERRUPT_SERVER_ENTRY,
+  RTEMS_RECORD_INTERRUPT_SERVER_EXIT,
+  RTEMS_RECORD_INTERRUPT_SERVER_INSTALL,
+  RTEMS_RECORD_INTERRUPT_SERVER_MOVE,
+  RTEMS_RECORD_INTERRUPT_SERVER_REMOVE,
+  RTEMS_RECORD_INTERRUPT_SERVER_TRIGGER,
+  RTEMS_RECORD_IOCTL_ENTRY,
+  RTEMS_RECORD_IOCTL_EXIT,
+  RTEMS_RECORD_IP6_INPUT,
+  RTEMS_RECORD_IP6_OUTPUT,
+  RTEMS_RECORD_IP_INPUT,
+  RTEMS_RECORD_IP_OUTPUT,
+  RTEMS_RECORD_KEVENT_ENTRY,
+  RTEMS_RECORD_KEVENT_EXIT,
+  RTEMS_RECORD_KQUEUE_ENTRY,
+  RTEMS_RECORD_KQUEUE_EXIT,
+  RTEMS_RECORD_LENGTH,
+  RTEMS_RECORD_LINK_ENTRY,
+  RTEMS_RECORD_LINK_EXIT,
+  RTEMS_RECORD_LISTEN_ENTRY,
+  RTEMS_RECORD_LISTEN_EXIT,
+  RTEMS_RECORD_LSEEK_ENTRY,
+  RTEMS_RECORD_LSEEK_EXIT,
+  RTEMS_RECORD_MKNOD_ENTRY,
+  RTEMS_RECORD_MKNOD_EXIT,
+  RTEMS_RECORD_MMAP_ENTRY,
+  RTEMS_RECORD_MMAP_EXIT,
+  RTEMS_RECORD_MOUNT_ENTRY,
+  RTEMS_RECORD_MOUNT_EXIT,
+  RTEMS_RECORD_OPEN_ENTRY,
+  RTEMS_RECORD_OPEN_EXIT,
+  RTEMS_RECORD_PAGE_ALLOC,
+  RTEMS_RECORD_PAGE_FREE,
+  RTEMS_RECORD_PER_CPU_COUNT,
+  RTEMS_RECORD_PER_CPU_HEAD,
+  RTEMS_RECORD_PER_CPU_OVERFLOW,
+  RTEMS_RECORD_PER_CPU_TAIL,
+  RTEMS_RECORD_POLL_ENTRY,
+  RTEMS_RECORD_POLL_EXIT,
+  RTEMS_RECORD_PROCESSOR,
+  RTEMS_RECORD_PROCESSOR_MAXIMUM,
+  RTEMS_RECORD_READ_ENTRY,
+  RTEMS_RECORD_READ_EXIT,
+  RTEMS_RECORD_READLINK_ENTRY,
+  RTEMS_RECORD_READLINK_EXIT,
+  RTEMS_RECORD_READV_ENTRY,
+  RTEMS_RECORD_READV_EXIT,
+  RTEMS_RECORD_RECV_ENTRY,
+  RTEMS_RECORD_RECV_EXIT,
+  RTEMS_RECORD_RECVFROM_ENTRY,
+  RTEMS_RECORD_RECVFROM_EXIT,
+  RTEMS_RECORD_RECVMSG_ENTRY,
+  RTEMS_RECORD_RECVMSG_EXIT,
+  RTEMS_RECORD_RENAME_ENTRY,
+  RTEMS_RECORD_RENAME_EXIT,
+  RTEMS_RECORD_RTEMS_BARRIER_CREATE,
+  RTEMS_RECORD_RTEMS_BARRIER_DELETE,
+  RTEMS_RECORD_RTEMS_BARRIER_RELEASE,
+  RTEMS_RECORD_RTEMS_BARRIER_WAIT,
+  RTEMS_RECORD_RTEMS_EVENT_RECEIVE,
+  RTEMS_RECORD_RTEMS_EVENT_SEND,
+  RTEMS_RECORD_RTEMS_EVENT_SYSTEM_RECEIVE,
+  RTEMS_RECORD_RTEMS_EVENT_SYSTEM_SEND,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_BROADCAST,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_CREATE,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_DELETE,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_FLUSH,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_RECEIVE,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_SEND,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_URGENT,
+  RTEMS_RECORD_RTEMS_PARTITION_CREATE,
+  RTEMS_RECORD_RTEMS_PARTITION_DELETE,
+  RTEMS_RECORD_RTEMS_PARTITION_GET_BUFFER,
+  RTEMS_RECORD_RTEMS_PARTITION_RETURN_BUFFER,
+  RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CANCEL,
+  RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CREATE,
+  RTEMS_RECORD_RTEMS_RATE_MONOTONIC_DELETE,
+  RTEMS_RECORD_RTEMS_RATE_MONOTONIC_PERIOD,
+  RTEMS_RECORD_RTEMS_SEMAPHORE_CREATE,
+  RTEMS_RECORD_RTEMS_SEMAPHORE_DELETE,
+  RTEMS_RECORD_RTEMS_SEMAPHORE_FLUSH,
+  RTEMS_RECORD_RTEMS_SEMAPHORE_OBTAIN,
+  RTEMS_RECORD_RTEMS_SEMAPHORE_RELEASE,
+  RTEMS_RECORD_RTEMS_TIMER_CANCEL,
+  RTEMS_RECORD_RTEMS_TIMER_CREATE,
+  RTEMS_RECORD_RTEMS_TIMER_DELETE,
+  RTEMS_RECORD_RTEMS_TIMER_FIRE_AFTER,
+  RTEMS_RECORD_RTEMS_TIMER_FIRE_WHEN,
+  RTEMS_RECORD_RTEMS_TIMER_RESET,
+  RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_AFTER,
+  RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_WHEN,
+  RTEMS_RECORD_SBWAIT_ENTRY,
+  RTEMS_RECORD_SBWAIT_EXIT,
+  RTEMS_RECORD_SBWAKEUP_ENTRY,
+  RTEMS_RECORD_SBWAKEUP_EXIT,
+  RTEMS_RECORD_SELECT_ENTRY,
+  RTEMS_RECORD_SELECT_EXIT,
+  RTEMS_RECORD_SEND_ENTRY,
+  RTEMS_RECORD_SEND_EXIT,
+  RTEMS_RECORD_SENDMSG_ENTRY,
+  RTEMS_RECORD_SENDMSG_EXIT,
+  RTEMS_RECORD_SENDTO_ENTRY,
+  RTEMS_RECORD_SENDTO_EXIT,
+  RTEMS_RECORD_SETSOCKOPT_ENTRY,
+  RTEMS_RECORD_SETSOCKOPT_EXIT,
+  RTEMS_RECORD_SHUTDOWN_ENTRY,
+  RTEMS_RECORD_SHUTDOWN_EXIT,
+  RTEMS_RECORD_SOABORT_ENTRY,
+  RTEMS_RECORD_SOABORT_EXIT,
+  RTEMS_RECORD_SOACCEPT_ENTRY,
+  RTEMS_RECORD_SOACCEPT_EXIT,
+  RTEMS_RECORD_SOALLOC_ENTRY,
+  RTEMS_RECORD_SOALLOC_EXIT,
+  RTEMS_RECORD_SOBINDAT_ENTRY,
+  RTEMS_RECORD_SOBINDAT_EXIT,
+  RTEMS_RECORD_SOBIND_ENTRY,
+  RTEMS_RECORD_SOBIND_EXIT,
+  RTEMS_RECORD_SOCKET_ENTRY,
+  RTEMS_RECORD_SOCKET_EXIT,
+  RTEMS_RECORD_SOCLOSE_ENTRY,
+  RTEMS_RECORD_SOCLOSE_EXIT,
+  RTEMS_RECORD_SOCONNECT2_ENTRY,
+  RTEMS_RECORD_SOCONNECT2_EXIT,
+  RTEMS_RECORD_SOCONNECTAT_ENTRY,
+  RTEMS_RECORD_SOCONNECTAT_EXIT,
+  RTEMS_RECORD_SOCREATE_ENTRY,
+  RTEMS_RECORD_SOCREATE_EXIT,
+  RTEMS_RECORD_SODEALLOC_ENTRY,
+  RTEMS_RECORD_SODEALLOC_EXIT,
+  RTEMS_RECORD_SODISCONNECT_ENTRY,
+  RTEMS_RECORD_SODISCONNECT_EXIT,
+  RTEMS_RECORD_SOFREE_ENTRY,
+  RTEMS_RECORD_SOFREE_EXIT,
+  RTEMS_RECORD_SOLISTEN_ENTRY,
+  RTEMS_RECORD_SOLISTEN_EXIT,
+  RTEMS_RECORD_SONEWCONN_ENTRY,
+  RTEMS_RECORD_SONEWCONN_EXIT,
+  RTEMS_RECORD_SORECEIVE_ENTRY,
+  RTEMS_RECORD_SORECEIVE_EXIT,
+  RTEMS_RECORD_SORFLUSH_ENTRY,
+  RTEMS_RECORD_SORFLUSH_EXIT,
+  RTEMS_RECORD_SOSEND_ENTRY,
+  RTEMS_RECORD_SOSEND_EXIT,
+  RTEMS_RECORD_SOSHUTDOWN_ENTRY,
+  RTEMS_RECORD_SOSHUTDOWN_EXIT,
+  RTEMS_RECORD_STATVFS_ENTRY,
+  RTEMS_RECORD_STATVFS_EXIT,
+  RTEMS_RECORD_SYMLINK_ENTRY,
+  RTEMS_RECORD_SYMLINK_EXIT,
+  RTEMS_RECORD_TCP_CLOSE,
+  RTEMS_RECORD_TCP_INPUT,
+  RTEMS_RECORD_TCP_OUTPUT,
+  RTEMS_RECORD_THREAD_BEGIN,
+  RTEMS_RECORD_THREAD_CREATE,
+  RTEMS_RECORD_THREAD_DELETE,
+  RTEMS_RECORD_THREAD_EXIT,
+  RTEMS_RECORD_THREAD_EXITTED,
+  RTEMS_RECORD_THREAD_ID,
+  RTEMS_RECORD_THREAD_PRIO_CURRENT_HIGH,
+  RTEMS_RECORD_THREAD_PRIO_CURRENT_LOW,
+  RTEMS_RECORD_THREAD_PRIO_REAL_HIGH,
+  RTEMS_RECORD_THREAD_PRIO_REAL_LOW,
+  RTEMS_RECORD_THREAD_QUEUE_ENQUEUE,
+  RTEMS_RECORD_THREAD_QUEUE_ENQUEUE_STICKY,
+  RTEMS_RECORD_THREAD_QUEUE_EXTRACT,
+  RTEMS_RECORD_THREAD_QUEUE_SURRENDER,
+  RTEMS_RECORD_THREAD_QUEUE_SURRENDER_STICKY,
+  RTEMS_RECORD_THREAD_RESOURCE_OBTAIN,
+  RTEMS_RECORD_THREAD_RESOURCE_RELEASE,
+  RTEMS_RECORD_THREAD_RESTART,
+  RTEMS_RECORD_THREAD_STACK_CURRENT,
+  RTEMS_RECORD_THREAD_STACK_SIZE,
+  RTEMS_RECORD_THREAD_STACK_USAGE,
+  RTEMS_RECORD_THREAD_START,
+  RTEMS_RECORD_THREAD_STATE_CLEAR,
+  RTEMS_RECORD_THREAD_STATE_SET,
+  RTEMS_RECORD_THREAD_SWITCH_IN,
+  RTEMS_RECORD_THREAD_SWITCH_OUT,
+  RTEMS_RECORD_THREAD_TERMINATE,
+  RTEMS_RECORD_UDP_INPUT,
+  RTEMS_RECORD_UDP_OUTPUT,
+  RTEMS_RECORD_UMA_ALLOC_PTR,
+  RTEMS_RECORD_UMA_ALLOC_ZONE,
+  RTEMS_RECORD_UMA_FREE_PTR,
+  RTEMS_RECORD_UMA_FREE_ZONE,
+  RTEMS_RECORD_UNLINK_ENTRY,
+  RTEMS_RECORD_UNLINK_EXIT,
+  RTEMS_RECORD_UNMOUNT_ENTRY,
+  RTEMS_RECORD_UNMOUNT_EXIT,
+  RTEMS_RECORD_UPTIME_HIGH,
+  RTEMS_RECORD_UPTIME_LOW,
+  RTEMS_RECORD_WORKSPACE_ALLOC,
+  RTEMS_RECORD_WORKSPACE_FREE,
+  RTEMS_RECORD_WORKSPACE_SIZE,
+  RTEMS_RECORD_WORKSPACE_USAGE,
+  RTEMS_RECORD_WRITE_ENTRY,
+  RTEMS_RECORD_WRITE_EXIT,
+  RTEMS_RECORD_WRITEV_ENTRY,
+  RTEMS_RECORD_WRITEV_EXIT,
+  RTEMS_RECORD_SYSTEM_238,
+  RTEMS_RECORD_SYSTEM_239,
+  RTEMS_RECORD_SYSTEM_240,
+  RTEMS_RECORD_SYSTEM_241,
+  RTEMS_RECORD_SYSTEM_242,
+  RTEMS_RECORD_SYSTEM_243,
+  RTEMS_RECORD_SYSTEM_244,
+  RTEMS_RECORD_SYSTEM_245,
+  RTEMS_RECORD_SYSTEM_246,
+  RTEMS_RECORD_SYSTEM_247,
+  RTEMS_RECORD_SYSTEM_248,
+  RTEMS_RECORD_SYSTEM_249,
+  RTEMS_RECORD_SYSTEM_250,
+  RTEMS_RECORD_SYSTEM_251,
+  RTEMS_RECORD_SYSTEM_252,
+  RTEMS_RECORD_SYSTEM_253,
+  RTEMS_RECORD_SYSTEM_254,
+  RTEMS_RECORD_SYSTEM_255,
+  RTEMS_RECORD_SYSTEM_256,
+  RTEMS_RECORD_SYSTEM_257,
+  RTEMS_RECORD_SYSTEM_258,
+  RTEMS_RECORD_SYSTEM_259,
+  RTEMS_RECORD_SYSTEM_260,
+  RTEMS_RECORD_SYSTEM_261,
+  RTEMS_RECORD_SYSTEM_262,
+  RTEMS_RECORD_SYSTEM_263,
+  RTEMS_RECORD_SYSTEM_264,
+  RTEMS_RECORD_SYSTEM_265,
+  RTEMS_RECORD_SYSTEM_266,
+  RTEMS_RECORD_SYSTEM_267,
+  RTEMS_RECORD_SYSTEM_268,
+  RTEMS_RECORD_SYSTEM_269,
+  RTEMS_RECORD_SYSTEM_270,
+  RTEMS_RECORD_SYSTEM_271,
+  RTEMS_RECORD_SYSTEM_272,
+  RTEMS_RECORD_SYSTEM_273,
+  RTEMS_RECORD_SYSTEM_274,
+  RTEMS_RECORD_SYSTEM_275,
+  RTEMS_RECORD_SYSTEM_276,
+  RTEMS_RECORD_SYSTEM_277,
+  RTEMS_RECORD_SYSTEM_278,
+  RTEMS_RECORD_SYSTEM_279,
+  RTEMS_RECORD_SYSTEM_280,
+  RTEMS_RECORD_SYSTEM_281,
+  RTEMS_RECORD_SYSTEM_282,
+  RTEMS_RECORD_SYSTEM_283,
+  RTEMS_RECORD_SYSTEM_284,
+  RTEMS_RECORD_SYSTEM_285,
+  RTEMS_RECORD_SYSTEM_286,
+  RTEMS_RECORD_SYSTEM_287,
+  RTEMS_RECORD_SYSTEM_288,
+  RTEMS_RECORD_SYSTEM_289,
+  RTEMS_RECORD_SYSTEM_290,
+  RTEMS_RECORD_SYSTEM_291,
+  RTEMS_RECORD_SYSTEM_292,
+  RTEMS_RECORD_SYSTEM_293,
+  RTEMS_RECORD_SYSTEM_294,
+  RTEMS_RECORD_SYSTEM_295,
+  RTEMS_RECORD_SYSTEM_296,
+  RTEMS_RECORD_SYSTEM_297,
+  RTEMS_RECORD_SYSTEM_298,
+  RTEMS_RECORD_SYSTEM_299,
+  RTEMS_RECORD_SYSTEM_300,
+  RTEMS_RECORD_SYSTEM_301,
+  RTEMS_RECORD_SYSTEM_302,
+  RTEMS_RECORD_SYSTEM_303,
+  RTEMS_RECORD_SYSTEM_304,
+  RTEMS_RECORD_SYSTEM_305,
+  RTEMS_RECORD_SYSTEM_306,
+  RTEMS_RECORD_SYSTEM_307,
+  RTEMS_RECORD_SYSTEM_308,
+  RTEMS_RECORD_SYSTEM_309,
+  RTEMS_RECORD_SYSTEM_310,
+  RTEMS_RECORD_SYSTEM_311,
+  RTEMS_RECORD_SYSTEM_312,
+  RTEMS_RECORD_SYSTEM_313,
+  RTEMS_RECORD_SYSTEM_314,
+  RTEMS_RECORD_SYSTEM_315,
+  RTEMS_RECORD_SYSTEM_316,
+  RTEMS_RECORD_SYSTEM_317,
+  RTEMS_RECORD_SYSTEM_318,
+  RTEMS_RECORD_SYSTEM_319,
+  RTEMS_RECORD_SYSTEM_320,
+  RTEMS_RECORD_SYSTEM_321,
+  RTEMS_RECORD_SYSTEM_322,
+  RTEMS_RECORD_SYSTEM_323,
+  RTEMS_RECORD_SYSTEM_324,
+  RTEMS_RECORD_SYSTEM_325,
+  RTEMS_RECORD_SYSTEM_326,
+  RTEMS_RECORD_SYSTEM_327,
+  RTEMS_RECORD_SYSTEM_328,
+  RTEMS_RECORD_SYSTEM_329,
+  RTEMS_RECORD_SYSTEM_330,
+  RTEMS_RECORD_SYSTEM_331,
+  RTEMS_RECORD_SYSTEM_332,
+  RTEMS_RECORD_SYSTEM_333,
+  RTEMS_RECORD_SYSTEM_334,
+  RTEMS_RECORD_SYSTEM_335,
+  RTEMS_RECORD_SYSTEM_336,
+  RTEMS_RECORD_SYSTEM_337,
+  RTEMS_RECORD_SYSTEM_338,
+  RTEMS_RECORD_SYSTEM_339,
+  RTEMS_RECORD_SYSTEM_340,
+  RTEMS_RECORD_SYSTEM_341,
+  RTEMS_RECORD_SYSTEM_342,
+  RTEMS_RECORD_SYSTEM_343,
+  RTEMS_RECORD_SYSTEM_344,
+  RTEMS_RECORD_SYSTEM_345,
+  RTEMS_RECORD_SYSTEM_346,
+  RTEMS_RECORD_SYSTEM_347,
+  RTEMS_RECORD_SYSTEM_348,
+  RTEMS_RECORD_SYSTEM_349,
+  RTEMS_RECORD_SYSTEM_350,
+  RTEMS_RECORD_SYSTEM_351,
+  RTEMS_RECORD_SYSTEM_352,
+  RTEMS_RECORD_SYSTEM_353,
+  RTEMS_RECORD_SYSTEM_354,
+  RTEMS_RECORD_SYSTEM_355,
+  RTEMS_RECORD_SYSTEM_356,
+  RTEMS_RECORD_SYSTEM_357,
+  RTEMS_RECORD_SYSTEM_358,
+  RTEMS_RECORD_SYSTEM_359,
+  RTEMS_RECORD_SYSTEM_360,
+  RTEMS_RECORD_SYSTEM_361,
+  RTEMS_RECORD_SYSTEM_362,
+  RTEMS_RECORD_SYSTEM_363,
+  RTEMS_RECORD_SYSTEM_364,
+  RTEMS_RECORD_SYSTEM_365,
+  RTEMS_RECORD_SYSTEM_366,
+  RTEMS_RECORD_SYSTEM_367,
+  RTEMS_RECORD_SYSTEM_368,
+  RTEMS_RECORD_SYSTEM_369,
+  RTEMS_RECORD_SYSTEM_370,
+  RTEMS_RECORD_SYSTEM_371,
+  RTEMS_RECORD_SYSTEM_372,
+  RTEMS_RECORD_SYSTEM_373,
+  RTEMS_RECORD_SYSTEM_374,
+  RTEMS_RECORD_SYSTEM_375,
+  RTEMS_RECORD_SYSTEM_376,
+  RTEMS_RECORD_SYSTEM_377,
+  RTEMS_RECORD_SYSTEM_378,
+  RTEMS_RECORD_SYSTEM_379,
+  RTEMS_RECORD_SYSTEM_380,
+  RTEMS_RECORD_SYSTEM_381,
+  RTEMS_RECORD_SYSTEM_382,
+  RTEMS_RECORD_SYSTEM_383,
+  RTEMS_RECORD_SYSTEM_384,
+  RTEMS_RECORD_SYSTEM_385,
+  RTEMS_RECORD_SYSTEM_386,
+  RTEMS_RECORD_SYSTEM_387,
+  RTEMS_RECORD_SYSTEM_388,
+  RTEMS_RECORD_SYSTEM_389,
+  RTEMS_RECORD_SYSTEM_390,
+  RTEMS_RECORD_SYSTEM_391,
+  RTEMS_RECORD_SYSTEM_392,
+  RTEMS_RECORD_SYSTEM_393,
+  RTEMS_RECORD_SYSTEM_394,
+  RTEMS_RECORD_SYSTEM_395,
+  RTEMS_RECORD_SYSTEM_396,
+  RTEMS_RECORD_SYSTEM_397,
+  RTEMS_RECORD_SYSTEM_398,
+  RTEMS_RECORD_SYSTEM_399,
+  RTEMS_RECORD_SYSTEM_400,
+  RTEMS_RECORD_SYSTEM_401,
+  RTEMS_RECORD_SYSTEM_402,
+  RTEMS_RECORD_SYSTEM_403,
+  RTEMS_RECORD_SYSTEM_404,
+  RTEMS_RECORD_SYSTEM_405,
+  RTEMS_RECORD_SYSTEM_406,
+  RTEMS_RECORD_SYSTEM_407,
+  RTEMS_RECORD_SYSTEM_408,
+  RTEMS_RECORD_SYSTEM_409,
+  RTEMS_RECORD_SYSTEM_410,
+  RTEMS_RECORD_SYSTEM_411,
+  RTEMS_RECORD_SYSTEM_412,
+  RTEMS_RECORD_SYSTEM_413,
+  RTEMS_RECORD_SYSTEM_414,
+  RTEMS_RECORD_SYSTEM_415,
+  RTEMS_RECORD_SYSTEM_416,
+  RTEMS_RECORD_SYSTEM_417,
+  RTEMS_RECORD_SYSTEM_418,
+  RTEMS_RECORD_SYSTEM_419,
+  RTEMS_RECORD_SYSTEM_420,
+  RTEMS_RECORD_SYSTEM_421,
+  RTEMS_RECORD_SYSTEM_422,
+  RTEMS_RECORD_SYSTEM_423,
+  RTEMS_RECORD_SYSTEM_424,
+  RTEMS_RECORD_SYSTEM_425,
+  RTEMS_RECORD_SYSTEM_426,
+  RTEMS_RECORD_SYSTEM_427,
+  RTEMS_RECORD_SYSTEM_428,
+  RTEMS_RECORD_SYSTEM_429,
+  RTEMS_RECORD_SYSTEM_430,
+  RTEMS_RECORD_SYSTEM_431,
+  RTEMS_RECORD_SYSTEM_432,
+  RTEMS_RECORD_SYSTEM_433,
+  RTEMS_RECORD_SYSTEM_434,
+  RTEMS_RECORD_SYSTEM_435,
+  RTEMS_RECORD_SYSTEM_436,
+  RTEMS_RECORD_SYSTEM_437,
+  RTEMS_RECORD_SYSTEM_438,
+  RTEMS_RECORD_SYSTEM_439,
+  RTEMS_RECORD_SYSTEM_440,
+  RTEMS_RECORD_SYSTEM_441,
+  RTEMS_RECORD_SYSTEM_442,
+  RTEMS_RECORD_SYSTEM_443,
+  RTEMS_RECORD_SYSTEM_444,
+  RTEMS_RECORD_SYSTEM_445,
+  RTEMS_RECORD_SYSTEM_446,
+  RTEMS_RECORD_SYSTEM_447,
+  RTEMS_RECORD_SYSTEM_448,
+  RTEMS_RECORD_SYSTEM_449,
+  RTEMS_RECORD_SYSTEM_450,
+  RTEMS_RECORD_SYSTEM_451,
+  RTEMS_RECORD_SYSTEM_452,
+  RTEMS_RECORD_SYSTEM_453,
+  RTEMS_RECORD_SYSTEM_454,
+  RTEMS_RECORD_SYSTEM_455,
+  RTEMS_RECORD_SYSTEM_456,
+  RTEMS_RECORD_SYSTEM_457,
+  RTEMS_RECORD_SYSTEM_458,
+  RTEMS_RECORD_SYSTEM_459,
+  RTEMS_RECORD_SYSTEM_460,
+  RTEMS_RECORD_SYSTEM_461,
+  RTEMS_RECORD_SYSTEM_462,
+  RTEMS_RECORD_SYSTEM_463,
+  RTEMS_RECORD_SYSTEM_464,
+  RTEMS_RECORD_SYSTEM_465,
+  RTEMS_RECORD_SYSTEM_466,
+  RTEMS_RECORD_SYSTEM_467,
+  RTEMS_RECORD_SYSTEM_468,
+  RTEMS_RECORD_SYSTEM_469,
+  RTEMS_RECORD_SYSTEM_470,
+  RTEMS_RECORD_SYSTEM_471,
+  RTEMS_RECORD_SYSTEM_472,
+  RTEMS_RECORD_SYSTEM_473,
+  RTEMS_RECORD_SYSTEM_474,
+  RTEMS_RECORD_SYSTEM_475,
+  RTEMS_RECORD_SYSTEM_476,
+  RTEMS_RECORD_SYSTEM_477,
+  RTEMS_RECORD_SYSTEM_478,
+  RTEMS_RECORD_SYSTEM_479,
+  RTEMS_RECORD_SYSTEM_480,
+  RTEMS_RECORD_SYSTEM_481,
+  RTEMS_RECORD_SYSTEM_482,
+  RTEMS_RECORD_SYSTEM_483,
+  RTEMS_RECORD_SYSTEM_484,
+  RTEMS_RECORD_SYSTEM_485,
+  RTEMS_RECORD_SYSTEM_486,
+  RTEMS_RECORD_SYSTEM_487,
+  RTEMS_RECORD_SYSTEM_488,
+  RTEMS_RECORD_SYSTEM_489,
+  RTEMS_RECORD_SYSTEM_490,
+  RTEMS_RECORD_SYSTEM_491,
+  RTEMS_RECORD_SYSTEM_492,
+  RTEMS_RECORD_SYSTEM_493,
+  RTEMS_RECORD_SYSTEM_494,
+  RTEMS_RECORD_SYSTEM_495,
+  RTEMS_RECORD_SYSTEM_496,
+  RTEMS_RECORD_SYSTEM_497,
+  RTEMS_RECORD_SYSTEM_498,
+  RTEMS_RECORD_SYSTEM_499,
+  RTEMS_RECORD_SYSTEM_500,
+  RTEMS_RECORD_SYSTEM_501,
+  RTEMS_RECORD_SYSTEM_502,
+  RTEMS_RECORD_SYSTEM_503,
+  RTEMS_RECORD_SYSTEM_504,
+  RTEMS_RECORD_SYSTEM_505,
+  RTEMS_RECORD_SYSTEM_506,
+  RTEMS_RECORD_SYSTEM_507,
+  RTEMS_RECORD_SYSTEM_508,
+  RTEMS_RECORD_SYSTEM_509,
+  RTEMS_RECORD_SYSTEM_510,
+  RTEMS_RECORD_SYSTEM_511,
+  RTEMS_RECORD_USER_0,
+  RTEMS_RECORD_USER_1,
+  RTEMS_RECORD_USER_2,
+  RTEMS_RECORD_USER_3,
+  RTEMS_RECORD_USER_4,
+  RTEMS_RECORD_USER_5,
+  RTEMS_RECORD_USER_6,
+  RTEMS_RECORD_USER_7,
+  RTEMS_RECORD_USER_8,
+  RTEMS_RECORD_USER_9,
+  RTEMS_RECORD_USER_10,
+  RTEMS_RECORD_USER_11,
+  RTEMS_RECORD_USER_12,
+  RTEMS_RECORD_USER_13,
+  RTEMS_RECORD_USER_14,
+  RTEMS_RECORD_USER_15,
+  RTEMS_RECORD_USER_16,
+  RTEMS_RECORD_USER_17,
+  RTEMS_RECORD_USER_18,
+  RTEMS_RECORD_USER_19,
+  RTEMS_RECORD_USER_20,
+  RTEMS_RECORD_USER_21,
+  RTEMS_RECORD_USER_22,
+  RTEMS_RECORD_USER_23,
+  RTEMS_RECORD_USER_24,
+  RTEMS_RECORD_USER_25,
+  RTEMS_RECORD_USER_26,
+  RTEMS_RECORD_USER_27,
+  RTEMS_RECORD_USER_28,
+  RTEMS_RECORD_USER_29,
+  RTEMS_RECORD_USER_30,
+  RTEMS_RECORD_USER_31,
+  RTEMS_RECORD_USER_32,
+  RTEMS_RECORD_USER_33,
+  RTEMS_RECORD_USER_34,
+  RTEMS_RECORD_USER_35,
+  RTEMS_RECORD_USER_36,
+  RTEMS_RECORD_USER_37,
+  RTEMS_RECORD_USER_38,
+  RTEMS_RECORD_USER_39,
+  RTEMS_RECORD_USER_40,
+  RTEMS_RECORD_USER_41,
+  RTEMS_RECORD_USER_42,
+  RTEMS_RECORD_USER_43,
+  RTEMS_RECORD_USER_44,
+  RTEMS_RECORD_USER_45,
+  RTEMS_RECORD_USER_46,
+  RTEMS_RECORD_USER_47,
+  RTEMS_RECORD_USER_48,
+  RTEMS_RECORD_USER_49,
+  RTEMS_RECORD_USER_50,
+  RTEMS_RECORD_USER_51,
+  RTEMS_RECORD_USER_52,
+  RTEMS_RECORD_USER_53,
+  RTEMS_RECORD_USER_54,
+  RTEMS_RECORD_USER_55,
+  RTEMS_RECORD_USER_56,
+  RTEMS_RECORD_USER_57,
+  RTEMS_RECORD_USER_58,
+  RTEMS_RECORD_USER_59,
+  RTEMS_RECORD_USER_60,
+  RTEMS_RECORD_USER_61,
+  RTEMS_RECORD_USER_62,
+  RTEMS_RECORD_USER_63,
+  RTEMS_RECORD_USER_64,
+  RTEMS_RECORD_USER_65,
+  RTEMS_RECORD_USER_66,
+  RTEMS_RECORD_USER_67,
+  RTEMS_RECORD_USER_68,
+  RTEMS_RECORD_USER_69,
+  RTEMS_RECORD_USER_70,
+  RTEMS_RECORD_USER_71,
+  RTEMS_RECORD_USER_72,
+  RTEMS_RECORD_USER_73,
+  RTEMS_RECORD_USER_74,
+  RTEMS_RECORD_USER_75,
+  RTEMS_RECORD_USER_76,
+  RTEMS_RECORD_USER_77,
+  RTEMS_RECORD_USER_78,
+  RTEMS_RECORD_USER_79,
+  RTEMS_RECORD_USER_80,
+  RTEMS_RECORD_USER_81,
+  RTEMS_RECORD_USER_82,
+  RTEMS_RECORD_USER_83,
+  RTEMS_RECORD_USER_84,
+  RTEMS_RECORD_USER_85,
+  RTEMS_RECORD_USER_86,
+  RTEMS_RECORD_USER_87,
+  RTEMS_RECORD_USER_88,
+  RTEMS_RECORD_USER_89,
+  RTEMS_RECORD_USER_90,
+  RTEMS_RECORD_USER_91,
+  RTEMS_RECORD_USER_92,
+  RTEMS_RECORD_USER_93,
+  RTEMS_RECORD_USER_94,
+  RTEMS_RECORD_USER_95,
+  RTEMS_RECORD_USER_96,
+  RTEMS_RECORD_USER_97,
+  RTEMS_RECORD_USER_98,
+  RTEMS_RECORD_USER_99,
+  RTEMS_RECORD_USER_100,
+  RTEMS_RECORD_USER_101,
+  RTEMS_RECORD_USER_102,
+  RTEMS_RECORD_USER_103,
+  RTEMS_RECORD_USER_104,
+  RTEMS_RECORD_USER_105,
+  RTEMS_RECORD_USER_106,
+  RTEMS_RECORD_USER_107,
+  RTEMS_RECORD_USER_108,
+  RTEMS_RECORD_USER_109,
+  RTEMS_RECORD_USER_110,
+  RTEMS_RECORD_USER_111,
+  RTEMS_RECORD_USER_112,
+  RTEMS_RECORD_USER_113,
+  RTEMS_RECORD_USER_114,
+  RTEMS_RECORD_USER_115,
+  RTEMS_RECORD_USER_116,
+  RTEMS_RECORD_USER_117,
+  RTEMS_RECORD_USER_118,
+  RTEMS_RECORD_USER_119,
+  RTEMS_RECORD_USER_120,
+  RTEMS_RECORD_USER_121,
+  RTEMS_RECORD_USER_122,
+  RTEMS_RECORD_USER_123,
+  RTEMS_RECORD_USER_124,
+  RTEMS_RECORD_USER_125,
+  RTEMS_RECORD_USER_126,
+  RTEMS_RECORD_USER_127,
+  RTEMS_RECORD_USER_128,
+  RTEMS_RECORD_USER_129,
+  RTEMS_RECORD_USER_130,
+  RTEMS_RECORD_USER_131,
+  RTEMS_RECORD_USER_132,
+  RTEMS_RECORD_USER_133,
+  RTEMS_RECORD_USER_134,
+  RTEMS_RECORD_USER_135,
+  RTEMS_RECORD_USER_136,
+  RTEMS_RECORD_USER_137,
+  RTEMS_RECORD_USER_138,
+  RTEMS_RECORD_USER_139,
+  RTEMS_RECORD_USER_140,
+  RTEMS_RECORD_USER_141,
+  RTEMS_RECORD_USER_142,
+  RTEMS_RECORD_USER_143,
+  RTEMS_RECORD_USER_144,
+  RTEMS_RECORD_USER_145,
+  RTEMS_RECORD_USER_146,
+  RTEMS_RECORD_USER_147,
+  RTEMS_RECORD_USER_148,
+  RTEMS_RECORD_USER_149,
+  RTEMS_RECORD_USER_150,
+  RTEMS_RECORD_USER_151,
+  RTEMS_RECORD_USER_152,
+  RTEMS_RECORD_USER_153,
+  RTEMS_RECORD_USER_154,
+  RTEMS_RECORD_USER_155,
+  RTEMS_RECORD_USER_156,
+  RTEMS_RECORD_USER_157,
+  RTEMS_RECORD_USER_158,
+  RTEMS_RECORD_USER_159,
+  RTEMS_RECORD_USER_160,
+  RTEMS_RECORD_USER_161,
+  RTEMS_RECORD_USER_162,
+  RTEMS_RECORD_USER_163,
+  RTEMS_RECORD_USER_164,
+  RTEMS_RECORD_USER_165,
+  RTEMS_RECORD_USER_166,
+  RTEMS_RECORD_USER_167,
+  RTEMS_RECORD_USER_168,
+  RTEMS_RECORD_USER_169,
+  RTEMS_RECORD_USER_170,
+  RTEMS_RECORD_USER_171,
+  RTEMS_RECORD_USER_172,
+  RTEMS_RECORD_USER_173,
+  RTEMS_RECORD_USER_174,
+  RTEMS_RECORD_USER_175,
+  RTEMS_RECORD_USER_176,
+  RTEMS_RECORD_USER_177,
+  RTEMS_RECORD_USER_178,
+  RTEMS_RECORD_USER_179,
+  RTEMS_RECORD_USER_180,
+  RTEMS_RECORD_USER_181,
+  RTEMS_RECORD_USER_182,
+  RTEMS_RECORD_USER_183,
+  RTEMS_RECORD_USER_184,
+  RTEMS_RECORD_USER_185,
+  RTEMS_RECORD_USER_186,
+  RTEMS_RECORD_USER_187,
+  RTEMS_RECORD_USER_188,
+  RTEMS_RECORD_USER_189,
+  RTEMS_RECORD_USER_190,
+  RTEMS_RECORD_USER_191,
+  RTEMS_RECORD_USER_192,
+  RTEMS_RECORD_USER_193,
+  RTEMS_RECORD_USER_194,
+  RTEMS_RECORD_USER_195,
+  RTEMS_RECORD_USER_196,
+  RTEMS_RECORD_USER_197,
+  RTEMS_RECORD_USER_198,
+  RTEMS_RECORD_USER_199,
+  RTEMS_RECORD_USER_200,
+  RTEMS_RECORD_USER_201,
+  RTEMS_RECORD_USER_202,
+  RTEMS_RECORD_USER_203,
+  RTEMS_RECORD_USER_204,
+  RTEMS_RECORD_USER_205,
+  RTEMS_RECORD_USER_206,
+  RTEMS_RECORD_USER_207,
+  RTEMS_RECORD_USER_208,
+  RTEMS_RECORD_USER_209,
+  RTEMS_RECORD_USER_210,
+  RTEMS_RECORD_USER_211,
+  RTEMS_RECORD_USER_212,
+  RTEMS_RECORD_USER_213,
+  RTEMS_RECORD_USER_214,
+  RTEMS_RECORD_USER_215,
+  RTEMS_RECORD_USER_216,
+  RTEMS_RECORD_USER_217,
+  RTEMS_RECORD_USER_218,
+  RTEMS_RECORD_USER_219,
+  RTEMS_RECORD_USER_220,
+  RTEMS_RECORD_USER_221,
+  RTEMS_RECORD_USER_222,
+  RTEMS_RECORD_USER_223,
+  RTEMS_RECORD_USER_224,
+  RTEMS_RECORD_USER_225,
+  RTEMS_RECORD_USER_226,
+  RTEMS_RECORD_USER_227,
+  RTEMS_RECORD_USER_228,
+  RTEMS_RECORD_USER_229,
+  RTEMS_RECORD_USER_230,
+  RTEMS_RECORD_USER_231,
+  RTEMS_RECORD_USER_232,
+  RTEMS_RECORD_USER_233,
+  RTEMS_RECORD_USER_234,
+  RTEMS_RECORD_USER_235,
+  RTEMS_RECORD_USER_236,
+  RTEMS_RECORD_USER_237,
+  RTEMS_RECORD_USER_238,
+  RTEMS_RECORD_USER_239,
+  RTEMS_RECORD_USER_240,
+  RTEMS_RECORD_USER_241,
+  RTEMS_RECORD_USER_242,
+  RTEMS_RECORD_USER_243,
+  RTEMS_RECORD_USER_244,
+  RTEMS_RECORD_USER_245,
+  RTEMS_RECORD_USER_246,
+  RTEMS_RECORD_USER_247,
+  RTEMS_RECORD_USER_248,
+  RTEMS_RECORD_USER_249,
+  RTEMS_RECORD_USER_250,
+  RTEMS_RECORD_USER_251,
+  RTEMS_RECORD_USER_252,
+  RTEMS_RECORD_USER_253,
+  RTEMS_RECORD_USER_254,
+  RTEMS_RECORD_USER_255,
+  RTEMS_RECORD_USER_256,
+  RTEMS_RECORD_USER_257,
+  RTEMS_RECORD_USER_258,
+  RTEMS_RECORD_USER_259,
+  RTEMS_RECORD_USER_260,
+  RTEMS_RECORD_USER_261,
+  RTEMS_RECORD_USER_262,
+  RTEMS_RECORD_USER_263,
+  RTEMS_RECORD_USER_264,
+  RTEMS_RECORD_USER_265,
+  RTEMS_RECORD_USER_266,
+  RTEMS_RECORD_USER_267,
+  RTEMS_RECORD_USER_268,
+  RTEMS_RECORD_USER_269,
+  RTEMS_RECORD_USER_270,
+  RTEMS_RECORD_USER_271,
+  RTEMS_RECORD_USER_272,
+  RTEMS_RECORD_USER_273,
+  RTEMS_RECORD_USER_274,
+  RTEMS_RECORD_USER_275,
+  RTEMS_RECORD_USER_276,
+  RTEMS_RECORD_USER_277,
+  RTEMS_RECORD_USER_278,
+  RTEMS_RECORD_USER_279,
+  RTEMS_RECORD_USER_280,
+  RTEMS_RECORD_USER_281,
+  RTEMS_RECORD_USER_282,
+  RTEMS_RECORD_USER_283,
+  RTEMS_RECORD_USER_284,
+  RTEMS_RECORD_USER_285,
+  RTEMS_RECORD_USER_286,
+  RTEMS_RECORD_USER_287,
+  RTEMS_RECORD_USER_288,
+  RTEMS_RECORD_USER_289,
+  RTEMS_RECORD_USER_290,
+  RTEMS_RECORD_USER_291,
+  RTEMS_RECORD_USER_292,
+  RTEMS_RECORD_USER_293,
+  RTEMS_RECORD_USER_294,
+  RTEMS_RECORD_USER_295,
+  RTEMS_RECORD_USER_296,
+  RTEMS_RECORD_USER_297,
+  RTEMS_RECORD_USER_298,
+  RTEMS_RECORD_USER_299,
+  RTEMS_RECORD_USER_300,
+  RTEMS_RECORD_USER_301,
+  RTEMS_RECORD_USER_302,
+  RTEMS_RECORD_USER_303,
+  RTEMS_RECORD_USER_304,
+  RTEMS_RECORD_USER_305,
+  RTEMS_RECORD_USER_306,
+  RTEMS_RECORD_USER_307,
+  RTEMS_RECORD_USER_308,
+  RTEMS_RECORD_USER_309,
+  RTEMS_RECORD_USER_310,
+  RTEMS_RECORD_USER_311,
+  RTEMS_RECORD_USER_312,
+  RTEMS_RECORD_USER_313,
+  RTEMS_RECORD_USER_314,
+  RTEMS_RECORD_USER_315,
+  RTEMS_RECORD_USER_316,
+  RTEMS_RECORD_USER_317,
+  RTEMS_RECORD_USER_318,
+  RTEMS_RECORD_USER_319,
+  RTEMS_RECORD_USER_320,
+  RTEMS_RECORD_USER_321,
+  RTEMS_RECORD_USER_322,
+  RTEMS_RECORD_USER_323,
+  RTEMS_RECORD_USER_324,
+  RTEMS_RECORD_USER_325,
+  RTEMS_RECORD_USER_326,
+  RTEMS_RECORD_USER_327,
+  RTEMS_RECORD_USER_328,
+  RTEMS_RECORD_USER_329,
+  RTEMS_RECORD_USER_330,
+  RTEMS_RECORD_USER_331,
+  RTEMS_RECORD_USER_332,
+  RTEMS_RECORD_USER_333,
+  RTEMS_RECORD_USER_334,
+  RTEMS_RECORD_USER_335,
+  RTEMS_RECORD_USER_336,
+  RTEMS_RECORD_USER_337,
+  RTEMS_RECORD_USER_338,
+  RTEMS_RECORD_USER_339,
+  RTEMS_RECORD_USER_340,
+  RTEMS_RECORD_USER_341,
+  RTEMS_RECORD_USER_342,
+  RTEMS_RECORD_USER_343,
+  RTEMS_RECORD_USER_344,
+  RTEMS_RECORD_USER_345,
+  RTEMS_RECORD_USER_346,
+  RTEMS_RECORD_USER_347,
+  RTEMS_RECORD_USER_348,
+  RTEMS_RECORD_USER_349,
+  RTEMS_RECORD_USER_350,
+  RTEMS_RECORD_USER_351,
+  RTEMS_RECORD_USER_352,
+  RTEMS_RECORD_USER_353,
+  RTEMS_RECORD_USER_354,
+  RTEMS_RECORD_USER_355,
+  RTEMS_RECORD_USER_356,
+  RTEMS_RECORD_USER_357,
+  RTEMS_RECORD_USER_358,
+  RTEMS_RECORD_USER_359,
+  RTEMS_RECORD_USER_360,
+  RTEMS_RECORD_USER_361,
+  RTEMS_RECORD_USER_362,
+  RTEMS_RECORD_USER_363,
+  RTEMS_RECORD_USER_364,
+  RTEMS_RECORD_USER_365,
+  RTEMS_RECORD_USER_366,
+  RTEMS_RECORD_USER_367,
+  RTEMS_RECORD_USER_368,
+  RTEMS_RECORD_USER_369,
+  RTEMS_RECORD_USER_370,
+  RTEMS_RECORD_USER_371,
+  RTEMS_RECORD_USER_372,
+  RTEMS_RECORD_USER_373,
+  RTEMS_RECORD_USER_374,
+  RTEMS_RECORD_USER_375,
+  RTEMS_RECORD_USER_376,
+  RTEMS_RECORD_USER_377,
+  RTEMS_RECORD_USER_378,
+  RTEMS_RECORD_USER_379,
+  RTEMS_RECORD_USER_380,
+  RTEMS_RECORD_USER_381,
+  RTEMS_RECORD_USER_382,
+  RTEMS_RECORD_USER_383,
+  RTEMS_RECORD_USER_384,
+  RTEMS_RECORD_USER_385,
+  RTEMS_RECORD_USER_386,
+  RTEMS_RECORD_USER_387,
+  RTEMS_RECORD_USER_388,
+  RTEMS_RECORD_USER_389,
+  RTEMS_RECORD_USER_390,
+  RTEMS_RECORD_USER_391,
+  RTEMS_RECORD_USER_392,
+  RTEMS_RECORD_USER_393,
+  RTEMS_RECORD_USER_394,
+  RTEMS_RECORD_USER_395,
+  RTEMS_RECORD_USER_396,
+  RTEMS_RECORD_USER_397,
+  RTEMS_RECORD_USER_398,
+  RTEMS_RECORD_USER_399,
+  RTEMS_RECORD_USER_400,
+  RTEMS_RECORD_USER_401,
+  RTEMS_RECORD_USER_402,
+  RTEMS_RECORD_USER_403,
+  RTEMS_RECORD_USER_404,
+  RTEMS_RECORD_USER_405,
+  RTEMS_RECORD_USER_406,
+  RTEMS_RECORD_USER_407,
+  RTEMS_RECORD_USER_408,
+  RTEMS_RECORD_USER_409,
+  RTEMS_RECORD_USER_410,
+  RTEMS_RECORD_USER_411,
+  RTEMS_RECORD_USER_412,
+  RTEMS_RECORD_USER_413,
+  RTEMS_RECORD_USER_414,
+  RTEMS_RECORD_USER_415,
+  RTEMS_RECORD_USER_416,
+  RTEMS_RECORD_USER_417,
+  RTEMS_RECORD_USER_418,
+  RTEMS_RECORD_USER_419,
+  RTEMS_RECORD_USER_420,
+  RTEMS_RECORD_USER_421,
+  RTEMS_RECORD_USER_422,
+  RTEMS_RECORD_USER_423,
+  RTEMS_RECORD_USER_424,
+  RTEMS_RECORD_USER_425,
+  RTEMS_RECORD_USER_426,
+  RTEMS_RECORD_USER_427,
+  RTEMS_RECORD_USER_428,
+  RTEMS_RECORD_USER_429,
+  RTEMS_RECORD_USER_430,
+  RTEMS_RECORD_USER_431,
+  RTEMS_RECORD_USER_432,
+  RTEMS_RECORD_USER_433,
+  RTEMS_RECORD_USER_434,
+  RTEMS_RECORD_USER_435,
+  RTEMS_RECORD_USER_436,
+  RTEMS_RECORD_USER_437,
+  RTEMS_RECORD_USER_438,
+  RTEMS_RECORD_USER_439,
+  RTEMS_RECORD_USER_440,
+  RTEMS_RECORD_USER_441,
+  RTEMS_RECORD_USER_442,
+  RTEMS_RECORD_USER_443,
+  RTEMS_RECORD_USER_444,
+  RTEMS_RECORD_USER_445,
+  RTEMS_RECORD_USER_446,
+  RTEMS_RECORD_USER_447,
+  RTEMS_RECORD_USER_448,
+  RTEMS_RECORD_USER_449,
+  RTEMS_RECORD_USER_450,
+  RTEMS_RECORD_USER_451,
+  RTEMS_RECORD_USER_452,
+  RTEMS_RECORD_USER_453,
+  RTEMS_RECORD_USER_454,
+  RTEMS_RECORD_USER_455,
+  RTEMS_RECORD_USER_456,
+  RTEMS_RECORD_USER_457,
+  RTEMS_RECORD_USER_458,
+  RTEMS_RECORD_USER_459,
+  RTEMS_RECORD_USER_460,
+  RTEMS_RECORD_USER_461,
+  RTEMS_RECORD_USER_462,
+  RTEMS_RECORD_USER_463,
+  RTEMS_RECORD_USER_464,
+  RTEMS_RECORD_USER_465,
+  RTEMS_RECORD_USER_466,
+  RTEMS_RECORD_USER_467,
+  RTEMS_RECORD_USER_468,
+  RTEMS_RECORD_USER_469,
+  RTEMS_RECORD_USER_470,
+  RTEMS_RECORD_USER_471,
+  RTEMS_RECORD_USER_472,
+  RTEMS_RECORD_USER_473,
+  RTEMS_RECORD_USER_474,
+  RTEMS_RECORD_USER_475,
+  RTEMS_RECORD_USER_476,
+  RTEMS_RECORD_USER_477,
+  RTEMS_RECORD_USER_478,
+  RTEMS_RECORD_USER_479,
+  RTEMS_RECORD_USER_480,
+  RTEMS_RECORD_USER_481,
+  RTEMS_RECORD_USER_482,
+  RTEMS_RECORD_USER_483,
+  RTEMS_RECORD_USER_484,
+  RTEMS_RECORD_USER_485,
+  RTEMS_RECORD_USER_486,
+  RTEMS_RECORD_USER_487,
+  RTEMS_RECORD_USER_488,
+  RTEMS_RECORD_USER_489,
+  RTEMS_RECORD_USER_490,
+  RTEMS_RECORD_USER_491,
+  RTEMS_RECORD_USER_492,
+  RTEMS_RECORD_USER_493,
+  RTEMS_RECORD_USER_494,
+  RTEMS_RECORD_USER_495,
+  RTEMS_RECORD_USER_496,
+  RTEMS_RECORD_USER_497,
+  RTEMS_RECORD_USER_498,
+  RTEMS_RECORD_USER_499,
+  RTEMS_RECORD_USER_500,
+  RTEMS_RECORD_USER_501,
+  RTEMS_RECORD_USER_502,
+  RTEMS_RECORD_USER_503,
+  RTEMS_RECORD_USER_504,
+  RTEMS_RECORD_USER_505,
+  RTEMS_RECORD_USER_506,
+  RTEMS_RECORD_USER_507,
+  RTEMS_RECORD_USER_508,
+  RTEMS_RECORD_USER_509,
+  RTEMS_RECORD_USER_510,
+  RTEMS_RECORD_USER_511,
+} rtems_record_event;
+trace {
+    major = 1;
+    minor = 8;
+    byte_order = le;
+stream {
+    event.header := struct {
+        uint32_t id;
+event {
+    name = "RTEMS_RECORDING_EVENT";
+    id=0;
+    fields := struct {
+		timestamp_t                  ns;
+		uint32_t                     cpu;
+        rtems_record_event           events;
+		uint64_t                     data;
2.7.4
